View Full Version : Questions and Answers
- Mounting Engine
- u can do .60-90 engine
- r/c carrier landing anyone???
- ARTF Engine Mount changing
- moki 1.80 parts
- Convert gas Trainer 40 to electric
- paper graphics???
- Bonanza V tail kit?
- New Hobbyist
- 4 stroke suggestion need help
- Monokote Technique
- OS 7D Carburetor Instructions
- spoke wire wheels?
- wing incidence problem
- Twist 3D .40 Electric Value?
- TEO Rodrigues are you still building
- Duel servos on a surface
- Using one receiver for all my plane
- WHO SELLS KYOSHO
- Looking for PA-18 1/3 scale kit or arf
- Finding CG on my YAK 54???
- Royal Skymaster
- ??super tiger.40 and 6oz. of fuel??
- Clear coat question
- What your favoirite R/C magazines?
- Adapter Needed for GP Aluminum Spinner for Saito 100
- O.S. 20 4cycle engine prop?
- Paint Match for Ultracote Pearls
- Nosecone Flew Today - Plane Didn't
- Solartex Question
- Servo changing.
- What is the CG. on a Giles G-202???
- Wing Retention Contraption???
- Whats the C.G. on TBF-TBM Avenger???
- removing adhesive left from old trim
- T connectors?
- NITRO MODELS LANCAIR 360 ARF
- Engine question
- Covering Questions
- VMAR F 4 PHAMTOM
- Robart Hinge
- recording merlin engine sounds
- Su -27 Flanker
- level flight problem
- Cheap Building Board
- Hobbico Sturdy Birdy II
- Futaba owns OS Engines
- Engine Repair
- Alternatives for discontinued Lustrekote colors
- Warping Wood
- BDU Professional High Speed SG5010 servo
- Wind
- Silkspan question
- Goldberg Bucker Jungman Kit
- Inverted Evolution .46
- Where can I fing 3mm tubing fittings?
- Carbon Fiber cloth instead of fiberglass cloth
- how do CA hinges work
- MosquitoBite Planes ROBIN
- APC ships L & R props
- Blue Angels Covering Scheme
- Cutting foam rubber?
- $$$s, build from kit or plans?
- This is impossible Help covering fairings
- Kavan fuel tanks
- Ultracote differences
- pilot figures
- fuel proofing
- CMP AT-6
- What is this plane?!
- Spinners for 4 Strokers
- Epoxy + Paint = What?
- CEramic Bearings
- MOUSSE CAN MUFFLER - tips or links
- inverted engine os 46ax
- H9 Mustang P51 .60
- wing and engine incidence
- irvine 53 settings
- Can I do this?
- favorite glues?
- Self Tapping Screws and #4 Screws Question
- Robart air retract actuator?
- legality of after market replacement parts
- lathe,drill,mill
- Funtana S90 ARF Question(s)
- servos for the Show time 4-D 90
- RC Pilot Options
- remote glow plug on Saito 150?
- Ultracote vs. Oracover
- Holding down edges
- Mounting Saito 100
- Halls Bulldog Racer
- pink foam ribs and koverall
- futaba indirect drive servos
- Please Identify
- Replacement parts
- Crate Shipping
- Which gas burner
- Hardened Allen Wrenches and Screwdrivers
- DX7 or DX6?
- Sportsman Aviation f20 fuslage
- Need help balancing Edge 540T!!! What do these symptoms indicate?
- Possible Gorilla Glue substitute?
- Ultracoat vs. Monocoat
- bp-12 problem
- Can't find a spinner to fit...
- Titebond III
- Tennessee bumpus mills
- Radio PCM or FM
- Jr match box
- Old field box?
- Hanger 9 Ultra Coat ?
- Question about a charger
- Floats on a Tigermoth
- 1/64th" chart tape-where?
- Does anyone recognise this bird and engine?
- Recievers- low band -high band
- Need product name and where to buy
- Striping airplanes!
- Where can I get one???
- futaba/hitec
- microballoons filler cure times
- need help with g-3 flight sim
- 52cc conversion engine and biplane
- CA Glue on finger
- decoupling surfaces - mixing, or what?
- what brushless motor to use?
- EVER USED TOWERCOAT???
- receiver servo limitations
- Which engine to use for the Hangar9 Showtime 4-D 90
- cg of WM rambler
- Battery charge
- On-board Glow System
- Protech IBIS 120
- Epoxy & CA Shelf Life
- Metal to metal interference
- Great Planes Servo Arms
- HELP! Engine Mounting Problem!
- Accu-cycle elite...incomplete?
- sig kadet senior throws?
- spitfire and irvine
- enjoyhobbies.net anyone heard of them?
- Fiber Glass 101
- CA Hinges or Robart Hinge Points
- What paint can I use under UltraCote paint
- Covering
- What engine is this?
- hinges for cermark sukhio 31
- JR pcm 9XII
- Flexible Exhaust building material?
- Electric retracts , what are they worth ?
- Engine Mounts, Saito 100
- What is this?
- Ultimate 40S Flight Question, First Time Flyer
- an anyone tell me where I can obtain feex. exhaust pipe either 1 1/4 or 1flex pipe
- Question on Fiberglassing
- RX PROBLEM
- Robart Retracts - How do you get them to operate smooth????
- RIGHT PLANE
- Gooey CA + CA hinges
- Can someone ID this plane?
- Motor stand offs for EVO 58
- Receiver tunning
- snow skis
- Zombie RC Pilot Figures
- Smoke System, i need help..
- Valve adjustments on 4 stroke motors
- Cleaning up old engines
- RC Report
- TowerPro servo compatibility???
- sheeting foam wing ?
- Os fp engines
- prop question
- Nitro models planes
- Any flyers in the Portland, Oregon area?
- Carbs from Perry Pump
- RF Interference
- prop
- warped foam wing park flyer
- KlassKote Users
- Right/down thrust-what effects?
- OS BX-1 Carb
- OS .46 LA carb question
- Need Help Sealing Shrink Film
- Just for fun, anyone actually log your time?
- Dead stick landing, pros and cons
- need info on wood glue
- thrust
- wing fillets, how to?
- The best power panel made ?
- Nitro fuel Question
- N/Models Ultimate 40s Question.
- Flame out problems with OS 1.08 engine
- sealing decals
- Shipping Models To The UK
- How do you balance your model?
- Crushing control horn mount
- Wing loading on Extra300s
- Mystery covering?
- F-117 Stealth,Balance point?
- Prop. Pitches
- Wich prop is the best?
- Suggested Engine Size for Bi-plane
- Gas and Oil...?
- Wondering about a couple of old plane engines...
- Removing good bearing from motor case
- unidentfied airplane (cap?)
- Hanger 9 DVT
- OS 160FX
- 1st time builder
- Dynathrust props
- need help on prop for up-roar 40
- Charging batteries from a field box
- Voltwatch problems..
- aileron servo idea
- 4.8v vs. 6v receiver batteries
- airtronics, are they in a coma?
- Bi-plane aileron set-up with 4 servos? brain teaser.
- nitro fuels
- Ready 2 From ARC
- Super Sportster 90-120
- o.s. 120AX "Break in prop"
- Hinge Slotters
- the shakes
- G3 Simulator Patch Cord
- Glass engine mounts-what fasteners?
- Which Clearcoat over Water-slide Decals ?
- Hobbi-Star 60 into a tail dragger
- R/C industry data
- Odd size props
- Spraying Clear Coat
- ULTRAKOTE over MONOKOTE??
- exhaust extension ?
- Taking old fabric
- Thinner for Butyrate dope and paint
- two stroke or four stroke power?
- Great Planes Master Caddy
- Covering hinge lines?
- RC CHAT
- Dope and Silk Covering questions
- Is NitroModels.com good
- channel no.
- Airfields in So Cal?
- Foam Wing cutting
- Using Trim Tape on Latex
- Gee Bee Jimbo
- Set Screw or Clamp on CJ retracts?
- Rudder or Ailerons
- LADO Gear?
- Engine shoping
