View Full Version : Questions and Answers
- BOEING 247
- Evolution 35GT2 wiring help
- Hinge Centering
- Z Bends, EZ Connector, Clevis. What's the Diff?
- Old MonoKote
- charger + battery compatibility
- What is a good reliable remote glow setup?
- jr 8103
- os 91 profile
- What kind of oil to mix for use in CRRC 26cc
- Muffler trouble on Supertigre
- Analog Servos w/Spektrum Rx?
- Cleaning Primed (Dusty) Surface Prior to Paint ? ?
- A waterproof need!!!!
- impedance of battery
- Need some plane field bench plans
- learning to take off
- Where to get diesel heads...
- Flexible Push Rod??
- nitro converting a diamante 25e
- Wattsup, whats it telling me re battery
- Thunder Tiger 46 pro
- Problem with Magnum engines?
- AMA Insurance coverage
- what engine for my .60 stik
- YS 120AC vs YS 120NC
- flying site in Wyoming
- Engine Upthrust?
- Aileron Servo tearing out
- Trainer .46
- Wing Fairing on a War Bird
- Pull Pull Help
- Futaba to Esky trainer cable
- Evlotion motor?????????
- Black Horse Katana 60 MkII C.G. question
- Looking for the best price on the net for a JRX9303 radio?
- Epoxy types
- picture viewing
- Spektrum Contol Arms
- Plane vs motor
- 1/2a control horns on a Skylane 62?
- Great Planes .40 Cessna ARF Engine Choice
- Spraying Automotive Paints with an Airbrush ? ?
- Fuel Tube sizing
- GMS .47 ABC Rebuild
- skyraider keleo muffler
- Wood laser cutter for 50+"???
- P-51 Mustang-46
- 2.4 ghz radios??????????
- Inverted ST 90
- Morgantown WV area Flier's .. Looking for a place to fly?!
- need a canopy
- Dubro hinges for Easy Sport
- Saito 100 problems?
- 46
- Black Covering
- Quick Fueling valves??? Yes or no??
- 2.4ghz radio
- Moki 1.8 recommended Prop size
- fuse gear for giant super chipmunck
- Radio Transmitter Interference
- Futaba battery with Spektrum receiver
- glow fuel
- RX battery - Li-Ion or NiMh?
- Questions about Split Elevator servos + Moki prop/glow plug please
- A charging question!
- Hinge Spacing
- Painting Question
- prop size for ys .91fz
- JR servo horns
- What's the best prop to break in my OS55AX?
- LiPo question
- any one heard of this ducted fan company?
- APC 15X4W Question
- F-27 Stryker Servo ?
- DymondRC??
- Plane wont stay still
- D-Sub Servo Connectors
- What Plane
- The Airpower EV5U multiport valve
- Carl Goldberg 1.20 SU26mx replacement parts
- question about j3 cub
- os 55ax help
- 4 stroke Help
- 12FG Futaba
- Over reamed Prop
- 4 Stroke Mystery
- Spektrum and Horizon Hobby
- Top Flite heat gun fuse link source/workaround
- MY rc do not esponse anymore
- Evolution 52NX wont fly HELP
- Receiver Battery Pack Is "Toast"
- battery pack for super cub
- Plane for Windy Conditions?!
- Stinger 120 & DX7
- Three Blade Prop
- 3 d rates
- Evo 26 muffler
- hitec neutron 6s reciever question
- construction problem
- Do you know these planes???
- Hanger 9 J3 cub 40 size
- wing covering
- fast glow battery chargers
- Ideas on transporting your airplane to the field
- Sig castor oil
- painting with rustoleum painters touch spray paint and need info on fuel proofing
- Paint to match covering
- smoke system?
- Carbon Fiber and R/C Airplanes
- How to drill holes in a carbon fiber landing gear
- Selling an Airplane??? Help!!!
- what is this plane and how much does it cost?
- JR2720 crows dont work
- Should you buy that ARF?
- how do you guys get avitars?
- Thread lock
- Stick won't take off
- Tower Talk August 31, 2008
- AA and AAA battery boxes
- .40 SIZE GLOW ENGINES
- dual conversion? pcm? ppm? anyone?
- Kansas City
- XFC-why no coverage?
- SS or Alloy engine Mt. bolts?
- Servos: Digital vs. Analog
- battery cycling
- wood filler under dope?
- Dope finishes
- os 55 ax problems
- Engine cleaning?
- funtana x100 landing gear
- Saito FA-125A fuel?
- magnum 180 4 stroke
- 7 CH Reciver question (Stupid one )
- Balsa USA ΒΌ scale Cub throws
- Wheel tensioner to keep a plane from rolling.
- Laser 150 fourstroke
- CG_ Why Upside Down
- Spektrum AR 9100 receiver
- fiber glassing plastic engine cowls
- mounting futaba ss receivers
- O.S 61 or Saito 91
- Jr/Spektrum Servo Compatibility?
- Bending oleo struts
- MDS 48 engine/carb.
- 14 MZ
- aluminum wing struts?
- Yak-11 Video
- D & D Hobbies - Mesa, AZ
- Help to I.D. R.C. Models
- Morris Hobbies (in business?)
- jr rs77s receiver
- Optional flaps
- Spraying Stits products with a PREVAL
- Aircraft Dope to use on Silk
- 45cc Skybolt Biplane. How do I determine CofG?
- Marks/Jemco Fun Scale P-51...Question
- Pianting cowls?
- 2.4 ghz vs 72 mhz receiver survivability
- p51 rascal
- GLOW FUEL SHORTAGE?
- level flight problem
- making a prop fit the spinner.
- Perry Valve
- Spring air nose gear assembly
- programing dx7?
- Cooling Question?
- Federal Standard Paint Colour
- burnt out esc?
- Futaba 9C upgrade
- Now what? (How to reverse servos w/o t/x reversing?)
- Park Zone Spitfire
- which engine for 120 superstar?
- saving a old arf
- Parkzone MUstang Question!!!!!!!!!!
- Clear coating over paint
- nearest hobby Shop?
- 4 strokes
- dummy engine
- help with red cat lighting car
- red car lighting
- YS 140FZ help nedded
- Flaps/flaperons down question
- Which plane to buy: Cosmic Wind Minnow/Chapman Cap 580?
- HomeBrewed CA Kicker???
- 72 Mhz to 2.4gh
- Futaba dual conversion receiver
- Futaba,JR,Airtronics???
- Krylon Fusion paint
- MEN Charger Repair
- modification of smart-fly
- Saito Break-in
- Decal material
- expanding Nyrod
- bind plug
- 4*40 Aileron Alignment
- hangar 9 corsair help..
- help... radio problem
- Replacing ring on Super Tiger Engine
- monocote model cleaning
- Landing Gear placement if converting to Taildragger
- Rx batteries
- Spareparts for Futaba 9ZH WC2
- unidentified plane.
- heat shrink
- Morris Hobbies??????
- exhaust residue in my fuel tank on OS46 from pressure line
- heat n sheet
- Is It windier this year ?
- taking videos
- Fried Battery
- Donalds Hobby Center?
- A SIG comment....
- who sells fiberglass F-16 fuesaladge
- Pull pull setup
- Battey Question 4.8v, 6v, regulators, Li, etc
- bill of materials
- Hi or low frequency ?
- top flite p-51 .60
- Biplane trimming problem
- Evolution .46 tuning issue
- st g75 stalling
- Flight Data Recorder Help
- replacement byron F16
- skydiving
- Closest r/c club to Lower Bank NJ?
- O.S. 1.60 spitting at me.
- RC Universe archives
- Converting Futaba 9C to 2.4GHZ system
- Help with Battery!
- best way to cut Tx case padding?
- OS 120ax Pitts muffler
- voltage level 5 cel pack
- Really need help ordering part for Saito .56
- Any Substitute for ca?
- Piper Cub J3 Trainer engine .40 question
- Ultrastrip & Ultratrim, what is the difference??
- battery
- Control throw setup for Edge 540
- What is this plane??
- Fuelproofing Question
- glow stik chargers
- fly baby
- Saito 150 4 Stroke Question... Help !!!
- Forums in Norway
- Magnum 120 4-stroke question
- Rusavia/Aviarestoration...how do get in contact?
- Hobby Pak wing bags
