PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. What plane is this
  2. CROSS COUNTRY FLIGHT 32MILES
  3. Big glow spad, tartan 77 twin engine prob?
  4. anyone used a weed eater motor
  5. Connectors and Receiver Info
  6. smoke on a O.S 120 surpass
  7. Old Futaba Gear
  8. OS .46 engine problem, Any Sugestions?
  9. Cirrus 900-XLC manual
  10. Designing own planes
  11. J-3 Cub & heading hold gyro= good take off?
  12. Futaba Servo Help
  13. What voltage-charger
  14. Motor suggestion for Twist 40
  15. What servo for my 90 size plane?
  16. Straighten Balsa Building Board
  17. cylinder sleeve to tight or not
  18. Model Aviation Technology.
  19. Foamie receiver
  20. *OS 120AX/Header & Pattern Muffler*
  21. Hitec Freedom 9, has anyone tried to program this new receiver?
  22. looking for pusher prop
  23. question on covering
  24. Stripping Monocote
  25. Mechanical Retracts
  26. Tail heavy REACTOR Bipe-HELP
  27. charging batterys
  28. What's an old glow engine worth?
  29. loose head bolts on a 120AX
  30. GOLD CUP HIRTENBERGER MODEL ENGINE 61 F ?
  31. High speed needle broke.. OS 46 fxi
  32. airstrip plans
  33. Tamiya Aircraft Paint: Fuel Proof?
  34. Tower Trainer Covering
  35. lanier ?
  36. Hanger 9 spitfire question
  37. telemaster 40
  38. Hanger 9 True Red spray paint
  39. tape
  40. Ya think ya have the worst plane, ey?
  41. second plane gas or electric
  42. Can I Paint 21st century Fabric?
  43. hoother places to get planes from???
  44. Continually burning up glow plugs
  45. IS THERE A WAY TO SAVE A SEARCH IN RCU CLASSIFIEDS???
  46. Cruiser 60 aircraft
  47. Sealing hinge gaps
  48. Non LHS Hobby Supplies (HomeDepot)(Lowes) or Hobby Supply Survival 101
  49. Whos flyin a YS FZ110?
  50. PCW not responding
  51. CA & UnderArmor...
  52. Are these places big enough for flying?
  53. 4-Stroke engine mounts
  54. Do Women Fly?
  55. Saito 100 Let Me down!
  56. Cleaning Engines
  57. Motor runs but no throttle control
  58. Spektrum AR6100E DSM2
  59. Cloth/fabric neck straps...
  60. Robart Hinges
  61. 2x 12 volt batteries for my starter ?..
  62. 4 stroke question
  63. How to mix in flaperons?
  64. Polarity question
  65. sx600 Charger
  66. Chatty Kathy at the Field
  67. UCD 60 with FS 91 Surpass- can I smoke it?
  68. Radio info
  69. How to smooth a fiberglass cowl
  70. OS 91 FS SURPASS
  71. .45 Super Tigre
  72. Goldberg Cub Fiberglass Cowl
  73. Super Tigre .40-.45
  74. OMP Profile Yak 54
  75. Hobbico Hobbistar 60 or Hangar 9 Arrow .40?
  76. Engine cut-out
  77. Hobby Stores in San Francisco
  78. NEWBIE here. Want to work my way up to rc jets.
  79. flite-metal
  80. Four Star 120 tail wheel springs
  81. Shipping Cost
  82. Converting 2 to 4 stroke power output equivalences
  83. 3 and 4 blade propeller conversion
  84. Looking for some flyers
  85. 2 to 3 blade prop help
  86. Help Lustrekote True Red!!
  87. Hot Line Commanche
  88. 2.1 kilograms, powered by a O.S. .50
  89. Best sounding engine...
  90. 20 AWG servo wire bulk?
  91. O.S. .40 Max FP
  92. Glowbee intellitach problem
  93. Glitching-Flyzone J3 Cub
  94. A Finer Edge Mfg. Starter Adapter
  95. Necessary Field Equipment
  96. air filters for planes?
  97. OMP Manual
  98. JOE NALL VIDEO!!!!
  99. Help needed re own design trim logos.
  100. Balsa Preperation before Covering
  101. OS 91 FS II Surpass
  102. GMS Engine
  103. Moki 1.8 onboard glow question
  104. G500A gyro
  105. Drilling carbon fiber...
  106. glow starter
  107. Anyone making a Fi-156 Kit?
  108. Elevator snapping issue
  109. li po overcharge?
  110. Anyone else ripped off by Tanks Hangar?
  111. Why is my plane doing this when I do a loop?
  112. Securing 4-Stroke Mufflers?
  113. OS 20 FP Fuel consumption
  114. What floats
  115. Sealing Lustrekote with clear polyurethane
  116. Smoke on .46
  117. Someone please help - servo jitters
  118. Mentholated alcohol
  119. SuperTigre G51
  120. Can anyone help me with this Smoker
  121. Alpha 40 repair question
  122. Exhaust oil color
  123. Constant speed props?
  124. No RPM out of a TOWER 75
  125. JR+spektrum binding question
  126. International Fiberglass Specialties delivery
  127. Four Star 120 ARF
  128. Radio frequencies
  129. Warp wing
  130. tucano
  131. Gas motor size
  132. first gas engne, g-26 help
  133. THROTTLE JUMPS AROUND
  134. Super Tigre Silent Mufflers
  135. Fuel
  136. loss of fuel on dive= dead stick
  137. Trim Problem
  138. loss of fuel on dive= dead stick
  139. Wing Spars - direction of grain?
  140. Engine performance reduced after crash... Repairable?
  141. Upside-down Plane
  142. EVP Setup
  143. Antenna Question
  144. G26EI BUILD IN 120 SIZE PLANE
  145. thunder tiger pro 40 engine fuel
  146. Help finding plane
  147. inner and outer wing tubes?
  148. i am looking to get into rc planes
  149. volt watch
  150. BOEING 247
  151. Evolution 35GT2 wiring help
  152. Hinge Centering
  153. Z Bends, EZ Connector, Clevis. What's the Diff?
  154. Old MonoKote
  155. charger + battery compatibility
  156. What is a good reliable remote glow setup?
  157. jr 8103
  158. os 91 profile
  159. What kind of oil to mix for use in CRRC 26cc
  160. Muffler trouble on Supertigre
  161. Analog Servos w/Spektrum Rx?
  162. Cleaning Primed (Dusty) Surface Prior to Paint ? ?
  163. A waterproof need!!!!
  164. Need some plane field bench plans
  165. impedance of battery
  166. learning to take off
  167. Where to get diesel heads...
  168. Flexible Push Rod??
  169. nitro converting a diamante 25e
  170. Wattsup, whats it telling me re battery
  171. Thunder Tiger 46 pro
  172. Problem with Magnum engines?
  173. AMA Insurance coverage
  174. what engine for my .60 stik
  175. YS 120AC vs YS 120NC
  176. flying site in Wyoming
  177. Engine Upthrust?
  178. Aileron Servo tearing out
  179. Trainer .46
  180. Wing Fairing on a War Bird
  181. Pull Pull Help
  182. Futaba to Esky trainer cable
  183. Evlotion motor?????????
  184. Black Horse Katana 60 MkII C.G. question
  185. Looking for the best price on the net for a JRX9303 radio?
  186. Epoxy types
  187. picture viewing
  188. Spektrum Contol Arms
  189. Plane vs motor
  190. 1/2a control horns on a Skylane 62?
  191. Great Planes .40 Cessna ARF Engine Choice
  192. Spraying Automotive Paints with an Airbrush ? ?
  193. Fuel Tube sizing
  194. GMS .47 ABC Rebuild
  195. skyraider keleo muffler
  196. Wood laser cutter for 50+"???
  197. P-51 Mustang-46
  198. 2.4 ghz radios??????????
  199. Inverted ST 90
  200. Morgantown WV area Flier's .. Looking for a place to fly?!
  201. need a canopy
  202. Dubro hinges for Easy Sport
  203. Saito 100 problems?
  204. 46
  205. Black Covering
  206. Quick Fueling valves??? Yes or no??
  207. 2.4ghz radio
  208. Moki 1.8 recommended Prop size
  209. fuse gear for giant super chipmunck
  210. Radio Transmitter Interference
  211. Futaba battery with Spektrum receiver
  212. glow fuel
  213. RX battery - Li-Ion or NiMh?
  214. Questions about Split Elevator servos + Moki prop/glow plug please
  215. A charging question!
  216. Hinge Spacing
  217. Painting Question
  218. prop size for ys .91fz
  219. JR servo horns
  220. What's the best prop to break in my OS55AX?
  221. LiPo question
  222. any one heard of this ducted fan company?
  223. APC 15X4W Question
  224. F-27 Stryker Servo ?
  225. DymondRC??
  226. Plane wont stay still
  227. D-Sub Servo Connectors
  228. What Plane
  229. The Airpower EV5U multiport valve
  230. Carl Goldberg 1.20 SU26mx replacement parts
  231. question about j3 cub
  232. os 55ax help
  233. 4 stroke Help
  234. 12FG Futaba
  235. Over reamed Prop
  236. 4 Stroke Mystery
  237. Spektrum and Horizon Hobby
  238. Top Flite heat gun fuse link source/workaround
  239. MY rc do not esponse anymore
  240. Evolution 52NX wont fly HELP
  241. Receiver Battery Pack Is "Toast"
  242. battery pack for super cub
  243. Plane for Windy Conditions?!
  244. Stinger 120 & DX7
  245. Three Blade Prop
  246. 3 d rates
  247. Evo 26 muffler
  248. hitec neutron 6s reciever question
  249. construction problem
  250. Do you know these planes???
