PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. DC3 C of G
  2. Looking for field stand
  3. Site Questions?
  4. Pcm over ppm
  5. Will A7 handle 11.1v
  6. Forgot how to use my charger
  7. Prop nut coming loose
  8. How do you control your aircraft?
  9. how long can equipment sit without going bad
  10. 3D Biplanes
  11. New to Forums
  12. spring air retracts help
  13. Radio Problems!!!
  14. Prop Balance/Wobble Problem
  15. Duracell 2650 Mah RX Battery packs???
  16. clear propellors
  17. Attaching clevises to carbon fiber
  18. Expert Electronics EX-100 Aero Gyro
  19. Dave Brown Skyloft have you tried it
  20. OS 26 4-stroke needs plane
  21. Thinning Sig Butyrate Dope ?
  22. Battery and receiver mounting in Airplanes
  23. What is the best way to patch Monocote?
  24. Profilm/Oracover Blistering
  25. 14.4 X 13 Propeller?
  26. How do you select spinner size?
  27. single conversion vs dual conversion
  28. mini pulse help
  29. multi- engine setup
  30. Unobtrusive Ignition Battery Switch
  31. Why can't you use electric props on glow engines?
  32. Tool list
  33. Wall Wart Charger Question
  34. 1/4 scale Gee Bee
  35. Anybody work for UPS? Help needed
  36. 3w 24 i ignition wiring
  37. Stern motor
  38. Rossi .91 DF engine
  39. Radios and Receivers
  40. Showtime 50
  41. 1/4 GP Wagstaff CA Failure!!!!!!!!!
  42. Rocket Plane
  43. Proportional Servo for Retracts
  44. Air in fuel line??
  45. ?? Why is O S putting big mufflers on their four strokes
  46. M.A.N Ultimate Plan is Garbage - are Angles and CG correct?
  47. Anyone know of these planes
  48. gear door hinges??
  49. Giant scale elect. starter?
  50. Elmers Wood glue Gel ?
  51. Is the OS 55AX engine a cross beween 40 size and 60 size?
  52. flags and logos
  53. 90 gm thrust for 240 gm AUW sufficent?
  54. Horizon ? or is it me ?
  55. Oracolor paints
  56. 1/4 Scale Zero Figures
  57. Mach 1 plane...
  58. Spektrum installation
  59. OS AX75 compared to OS 61FX - are the mount holes the same?
  60. Anyone know what this airplane is????
  61. OS 160 Twin Propeller Mounting
  62. Why is the Piper Cub such a popular plane?
  63. Is Dave Patrick Models out of business?
  64. nose heavy GP Super Giant Sportster
  65. Saito FA125 or FA-125A?
  66. Winter Plane Storage
  67. Scale prop ?
  68. Reshaping Aluminum Landing Gear
  69. Name That Plane Part 11
  70. Where to get covering template
  71. Berg Microstamp
  72. Can't find this retract
  73. Fuel tank plumbing.
  74. ?? re-fillable air cy 4 landing gear ??
  75. JIS scews and tools?
  76. storing planes?
  77. OS 91 4stroke and 10 lb plane
  78. Sullivan on board glo igniter
  79. AFTER RUN ENGINE OIL QUESTION
  80. Need an alum wing tube
  81. Accu-cycle pro series Elite
  82. Balanc a 3 blade prop
  83. What hinges do you prefer?
  84. SIG Somethin' Extra Props and Servos
  85. Polycrlic with Nelson's Crosslinker
  86. One question.
  87. 4-stroke publications?
  88. Accidently left RX switch on - Still safe to use battery?
  89. K-36 in low temps
  90. what to cover my large scale spity with?
  91. YS-63S is equivalent to what size 2-stroke?
  92. BATTERY LEVEL INDICATOR
  93. Why would you put a 4-stroke on your airplane?
  94. Shops near Allentown, PA ??
  95. spektrum module systems?
  96. What Size Engine Do I Need?
  97. JGRC website
  98. What Happened To The Glow Engine Forum?
  99. How many servos
  100. *How To Fasten Your Cowl, Canopy, Etc.*
  101. Club Operations
  102. Epoxy Removal
  103. Break down workbench
  104. Incidence Meter
  105. Servo Connectors
  106. Turbo Porter fuel tanks
  107. Geartplanes F-15
  108. Start them young!
  109. Wheel collars
  110. Z-bends...yes or no?
  111. Hair dryer or Heat gun?
  112. Fabric covering question
  113. How many Robart Hinges vs CA hinges???
  114. SPAD Dogfighter - strange behavior at high speeds
  115. Source needed for Titanium bolts
  116. Best way to remove monokote?
  117. What do you think I can get out of this?
  118. Freezing batteries!?
  119. Ultimate Engine Test Stand
  120. Dope,,, Where did it go?
  121. Good Idea...Or yard dart recipe?
  122. Looking for help to place value on a couple of .18 engines
  123. West Epoxy System
  124. Please help me Identify these Planes!
  125. 2008 Toledo RC Show
  126. problem with my airtronics rd8000
  127. Ultra-Rc Giles 202 C.G.
  128. O-Rings for Cub Gear
  129. Ultracote on fiberglass?
  130. Missing Goldberg 40 Cub Blue Prints ???
  131. 6 Volt?
  132. magnetic building board
  133. Need Help on a right angle exhaust OS MAX 55AX
  134. gummed up carb
  135. twisting wires
  136. Golden Oldie Kit Price.
  137. Dumb oil question?
  138. Great Planes Seawind engine question
  139. Somethin' Extra Cowl
  140. Triton Jr. charger for RX and TX
  141. to Iron or not ------- wing covering
  142. how do you modify fiberglass panels?
  143. camera pivot
  144. Dual receiver battery packs
  145. Gas engine, Mag Flywheel mods ?
  146. Buddy Box Cable Options
  147. Nylon screws?? Help!
  148. Scaling down plans??
  149. Online shop
  150. What building bench do you use?
  151. Can you unwarp a wing?
  152. BSI Bulk CA
  153. Need a throw/incidence meter...
  154. CA Warning
  155. 2-56 or 4-40
  156. 4.8 or 6.0 volts RX battery?
  157. Hitec to Futaba???
  158. charged wrong...oops!
  159. Can anyone help me?
  160. .60 GP SPACEWALKER AND .91 MAGNUM FS
  161. Straightening ply?
  162. Prop shaft size on Saito 180
  163. ft 120 in a lancair
  164. *Free Music For Video*
  165. Another GP GEE BEE Question (Mixing Elevators)
  166. Covering Materials
  167. help mounting an engine
  168. REAL COOL COVERING TECHNIQUE
  169. Balancing 3 blade props
  170. Mercury CA brand????
  171. *Fuel Tank Distance*
  172. GP GEE BEE Instructions Question ?
  173. Need a idea.
  174. Power Panel/Charge Field Battery Question
  175. katana 120
  176. Balsarite or stix-it?
  177. Epoxy Primer and Urethane Paint
  178. CG question
  179. Magnum Engines Dimensions
  180. which engine?
  181. My addiction just made me buy a piper cub, now i have q's?
  182. Confused About Retracts and Retract Servos
  183. gas vs glow
  184. got a question about my radio.
  185. Class sizes
  186. Low Passes Forbidden?
  187. Lanier Models quality question
  188. Real-world NRG Soloprop & DL-50/DA-50 experience?
  189. Filler for epoxy glassed cowl
  190. Do you use CA, for building model airplanes?
  191. Phoenix Extra 300S CG balance
  192. Name that plane part 10
  193. dope or coat????
  194. UCANDO 60 CG
  195. TEXAS RC PLANES LOW WING TRAINER
  196. After run oil for Saitos
  197. Building with wood glue.
  198. Anyone have first-hand LADO experience?
  199. Goldberg Sukhoi engine
  200. Saito FA 120 help needed.
  201. Prop mount position in relation to piston position
  202. Moki 1.8 "standard" muffler source
  203. Winter time building
  204. PROP NOISE
  205. FORMULA 560 CANOPY GLUE/ A QUESTION???????????
  206. BEST FUEL TO RUN?
  207. Seidel ST 770
  208. 3D prop for Saito FA-100
  209. Dave Brown Mount Dimensions
  210. tool for starting/holding tiny screw heads?
  211. Fuel tank stopper hookups
  212. Enough power?
  213. How to cover around tight radius
  214. Pinhole Camera-Has anyone used one of these
  215. spring air -tri gear set up--i am clueless
  216. Saito FA-82
  217. in-flight accessories switch
  218. ZIPPER question
  219. About Receiver setup
  220. Cleaning Solution
  221. Flight simulators...
  222. How do you cover small parts without wrinkles?
  223. Klass Kote Epoxy Paint
  224. Magnum XL 70rfs 4 stroke
  225. Kick'n it up a notch (Nitro)
  226. Skryker Help
  227. OS FT120 fuel tank location ?
  228. What turbine for...
  229. os fs 70 surpass black residue
  230. 4-40 Bolt - What's this mean?1
  231. Feedback on Magnum Engines
  232. servo leads
  233. LIPO vs NIMH A7 Tornado-Hugh Difference!
  234. Whats the Scoop with 61's
  235. DX6 loses settings Heli to Plane Vice Versa HELP!
  236. Rhom retracts question
  237. Removing Covering
  238. Futaba Receiver channel lay out
  239. DX6 model selection problems!!!
  240. What Plane for the new Saito 36 Gas
  241. Clearcoating question
  242. Planes in restaurants
  243. Pull Pull Steering
  244. Transmitter Antenna Replacement
  245. GP giant super sportster tail wires
  246. 2.4 ghz and interference from Spark ignition
  247. Spectrum recievers
  248. DX 7 & Capacitor
  249. can i run two 2400mah packs 4.8v to make it 4800 mah?
  250. Goldberg Sukhoi kit fiberglass cowl
