PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Cutting Aluminum spinners....best tool?
  2. AIR BLEED VRS IDLE SCREW ADJUSTMENTS
  3. Channels for separate Rudder and nose gear servos
  4. Toledo Expo
  5. OnBoard Glow 1.5v regulator for lipo setup
  6. Wall Charger Question...
  7. OS FS-70 Ultimate 4Stroke??????
  8. World Model
  9. Mode I or mode II
  10. Plans or kit
  11. Help with front 90 degree rotating retracts
  12. cylinder head question
  13. ONBOARD GLOW DRIVER HELP
  14. Landing gear wheels--How tight do you make them ?
  15. Tower Hobbies Glow Plugs
  16. JR transmitter, Futaba and GWS receiver
  17. reversing a servo
  18. Rustoleum Gloss Clear
  19. MVVS 26cc gasser - electronic ign voltage?
  20. u can do 46 firewall & scratch build
  21. Want to up-grade to LiPo with regulator
  22. Single or dual conversion?
  23. How Hard Is It 2 Recover ??
  24. Radio Frequency Interference
  25. Engine Test bench
  26. jr pcm transmitters
  27. Flight stabilizers
  28. Polycrylic vs epoxy for glass cloth finishing
  29. Brushless motor problems
  30. Dave Brown spinner vs. Tru turn
  31. SSE wing tube
  32. what type of covering?????
  33. Mufflers For Smoke Systems
  34. Best way to paint fiberglass fuse/foam wing
  35. great plane ultimate .40 what engine?
  36. Define Pico?
  37. After Market Servos
  38. fueling system
  39. Radio and reciever frequency question
  40. Tower 6XM Trainer
  41. OS -vs- Evolution: 91 / 100 Glow 2 Stroke
  42. Fuel Tank Dimensions for Lanier 300 Extra
  43. Nicads for 12V starter
  44. FW 190 A8 landing gear?
  45. Need a manual for my DPM Ultimate Bipe
  46. Fuselage and engine cowl
  47. Is Gorilla Glue fuelproof ?
  48. How much dihedral for low wing 3Ch. plane?
  49. Muffler/engine mount
  50. Trouble attaching letters on top of wing
  51. muffler question
  52. soldering steel control rods
  53. Banner pulling?
  54. workbench question
  55. Want to make a parachute drop.
  56. Super Custom 91 4 stroke
  57. Questions for general turbine experts
  58. Ring Cowl?
  59. Planes twisted?
  60. Man are you fat!
  61. Williams Brothers
  62. Torn Hinge
  63. Crow Mode
  64. Lipo's for receiver packs can it be done and how?
  65. hi where to fly on Irving Tx
  66. first time pilot buying engine- will it last long enough to warrant buying one with bearings?
  67. cap 232
  68. New TX
  69. Radio Conversion Mode 1 to Mode 2
  70. my tank on my hannable empteys it self
  71. What's the dif?
  72. Does anyone buy those cheap Ebay batts??
  73. 9 CAP vs 9 VAP
  74. Trainer Cord
  75. Retract Setup
  76. Electric motor help
  77. balancing
  78. RCM what's up?
  79. 4ch controller setup for 3Dplane?
  80. Servo maintenance
  81. Which Titebond do you use.
  82. Piper Cub - Explained
  83. nitro conversion mini edge 540?
  84. 40 Cloud Dancer Setup?
  85. Setting up the Incidence
  86. Hollow core door vs. Solid panel door for building table
  87. car verse airplane fuel
  88. How do i get JB weld to release?
  89. Webra TN in flight mixture control carb
  90. SHEETED FOAM FIX ? HELP
  91. HELP servos operated hi speed
  92. What is pin size for Klett hinges?
  93. Telesport 40 by Hobby-Lobby?
  94. jr reciver
  95. Dual vs Single Conv (nube)
  96. Heeellllppppp.....
  97. Skywriter or Slimline on non-programmable radio?
  98. New Futaba X-tals
  99. Glow Ignitor Servo Interferance
  100. Solar Lac
  101. Nexstar Mods
  102. Reversed Throws
  103. dual trottle servos
  104. Katana Mini + Saito 4 stroke ??
  105. Lite Foam
  106. D.I.Y. Plane Stand?
  107. ENYA MANUALS & PROPS
  108. O.S. .40 TT .46 engine mount
  109. OS.46 AX Zero nitro
  110. Saito .72
  111. Sponsor Apparel
  112. Best Model Shops Nr Weston,Florida
  113. Pump for the big boys, 40%
  114. Radio case foam
  115. epoxy old??
  116. O.S. 46 AX question
  117. Y and 2 bats.
  118. Is NiCD a dieing breed ??
  119. Tail wheels
  120. Servo driven smoke valve?
  121. Has anyone tried adapting a cordless drill into a starter?
  122. Sportsman Aviation Waco 30 -Electrification
  123. YS engine mounting
  124. Paper Towel Squirt Bottle
  125. Colour Schemes
  126. Shipping a 40 size
  127. What Sunglasses ?
  128. Crystal Capability????
  129. Magnum on par with OS/Saito?
  130. Airworld SU-26MX
  131. nitro planes quest50
  132. Question about RC Companies
  133. Which Plane is faster?
  134. Throw measurement on tapered control surfaces
  135. CAP 232 or Extra 330
  136. Saito 125 problem
  137. Strange repair materials used
  138. R/C Airplane Engine Type
  139. Engine size??
  140. OS 91 can it smoke?
  141. OS 46AX Prop Size
  142. Hitec Eclipse 7
  143. gaps in plastic cowl
  144. Kill Switches
  145. Las Vegas Q?
  146. question on selling my Byron STA / PT22
  147. TR260 plans needed
  148. Dual elevator halves uneven. Setup help needed.
  149. Horizon Hobby Service
  150. Pulse jet engines
  151. RV-4 Help
  152. Nylon or metal clevis - which is best?
  153. New York Hobby Shop
  154. Thin foam wings-how to spar?
  155. changing your CG?
  156. gas spark engine for kaos 90
  157. OS MAX 55 clean
  158. Stick to Flight Video
  159. Electric fuel pump for new flight box, which one?
  160. Whip antennas
  161. Dubro Tru-Spin Instructions needed
  162. Bates SB2C Helldiver
  163. jr matchmaker
  164. Gear Doors
  165. Futaba trans. airtronics reciever&servos
  166. How many hours?
  167. zenoah g23-26 INFO
  168. Selling your babies?
  169. Walkera WK1001
  170. Narrow Band
  171. Reciever antenna
  172. FOUR-STAR 40 CG
  173. small custom trailer
  174. diesel engines?
  175. Stinson Voyager 150
  176. Silver soldering
  177. Which is lighter, silkspan or monokote?
  178. kerosene in glow engine
  179. ENYA ENGINE PARTS::
  180. Painting SolarTex
  181. Midwest Aero Gloss
  182. ThrustHP calculator question
  183. Colored Smoke on your Airplane??
  184. HELP ME DECIDE WICH ENGINE WICH PLANE !
  185. discharge a battery?
  186. Hinges
  187. Has anybody built a Model Tech ARC Cessna
  188. Changing Engine Bearings
  189. Trimming Monocote Grrrr
  190. Pica 1/6th Mustang
  191. Aluminum spinner mod??
  192. Where can I buy this plane?
  193. Glassing a wing with access-to-servo hatche/covering plastic
  194. to much washout?
  195. Paint Ball Bomber Kit?
  196. Robart or Spring Air Retracts?
  197. Crow Mode
  198. battery question
  199. CA Question
  200. Barrel connectors- What's the current rating?
  201. RC flying in NY
  202. radio glitches
  203. Chart Tape ????
  204. Super Tigre 75 with a YS Carb
  205. Robart Mechanical Retracts
  206. Inst. Of Control Horns
  207. what is this
  208. HELPP Airplane 180size on my Car roof.. what is the Max speed???
  209. Robart incidence extension bar
  210. four stroke assembly
  211. What size servos?
  212. Reciever voltage?
  213. Epoxy question
  214. Air Lines
  215. Need Help With Engine Choice
  216. Monocoat
  217. price for a Flyline Models Megowcoupe kit??
  218. ailerons and flaps
  219. Beveling Control Hinge Lines
  220. Fuel tank position
  221. Engine mounting question
  222. Grrrr . . . pulling my hair out
  223. Expoy Painting in Australia
  224. Small Spinners?
  225. What size servo should I use?
  226. EZ connectors
  227. Perry Pump testing
  228. Is 16.8V for the starter safe?
  229. Waterproof RC Glove????
  230. Remote glo plug-how to make?
  231. GP Slot Machine - Parts?
  232. moki 2.1 please help find
  233. Can I Raise The Height Of Engine??
  234. Tapered Edges
  235. wing-bag recommendations
  236. After run oil in OS engine carb.
  237. How to break in a nitro motor?
  238. Prop Chart
  239. Outrunner Problems
  240. Futaba S136G Retract Servo Voltage
  241. Hi Folks!
  242. Funtana 90 CG
  243. mounting my G-26
  244. Pictures accompanying posts
  245. vinyl covering...add your idea here.
  246. horse power converter
  247. XUFO Battery issue
  248. Saito Carb
  249. mounting airsoft guns
  250. V- Tail direction ( HELP)
