PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. need help on a engine question
  2. Joining sheeted foam wings
  3. batteries can use lipo's with brushed motor
  4. prop shorter on one end
  5. F6F Hellcat
  6. AT-6 canopy....need one
  7. os 4 stroke
  8. Magnum engine and Pitts muffler
  9. epyaya.com
  10. Flying tail wires, tension?
  11. Question on Fuel Proofing with WBPU
  12. Looking for club and place
  13. Dave Brown Spinner
  14. ceiling tile question
  15. Bi-plane unkown type
  16. Supertigre G60 Bluehead Gaskets
  17. Whats the best smoke system for my new saito 72?
  18. crock pot cleaning
  19. Futaba rx with hitec cristial
  20. slightly off topic, but an airplane related q anyway
  21. Dubro 866 Control Horns Getting Sloppy
  22. Airplane reaction and responce
  23. Metallic Colored covering?
  24. Prop. 15x6-10
  25. Extreme Vibration on UcanDo46 w/ Saito 82
  26. Bomb Bay doors.
  27. How do I install a Perry pump
  28. Camera Systems
  29. Weatronic 12-20 R GYRO
  30. Two engines & Two airplanes, your thoughts
  31. Hinge Slotting Tools
  32. Help my paratroopers- Looking for ideas for rotation mechanics
  33. Servo for retracts
  34. Servos w/Spektrum DX-7
  35. hanger 9 60 size
  36. cheapest servo you would run on a 60 size plane
  37. Filler
  38. Rossi .53 need help please!
  39. Hinge Tape
  40. Great tool bought cheap
  41. help w/ Sig Coverall
  42. Set screws? itty bitty ones.
  43. Marvel air tool oil?
  44. HELP - How to stop a muffler rotating ????
  45. webra 91 p5
  46. oil soak and fuel please help
  47. Painting vs Monokote
  48. Motor won't run
  49. Ceramic Heat Blanket attaching
  50. Plane Question
  51. Aliphatic glue to hold in CA hinges.....
  52. newbie question
  53. Topflight Flat Clear & Sun Problems?
  54. glow plug threads???
  55. Ailevator Question
  56. good sandable primer for plastic
  57. Ducted Fan Jet
  58. Using Flaps
  59. Help w/TT Staudacher 300s
  60. Fuel Tank question
  61. Low compression when hot
  62. Glitch busters & 6 volts
  63. os 55ax manual
  64. New club website colbyrcflyers.com
  65. Installing a tuned pipe on ringed K&B .61 Is it worthwile?
  66. OS FL-70 four stroke
  67. CMP F6F Hellcat Question
  68. Propeller length and pitch, questions?
  69. laquer, or pollyurethane?
  70. CMP Giles 202 140 servos?
  71. gas oil mix ?
  72. First Aid Kit?
  73. is it hard to recover a tower trainer 40
  74. would this be possible?
  75. O.S.91 4-S.
  76. Monokote Iron Temp...
  77. Radio Repair
  78. ultracoat covering question
  79. Is there a formula to find electric engine power to nitro engine power????
  80. Funtanna X-50. SFG's Y/N
  81. CG on an Aerobird Extreme
  82. Engine mounted off center.....
  83. Super Tigre G-61 and G-75 Engines Compatability?
  84. Magnum engines
  85. Thining epoxy
  86. Dose a pumped OS 91 get after run oil
  87. Saito 80 GK problem
  88. What fuel tubing?
  89. How-To for Pull Pull systems
  90. Funtanna X-50
  91. Hitec Eclipse 7 channel radio.
  92. RK-Aircraft
  93. brakes on trainer 40
  94. nitromodels 50cc yak
  95. AP.15rc yellowjacket
  96. Monokote
  97. need needle valuve oring for older Royal 46
  98. Cessna 182
  99. Hinge Line
  100. engine equivalents
  101. Ailevator--what is it?
  102. Could someone give me some painting advice
  103. Saito . 72 stuttering
  104. Airfields - Clubs - Parks
  105. Transmitter Trainer cord question
  106. help 1/5 pica p-51
  107. Scale instrument panel ?!?!?
  108. Tail heavy? CG? problem
  109. Glow driver using 4.8v flight pack
  110. Remote glow on a Saito Golden Knight - what's up with that?
  111. Flaperons
  112. Don Harris smoke pump
  113. Which is the better nylon push rod?
  114. foam safe CA glue ?
  115. What is it?
  116. painting aluminum - again
  117. What dictates prop diameter?
  118. Help with Bi-plane wing Incidence.
  119. Spacewalker II power?
  120. ENGINE NOISE
  121. 1/2A Gee Bee
  122. ikon n" west
  123. In search of prop.
  124. NMP inline muffler
  125. FF7 or FF9 versus JR9 or JR X-2720 whats the easiest to program
  126. futaba 9 cap
  127. Which Engine?
  128. Kadet Senior Throws
  129. Aero Gloss Sanding Sealer...
  130. Nylon landing bolt
  131. Lipo for Tx?
  132. Two Fuel Tanks, One gas Engine
  133. airbrakes and flaps transmiter setup
  134. Hitec Servos Not Centered
  135. Exhaust Mounting Question
  136. Need a Windsock
  137. Texas
  138. Need Help - YS-91AC
  139. threading pushrods dilemma
  140. Elevator servos going different ways
  141. saito 82 what prop for more thrust
  142. Ruder and Aileron mixing.
  143. supertigre 2500
  144. Gluing laser cut ARFs
  145. US Engines.
  146. First giant/gas
  147. soldering aluminum mufflers ??
  148. Covering question
  149. waht profile of elevators and rudder?
  150. Need more spinner clearance
  151. Guage For ALuminium Wing Joiner Tube
  152. Saito fa-125a break-in
  153. Tiger Stick .40 - what battery pack
  154. What shops to visit in Singapore??
  155. Obese Gas Engines
  156. Lost Model Alarm
  157. ultra hots
  158. 0lder osfs 120ll with pump
  159. Antifreeze/Crock Pot Questions
  160. LARGER ROLLS OF ULTRA COAT
  161. silicon tubing
  162. Exhaust oil in the fuse..how do I seal it up?
  163. Airstrip Size
  164. deisel conversion
  165. Propellers
  166. OS 61FX Vs 75AX n Tiger60
  167. glitches
  168. Aileron-Only-glitches! help
  169. Receiver/battery mounting question
  170. magnum engine parts
  171. Fuel Question
  172. Sealing iron
  173. http://www.rc-asia.com/ Does anyone know them?
  174. crash video
  175. AM Transmitters
  176. white trailer, washer it, it looks like I’m pouring milk
  177. CG Tiger 60
  178. What can i do
  179. Cowl gromments
  180. landing gear -giant super chipmunk
  181. enamel paint flattening agent
  182. New OS 32SX
  183. !/3 Modeltech ARF Manual?
  184. Dyeing Silk
  185. Spraying Latex Paint
  186. Retract question
  187. How to cover my Big Stik
  188. Duel rates with buddy box question
  189. sc engine question
  190. RX crystal
  191. Which ENGINE???
  192. Control surfaces
  193. Spectrum DX7 TX Charging
  194. Saito 82
  195. Need help determining the size to build an airplane for a 50cc gas engine.
  196. What to do? Sport or 3D?
  197. Magnetic Switch
  198. prop balancing
  199. NMP?
  200. Longest flight duration and distance?
  201. Foam cores
  202. Tail weight?
  203. RIPMAX BOSSANOVA
  204. Tail wheel steering?
  205. Dope Finishing Problem...Help!
  206. heavy Tiger 60
  207. Thunder Tiger PRO 70H for airplane?
  208. test stand
  209. Slot Machine Modifications
  210. replacemant cowls & wheelpants?
  211. Please recommend a Prop for a Saito 100
  212. servo leads and servo extensions
  213. K&B .45 sportster needle question
  214. converting to gas:
  215. Monokote covering
  216. Anyone have this cub before?
  217. Needing to refresh my memory Misc Help
  218. SEAWIND INFO
  219. transmitter fuse
  220. peak charging
  221. Glo engines
  222. g-26 air filtering
  223. *Fuel Dot With "T" fitting Leaking*
  224. primer help ?
  225. What about Corona recievers
  226. Motor keeps "popping"
  227. Best way to cut a fiberglass cowl
  228. What Plane for a OS Pegasus (Again)
  229. what happened to it all
  230. Filton Extra 330s Freestyle
  231. Best hatch latch?
  232. Float mounting
  233. painting
  234. Canopy Repair
  235. Canard Long EX take-off problem
  236. Painting Super shrink Coverite
  237. Vacuum forming questions
  238. piper pawnee ?
  239. Cap x sunburst cover
  240. wiring aG-26
  241. high and low
  242. how to store a plane
  243. Engine Thrust
  244. G-26 prop advice
  245. Aileron deflection on a biplane
  246. Obsolete OS parts
  247. servo noise
  248. Help with VERY old monocoat !
  249. Help me rate my expertise
  250. stripped threads?
