PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Saito Carb
  2. mounting airsoft guns
  3. V- Tail direction ( HELP)
  4. AX 55 output ps vs. bhp
  5. Bombing Ideas
  6. Where did I go wrong?
  7. 2 battery setup on receiver ????
  8. RC in Seattle
  9. What causes radio glitches
  10. FS 70 vs saito 82 with <10% nito
  11. Futaba Transmitter
  12. receiver size, does size matter?
  13. Where to get a Canopy for a Cloud Dancer?
  14. Charging dual Batts off One charger
  15. What Spinner do I need??
  16. Katana-vs-Edge-vs-Extra-vs-Cap
  17. air in fuel lines
  18. Where i can find Kent Mckenna?
  19. Engine Down Thrust
  20. Question about Master Airscrew props
  21. GMS 1.20 Pitts muffler?
  22. Polyester Resin - Where to buy
  23. modelSPORT Video Magazine ?
  24. please recomend plane
  25. Century 7 twist knob control ugrade
  26. kyosho Pitts S 2C
  27. OS Four Stroke needle settings
  28. Help me identify these retracts!
  29. Pulling Banners?
  30. Inside cowl muffler
  31. The best plane for beginners?
  32. anyoe use traplett publications..
  33. New 6 channel radio
  34. Charging 6V battery with 4.8V Charger
  35. Affects of Relocating Fuel Tank?
  36. PLEASE HELP PLANE CLIMBS AT LOW SPEED AND DIVES AT FULL THROTTLE
  37. Masking off Dope
  38. fuel proof paint
  39. using two battery packs
  40. Paint Needed?? "HELP"
  41. yardstick?
  42. Looking for reliable/durable pull-pull hardware
  43. Storing Servo Extensions
  44. Wheel Problems
  45. tower is getting slow on shipping
  46. *1800 mAH Battery In Cold Storage*
  47. Futaba tx-Jr rec
  48. TOC 30% Yak 54 with Tune Pipe Setup?
  49. jr10 z
  50. Engine Help!!!!!!!!!!
  51. What is the actual definition of NEWBIE ?
  52. Midwest Extra 300 Questions
  53. RC magazines rant...
  54. I want to learn some stunts
  55. slimline shipping
  56. What size spinner?
  57. Where to install a fuel dot???
  58. Why is it so hard to make servo extensions?
  59. Mechanical Rotaing Retracts & Servo
  60. Best R/C Auction Sites
  61. GOOD PAINT
  62. keycreator 6
  63. taildragger conversion, removable stab
  64. clunk/ tank question
  65. Burp tank-what is it?
  66. Ultracoat Repair Question
  67. where can you buy a wire saw for cutting foam??
  68. Prop size for os 55 ax
  69. LongEZ balance with tank full?
  70. Glow Fuel Cleanup
  71. magic extra
  72. i have an os 91 fx 4 stroke to go into a spitfire
  73. RC CLUBS in PORT ST. LUCIE or WEST PALM BEACH AREA
  74. Hobby shops in Kalamazoo Michigan
  75. Excel or F1 Fueler for my Alpha 40 plane
  76. What to do with bateris for the winter
  77. OS .52 vs OS .61FX
  78. To de-fuel or not to de-fuel that is the question
  79. P-51 Mustang PTS RTF Engine
  80. Radio setup with dual elevator and aileron
  81. Interference at local club
  82. Perry Pump
  83. P 40 rotating retracts please help!!!
  84. Pattern, Sport, Or both?
  85. Hinges for GWS A-10
  86. I want to buy the new spektrum 7 radio. but i don´t find retailers in EUROPE
  87. Recovering
  88. will 12v 15A kill my power panel?
  89. OS FS70II Exhaust outlet tube need different
  90. What are the ingredients in glow fuel?
  91. Lowest nitro content
  92. prop for supertigre 45
  93. How to fix/patch holes?
  94. 3 blade propelor for my engine
  95. Shipping RC Aircraft? Who do you use?
  96. Engine Mount CHANGE
  97. 72 mhz to 36 mhz
  98. RCV90SP Anyone Anyone Buhler,.....
  99. Trike MLG position
  100. DH Lepoard Moth 85
  101. Angle Pro owners… input please
  102. R133JE receiver
  103. Fluttering Servo
  104. hinge slot cutter
  105. Monokote Ultrakote or whateverkote
  106. Towing a trailer with a Dodge Caravan
  107. MODEL MANIA
  108. Tower Hobbies Special $25 off -- missed it
  109. Maximum Nitro Content
  110. Kit plans
  111. Sending parts to Great Planes?
  112. getz stuck!!!
  113. use tygon fuel line with nitro?
  114. Just what is "Nitro"?
  115. Aluminum servo arms
  116. 1/4 scale Giles 202
  117. ilowest nitro content?
  118. Have you ever noticed.....
  119. Help Converting a Super Sportster Ep to Glow..
  120. Prop question
  121. os 91 Four Stroke Pump????? Need Help
  122. setup 2 elevator servos
  123. help starting a cold engine
  124. wash-in in a PT-40 wing
  125. OS 120 pumper parts
  126. Goldberg Ultimate
  127. Hinge points and excessive gap
  128. Have you had a Fun Fly at your club?
  129. WHERE TO FIND
  130. Pearl white monokote
  131. Great Planes Christian Eagle firewall pulling out?
  132. Dubro Servo Arms Super Strength Futaba issue
  133. V-22 Ospray-question?
  134. The Big Question
  135. skystar 40
  136. knife edge spin
  137. Covering
  138. GP RV-4 fiber glass parts?
  139. Controlling of Blue bird BMS660MG+HS RC Servomotor -Help PLZ...Urgent
  140. Pitts/saito 150 prop selection
  141. US release of phoenix yak 54
  142. JR R790 ScanSelect PCM Receiver
  143. Glow or gas?
  144. Can I repair a broken rx antenna by soldering it?
  145. What gear box
  146. crystal and reciever help?
  147. varathain
  148. engine mounts
  149. Radio /receiver question
  150. Deadsticks in turns only
  151. Is KRYLON/RUSTOLEM primer compatible with LUSTERCOTE?
  152. pilot figures
  153. tips for g.p big stik 40
  154. Ultra Stick 120 Lite Elevator Failure
  155. O.S. FF-320 Peguses Starter Information
  156. Ultra Sport with flaperons
  157. Muffler dilemma?
  158. AA Reciever batteries?
  159. charging batteries, need help!
  160. Latex paint
  161. JR SX600
  162. flight idea
  163. gp 1/3 pitts question
  164. Futaba 9C Super Airplane verson or Heli Version
  165. info on macs smoke system
  166. Low voltage cutoff
  167. To rich?, To lean?.Please help.46
  168. Ultra stick 60 powered with an OS 46 engine
  169. does automotive paint resist fuel?
  170. RC Plane Ring Tones
  171. what company made the stephens acro-bipe
  172. throttle setup with funtana x 50
  173. Inverted engine setup: question
  174. *Battery Cycler vs Wall charger*
  175. Battery Charger
  176. Aileron Setup Help Needed - Futaba 7CAP
  177. SuperTigre exhuast
  178. Need favor from someone with Kadet Senior ARF, need firewall picture.
  179. Magnum 52 four stroke
  180. NEW HANGER 9 P-51 1.50 80:"
  181. Spraying Dope
  182. Glue recomendation.
  183. ROTATING RETRACTS HELP!!!!!!!!!!!
  184. Auto glow construction article
  185. Using Epoxy Finishing Resin on balsa?
  186. Dubro Swivel Ball Link Question
  187. Radio talk
  188. Paint remover
  189. high torque servos
  190. Cleaining engines
  191. Stripped Screw Holes in ST G-90
  192. Wing Rigging / Flying Wire
  193. lost, rc aircraft info web site.
  194. weight verse performance and durability
  195. TACH READING HELP
  196. ASP 400 5 cyl. radial starting
  197. *Reversing "Y" Harness*
  198. RCV engines?
  199. Clear dope substitute?
  200. Dual tanks for a scratch built design
  201. Carburator is Stuck
  202. What is everyone building this winter?
  203. What song is this?
  204. OzCover and RhinoCover
  205. 60 Ultra Stick W/ OS 91 engine
  206. Tower Hobbies Codes, Comming UP?
  207. Throttle and steering control
  208. hitec 615 servoes
  209. Futaba 7CAP radio ch# 28 to ch#41
  210. G62 ignition question?
  211. Retiring a Plane
  212. space shuttle
  213. Why "Nitro"?
  214. multiple drill holes in a firewall
  215. Flat MonoKote
  216. Nitro methane replacement.
  217. Giant U Can Do 3d
  218. 9CAP super radio ?
  219. Cool Power Fuel
  220. Gaint Super Sportster
  221. Glow Plug fabrication
  222. the effects of the rudder
  223. Piper Cubs?
  224. Attaching pilot figures
  225. Horizontal stan aligment problem
  226. Having problems with Zap CA
  227. Cleveland Model Supply plans-anyone?
  228. carbon fiber landing gear
  229. Help! My workbench isn't level!?
  230. Wisely Selecting Wood
  231. Which Servo Should I Get
  232. *3 1/2" Plastic Spinners*
  233. canopy question
  234. Nicads & Winter Temps
  235. HVLP Paint Sprayer -Good Brand?
  236. Flying fields and hobby shops in Lafayette, LA?
  237. Which Glue?
  238. dealing with Singapore
  239. pushrod horns
  240. ARF Stickers
  241. Whip Antenna with receiver antenna
  242. Midwest Attacker
  243. Why no SIG online manuals?
  244. R/C Clip Art Website?
  245. HS-56 ball-bearing
  246. OS max 120 surpass w/pump problems.
  247. os. .46 fxi prop???
  248. question about 3 year old fuel
  249. water in reciever
  250. Hanging a plane from the cieling?
