- help me figure out what kind bi-plane this is
- ZDZ80RV MOUNTING ?
- For my 3rd plane
- 46ax tuning help!!!
- Yak-54 Phoenix Models
- Bipe incidence
- Trim/Sub Trim & DR - What is the efficient way of setting it?
- need help on wm rambler 30
- need help finding a cowl for a plane...
- Where to find flex cable?
- RC cat name?
- Has anyone tried to deal with EdgeRC lately?
- Pacer Hinge Glue and RC56
- stryker cog
- Horns
- making your own cowl?
- House of Balsa's Micro electric AT-6 Texan KIT
- Ultracote vs Easycoat...what's the difference?
- which engine will do
- Pulse jet plane wanted!!!?!??!?!?!
- Seagull Edge 540 with Saito 91 .. problems!
- Turbines? Help
- Airtronics VG6000
- Prop size for OS 60 FX
- Painting Solartex
- Li-Po Pack goes bad after only 2 months
- filter screen for 70 surpass
- Use of Tach for Break-in on Saito 125a
- CG extra 300 fibreglass parts
- Do 28 Skyservant
- Seagull Yak Antenna
- Kyosho 40 size Pitt Special control throws and CG
- Klett Hinges
- Aluminum
- RaidenTech.com Coupon Codes???
- SuperTigre carb attachment?
- Spinner for large apc
- OS 1.08 Idle issues
- Quick links seem Quick to fail
- 4 stroke cam timing
- I want a Video Camera
- Spinner weight goodness
- Nicad cycling question
- BME .90 SuperTigre gas conversion
- Twist 150, Saito 180 and DX-7
- Hanger 9 FuntanaX 100 vs. Seagull Yak54
- what size 4 stroke in a Global Fokker D-7?
- Dewyville special???
- Evo 40 HELP
- Phoenix Models CP232
- Canopy Problem: Jack Stafford Alon Aircoupe
- Incidence needs tweaking?
- STik whats next?
- 2 battery RX
- how long is a 16"x6 APC prop
- servo connector housing question
- Where to find an RV-3 or RV-4 @ 100 inches..??
- Paint matching Monokote - second question
- New battery chemistries?
- Krylon Fusion on Elapor Foam
- Two JR radio trim differences?
- engine for 1.25 lb plane
- 10 - 15 size motors
- Irvine 1.50
- Hydrofoam/Flydroboat vs Storm Launcher
- Aluminium covering
- 5in1 Camera Power from Servo Lead
- disposible camera's flash unit ?
- chargeing a niMH question
- Extreme Flight Extra 300?
- Engine thrust measurement
- Lost a prop in the air...
- reflex
- Brown paper covering !!
- Help ... quick question !!!! how to remove broken screw
- 72MHZ OR 2.4MHZ
- What happened to Dave Patrick Models?
- CG for CMPRO Extra 300
- White waterslide lettering?
- Will polyester resin adhere to a doped surface?
- problem with radio?
- Help with YS 60 2 Stroke
- need XTRA Brushless ESC Programming notes
- Robart hinges
- fuel on balsa
- What plane?
- Magic Words
- Which AC Charger Would You Reccomend?
- servo bounce
- Fort Riley K.S
- rudder use
- What to do with an old trainer?
- on board camera
- Mount a cowl with magnets?
- rc pilot
- Buying fuel in Germany.
- help on the PROPS
- Receiver / Servo Questions
- H9 Cub differential ailes
- consealing servos
- solder steel nut to alum
- Looking for Capt'n Eddie pilot
- asp 61 what prop
- Ultracote over Monokote
- Scale props on a warbird?
- Canopy install
- Landing Gear Bolts
- what will burn more fuel?
- YS45
- Landing gear
- Spektrum DX7 Question
- TME smoke tank setup question
- BVM Air Fill Chuck and Robart Air Fill Valve
- satio 100
- Solarfilm
- Which Park Flyer to buy?
- Nitro fuel residue
- 6volts for receivers
- Help/Suggestions for new plane needed
- Quick Field Charger MKII
- Landing gear
- Receiver for gas powered airplane.
- Building Surface
- Airbrush selection
- Big Stik monokote color?
- Engine RICHENS when I point the nose UP?
- Carb setting
- Recievers for Airtronics VG6000 radio??
- Mounting aileron servos on Sig 4* 60
- I cant get my evloution .61 to be rich
- pros &cons of using 4. 8 or 6 volt for rx
- satio 100 good engine?
- motor hesitates while adding power
- Wondering...
- Thunder tiger giles and Phoenix Models wings
- What prop do I need???
- 2-56 threaded rod
- Monokote QC problems
- Deceleration of Conformity for Futaba FF7
- Cowl painting
- RC in Philippines?
- does 6 channel futaba radio have servo reversing ?
- Saito Muffler Stripped ??
- Instrument panel
- split elavater
- Sealing balsa for glassing
- Opinions & Advise Wanted
- Speed control for fomie
- Could anyone let me know what this plane is??
- JR X-347 radio module
- # of servo's
- Balsa filler question
- Glue to use on field box?
- Top Flite Panel Line Pen, is it fuel proof?
- Chipped prop - when do you quit sanding/reshaping and toss it?
- dan santich hots
- Twist and evolution 46 dead sticking after 2-4 mins into flight.
- IMAC vs 3D/pattern & What plane?
- M.I.A. motors
- What size 4-stroke for Mid Star 40
- .46 AX on Sig Somethin' Extra - what prop for IMAC patterns?(removed baffle - gained 450 rpm)
- Help - New to the plane scene
- How do you handle trash at your field?
- Opinions on SuperTiger G 2300 motor
- Pusher Propeller
- Building tables
- Club Involvement
- Painting Solartex
- Would you buy these servos?
- Sig Aerokote & colours
- Fuel proof transparent paint
- GMS engines
- tx-rx compatability
- Moving / Relocating your planes without damage
- Plans for a Trailer for Models
- Airtronics Connection with pc
- Spectrum Setup
- Balsa Hardener? (prevent dents/dings in softer basla)
- Futaba T9CAP
- Who is the manufacture of this fuse??
- sig astro hog
- Control Horn Screws
- Fuel Tank Distance
- spinner question
- balanceing biplanes
- ASP .28 WILL NOT RUN
- Model weight reduction
- inverted saito
- os 70 surpass vs os 61 fx - fuel consumption
- Switching to glow, is this a good "first" plane?
- two cylinder on board glow
- 1950 Riis Park Flyers
- Where is Sig
- DX6 Programmable Aircraft
- Magnets = Interference?
- Moki 2.1 & 1.8 Motor Mount Help !!!!
- Remote Glow ?? What am i doing wrong ??
- Need help with radio
- engine spuder
- radio,s
- K&B glow plugs and plug caddy???
- Does this mean I am HOOKED????
- CA debonding wood
- What glues can be used to attach canopies to planes?
- g51 exhaust header question
- What Model is it ?
- Smoke Kit
- WANTED: Ohio Pilots for airshow
- what size is this motor
- 4 cycle and 2 cycle engine comparison
- wing fillets
- Decal/Fuel Question
- How far will a can of Lustrekote go?
- What size motor?
- asp 75 2 stroke engine
- WEN-MAC Challenger 1958
- Saito .80 carb replacement
- Landing gear bending problems
- cuts out when i accelarate
- Why does my 202 dutch roll when I try to loop?
- electric engine for Me109E
- Switch to glow planes?
- Charging a single cell 3800mah battery
- Pitts S2 Smoke Muffler
- buy a spectrum or a futaba radio
- What Kit Or ARTF for a Saito 170 3cyl Engine
- Progressive Plugs
- NEED A COMPOSITE EXPERT..
- Lubricating Retract Air Cylinders
- Sky Writer Smoke System - Questions
- How do you properly align a motor when mounting
- Acrobatics
- Why is it when searching for DA 50 nothing shows?
- retracts
- ys 110 muffler
- The new taste of Monokote...or... where's my fumes?
- Challenger 720 radio crystals?
- Can you mix epoxy & dope?
- Need help ID'ing another plane
- Safari
- How 2 make a home-made on board glow driver?
- Installing Retracts: Best Fasteners
- Are any Lipos good for onboard receiver packs?
- what makes more thrust?
- Futaba Servos 3010 vs 9001
- help! glitching probs.
- Carbon Fiber pushrods
- More on safety stands
- Air bubbles in fuel line ?
