PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. 62''Ultimate
  2. fiberglassing ??
  3. Trailers, duel axles or not?
  4. 6V Nihm Receiver Packs - Regulator or not
  5. O.S. MAX 61 VR ABC GS R-1 engine
  6. Can You Slow Down a Servo?
  7. half-tank 70 surpass dilema
  8. super chipmunk tailwheel ?
  9. Glow plug?
  10. futaba conquest radio system
  11. Nylon bolts and thrust wedges
  12. Fun One
  13. futaba fp-s33 servos
  14. Carb is gummed up,what would work to unstick it?
  15. H9 Solo Sport tank problem?
  16. Experience with Electro Dynamics Ultra Switch II?
  17. Prop for MDS .68
  18. Is my motor bad or speed controller??
  19. Saito/OS lock nuts
  20. webra engines
  21. Relocate Antena
  22. biggest plane you've ever put a .40 into
  23. U.S. 41 engines
  24. GB Falcon 56 vs the New GB Falcon III
  25. finding cg on a F-6F HELLCAT 90
  26. Seagull Spacewalker with OS 40-LA
  27. OS LA-40 compared to OS FP-40
  28. Trimming Slimline to fit
  29. Any ideas
  30. Is Grish Propellers still around?
  31. Breather Nipple for Saito 125 ???
  32. What size K&B
  33. Any Ideas on a good kit cutter
  34. battery question
  35. Futaba or JR
  36. Aerial Banners?
  37. who else fears this problem
  38. two fuel tanks on pusher jet
  39. Hobbico low battery warning & plane finder
  40. NEED HELP WITH ENGINE
  41. name this plane
  42. Canopy glue
  43. Repairing a wing by grafting
  44. MDS .46
  45. Where to add the weight?
  46. castor oil
  47. Will this work well ?
  48. Hanger 9 120 Edge 540 Canopy needed
  49. Best way to make arf covering not peel
  50. glitches caused by onboard glow driver
  51. FDLabs mixII elevon/v-tail mixer
  52. Problem breaking-in a ASP 120
  53. Identify this retract?
  54. Will ISC-300 Do the Trick?
  55. Indoor Waypoint Navigation
  56. Need to make a pipe for a Saito 220.
  57. pitts muffler for Saito GK
  58. Black Liquid on Engine
  59. Indoor Flying near Tacoma or Seattle, WA?
  60. Little Help..?
  61. Dope clear over latex
  62. MVVS 1.60
  63. Saito 182 Twin
  64. Flying Fish-E featured in Oct05 RC Model World Mag
  65. YS .61-R - Exhaust Help
  66. Duralite digital switch
  67. Traveling with Radio Equipment
  68. After run oil??
  69. Monokote Covering Question
  70. Foaming Fuel
  71. O.S. 160 QUITTING IN THE AIR
  72. Help On CG for Sig Hog Bipe 60
  73. silicone deflectors
  74. BAD VIBRATIONS from OS 120
  75. Fundango power
  76. HELP ME PLEASE!!!
  77. Thunder Tiger Staudacher
  78. Evolution engines stink!!!!!
  79. Os FS 120 Surpass (pumped)
  80. JR7202 Mixing
  81. TX > RX > Servo compatibilities
  82. Long term engine storage
  83. Where to check? Hobbico SU-31
  84. Hinge replacement. Firewall pushrod
  85. Printing white letters?
  86. SMOKE SYSTEM
  87. nexstar problems
  88. PARTS ~ K&B SPORTSTERS
  89. Vortech Spinner fitment problem
  90. Sig Hog Bipe Removing old covering??????
  91. How to tell the band of a Rx
  92. gas fuel line
  93. engine noise
  94. Recovering oil soaked balsa help!
  95. l-19 bird dog
  96. Question about ESC
  97. Third Coast Hobbies?????
  98. O.S. .75 AX RINGED TWO-STROKE RINGED??
  99. Sky Scooter Pro 2 parts in a different plane?
  100. Need advise on drilling upper left hand hole in back of crankcase on OS 160FX
  101. Yamada YS120 - need instructions!
  102. Where to buy scales?
  103. fuel tank setup
  104. Sierra vs. Robart retracts?
  105. Prop bolt for DA100-50
  106. Do Tru-Turn Spinners fit Bolly Props?
  107. NiMH Failure Thread!!
  108. Kudos for HiTec RCD
  109. quesiton about my new nexstar
  110. Thunder Tiger 91 4 stroke
  111. Got a Hitec Neon with a Trainer Plug?
  112. Stupid question of the day.
  113. Best Hobby Shop in Bay Area
  114. fut.9zw
  115. os 40 on canard
  116. Battery and Receiver
  117. getting that prop nut tight
  118. Props and paint jobs
  119. CG Help
  120. CA on Vertical joints
  121. my plane seems underpowered, any insight please.
  122. Prop Lock Nut
  123. fire walls
  124. 2 Stroke inverted mounting
  125. brushless conversion
  126. games for a fly in
  127. Performance propeller?
  128. stiffining home made foam wing
  129. looking for old Goldberg Ranger 42 instruction sheet
  130. K&B 65 Sportster
  131. 2 Stroke vs. 4 stroke Engine
  132. Odd aileron servo issue.
  133. How To Repair Foam Wing?
  134. Want to install Flaperons
  135. PTS Mustang retracts
  136. Dual conversion RX
  137. Christen Husky
  138. why is my muffler tarnish after only 3 flights
  139. Nose art decals?
  140. Problems with Byron Original Christen Husky
  141. trainers
  142. jr and hitec / hs225
  143. Inverted engine
  144. where to put after run oil?
  145. Glow vs. Gas Question
  146. Help!!! Can't start my Saito FA450R3, backfiring
  147. GP Ultimate aerleron flutter
  148. 2 stroke vs 4 stroke
  149. saito 100 wont start?
  150. help me figure out what kind bi-plane this is
  151. ZDZ80RV MOUNTING ?
  152. For my 3rd plane
  153. 46ax tuning help!!!
  154. Yak-54 Phoenix Models
  155. Bipe incidence
  156. Trim/Sub Trim & DR - What is the efficient way of setting it?
  157. need help on wm rambler 30
  158. need help finding a cowl for a plane...
  159. Where to find flex cable?
  160. RC cat name?
  161. Has anyone tried to deal with EdgeRC lately?
  162. Pacer Hinge Glue and RC56
  163. stryker cog
  164. Horns
  165. making your own cowl?
  166. House of Balsa's Micro electric AT-6 Texan KIT
  167. Ultracote vs Easycoat...what's the difference?
  168. which engine will do
  169. Pulse jet plane wanted!!!?!??!?!?!
  170. Seagull Edge 540 with Saito 91 .. problems!
  171. Seagull Edge 540 with Saito 91 .. problems!
  172. Turbines? Help
  173. Airtronics VG6000
  174. Prop size for OS 60 FX
  175. Painting Solartex
  176. Li-Po Pack goes bad after only 2 months
  177. filter screen for 70 surpass
  178. Use of Tach for Break-in on Saito 125a
  179. CG extra 300 fibreglass parts
  180. Do 28 Skyservant
  181. Seagull Yak Antenna
  182. Kyosho 40 size Pitt Special control throws and CG
  183. Klett Hinges
  184. Aluminum
  185. RaidenTech.com Coupon Codes???
  186. SuperTigre carb attachment?
  187. Spinner for large apc
  188. OS 1.08 Idle issues
  189. Quick links seem Quick to fail
  190. 4 stroke cam timing
  191. I want a Video Camera
  192. Spinner weight goodness
  193. Nicad cycling question
  194. BME .90 SuperTigre gas conversion
  195. Twist 150, Saito 180 and DX-7
  196. Hanger 9 FuntanaX 100 vs. Seagull Yak54
  197. what size 4 stroke in a Global Fokker D-7?
  198. Dewyville special???
  199. Evo 40 HELP
  200. Phoenix Models CP232
  201. Canopy Problem: Jack Stafford Alon Aircoupe
  202. Incidence needs tweaking?
  203. STik whats next?
  204. 2 battery RX
  205. how long is a 16"x6 APC prop
  206. servo connector housing question
  207. Where to find an RV-3 or RV-4 @ 100 inches..??
  208. Paint matching Monokote - second question
  209. New battery chemistries?
  210. Krylon Fusion on Elapor Foam
  211. Two JR radio trim differences?
  212. engine for 1.25 lb plane
  213. 10 - 15 size motors
  214. Irvine 1.50
  215. Hydrofoam/Flydroboat vs Storm Launcher
  216. Aluminium covering
  217. 5in1 Camera Power from Servo Lead
  218. disposible camera's flash unit ?
  219. chargeing a niMH question
  220. Extreme Flight Extra 300?
  221. Engine thrust measurement
  222. Lost a prop in the air...
  223. reflex
  224. Brown paper covering !!
  225. Help ... quick question !!!! how to remove broken screw
  226. 72MHZ OR 2.4MHZ
  227. What happened to Dave Patrick Models?
  228. CG for CMPRO Extra 300
  229. White waterslide lettering?
  230. Will polyester resin adhere to a doped surface?
  231. problem with radio?
  232. Help with YS 60 2 Stroke
  233. need XTRA Brushless ESC Programming notes
  234. Robart hinges
  235. fuel on balsa
  236. What plane?
  237. Magic Words
  238. Which AC Charger Would You Reccomend?
  239. servo bounce
  240. Fort Riley K.S
  241. rudder use
  242. What to do with an old trainer?
  243. on board camera
  244. Mount a cowl with magnets?
  245. rc pilot
  246. Buying fuel in Germany.
  247. help on the PROPS
  248. Receiver / Servo Questions
  249. H9 Cub differential ailes
  250. consealing servos
