PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Name That Plane - Sunday Edition
  2. How big a gap in hinge line????????
  3. great planes revolver
  4. instruction Manual
  5. Koverall and Dope
  6. newbie needs help setting up brushless motor with esc
  7. magnum flex pipe
  8. Crashed Futaba R127DF substitution
  9. Sullivan Glow Driver
  10. Edge gluing sheeting
  11. Anyone know?
  12. Ni-cd vs. Ni-MH batteries questions...
  13. Transparent covering
  14. Gorilla glue versus epoxy?
  15. Need to replace pushrods and arms
  16. Krylon Fusion Paint - Fuel Proof?
  17. ww1 planes.
  18. oil soaked ply
  19. Magnetic Building Boards
  20. Aifield Markings
  21. Help With Elder 40 ailerons
  22. Sad situation... but there's always a hope
  23. Fabric covering ?
  24. Trueturn Spinners??
  25. Glue_Fuel Proof?
  26. What would be the nicest airplane for this engine? O.S. FS-30S Surpass 4 stroke.
  27. engine
  28. WWII 1/10 scale pilot
  29. ikon Nwest kits
  30. What size tank
  31. mixing aileron and rudder ratio on hanger 9 pts p-51?
  32. TF Cessna 182 servos
  33. Engine mount and nose gear mount Q
  34. Glow plug connectors for On Board Glow
  35. Flying with twin engines
  36. Aileron Wobble
  37. NiMh and Trickle Charge
  38. Thinning polyester resin?
  39. Help w/ Muffler
  40. Multiple servo control question help please.
  41. Is anyone going to an airplane event in south miami?
  42. Where To Get Velocity Stacks
  43. shipping a plane
  44. Best versatile battery charger?
  45. World Models Glow Assist
  46. White smoke coming out of Motor Control
  47. crash - explanation
  48. 2 stroke vs 4 stroke
  49. Covering Material - Ultracote on a 1/2A plane?
  50. katanna and dl 50cc need help
  51. been away for 12 years
  52. any one know about w/m giant scale spitfire ???
  53. proper way to measure horizontal stab on a biplane
  54. So many pilots, so little time ...
  55. Where to find retracts?
  56. How do you figer out CG??
  57. Smoke systems
  58. need info about smoke systems
  59. Ideas for Chevy Suburban plane rack for transportation
  60. How do you do that????????
  61. best glue for, Wood to fiberglass bond?
  62. What're y'all saying?
  63. setting up 2 servos for rudder and elevator in 9c radio
  64. Cold weather plane storage?
  65. Book Or Video
  66. Channel assignments
  67. Question: Prop shaft too short and fueling a cowled engine
  68. Plan protection while building
  69. motor for my micro whizz?
  70. Dynathrust props
  71. nitro & extreme cold
  72. how do you add pictures to these?
  73. Work table size
  74. Spiggen.... Anyone built it?
  75. How to bevel a rudder???
  76. F-117 control surfaces
  77. Servos
  78. edge 540 v2
  79. Flying without a spinner?
  80. battery duration
  81. OK to fly to what voltage
  82. Covering horizontal and rudder LE???????
  83. Anyone build off glass?
  84. On board ignition system/glo driver
  85. RCM Plans. Looking for a biplane
  86. how many coats of latex paint
  87. flaps on sig kadet senior?
  88. 2 stroke
  89. Winter flying on snow skis
  90. 2 blade - 3 blade pusher question
  91. help w/ .46 prop at 5000 ft MSL
  92. Engine checkout and cleaning after crash
  93. another amazing customer service experience with horizon hobby!!
  94. cutting foam wings
  95. Fokker F27/ F50 Kit or ARF
  96. Cant keep exhaust from coming loose
  97. Smoke system for Ag Wagon
  98. engine fit for giant super decathlon
  99. Plane for 53 Irvine
  100. Ys 140dz muffler
  101. OS FS 52 Tuning help
  102. club dues violators
  103. Annodized spinners?
  104. Oz Cover
  105. What could casue this? (crash of ultra sport)
  106. Can you setup duel rate Alorons with Y harness?
  107. How to set up radios w/ trainer cord
  108. OS sx50 ringed motor
  109. Spinner Back Plate Holes for cooling
  110. paint
  111. help me with my nitro car
  112. What kind of plane is this????
  113. Futaba 6EX 2.4 fasst ?
  114. Charge Time
  115. PLEASE MEASURE YOUR 33% CANOPY
  116. How to replicate exhaust smoke stains?
  117. GP Cub 40 problem
  118. Phaeton Help
  119. Where to get Engine sound system
  120. servos not moving after crash?
  121. converting futaba 6exap 72mhz to 35mhz
  122. Light Smoke system
  123. re paintig a cowl
  124. Anxious to Train
  125. Fuel question
  126. Webra engine question
  127. ? conversion 2 blade to 3 blade prop
  128. Building Boards
  129. JR X9303 2.4GHz Transmitter Case
  130. Glow Fuel gone bad??
  131. OS FT 240 engine
  132. Extra 330L Size 60
  133. Futaba'a 3115 servo
  134. Carden
  135. Hitec and 2.4
  136. CB radio cause interference?
  137. jb-weld for exhaust repair
  138. Flaps on my Trainer?
  139. Joining Large Wings
  140. Walk Around_Preflight
  141. HOBBY SERVICE FOR WARANTY
  142. Finding cg on a low wing.
  143. K&B 61 with perry pump
  144. 25 LA hp
  145. engine woes.
  146. small bi-plane C.G.
  147. Video Hardware Needed
  148. Filling loose hinge slot??????
  149. Using a die in place of threaded coupler?
  150. Anyone hacing problems posting pics?
  151. Hitech address?
  152. magnum 91 xls break in problem
  153. Has anyone in the UK ordered from giantcod.co.uk
  154. Throttle Return Problems
  155. Buddy Box
  156. Hobby budget?
  157. Sealing/Fuel proofing covering???????
  158. CG for unknown 28% 540 Edge
  159. Has anyone seen/heard from 1/8 AirForce
  160. Jack screw actuator-how to make?
  161. Building board
  162. Ultimate set up
  163. GreatPlanes UlraSport .60 Engine ?
  164. Solder or plug
  165. Sears 10 inch bandsaw on killer sale
  166. returning an old engine to service
  167. Cam timing Enya 80 4c
  168. flying thingy
  169. Recommendations for personal use vinyl cutter?
  170. Converting control line to R/C
  171. How many have used HobbyCity.com?
  172. Modeltech Magic Extra 300L CG
  173. Checking Lipo Capacity.
  174. Mid wing .40 sized?
  175. I'm having a great day--question and answer story
  176. Need help with a Magnum 1.20 f/s
  177. Good Fiberglassing and Painting Video
  178. Air pressure for retracts
  179. Balsa Education
  180. Is a Heat Gun really needed ?
  181. Free Marvel Mystery Oil (After-run)
  182. Covering corners??????
  183. Anyone here with a Hitec Flash 4, I need your help
  184. stupid question, whats a 3d plane??
  185. looking for a giant scale 3d
  186. Fuel Spill
  187. top flie paint
  188. Need a new pressure fitting
  189. Airtronics Tx needs help.
  190. warbirdcolors.com paint for P-51
  191. Futaba FAAST 2.4Ghz range?
  192. Ace servos,any good?
  193. ENYA 80 4c parts???
  194. prop to engine?
  195. Smoker System ?
  196. SIG HOG BIPE WINDSHILD SET UP
  197. Smoke system high temp tubing
  198. Night flying - ESC for lighting switch? Help !!
  199. Is the 3 cyl Saito 90 a good engine?
  200. FWIW... what I learned today.
  201. OS 160FX ...Can't get enough Fuel to it at WOT?
  202. What plane is this?
  203. My wing is 5/8 off on a ARF help
  204. OS 46 AX engine mounts
  205. Mystery Airplane, can anyone help?
  206. wish to cover and paint ...need help
  207. Excelleron 50 and OS 70 four stroke
  208. SAITO FA65 BEST % NITRO?
  209. electric field interference
  210. Using new hi torque servos with Kraft radio
  211. Will a plane take off from sitting on a running treadmill???
  212. understanding prop size on my saito powered rambler 45----help
  213. inverted DX7
  214. Attaching a cowl - screws or magnets?
  215. German webshop promoting Saito four strokes?
  216. how do you make diesel fuel
  217. removing old iron on covering
  218. turkish frequency?
  219. Painting Balsa
  220. Who sells 3/16" wire retract struts?
  221. RTV silicone???
  222. how do you remove RC-56 residue?
  223. Ignition battery
  224. G20 Ignition
  225. Going to start a small hobby shop-NEED HELP!!!!!!
  226. Couple ailerons and rudder
  227. Futaba FPS131s servos
  228. Flaperons
  229. Moki 360 Twin
  230. Top Flite Lustrekote
  231. OS 1.60 and VP-20 pump
  232. Adverse Yaw??????
  233. Spread spectrum problems, anyone?
  234. IMAX/Shenzhen SKYRC Technology Co., Ltd.
  235. Fiberglass storage?
  236. RC video camera on smaller aircraft?
  237. air bubbles in fuel line at idol
  238. voltage regulator
  239. SPektrum DX-7 and RV4-40?
  240. the idiotic things that cost planes
  241. Shop recommendation in bay area please
  242. Cessna 310 Gear doors
  243. Canopy Glue
  244. Thermostat Operated Servo to open Engine Cooling Vent
  245. What to put behind a saito 100 twin
  246. *Remote Glow Ignitor*
  247. GreatPlanes Kits
  248. Identify This Plane....
  249. Spray gun recommendations
  250. Can someone help me find a plane for me?
