PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. 5 unique flying RC designs.
  2. Returning to the Hobby
  3. OS FS-120 Disassembly
  4. E ignition batteries
  5. 2 blade to 3 blade
  6. looking for pictures and ideas for taking planes to and from field
  7. what size prop for saito .82
  8. Engine rings
  9. Good Quality Razor Saw
  10. Adjustable Engine Test Stand
  11. Thunder Tiger Expo 3D - help me!
  12. Tower Hobbies 61 carburetor
  13. Brand new to gas. DLE 30... Break-in clarification??
  14. JR 12X screen stain
  15. OS 91 fourstroke problems
  16. Tx batteries
  17. Old Magnum Pro 40 FSR-ABC
  18. RC FOAMIES in a hot car ??
  19. Ys140
  20. Reversing Y-harness use
  21. Ultracote covering over Auto Primer??
  22. what is up with super tigre??
  23. Ok models p51
  24. saito fa50 with missing rocker cover ? can I still fly with it?
  25. Covering question. Bill Evan future Shock
  26. I have a question about hex key/ Allen key / Allen Wrench and Screws.
  27. eneloop batteries
  28. A 2.4ghz question
  29. Tubing
  30. employment
  31. FPV Worthy Canopy for Great Planes Cherokee
  32. G62 Propping
  33. OS Engines 15GGT- Issues or Concerns
  34. prop size for saito 72
  35. Tactic radio
  36. Twinstar II FPV Build Options - 1.3ghz plan and thoughts?
  37. Chartpak tape still available ?
  38. What brand servo work with airtronics rd 8000
  39. Plane ID
  40. Nitro Engines O.S. .46 FX and Magnum .91
  41. dx7 and visionaire
  42. futaba 6 ex radio
  43. Question for Barstow California RC pilots.
  44. Dromida omiubus
  45. takeoff control
  46. Jack Devine Modles
  47. tower and JR
  48. do you save clevases, control horns, bolts from wrecked planes?
  49. New to buying, need any help I can get!
  50. swamp tiers
  51. World Models Super Chipmunk and Saito 82 GAs ( 14cc)
  52. MVVS 26 front bearing
  53. air retract pressure gauge
  54. sullivan battery box
  55. Transmitter
  56. Brushless motor issues
  57. Gas engines
  58. Rc ignition kill switch setup
  59. Hanger 9 Angle Pro
  60. FMS 1700mm F4U FLap servos chatter
  61. NiMh battery problems
  62. Carb help!
  63. Ultracote paint match
  64. Help me understand props....
  65. there was a co that made?
  66. What is the deal with WILL NOT SHIP!?
  67. Adheasives & Epoxys
  68. Cline regulator
  69. Fuel Pump with Brass Gears
  70. Checking rubber
  71. Stuck Backplate OS 120 Surpass II Pumped
  72. OS FL 70 Piston Removal
  73. OK models
  74. Best hand-crank pump for gasoline
  75. Question... how do you put on the 2 throttle arms AGM-60
  76. Ok p51
  77. removing balsa wrinkles on foam sheeted wing
  78. Satio FA-56 no compression, why?
  79. Why are Electric Props Different?
  80. Glow Fuel Question
  81. gummy clear coat removal
  82. covering iron controls
  83. E-Flite Electric Retrat PCB/Controller replacement?
  84. futaba 6208
  85. In search of:
  86. OS FX-40 direction of rotation?
  87. looking for a PILATUS PORTER 23cc size......
  88. Can you identify this plane for me ?
  89. Webra 145 Aero break-down
  90. Lustercoat Compatible Paint
  91. Concealed hatch question
  92. SIG 40 wing
  93. canister muffler for twin cylinder engines
  94. Help with a THOR 45 Part
  95. Glow fuel cleanup
  96. Near lost choosing the right ESC and which motor for a 50" scratch Kadet....
  97. Gee Bee 55cc wheel pants and strut covers
  98. need help with this.
  99. Canister exhaust rear dump for RCGF 60cc twin cyl and Saito 57TS 4 stroke
  100. Looking for a good LiPo starter
  101. Gee Bee 50cc R3
  102. air speed squeaker
  103. Canopy
  104. Flair kits
  105. Graupner Taxi 2000
  106. Ignition causing servos to twitch
  107. How to un-subscribe
  108. Super Tigre carb
  109. rcu marketplace problems
  110. Saito 150 intake gasket
  111. Mounting props to backplates with spinners
  112. Remote glow adapter
  113. Windows a twin
  114. Question on Kraft servo compatibility
  115. DLE On Board Tachometer
  116. 2.4 Glitch/Hit???
  117. TX maintenance
  118. help with finding c.g Point on some planes
  119. Apprentice Motor Change
  120. Brotherhoods
  121. Engine choice question/opinion... Decisions..... Decisions.....
  122. E*flight retracts
  123. Graupner props
  124. Hyperion Servo Slower Problem
  125. RPMs
  126. Using dope on Tiger Moth.
  127. Idle problem
  128. Robart Hinge Points, how many and what size?
  129. aileron to rudder setting
  130. DX5e compatibility with AR636 receiver
  131. ducted fan motor for a prop plane
  132. Futaba 14SG
  133. Repaint New Cowl
  134. Solar Plane
  135. I need info on a P-51
  136. Carb switch on RCG 26cc
  137. Kyosho 188 agwagon 69" wing spand
  138. Futaba T14SG Problm
  139. Hangar 9 Sundowner F1
  140. Crash caused by faulty rx?
  141. 3M Scotch Super 88
  142. Servos voltage
  143. Solar power
  144. Prop Info
  145. Question: Where can I learn about 4-stroke RC engines and brands?
  146. Macchi Veltro or the Blackhorse models Macchi
  147. O. S. GGT10 Glow Gas Engine
  148. OS 7D carb throttle link connection
  149. Programming Ch. 6 Futaba T7C Trying to get full travel
  150. looking for the HZ of a hitec hs 55..........
  151. White Gas
  152. Interference with 72 mhz antenna
  153. Need Help with some Old Planes/Engines
  154. Mystery Edge 540
  155. wing tube
  156. Need help sourcing a replacement wing tube!
  157. Saito Throttle Lever
  158. Mystery plane solved!
  159. Motor acceleration lag
  160. Motor acceleration lag
  161. Aileron
  162. how to inlarge..plans
  163. how to inlarge..plans
  164. air intake to carbs????????????????????????????????????
  165. Winter storage
  166. lazer lizzard , chico texas
  167. Re: Aero sport 300l
  168. O.s. Fs-91s
  169. spektrum AS3X 636 RECIEVER
  170. OS 7 D carb throttle lever moification
  171. What receiver should I use?
  172. Robart #307 Hinge Dimensions?
  173. Whatever happened to pushers?
  174. Electric Retract Question
  175. help to progam DX8
  176. How to drill a perfectly straight hole through a wooden dowel without a drill press?
  177. Sierra Giant still around?
  178. Good Battery Charger
  179. Perry Swap Meet from Ohio Area
  180. Old 60's? Webra vs HP vs HB
  181. Older sailplane with can motor
  182. more pictures of the mystery plane
  183. Who makes this plane?
  184. Kadet Senior spar webbing
  185. Glue for foamies?
  186. Custom-Cut Vinyl Graphics
  187. Is this a good spark?
  188. Question re Elevator Trim
  189. Can Someone Help Me Identify this Radial Gas Engine?
  190. Who's covering is it
  191. RC Aerodyne
  192. Balsa wood tree
  193. Servos and Voltage Question
  194. Saito 100 Muffler Extension
  195. Where to get fiberglass cloth
  196. fale safe settings
  197. most used fail safe settings
  198. testing switches
  199. 11 mm carbon tube in Europe
  200. Sullivain RC Products No Good Customer Service
  201. Adjusting Spray Gun - Latex
  202. Need Small Piece of Monokote Gold
  203. Loose Blind Nut in tight spots
  204. RC Engine Starting Stand
  205. replacement carb for RCG 26cc
  206. Hitec Equipment
  207. Team duster designs air tractor 502-72
  208. How to refresh or clean old fabric covering?
  209. Align 615 servos in a 30cc plane!
  210. Brotherhoods
  211. Tactic radio suitability?
  212. help
  213. looking for long pointed style plastic spinners for ultimate biplane...
  214. DX8 RX too crowded
  215. info on Mintor 22
  216. Regulator question
  217. Engine requirement
  218. 2 blade or 3 blade............now thats a good ?
  219. 20 yr. break from flying
  220. differance in engines
  221. Airtronics RD6000 72MHz Radio
  222. 1988 O.S. .21 MAX EXR and O.S. .21 MAX RF Factory Needle Settings HELP?
  223. Tower Hobbies Evolution .46NX (Original) Factory Settings
  224. removing decals
  225. Hinges for a side hinge canopy
  226. Fuel for Supre Tiger 3250
  227. Brian Taylor Spitfire "CG"
  228. larger cone for my electric starter
  229. RealFlight's Edge 540 has me wondering if it's a fine beginners plane for me. (??)
  230. Will Monokote Stick to Polyurathane
  231. Thinning Oil Based Polyurethane
  232. Good Oil
  233. Latex painting
  234. First Model With Flaps and Retracts. Which Channels should they be put on?
  235. Anybody know what has happened to Carstens plans and books inventory?
  236. P-51 Exhaust
  237. DLE 60 twin
  238. Center of gravity for a Hobby Lobby Senior Telelmaster ARF 96 inch Wingspan
  239. Toughflon? Is it a good covering
  240. Flutter - How to find the cause??
  241. rc universe ads?
  242. 1st time with Inverted Engine, does this look right?
  243. enya 80 four stroke
  244. Rotate carb on DLE 20 gas engine?
  245. Ringmaster Remote control (not u control) center of gravity.
  246. Who still sells O.S. FS-30 4-stroke engine?
  247. glow fuel?
  248. Room temp for appling monokote
  249. Have 72 MHz radio, should I upgrade to 2.4 ghz
  250. Savex model planes
