PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Sportsman Aviation f20 fuslage
  2. Need help balancing Edge 540T!!! What do these symptoms indicate?
  3. Possible Gorilla Glue substitute?
  4. Ultracoat vs. Monocoat
  5. bp-12 problem
  6. Can't find a spinner to fit...
  7. Titebond III
  8. Tennessee bumpus mills
  9. Radio PCM or FM
  10. Jr match box
  11. Old field box?
  12. Hanger 9 Ultra Coat ?
  13. Question about a charger
  14. Floats on a Tigermoth
  15. 1/64th" chart tape-where?
  16. Does anyone recognise this bird and engine?
  17. Recievers- low band -high band
  18. Need product name and where to buy
  19. Striping airplanes!
  20. Where can I get one???
  21. futaba/hitec
  22. microballoons filler cure times
  23. need help with g-3 flight sim
  24. 52cc conversion engine and biplane
  25. CA Glue on finger
  26. decoupling surfaces - mixing, or what?
  27. what brushless motor to use?
  28. EVER USED TOWERCOAT???
  29. receiver servo limitations
  30. Which engine to use for the Hangar9 Showtime 4-D 90
  31. cg of WM rambler
  32. Battery charge
  33. On-board Glow System
  34. Protech IBIS 120
  35. Epoxy & CA Shelf Life
  36. Metal to metal interference
  37. Great Planes Servo Arms
  38. HELP! Engine Mounting Problem!
  39. Accu-cycle elite...incomplete?
  40. sig kadet senior throws?
  41. spitfire and irvine
  42. enjoyhobbies.net anyone heard of them?
  43. Fiber Glass 101
  44. CA Hinges or Robart Hinge Points
  45. What paint can I use under UltraCote paint
  46. Covering
  47. What engine is this?
  48. hinges for cermark sukhio 31
  49. JR pcm 9XII
  50. Flexible Exhaust building material?
  51. Electric retracts , what are they worth ?
  52. Engine Mounts, Saito 100
  53. What is this?
  54. Ultimate 40S Flight Question, First Time Flyer
  55. an anyone tell me where I can obtain feex. exhaust pipe either 1 1/4 or 1flex pipe
  56. Question on Fiberglassing
  57. RX PROBLEM
  58. Robart Retracts - How do you get them to operate smooth????
  59. RIGHT PLANE
  60. Gooey CA + CA hinges
  61. Can someone ID this plane?
  62. Motor stand offs for EVO 58
  63. Receiver tunning
  64. snow skis
  65. Zombie RC Pilot Figures
  66. Smoke System, i need help..
  67. Valve adjustments on 4 stroke motors
  68. Cleaning up old engines
  69. RC Report
  70. TowerPro servo compatibility???
  71. sheeting foam wing ?
  72. Os fp engines
  73. prop question
  74. Nitro models planes
  75. Any flyers in the Portland, Oregon area?
  76. Carbs from Perry Pump
  77. RF Interference
  78. prop
  79. warped foam wing park flyer
  80. KlassKote Users
  81. Right/down thrust-what effects?
  82. OS BX-1 Carb
  83. OS .46 LA carb question
  84. Need Help Sealing Shrink Film
  85. Just for fun, anyone actually log your time?
  86. Dead stick landing, pros and cons
  87. need info on wood glue
  88. thrust
  89. wing fillets, how to?
  90. The best power panel made ?
  91. Nitro fuel Question
  92. N/Models Ultimate 40s Question.
  93. Flame out problems with OS 1.08 engine
  94. sealing decals
  95. Shipping Models To The UK
  96. How do you balance your model?
  97. Crushing control horn mount
  98. Wing loading on Extra300s
  99. Mystery covering?
  100. F-117 Stealth,Balance point?
  101. Prop. Pitches
  102. Wich prop is the best?
  103. Suggested Engine Size for Bi-plane
  104. Gas and Oil...?
  105. Wondering about a couple of old plane engines...
  106. Removing good bearing from motor case
  107. unidentfied airplane (cap?)
  108. Hanger 9 DVT
  109. OS 160FX
  110. 1st time builder
  111. Dynathrust props
  112. need help on prop for up-roar 40
  113. Charging batteries from a field box
  114. Voltwatch problems..
  115. aileron servo idea
  116. 4.8v vs. 6v receiver batteries
  117. airtronics, are they in a coma?
  118. Bi-plane aileron set-up with 4 servos? brain teaser.
  119. nitro fuels
  120. Ready 2 From ARC
  121. Super Sportster 90-120
  122. o.s. 120AX "Break in prop"
  123. Hinge Slotters
  124. the shakes
  125. G3 Simulator Patch Cord
  126. Glass engine mounts-what fasteners?
  127. Which Clearcoat over Water-slide Decals ?
  128. Hobbi-Star 60 into a tail dragger
  129. R/C industry data
  130. Odd size props
  131. Spraying Clear Coat
  132. ULTRAKOTE over MONOKOTE??
  133. exhaust extension ?
  134. Taking old fabric
  135. Thinner for Butyrate dope and paint
  136. two stroke or four stroke power?
  137. Great Planes Master Caddy
  138. Covering hinge lines?
  139. RC CHAT
  140. Dope and Silk Covering questions
  141. Is NitroModels.com good
  142. channel no.
  143. Airfields in So Cal?
  144. Foam Wing cutting
  145. Using Trim Tape on Latex
  146. Gee Bee Jimbo
  147. Set Screw or Clamp on CJ retracts?
  148. Rudder or Ailerons
  149. LADO Gear?
  150. Engine shoping
  151. Checkerboard covering?
  152. AM Radios
  153. putting a 2 bladed prop on my alpha 60
  154. fma direct co-pilot?
  155. Receiver battery toggle?
  156. NiCd peak charger as foam cutter power supply
  157. B&D Retracts
  158. Hitec HS5745 Digital Servo
  159. Futaba R-138- DP PCM recievers
  160. 21st Century Fabric Covering
  161. New to Electrics
  162. Silkspan experience ?
  163. servo connectin keepers
  164. Covering a fuel soaked plane
  165. Aileron setup for Dazzler/uproar types
  166. 8.8lb plane with a .61, how will it fly?
  167. wing dihedral
  168. Accus
  169. Gas vs Nitro 4s & 2s engine equivelents ?
  170. Canopy Glue?
  171. mousse can muffler question
  172. Looking for Pusher Props
  173. Testing wrecked servos
  174. ARF or Kit?
  175. Spinner bushings
  176. Pitts stab incidence?
  177. Lost art of glassing a warbird
  178. Nose gear brake
  179. mildew problem
  180. Magister Parts needed
  181. Question about flaps and flaperons
  182. GWS CargoTrans C-130 Hercules Blue Angels Fat Albert Decals
  183. Yellow aircraft F-4
  184. Folded up clunk
  185. 4 stroke motor mount question
  186. screensavers&wallpaper
  187. Iron Bay Model Company
  188. Painting Alumiumn Landing gear
  189. Looking for a new electric starter
  190. Hog Bipe maiden flight
  191. Painting Field Box
  192. Fixing Broken Engine Mounts
  193. os 160 fuel problem
  194. Age old question.... about PAINT
  195. Joe Nall
  196. HELP! How to keep trim down!!
  197. Trainer cords question
  198. Do Dave Brown Foam Wheels Ever Puff Up Again?
  199. Winterizing plane question
  200. Tricycle Air Retract Set up
  201. Ultracote Source?
  202. Lazy Ace Wing weight?
  203. phoenix decathlon reciever pack questions
  204. need help posting pics
  205. Help a fellow modeler keep his wife from killing him!
  206. How to Post a Video?
  207. covering over foam
  208. pitts muffler changing performance
  209. Fuel - Are you worried about Cancer?
  210. 12x1.0mm threaded tube/pipe
  211. NY hobby stores??
  212. HOPPER TANKS
  213. Prop pitch advice...
  214. Radio Trouble
  215. cleaning monocote/Ultra cote
  216. ?Funtana X 100 Questions???
  217. Storing Batterys for the winter
  218. brushless motor run in
  219. Where can I get these virtual reality goggles?
  220. epoxy or gorilla glue
  221. Engine mounting
  222. OV-10 RETRACTS
  223. Latex Coverage
  224. Club Fun Fly Recommendations
  225. Evolution 26gt2 in a Skyshark Edge 540
  226. Zap CA 3/4 full?
  227. Ready to cover with silk, but I need advice on this!
  228. Will Ultracote adhere to a painted fiberglass cowl ?
  229. Solartex Users - Question
  230. Glasses
  231. strong retracts question
  232. small rc planes
  233. Flying on Grass
  234. lipo receiver packs
  235. Which battery cycler??
  236. Attaching cabanes and N-struts
  237. How to straighten a glass fuselage
  238. Trim tape unsticking
  239. CMP Product Reviews
  240. retract nose gear-help?
  241. balloons for my battery and receiver
  242. Wing Ribs Sandwich Method
  243. Storing engines, avoiding the dreaded gummed up.
  244. How is the performance of the LXK422 Global Tequila Sunrise 25 ARF .25-.28,36"
  245. PROP SIZES FOR ENGINES
  246. Phoenix Models Super Decathlon ARF .46 - Instruction Manual
  247. Flying time!!!
  248. Is it ok to double up RX Nicads?
  249. Sealing Monokote edges
  250. Best material for masking curves
