PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. thrust for showtime 90
  2. NEED A COWLING
  3. Servo
  4. Prepainted Fabric Covering - which is best
  5. Starter Problem
  6. Carbon fiber wing tube source?
  7. oil in the gas tank !
  8. Tartan Twin Model 77 engine parts needed
  9. Hobbico Tach Readings Make No Sense
  10. Fuel/Nitro Mixing
  11. Inline fuel shutoff valves
  12. Nylon bolt question
  13. Valley Forge Signal Seekers - RC Airplane club in PA - is anybody a member there?
  14. Source for a good Pilot Figure
  15. Servos torque
  16. ASP/ MAGNUM RADIAL ENGINE
  17. Plans for ARFs?
  18. Help with Color Scheme
  19. Need help with PICA Cessna 182
  20. Airtronics and Hitech RCD receiver.
  21. Open Bay Areas
  22. Shops in San Francisco and Las Vegas
  23. Where to buy a wing tote-bag...
  24. four stroke engine mounting
  25. Funtana 90 SK110 or 130?
  26. 1.25 inch metal servo arms
  27. Mark .61 duel bearing engine? Feed back!!
  28. Feul soaked wood???
  29. Standart Economic Servos.... Share your experience
  30. field table question
  31. Kyosho D/F Sabre
  32. Can't drill parallel.
  33. ST90 for harrier 90?
  34. H9 Ultra Stik 60 dimensions?
  35. Ultra stick lite servos
  36. BUSA Cub (L4) Repair ?? (Tail feathers)
  37. Hitec prism 7 LCD
  38. LED light
  39. JR XP7202 Radio
  40. building board
  41. What is POS/NEG shift? what is dual conv
  42. Sheeting Foam Wings question
  43. Old engine start
  44. APC Prop Balance
  45. LHS Comparison from an Old Guy
  46. OS Engine HELP
  47. Where to find 1/6 Scale F4U Decals?
  48. Smoke Muffler Manufacturer
  49. Building board question
  50. Flite Life tester info needed
  51. What prop size for magnum 52 four stroke
  52. what rpm to operate at?
  53. Help for pull pull controls for first timer?
  54. Diagram for a retard.
  55. TURBINE PILOTS, can you help me find a.r.f. jet kits for turbine stores
  56. Which 4-Stroke for Sig Senorita?
  57. help with hot wire saw please, proper output voltage?
  58. OS Surpass 52 in a SIG Fourstar?
  59. T Fitting Blues
  60. Source for Airodynamic Aluminum
  61. OK PC-6
  62. building
  63. 1/3 scale laser 200 cowl
  64. motor for Kangke 1/5 Monocoupe 90A
  65. Lipo question
  66. Filler choices.
  67. SAITO100 assembly??
  68. Auto Paints for Models
  69. putty for glassing and painting
  70. Lost Transmitter, help
  71. burning out motor
  72. Help for BME .90ci Supertigre Gas Conversion
  73. Uneven servos
  74. Glues
  75. Rudder dried a little off center
  76. Towers new Digital Servos
  77. Thrust line of an engine???
  78. Magnum 91RFS ?
  79. New purchase!
  80. Engine Mount Modification ? Opinions
  81. Has anyone built a plane using Gorilla glue only?
  82. wall wart charger
  83. Funtanas
  84. Want some speed
  85. lanier predator
  86. Twinstar engine options
  87. .46 LA Wont idle
  88. What is that thing??
  89. 12 volt batteries for my new hanger/trailer
  90. Engine trouble - what to look for?
  91. starter battery for big motor?
  92. Smoke system 2nd battery
  93. Where did Pilot2PilotHobbies go?
  94. Need to fly!
  95. Mirage 550 power?
  96. Adding another channel
  97. Two questions - battery/receiver
  98. Tiger 2 and OS 55
  99. Cap X
  100. remote wind indicator?
  101. Funtana 100x engine choice
  102. JR Servo's
  103. Livestock electric fence cause interference?
  104. FX 91 os...Help
  105. Piper Pawnee PA 25 - Whyte Wings
  106. Identify this plane.
  107. What engine?
  108. Airplane transportation on pick-up truck
  109. new interferance problem, whats up w/that
  110. Solution for oversized prop-holes?
  111. 4 STROKE.... SAITO'S .... FUELS USED
  112. Gasoline fuel to glow fuel tank set up question
  113. Covering on Nexstar
  114. Pod for Seamaster
  115. Retract Gear Weight
  116. identify model
  117. Can U Name This Plane?
  118. Futaba 2.4 Ghz radios
  119. what RECIEVER do i need?.
  120. Looking for a shop that has a FS-120SP
  121. Funtata 40 Help on Repair
  122. Where to get foam pad for plane cradle?
  123. Which Battery for Field Box
  124. Piper Cub Embroidered Patch
  125. Is it just me
  126. R.I.P Funtana---New plane question
  127. sig 60 skybolt
  128. saito 150 rebuild
  129. Is this fuelproof?
  130. Spektrum 7 Radios
  131. Phone number Quicktechhobby
  132. what is this, i want one....
  133. paint to match ultracote
  134. Fuel Flow Problem
  135. Saito 82 please help
  136. OS 55ax on 30% heli anyone?
  137. Thrust Ratios
  138. Hitec Laser 6 and H9 Ultra stick 60
  139. Electric vs Glow & Gasoline power and the R/C press?
  140. learning to glass w poly ?s
  141. Where can i find an F-117?
  142. Fiberglass arrowshaft pushrod question
  143. magnum 1.08 2 stroke?
  144. Micro sevos for throttle control?
  145. Glow Engine Smoke System
  146. Phoenix 330 + Saito 100 anyone?
  147. What size of engine for my TF GE Corsair 60?
  148. Why go 2.4?
  149. Good ni-cad?
  150. Radio brand
  151. 21st Century Space Age Piant, where did it go ?
  152. Experienced Pilot going backward for peace of mind
  153. TV Series "24"
  154. Ultracote matching paints
  155. AUX batterie?
  156. Sig Koverall
  157. Off the wall question
  158. Graphics / decals
  159. LETS SHOW OFF OUR COVERING DESIGNS!!!!
  160. Phoenix models cap 232 80"
  161. Panel lines AAARRRGH
  162. Smoke System Effects On Engine
  163. EXTRA 300 THRUST
  164. Electric / Nitro
  165. FUTABA T6XA TX PCM AND THE HITEC RX QPCM 7 CHANNEL
  166. crashed plane how to check RX
  167. Wing Incidence differences
  168. Need objective comments on radio gear
  169. How do I get Ultracoat Paint?
  170. Prop Noise
  171. Servo for Landing Gear Doors ?
  172. Chip Hyde Quiet Pipe
  173. How do you clean your nitro planes?
  174. Is the K&B .65 a good engine? I found a new one in the box.
  175. DX7 set-up question
  176. Field charge a new battery?
  177. plane for os 32 sx
  178. Fuel Proofing arfs firewall?
  179. Inverted engine/header tank/fuel pumps
  180. brushless motor for aerostreak
  181. Help!!! Older extra 300s
  182. RCM Magazine August 2003
  183. SELECTING A .15 GAS/NITRO ENGINE
  184. Fabric and paint covering options
  185. GP Super Sportster Biplane?
  186. Balancing 20" + props?
  187. Gyro for Funtana
  188. Who makes this hardware?
  189. Spacewalker vs Four-Star 120
  190. Magnetic building system... Question For All, I'm Sure Ken can answer as well
  191. Safely Removing Dried CA from Covering
  192. Alpha Models Mig I5 / E-flight 4200kv
  193. Retractset shipping to Holland?
  194. Fuel-proofing decals
  195. What Charger to use
  196. Why does my paint match?
  197. Building Videos
  198. Web Addresses
  199. Nortwest Model hobby Expo
  200. Am I making a Covering Blunder?
  201. glow fuel
  202. Propeller size for OS 61 FX
  203. Sky-lite wheels
  204. my os 10 fp blew up
  205. compensating weight
  206. magnum pro 45
  207. Manual Jr XP 7202 en castellano
  208. OS 160FX remote needle location question
  209. Hampton Grey's Corsair
  210. Battery age or number of cycles
  211. PIPER CUB (sig) 107INCH SPAN C OF G ??
  212. WWI aficionados & Builders
  213. Sig Four-star 3 draw plans for covering design
  214. Covering question
  215. Inverted glow help!!!!!!!!
  216. Air brush painting
  217. name of bipe
  218. How much time per week do you RC??????
  219. prop timming
  220. What is the source of your model engine fuel?
  221. Planes transportation
  222. Clubs in NC
  223. storing my planes outside
  224. Identify this plane win a KISS
  225. Hopper Tank Fueling
  226. Controls failed on Me
  227. increase battery Mah
  228. SR71 blackbird
  229. Good place to get a corsair pilot
  230. Hitec/Airtronics Z servos and Futaba receivers
  231. covering a tiger moth
  232. Made a OnBoard Lipo glow driver woot woot
  233. virtual reality remote control video goggles
  234. Ultracote TRUE RED discontinued??
  235. Picco Z vs. Havoc Heli
  236. Sig Somethin' Extra representation
  237. Airbrush - Badger 360-7
  238. Trigger Finger
  239. saito 120
  240. Servo not centering
  241. PUSHER engine - fuel flow problem w 2 tanks
  242. Carburator Ice
  243. Tiger 60 ARF motor mount........
  244. DA 50!?! anythign compare to it???
  245. painting helo plastic body
  246. Can you suggest a starting prop
  247. Retracts Hangar 9 Miss America
  248. gaps between control surfaces
  249. Positive and Neg Shift
  250. Hobbico Accu Cycle ??
