PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Switch Direction? Which way for on/off
  2. Fuel line. Std or Large
  3. interferance
  4. Another servo wire question
  5. Goldberg Ultimate and Zenoah G26ei
  6. Field box battery?
  7. Nitro flying is becoming extinct!?!?
  8. JR going slow on 2.4 ghz radios? how long to wait for 6102 -2.4 ghz
  9. Guess what plane
  10. aluminum parts and potential radio interference
  11. Tell me I'm not insane....
  12. tiny tools-where?
  13. Muffler question
  14. Fool Proof way to test Rx's ???
  15. Aileron Differential
  16. airbrushing monocote or ultracoat then clearcoating everything
  17. What is the best Building board???
  18. avistar- nose high
  19. Tinning
  20. Epoxy cure problem
  21. Who knows this program?
  22. how come no lipos?
  23. how do you know your tank is full?
  24. HELP! I NEED SOME! Brushless/LiPo/esc problem
  25. What do you think?
  26. Futaba PCM receiver change frequency 38 to 30
  27. Quadra Question
  28. Hardened 2-56 threaded rods?
  29. Problem with an OS 120 with pump
  30. 7-Channel 2.4GHz System ???
  31. ultracote too heavy for a parkflyer?
  32. Graupner R16 scan 35MHZ
  33. problems using dx-7 with ar6100 receivers?
  34. how do i know its on straight?
  35. what can i use to balence?
  36. prop balencing?
  37. temp for break in
  38. What went wrong with this engine?
  39. .40 Pitts s1 kit or plans
  40. What kind of covering is this, and will Monokote stick to it?
  41. Hangar 9 60 size Corsair
  42. How many planes a year ?
  43. Favorite Covering, 3rd Choice
  44. Tower Hobbies Mailers - would you opt to reduce them?
  45. Spring air
  46. Muffler for for old engine
  47. TexasRCPlanes.com
  48. Favorite covering, your 2nd choice..
  49. Futaba > sanwa connections
  50. GP Dazzler and 4 stroke
  51. vess propellors
  52. need tips on covering
  53. What to use for servo rails
  54. Problems with shop
  55. T-28 Trojan?
  56. Favorite covering
  57. Sorting Buy or Sell items
  58. need mode 1 conversion answers
  59. size or retract servo
  60. Sharpening blades?
  61. Gloves
  62. engine knock ?
  63. airbrushing planes
  64. Twin Elevator servos
  65. Looking for receiver
  66. Dave Patrick Models
  67. Building in thrust angle?????
  68. fast 2.4 reciever discountinued?
  69. Slo-V Reciever burnout.... ANYTHING ELSE DAMAGED!?
  70. Warbird Trailer Question
  71. Great Planes/ Tower Hobbies Vs. Horizon Hobbies/ Hangar 9-eflite, etc etc.
  72. In a Club of both
  73. help with this petrol engine make and cc
  74. Engine Weight Comparison
  75. lead weights
  76. linkage help
  77. WHAT IS THIS 1/4 SCALE SPORSTER ?
  78. dubro Z-bender, any one use these??
  79. Building board Question....
  80. unkown aircraft, what is it??
  81. Sodering servo leads
  82. Glue to use
  83. new kangaroo wren 54
  84. O.S. 46 AX vs. Saito .72 ACC
  85. 2 Metal minis versus one standard servo
  86. Need a NIMH charger
  87. anybody know?
  88. Large servo for throttle. Overkill?
  89. Hayes Clamps
  90. GP Sand Bars
  91. Looking for Enya 120-4c needle valve
  92. Question about selling stuff.......
  93. light over dark covering?
  94. How to paint fiberglass cowl
  95. Saito 50 running problems
  96. Ultracote -vs- Monocote
  97. Futaba - JR Mix?
  98. Muffler identification ?
  99. every plane has an expiration date?
  100. Winter Flying
  101. how do rc airplane engines explode?
  102. Monokote does not stick to Ultracote
  103. Neon yellow monokote paint match
  104. Solartex weight
  105. YS FZ110S vs OS 1.20SE?
  106. finding lonestar balsa
  107. E-2C Hawkeye
  108. make a darker canopy
  109. Smoke system problems
  110. Lost a Website Link
  111. SYLVIAN 1975 YAK54
  112. Covering help. Can i use iron?
  113. Winter Season????
  114. Dazzler Tail Dragger question
  115. Latex paint
  116. Radio still OK to use?
  117. covering buzzard bombshell
  118. I need help with a software
  119. Throttle linkage
  120. Spectrum vs NGK spark plug !!!
  121. Help Pls - Squaring Sig Somethin Extra Tail
  122. Home Made Iron Sock?
  123. Spektrum DX7 Tx making 'chirping' noise!!!
  124. transfering TX data
  125. Hinging Glassed Control Surfaces
  126. Monokote Question
  127. Engine Prices -vs- Quality
  128. Servo Speed
  129. Airtronics Servos
  130. To ubec or not to ubec
  131. Herr P-51 dihedral??????
  132. Satio 100 prop shaft too short?
  133. fourth plane, sporty but not too sporty, what to get?
  134. Fabric Covering
  135. Best paint match
  136. Fequency Control at Your Feild?
  137. Satio 180 - No High RPM -Need Help
  138. Online Monokote How To?
  139. what size outrunner
  140. linkage for retractabel nose gear?
  141. Expansion pack - add on's ?
  142. heli engine for airplane use?
  143. Flying Area - Size Needed
  144. Source for thin CA
  145. Looking for a Club ?
  146. Bought kit from Tower... has some broken balsa parts... what to do?
  147. long range plane
  148. covering with Solartex
  149. balancing spinners
  150. Gas engine for TF P-40?
  151. sportsman aviation fw 190 spinner
  152. Dooling .29
  153. *Good Camera For RC Pics & Video*
  154. lhs or tower?
  155. Paint question
  156. Covering ?
  157. Gas on nitro engine
  158. paint mach for coverite
  159. How much exponential do you use?
  160. Ultracoat / Ultracoat lite
  161. weed trimmer motors
  162. Help to source flap hinges
  163. Plans for a Steath
  164. Latex Paint
  165. cowering weight???
  166. Help w/ CG on Bipe
  167. Hobbico Accu-Cycle pro series charger-dead
  168. Any good screen savers out there?
  169. on-line rc shops
  170. FAI fule
  171. Any pilots in the Florida Panhandle?
  172. servo arm screw almost stripped
  173. Trainer radio setups
  174. what should i (not) do?
  175. Coolest thing I've ever seen..
  176. Looking for info and members of the Plymouth Rock fliers club (MA)
  177. What is your paint setup?
  178. Futaba 9C Dual Elevator
  179. glow engines
  180. Great Planes Cub 20 -- is Saito 30 overpowering it?
  181. Fuel
  182. servo reversion
  183. Magnum XLS 46 power output?
  184. CA hinges
  185. Problems with remote glow...loss of voltage?
  186. Can you use a real glow plug to make a dummy?
  187. Engine Upgrades?
  188. OS Max 91 Silencer Mounting problem
  189. How to remove paint from a canopy?????
  190. Y servo reverse problem
  191. towerkote!! any good?
  192. airplane to helicopter some ideas
  193. lithium tx packs
  194. When 2 adjust 4stroke valves?
  195. Extra 300 Plans...Where to get???
  196. painting canopies
  197. Reliable Forecast?
  198. Can you identify this cockpit?
  199. Tornado "AT" ARF instructions needed
  200. Tiny Hole in wing
  201. Speed Brakes or not ?
  202. servo mounting type of wood/balsa and size
  203. SAME STROKE OR ALTERNATE SAITO TWIN ?
  204. Custom Foam planes
  205. Receiver placement when using Gas engines.
  206. What reciever is this ?
  207. CA glue for foam-does it work?
  208. Do you balance props?
  209. c of g location
  210. wing warp
  211. Name this plane if you can
  212. What kind of plane is this?
  213. Spun Aluminum Spinners
  214. Aileron Differential Throw ?
  215. Easy Star first try and crash 1 foot away?
  216. Where to find muffler for old Enya 60
  217. Robart Hinge Point Installation
  218. I just bought a bobcat 5o from nitro planes. can someone tell me the best way to set up this plane
  219. Coverite 21st Century Film Question
  220. which sportster for saito 182 twin ?
  221. Third plane
  222. brushless upgrade
  223. plastic-kote paint
  224. Cool Power MV15 Fuel
  225. 3W 150 TOC ignigtion
  226. More Power?
  227. hydraulic system?
  228. Difference between red and blue selector valve from robart
  229. Parts
  230. A PRACTICAL TOOL FOR RETRIEVING A PLANE FROM A TREE
  231. 2 stroke to Gas conversion
  232. What prop? 44" Yak 54 w/evolution .36nt
  233. Balancing a Carbon Fiber Prop
  234. Where to get downed plane locater
  235. electronic ignition module mounting
  236. radios
  237. Laser Lizard ?
  238. RCM Funster CG
  239. One in a million?
  240. RC in Toronto
  241. Help! - Kyosho Cessna Dihedral
  242. Fuel tank distance question?????????
  243. Beechcraft Baron 58 ARF 75in wing???
  244. futaba 7c setup
  245. O.S. Bubbleless Clunk?
  246. Polk’s Tracker III Programming Question
  247. Name That Plane - Sunday Edition
  248. How big a gap in hinge line????????
  249. great planes revolver
  250. instruction Manual
