PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Phaeton II CG ??
  2. 2 Rx batteries ?
  3. Who can BEAT Tower Hobby prices?
  4. Centering/reversing Digital Servos
  5. Byron Originals Pit Pal Any Good?
  6. Zenoah 20cc on Hangar 9 Funtana X 100 - Best Prop?
  7. Futaba FP-R122JE crystal change and antenna lenght
  8. Need expert help balancing a giant scale stinger.
  9. Glow engine help! OS .15
  10. Piper Pawnee
  11. How do i wire in an extra battery for retract servo?
  12. E-Domodel F-15 eagle
  13. What size engine?
  14. "Thunder Tiger engine.
  15. rc specialties
  16. RC field etiquette? Help!
  17. GPS or Tracking?????
  18. *Glow Fuel Price & Availablity*
  19. Supertiger backwards?
  20. Prop adapter question?
  21. Trying to find 48" Balsa wood
  22. Putting a .45 engine on a .39 airplane kit
  23. Balancing
  24. What is a good .60 Size Bi Plane?
  25. threading 4-40 rods for ball links
  26. What to you think of Goldberg?
  27. Hanging up your airplanes? Help
  28. Help with getting an RC appliance.
  29. Need Carb for Thunder Tiger 46
  30. Enya 60 Model 7032 prop nut size
  31. GWS
  32. spe ignition module setup
  33. Receiver batteries. please help.
  34. Knife Edge Streamer Cut
  35. cycle down a battery?
  36. CG on 50cc or 30% SD yak
  37. Fuel Tank mounting
  38. MOVED: DIY Parachute/Skydiver
  39. Trainer cord set-up
  40. Piper J3 Club Landing Gear
  41. nitro cessna=182
  42. SPECTRUM 2.4 DX7 Radio range?
  43. Vibration in Frenzy from Hangar 9?
  44. 5% or 10%
  45. telemaster 40
  46. Transmitter battery question
  47. EPOXY ALTERNATIVE, HELP! ALERGY
  48. Yak 54 Queries
  49. Dremel 8000 Lithium Ion / tool forum
  50. wing tips for great planes Space Walker
  51. JR7202 + showtime 50 3D setup help!!!!
  52. Pusher motor question
  53. Lookin for 3 cyl on board glow??
  54. bending of brass pipe
  55. Mounting dual elevator servos
  56. Tru turn prop ?
  57. Beeping motor
  58. Aileron Roll
  59. o.s. .46 fx
  60. jammed fuel injection valve in the carburetor
  61. Hanger 9 tach instructions
  62. Econokote vs Monokote
  63. Glow Plug Life Expectancy
  64. will never buy from nitroplane again
  65. Polikarpov I-16
  66. Will OS 70 Surpass fly the Great Planes RV-4 601/4?
  67. Extreme Flight Outlaw
  68. What is IIRC?
  69. Saito 91
  70. Program function for JR 9303 2.4
  71. Abell RC
  72. QQ Yak 102 DA 100
  73. Drilling Prop For 3W75
  74. Futaba Radio
  75. Cordless screwdriver and drill bits question ... ?
  76. JR DX6i Spectrum radio
  77. Heres a thought....
  78. muffler and needle valve extensions
  79. sliding canopy
  80. O.S. Engine parts .61 (Drive Washer)
  81. I keep losing mufflers
  82. Pilot Bust painting
  83. DA 100 CANISTERS VS STOCK MUFFLER
  84. os 91 on a spitfire h9
  85. Rustoleum question
  86. How do I get an avatar?
  87. OS max 40 run problems
  88. Irvine 46 Vertical Prop?
  89. RX battery choice
  90. Solartex
  91. Question for RC Ken
  92. Futaba Servo's
  93. OS FS 91 is it capable ?
  94. Spinner for APC 12.25x3.75?
  95. 2.4 RC radio
  96. HOW LONG DOES GREYHOUND TAKE TO SHIP LARGE AIRPLANE????
  97. Monocoat & Oil Troubles
  98. Super tigre 2300 prop question
  99. lipo flight pack
  100. Towing a flag/banner
  101. crystal question(s)
  102. Anyone have their 14MZ screen go blank then give error message
  103. battery tester
  104. Sanwa compatability with other companies
  105. Slimline Sport Scale I Muffler O.S. .61 SF & .61 SF ABC,need help
  106. Kress RK-20 or RK-720???
  107. prop choice and flap throws????
  108. Engine Break in Stand. Don't need to buy one!
  109. Need help locating company
  110. Balancing plane
  111. OS FS-48 Replacement Head
  112. Saito 120 Trouble
  113. Not sure how satisfied with horizon / saito warranty
  114. Electronic brake ESC. setting help
  115. High Speed neddle setiing for Webra .32
  116. Tower Hobbies 15% airplane fuel ?
  117. Radio most used at events?
  118. Manual OS MAX 25FP & 40FP
  119. Futaba 2.4 14MZ with integrated TX antenna
  120. Does a spinner come with a cap screw?
  121. help plane nose's over
  122. Squealing Saito?
  123. Differance between S-PCM and Z-PCM
  124. servo compare
  125. c.g Help
  126. Small Pusher Props??
  127. CG problem
  128. Fuel question Re: Inverted Flight
  129. Slow Poke wing question
  130. What causes glitches?
  131. Antenna routing tips
  132. E-flite 25A ESC fried, or is it the motor??? Help?!
  133. G26ei Help!!!!
  134. Using old servos
  135. OS 120 Surpass Parts
  136. Eflite 480 help
  137. Futaba FBC-8B charger
  138. please help my new macstar 28 wont run
  139. PZ radio Glitch
  140. Long Leads
  141. Re: Noise Levels, engines and mufflers?
  142. Monocoat / Ultracoat
  143. Motor and tank mounting
  144. Help with Robart 607 nose gear
  145. os 70 ulimate pump assembling
  146. SCALE Wheels?????????
  147. battery / ignition proximity
  148. Battery location vs ignition coil
  149. Irvine 46 or OS 46ax
  150. my li-po battery won't charge
  151. BYRON AT-6 CG
  152. Magnum .52 rfs engine noise
  153. Newbie help ><
  154. Help! Snapped Rx Aerial
  155. Sport, Pattern, Pylon Props - Differences?
  156. ducted fan blade doesn't fit in tunnel. sand the blades?
  157. spektrum DX7
  158. unknown electric plane
  159. remote glow plug connector, mod?
  160. flycameone2
  161. Can a DX 7 get glitches and interference ?
  162. JR to Futaba Training Cord
  163. Solartex, Coverall, Coverite and 21st Century fabric
  164. Hitec hs-635 High Torque servo...any good?
  165. Fuel tank setup??
  166. Lipo battery in transmitter
  167. blowing plugs?
  168. RC engine horse power ratings
  169. trim covering problem
  170. SPEKTRUM DX6i CHARGE PROBLEM:
  171. Screeming hellcat? What?
  172. Mystery Biplane
  173. Spring air retracts parts
  174. plane model?
  175. Need help on a wiring diagram?
  176. JR servo's
  177. Heli engine shaft
  178. Slimline exhaust dimensions
  179. Velocity stacks?
  180. Fly-It-Yourself F-22 ducted fan jet - fan blade broke off
  181. super tigre 75 soup up??
  182. Top Flite's LusterKote paint
  183. futaba 6 transmiter question
  184. Sorry Triton 2 Charger or Battery?
  185. Retracts
  186. CG for Super Chipmunk
  187. JR NES 4735
  188. Dreamworks Model Producs
  189. Field Charger
  190. Engine Surging Question
  191. Hanger 9 P-47 build help
  192. GAS ENGINE HELP NEEDED!!!
  193. Hitec Repair?
  194. 4.8 or 6 volt
  195. Does anybody know what this is or the maker?
  196. A thought
  197. magnum .91 rfs 4 stroke question
  198. "Nor Cal" Aero Continental
  199. polk hobby pro 60 speed control
  200. Need to Find Crankshaft & Gasket Set for old Saito 120
  201. carbon pushrods
  202. Who made this airplane?
  203. How long does a razor saw last?
  204. Best power making fuel for my Saito?
  205. Avitar how to
  206. Enya 120 4 stroke
  207. How to construct and tow a banner ??
  208. Is there an alternative to Lustrekote paints for Matching Monokote?
  209. wankel 49-pi
  210. Something Extra Control throws
  211. Receiver question for 50cc yak
  212. OS 60 FP
  213. how long is safe on a wall-cube?
  214. PLANE
  215. pressure tubing for retracts
  216. AXI Electric 4130/20 Motor Which batteries?
  217. li-po newbie, how do i charge this thing?
  218. Air retract valve questions...
  219. Glow plug igniter baffles me!
  220. Flying near real aiport?
  221. Charging Batteries
  222. DA 50 IGNITION SWITCH
  223. saito fa56 4stroke
  224. JR X9303 2.4 Radio!!!! ATTENTION Broken wires!!!!!!!
  225. pneumatic retrac undercarriage
  226. CUb with a Heli-max hm 4000 ??
  227. Powerbox sensor switch
  228. warped leading edge balsa
  229. Tower Hobbies .46 engine trouble
  230. engine for World Models Katana
  231. Prop/ engine combo??
  232. Which is the RCU forum user with more posts?
  233. super tiger vs os AX series
  234. My SU-27 Drains battieries too quick, help!
  235. Installation on Evolution 26GX (1.6) Gas Engine
  236. More radio help please
  237. OS Max Tight at top dead center
  238. Full Length R/C Videos?
  239. evo 40nt needle valve assy
  240. GLITCH!!!!!!!!!!!!!
  241. low end needle adjustment
  242. disassembly of Mega 16-15-series ?
  243. Moki Engine parts
  244. airspeed indicator
  245. Coloring a Canopy.
  246. Evolution .46 NT engine
  247. Wing Area Calculation
  248. What plane is this
  249. CROSS COUNTRY FLIGHT 32MILES
  250. Big glow spad, tartan 77 twin engine prob?
