PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. on board glow plug drivers
  2. Never Left The Ground But Sale?
  3. Does Anyone Know Where There Are Some Plans For Skiis?
  4. WHAT DO I HAVE??
  5. Nose gear brakes
  6. Painting props
  7. Koverall question
  8. what spinner needed on 26gt2
  9. Central Hobbies CF pushrods
  10. .15 size Ugly Stick Does anyone make one
  11. year of frequency changes
  12. G-38 mounting bolts
  13. Rudder Problem with RC airplane
  14. 3 Blades vs 2 Blades
  15. What to use to check 12v 7.5 ah battery
  16. acrylic paint - fuelproof?
  17. Tuned Pipe - Pressure Nipple Location
  18. Glow Chargers - Best Way To Clean 'Em
  19. What kind of airplane starter are you using?
  20. 4 stroke engine life
  21. Covering with Ultrcote
  22. Testing the 'Test Stand' Waters...
  23. what is the smallest?
  24. E SKY Receiver ,xtl problem
  25. Getting the CA out of the air in my 'hangar'
  26. Prop fit question
  27. how do you use the throttle recovery mode on dx7?
  28. Retracts: Air-in/out vs Air-in/spring-out
  29. nimh receiver packs from standard button end storebought batteries
  30. Servotray an bellcrank.For Rudder pull-pull
  31. Question about YS Engine
  32. RIPMAX F4 Phantom
  33. Please Identify
  34. Saito 56GK exhaust help needed
  35. Concensus on Ultra Sport 60 Engine Size??
  36. hinges on GP Giant SUPER sportster
  37. texasrcplanes.com yak, super buy! great flying plane!
  38. PCM receiver problems
  39. Does anyone know what this is?
  40. what is the best way to keep paint from leaching under tape
  41. measurements ?
  42. Nitro fuel
  43. Sig Aerokote Aluminum covering???
  44. Aileron Warpage
  45. over powered
  46. X-Twin/Aeroace planes Discussion?
  47. Air Compressor set up - water trap and hose length?
  48. Spray system for RC Spray Plane??
  49. F22 PTS ARF With retracts
  50. landing gear and CG
  51. looking for a Dave patrick manual for 300l
  52. dpm
  53. Professional Plane Builders
  54. Less than perfect stab and fin alignment
  55. Building Table Surface Material
  56. Futaba 7C - P Mix Problem
  57. pull pull rudder
  58. Receiver battery capacity?
  59. Bipe aileron setup?!
  60. pull pull rudder
  61. Where to find 18X6 three blade prop???
  62. gas engine fuel tank???
  63. 4.8 volt NIMH
  64. FS-30 Surpass (4 stroke)
  65. 7c 2.4 GHZ feature vs 9c
  66. Tower Hobbies Digital servos, any good?
  67. Epoxy Hardener wasted??
  68. Seeking International Orange
  69. Wing bag for smaller planes
  70. PROFI ENGINES
  71. What are these?
  72. How many still keep a trainer around?
  73. Futaba 6EXP Mixing
  74. engine selection for large racer
  75. MONEYCOTE
  76. Old Fuel
  77. Hobby shops in usa list wanted
  78. I Need a New Digital Scale .... Any Suggestions
  79. too much fuel
  80. what torqe
  81. Goldberg .60 Ultimate 10-300 setup?
  82. ultacoat pain
  83. throttle linkage set-up
  84. Links for micro servos
  85. Cleaning hardener or resin from toolbox
  86. Airplane Christmas List!? :)
  87. #11 Blades
  88. 2-56 wire diameter
  89. Nitro Planes 50 servos
  90. Aluminum Spinners
  91. Sweetest Running Engine
  92. BP Hobbies covering??
  93. 4 Star 40 question
  94. Imperial Allen Bolt Head Size
  95. Storing the small stuff
  96. Bubbles in Ultracote Covering
  97. Bind Plug HELP HELP
  98. what is this strange plane?
  99. Why do most flight videos have music????
  100. Robart retracts
  101. Magazine test and reveiws
  102. servos buzzing
  103. RV-4 Engine mounting problem...
  104. TWAS THE NIGHT BEFORE CHRISTMAS - Avaition Style
  105. Where to get Shark Mouth Decal?
  106. NEED HELP PLEASE?????????????????! i hate hobby lobby
  107. Recover 4* 60
  108. Propeller Problem
  109. monokote
  110. WHAT IS YOUR FAVORIATE TOOL or GIZMOE?
  111. IDENTIFY THIS PLANE! :)
  112. Paint?
  113. Sport Flying with skis
  114. Site slow this week?
  115. Ship it or buy a new one??????
  116. EXTRA %
  117. need 1/8 or 1/9 ww2 bomber pilots
  118. OS Engine Service?
  119. Heli engine on plane
  120. Monokote question
  121. How to cut spar notches in ribs
  122. LIGHTS
  123. smoke systems
  124. 7/16th Aileron Stock?
  125. miss hydro plane HELP!!
  126. Futaba 9zap query
  127. What does the FP stand for on the OS60fp rn
  128. Do JR 9411's Really kill you?
  129. Pressure Sensitive Trim
  130. engine parts
  131. Props vs Thrust?
  132. Foam wings
  133. Where is the Club House?
  134. Futaba 9c 2.4 ?????????????????
  135. Craft ROBO Vinyl/paper cutter...
  136. MOVED: Answer: Stop using acronyms in titles!!!
  137. how to check Center of Gravity ..CG..
  138. Split Aileron Servo
  139. Pheonix models
  140. battey question
  141. My Prop hits my spinner and breaks!
  142. Help me identify these pneumatic retracts?
  143. OS 91 fs prop
  144. Concerning Floats
  145. OS .46 LA rebuild
  146. dreaming
  147. oil leaks- front bearings?
  148. converting gas to edf
  149. 2.4GHZ radios?
  150. jr radio
  151. Best RC simulator
  152. Your favorite money saving RC stores-list them here and why.
  153. Trim Scheme Poster or ideas
  154. cutting holes in cowl
  155. OLD O.S. 40 Question
  156. Tail dragger conversion
  157. Robart Hinge Point Installation
  158. Battery Chargers
  159. any idea's where to buy an irvine .40mkII muffler?
  160. elevator & throttle servos glitching when engines is running
  161. Spektrum DSX-7 amnesia
  162. what type of li-po batteries?
  163. Need Lusterkote out of production color
  164. Old Style Covering ?
  165. Flitecraft Aerobat??
  166. Futaba verses dx6i
  167. Muffler Modfication
  168. Frequency checker opinions
  169. Apc contact info.?
  170. Contact cement
  171. break in at WOT?
  172. I have a 6XA-FM Futaba Radio, will this receiver work?
  173. Flycamone2
  174. Motor mounting & balance questions
  175. O.S. FT 120 Usage..
  176. Magazine Subscription
  177. Would you buy an ARC over an ARF
  178. Hello, I've got a problem!
  179. Covering help
  180. Technical data
  181. Tinting Plexiglas
  182. Automatic assumptions
  183. ENGINE SIZE?
  184. Mixing glow fuel
  185. need help on brushless motors
  186. Heli Transmitter for plane?
  187. Reciever Battery Suggestions?
  188. Fuel Tank Location Question
  189. CA Hinges
  190. 4.8 or 6v batteries
  191. Small Cf props?
  192. Antanna question
  193. fuji bt32atm review
  194. Lipo batteries for 12v starter?
  195. Trigear Retracts
  196. Aeroworks Edge 540T
  197. help me decide
  198. Thunderbolt #3 (115559) glow plugs
  199. Bisson or Slimline
  200. CNC Machine.
  201. Covering queston ?
  202. Aileron Twist
  203. Sig Somethin Extra Engine
  204. Fuel delevery
  205. evolution limiter removal
  206. What Glue to use?
  207. 72 mhz in turkey?
  208. accel Katana 40
  209. Customizing monokote/ultracote looks (ie painting on/detailing) Hangar 9 Spitfire
  210. Name the spinner
  211. applying monokote
  212. smoke trail makers
  213. PERRY PUMPS
  214. tool to tune G-26/38
  215. What can you do with a few old laser printers
  216. good source for balsa
  217. big engine, small plane
  218. Electrical interferance Zenoah g23 to servos
  219. One Six Right
  220. Fueling Question
  221. Calling all fellow Geeks -reciever activated relay
  222. Inverted Engine
  223. Switch toSpectrum Technology Question
  224. silicon tubing--where to find
  225. 1936 Model Aircraft National Championship (vid)
  226. Midwest Balsa - Craft Plywood 'no aircraft use'
  227. 3" Spinner, and 21x10 prop
  228. 1/18 brushless
  229. 4-stroke fuel?
  230. electric motor size question
  231. High altitude engines
  232. Servo Placement
  233. Cub tail gear ?
  234. Aeroslave???
  235. Look in for marker lights
  236. What is your favorite egnine manufacturer?
  237. Glow Fuel Life
  238. What's your favorite engine size?
  239. Need help
  240. Perry pump with flat twin?
  241. Your ultimate field box?
  242. Fliton 540. Not runing right
  243. Removing Rear Bearings
  244. want to go 4 stroking
  245. Krylon Fusion and H2O paint???
  246. contest balsa sources
  247. magnito
  248. old perry pump
  249. Paint Question
  250. hepl to hinge removable surface
