PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Help! - need bolt for OS FS
  2. Zenoah G26/Choke
  3. Beijing
  4. SERVOS/COMPATIBILITY
  5. FOR WHAT IS A 13.4 X 13.5 THREE-BLADED PROP USED?????
  6. tuning 4 strokes
  7. How do you post pictures?
  8. Silane Finished Glass & WB PolyC
  9. smoke-writer cartridges
  10. What is Australian for polycrylic..?
  11. R/C related gear
  12. What servo size 1/5 Spitfire?
  13. Changing out Hitec radio crystals
  14. Who ate to much turkey dinner???
  15. transmitter ?
  16. prop size conversion-from two to 3 or 4 blade APC
  17. asphalt runway
  18. how low can a 6 volt be and be safe
  19. FUNTANA?
  20. OS 46 starting problem
  21. How to dispose of Lipo batteries
  22. aileron servo rod help ???
  23. Engine runup problem
  24. Need help
  25. twin engined electric plane setup options????
  26. what engine for GP RV 4 Sport 40?
  27. covering problem
  28. second plane
  29. altitude
  30. slow stick problem
  31. Sometin Extra w/ Smokey mod
  32. Hobby Lobby Gee Bee R3
  33. Name this plane!
  34. electric motor sizes for an airliner...or stick with glow
  35. Metal gear servos thread lock
  36. Second Airplane
  37. JR XF 622
  38. How do I reverse 1 hitec 985 coreless analog servo (split elevator)
  39. OS120 on 1/4 scale Sig Cub
  40. beaver information
  41. Elevator Repair
  42. Moki 210
  43. Repairing ASP FS120AR
  44. Tricycle To Tail Dragger
  45. BALL LINK CONTROL ROD
  46. Tuninig a Perry Pump
  47. which one to buy Magnum xl 40 or OS 40 LA?
  48. BEHR Silver Latex Paint 'NO MORE'
  49. Building Lighter - Titebond / Aliphatic Glues - dillute / water-down?
  50. connector to link different diameter tubing?
  51. DX7 / AR7000 receiver: how do I program 2 elevator servos?
  52. Large Box for shipping completed airplane
  53. Any issues in using larger fuel tank than usual?
  54. Piper Cub Decals???
  55. O.S .91FX..Muffler Restrictor
  56. How do I bend windshield plastic?
  57. storing planes in garage
  58. R/C Christmas Gift Ideas?
  59. MRC Super Brain 977 Help !
  60. Kyosho Calmato Sport wing incidence
  61. Building board and supplies!
  62. Zanoah g45
  63. Fuel Tank Setup
  64. HOW TO CHARGE NEW LIPOS
  65. TOP FLITE P-47 NOSES OVER ON LANDING
  66. aranka (sp?) champ plans?
  67. Balsa Usa Force one (MOD)
  68. whats your favorite plane?
  69. Motor / prop clearance: electric profile
  70. 72 MHz antenna and magnetic hatches
  71. Old Saito 80 4 stroke
  72. What is this motor???????????????
  73. YS F-91AC Question
  74. Long servo arm or short control horn?
  75. Where can I get a COX 1/5 WACO YMF ARF?
  76. Darker yellow...add what color??
  77. anyone have any good designs for a bracket for transporting and 27% edge for a small pickup truck?
  78. JR XP6102
  79. Zenoah G26
  80. Nitro Models Bobcat
  81. How to get a perfectly flat (=plan, leveled) workbench?
  82. E Flite 400 Parkrunner - reverse shaft
  83. Replacement wings.
  84. Help with choice of airbrush
  85. Hobbico Voltwatch w/6.0v battery issue?
  86. AIRPLANE TRANSMITTER BATTERIES
  87. WHICH PLYWOOD???
  88. Muffler bolt size for 46AX?
  89. Curing Epoxy
  90. Paint on UltraCote
  91. Flying with or fixing warped elevator control surface
  92. Setting the Timing in a Saito 150
  93. lanier stinger cowel
  94. Is OS 40 LA a good or bad engine?
  95. Whats the Strongest/Best .46 engine?
  96. Enya 60X Question
  97. What's the best incidence meter out there?
  98. what makes glow fuel so hard on paint?
  99. Starting a 4-stroke engine
  100. Vacum forming questions
  101. Nitro exposure and stiff servo wiring
  102. Nose gear in air retracts steering ?????
  103. 4-stroke Starters?
  104. Jett Powered SIG King Cobra
  105. crankcase vent mess
  106. Silk, Sanding Sealer & Water-based Polyurethane
  107. Jet Hobbie info
  108. Another Nose Gear Issue
  109. C-tronics onboard glow drivers
  110. Motor Mount 1.20 4-Stroke
  111. Mechanical vs Pneumatic retracts
  112. Help with covering
  113. Paint match for Ultracote Deep Red & White
  114. 2Stroke vs. Electric
  115. SERVO SEARCHING
  116. Dash 8 needed money not an issue
  117. New at glow plane building question
  118. Carbon fiber in Mid Star 40??
  119. Two Stroke VS four Stroke
  120. Has anybody built Venture 60 from plans?
  121. funtana s 40 control throws
  122. Ball linkage question..
  123. Repair
  124. Locktite, lockout: cowl bolts froze to blind nuts
  125. Best Place to buy Lipos?
  126. Big Stik History.
  127. What size servo?
  128. Installing twin ducted fans.
  129. Futaba 10 CAP & y-harness on rudder
  130. Redo paint on yellow arrow on F18C
  131. Engine for Seagull Extra 260 -180
  132. Carbon Fiber
  133. dope for strength
  134. Are there any RC flying clubs in Jacksonville fl?
  135. Charging a 6V 1400mh rx battery??
  136. Mark 3.160
  137. optic 6
  138. C G four-star 120
  139. Super Custom (SC) 40 Idle Problem
  140. Swap meets-worth the trouble?
  141. Horizon Price Increase
  142. JR X9303 mode 2 to mode 1
  143. *Black Residue From Gasser*
  144. SAITO 100 STARTS BACKWARDS ALOT
  145. Seagull Yak-54 .60 is this a good deal????
  146. evo 46 HS needle valve on carb
  147. servo plug replacement
  148. nylon hinges vs fiberglass
  149. Thunder Tiger .46 Pro, Won't go!
  150. Byron's originals
  151. What size 4 Stroke for a 40 size trainer?
  152. supper coverite antique covering
  153. MAGANINE LIBRARY
  154. NIMH Receiver Battery Explodes? Why?
  155. Tip Stall Question
  156. Deans Mini Antenna
  157. charge switch question
  158. Source/Recomendation for a 3D Profile with removable wings
  159. Mosquitobite Planes
  160. how to make engine look like new?
  161. printing decals
  162. Fuel Filler Valve question..
  163. Four * 40 flight trimming
  164. 4* 60 radio set up
  165. ENGINE BREAK IN
  166. cleaning an engine?
  167. AR7000 DSM2 7Ch Receiver
  168. pull pull question
  169. Glassing P-51 Questions
  170. HELP FOR F 22 RAPTOR
  171. anyone know this motor
  172. twin servo elevator problems
  173. evolution engines
  174. Master Airscrew verses APC props.
  175. thunder tiger super decathlon
  176. Reliable mid-range 2.4Ghz radio options
  177. Alternatives to servo connectors?
  178. 2-56 or 4-40?????
  179. Spektrum Issue??????
  180. Airborn VIDEO tranmitters?
  181. saito 91 /slimline smoke muffler / tme smartsmoker
  182. Nexstar + Real Time Camera =Crash?
  183. VQ Models
  184. Aileron servo tube
  185. Centering servos....
  186. PT-17 Belly Pan "flushness" :)
  187. Y.S. 45 Information Needed
  188. Saito .91 or O.S. 91
  189. charger question
  190. oderless CA is it safe?
  191. Micro Receiver
  192. SIG Koverall question
  193. ARG: E-flight's pitts m12
  194. need tower coupon
  195. Anyone use the Micro Glow Onboard glow driver
  196. who sells props?
  197. Digital -vs- standard servos - what is the benefit?
  198. OS 75 AX or OS 91 FX - for Pusher ?
  199. help finding RC plane?
  200. where have all the kits gone ???
  201. glow versus electric
  202. Saito 220
  203. how bright does a glow plug have to glow
  204. Charge an 8.4v battery w/ a 7.2v charger?
  205. battery information need
  206. Does anybody have austar aircraft??
  207. Jr 9303 2.4 or futaba 10c 2.4
  208. 3W 55I
  209. 3W 55I
  210. Great Plains 120 Chipmunk Paint Colors
  211. + or - expo for hitec radios ?
  212. OS Max 46AX- needle valve or carb issue
  213. Is Southeast RC on vacation or closed?
  214. lipo batteries
  215. Crystals...
  216. Respirator for CA??
  217. New CNC Router Design
  218. Who makes this plane
  219. Help to Identfy these retracts
  220. Difference between 9CAP and 9C Super
  221. Engine overheating
  222. 180 saito
  223. saito 115
  224. Product Question for JR or Spektrum
  225. Os 91 and RPM's
  226. fast riot 3d
  227. V-Tail rudder-vator deflection directions
  228. r1222 dsm, problem
  229. G-38 prop?
  230. Lazy Ace control throws
  231. Unlikely Flight Report CMP Katana 50/w a 1.20 Engine
  232. ? on cleaning fuel tanks
  233. Noisy Saito
  234. saito 115
  235. RV-6 Cowl
  236. how do I do a pull-pull rudder ?
  237. traveling with lipos
  238. RPM on Saito .82
  239. Tachometer recommendation
  240. Balancing Waco bipe
  241. smoke on 2 stroke
  242. engine anti-vibration standoffs
  243. winter storage
  244. r
  245. Electronic ignition
  246. Want to try smoke
  247. RAM machine gun sound
  248. Anybody know Steve Peterson?
  249. Elevon problem....
  250. List servos compatible with 2.7v signal std
