- Bought kit from Tower... has some broken balsa parts... what to do?
- long range plane
- covering with Solartex
- balancing spinners
- Gas engine for TF P-40?
- sportsman aviation fw 190 spinner
- Dooling .29
- *Good Camera For RC Pics & Video*
- lhs or tower?
- Paint question
- Covering ?
- Gas on nitro engine
- paint mach for coverite
- How much exponential do you use?
- Ultracoat / Ultracoat lite
- weed trimmer motors
- Help to source flap hinges
- Plans for a Steath
- Latex Paint
- cowering weight???
- Help w/ CG on Bipe
- Hobbico Accu-Cycle pro series charger-dead
- Any good screen savers out there?
- on-line rc shops
- FAI fule
- Any pilots in the Florida Panhandle?
- servo arm screw almost stripped
- Trainer radio setups
- what should i (not) do?
- Coolest thing I've ever seen..
- Looking for info and members of the Plymouth Rock fliers club (MA)
- What is your paint setup?
- Futaba 9C Dual Elevator
- glow engines
- Great Planes Cub 20 -- is Saito 30 overpowering it?
- Fuel
- servo reversion
- Magnum XLS 46 power output?
- CA hinges
- Problems with remote glow...loss of voltage?
- Can you use a real glow plug to make a dummy?
- Engine Upgrades?
- OS Max 91 Silencer Mounting problem
- How to remove paint from a canopy?????
- Y servo reverse problem
- towerkote!! any good?
- airplane to helicopter some ideas
- lithium tx packs
- When 2 adjust 4stroke valves?
- Extra 300 Plans...Where to get???
- painting canopies
- Reliable Forecast?
- Can you identify this cockpit?
- Tornado "AT" ARF instructions needed
- Tiny Hole in wing
- Speed Brakes or not ?
- servo mounting type of wood/balsa and size
- SAME STROKE OR ALTERNATE SAITO TWIN ?
- Custom Foam planes
- Receiver placement when using Gas engines.
- What reciever is this ?
- CA glue for foam-does it work?
- Do you balance props?
- c of g location
- wing warp
- Name this plane if you can
- What kind of plane is this?
- Spun Aluminum Spinners
- Aileron Differential Throw ?
- Easy Star first try and crash 1 foot away?
- Where to find muffler for old Enya 60
- Robart Hinge Point Installation
- I just bought a bobcat 5o from nitro planes. can someone tell me the best way to set up this plane
- Coverite 21st Century Film Question
- which sportster for saito 182 twin ?
- Third plane
- brushless upgrade
- plastic-kote paint
- Cool Power MV15 Fuel
- 3W 150 TOC ignigtion
- More Power?
- hydraulic system?
- Difference between red and blue selector valve from robart
- Parts
- A PRACTICAL TOOL FOR RETRIEVING A PLANE FROM A TREE
- 2 stroke to Gas conversion
- What prop? 44" Yak 54 w/evolution .36nt
- Balancing a Carbon Fiber Prop
- Where to get downed plane locater
- electronic ignition module mounting
- radios
- Laser Lizard ?
- RCM Funster CG
- One in a million?
- RC in Toronto
- Help! - Kyosho Cessna Dihedral
- Fuel tank distance question?????????
- Beechcraft Baron 58 ARF 75in wing???
- futaba 7c setup
- O.S. Bubbleless Clunk?
- Polk’s Tracker III Programming Question
- Name That Plane - Sunday Edition
- How big a gap in hinge line????????
- great planes revolver
- instruction Manual
- Koverall and Dope
- newbie needs help setting up brushless motor with esc
- magnum flex pipe
- Crashed Futaba R127DF substitution
- Sullivan Glow Driver
- Edge gluing sheeting
- Anyone know?
- Ni-cd vs. Ni-MH batteries questions...
- Transparent covering
- Gorilla glue versus epoxy?
- Need to replace pushrods and arms
- Krylon Fusion Paint - Fuel Proof?
- ww1 planes.
- oil soaked ply
- Magnetic Building Boards
- Aifield Markings
- Help With Elder 40 ailerons
- Sad situation... but there's always a hope
- Fabric covering ?
- Trueturn Spinners??
- Glue_Fuel Proof?
- What would be the nicest airplane for this engine? O.S. FS-30S Surpass 4 stroke.
- engine
- WWII 1/10 scale pilot
- ikon Nwest kits
- What size tank
- mixing aileron and rudder ratio on hanger 9 pts p-51?
- TF Cessna 182 servos
- Engine mount and nose gear mount Q
- Glow plug connectors for On Board Glow
- Flying with twin engines
- Aileron Wobble
- NiMh and Trickle Charge
- Thinning polyester resin?
- Help w/ Muffler
- Multiple servo control question help please.
- Is anyone going to an airplane event in south miami?
- Where To Get Velocity Stacks
- shipping a plane
- Best versatile battery charger?
- World Models Glow Assist
- White smoke coming out of Motor Control
- crash - explanation
- 2 stroke vs 4 stroke
- Covering Material - Ultracote on a 1/2A plane?
- katanna and dl 50cc need help
- been away for 12 years
- any one know about w/m giant scale spitfire ???
- proper way to measure horizontal stab on a biplane
- So many pilots, so little time ...
- Where to find retracts?
- How do you figer out CG??
- Smoke systems
- need info about smoke systems
- Ideas for Chevy Suburban plane rack for transportation
- How do you do that????????
- best glue for, Wood to fiberglass bond?
- What're y'all saying?
- setting up 2 servos for rudder and elevator in 9c radio
- Cold weather plane storage?
- Book Or Video
- Channel assignments
- Question: Prop shaft too short and fueling a cowled engine
- Plan protection while building
- motor for my micro whizz?
- Dynathrust props
- nitro & extreme cold
- how do you add pictures to these?
- Work table size
- Spiggen.... Anyone built it?
- How to bevel a rudder???
- F-117 control surfaces
- Servos
- edge 540 v2
- Flying without a spinner?
- battery duration
- OK to fly to what voltage
- Covering horizontal and rudder LE???????
- Anyone build off glass?
- On board ignition system/glo driver
- RCM Plans. Looking for a biplane
- how many coats of latex paint
- flaps on sig kadet senior?
- 2 stroke
- Winter flying on snow skis
- 2 blade - 3 blade pusher question
- help w/ .46 prop at 5000 ft MSL
- Engine checkout and cleaning after crash
- another amazing customer service experience with horizon hobby!!
- cutting foam wings
- Fokker F27/ F50 Kit or ARF
- Cant keep exhaust from coming loose
- Smoke system for Ag Wagon
- engine fit for giant super decathlon
- Plane for 53 Irvine
- Ys 140dz muffler
- OS FS 52 Tuning help
- club dues violators
- Annodized spinners?
- Oz Cover
- What could casue this? (crash of ultra sport)
- Can you setup duel rate Alorons with Y harness?
- How to set up radios w/ trainer cord
- OS sx50 ringed motor
- Spinner Back Plate Holes for cooling
- paint
- help me with my nitro car
- What kind of plane is this????
- Futaba 6EX 2.4 fasst ?
- Charge Time
- PLEASE MEASURE YOUR 33% CANOPY
- How to replicate exhaust smoke stains?
- GP Cub 40 problem
- Phaeton Help
- Where to get Engine sound system
- servos not moving after crash?
- converting futaba 6exap 72mhz to 35mhz
- Light Smoke system
- re paintig a cowl
- Anxious to Train
- Fuel question
- Webra engine question
- ? conversion 2 blade to 3 blade prop
- Building Boards
- JR X9303 2.4GHz Transmitter Case
- Glow Fuel gone bad??
- OS FT 240 engine
- Extra 330L Size 60
- Futaba'a 3115 servo
- Carden
- Hitec and 2.4
- CB radio cause interference?
- jb-weld for exhaust repair
- Flaps on my Trainer?
- Joining Large Wings
- Walk Around_Preflight
- HOBBY SERVICE FOR WARANTY
- Finding cg on a low wing.
- K&B 61 with perry pump
- 25 LA hp
- engine woes.
- small bi-plane C.G.
- Video Hardware Needed
- Filling loose hinge slot??????
- Using a die in place of threaded coupler?
