PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. repair of durbro tires???????????????????????????????????
  2. Covering Match for Fun Tiger G-200
  3. Electric H9 Fueler/Defueler Signal Interference
  4. OS 120 Surpass II with Pump or YS115FZ for my Twist 150?
  5. Oracover paints and sources
  6. Can you take LIFE batteries on airplanes
  7. OS 91 FS backfired/kicked on start- now ill not restart
  8. Help identify please?
  9. DLE 55 Engine Issue - Help please
  10. mono-coat
  11. need TBF avenger plans???
  12. Aileron flap mix using 4 servos per wing?
  13. rx battery extensions
  14. best battery brand?
  15. WBPU vs Polycrylic
  16. Ace Bingo .60 Manual
  17. DLE 20 RA in a U-Can-Do 3D
  18. rx battery pack
  19. Tremor ST trouble
  20. DIY camera follow focus from RC system question
  21. Help with ice man gyro
  22. Nord 2501 Noratlas
  23. No one is taling about the Hangar 9 Valiant?
  24. Rotary tools
  25. Looking for a spinner
  26. Miracle switch issues
  27. PowerBox Royale SRS - sequencer alternative uses?
  28. Futaba 6014HS receiver on unregulated 2 cell 7.4 lipo direct?
  29. Recovering a plane and need help with hinges
  30. easy sport 40 plans
  31. TT Pro motors?
  32. When you Balance a model with retracts do you Balance with them up or down?
  33. Bryon P-51
  34. os 5 cyl. ?
  35. PTE gas engine
  36. Can anyone ID this engine? No Markings on it
  37. Igyro 3e........where to buy one
  38. anyone kitting a cap 10B
  39. 3 vs 2 blade props
  40. Easy Tiger Models
  41. Easy Tiger Models
  42. Hobby 88
  43. Name this Corsair
  44. removing plugs from specktrum dual receiver
  45. identifying Brisson engines
  46. 2.4 oz Servo Load in Neutral Position FLAPS
  47. Which gas engine?
  48. What type of aluminum?
  49. Engine cleaner
  50. futaba extension
  51. Ailerons... Y cable or two channels????
  52. painting over solartex
  53. Pull-pull setup
  54. rebuilding 1/4 cub...need parts
  55. Cannot contact Flyingthingz company, help !!!
  56. Retracts
  57. Returning to RC after 25 years- Radio Question
  58. Resin
  59. Throttle Hold / Throttle Cut
  60. Could my motor be defective or did I kill it somehow?
  61. 90 Twin on Sig 1/5th Cub
  62. Spektrum AR 6210 placement
  63. prop size
  64. How to enlarge hole with drill press ?
  65. Balsa plane replacement blades
  66. elevons
  67. brotherhood rant
  68. using deflection on ailerons
  69. Is Spektrum coming out with a 10 or 12 channel radio ?
  70. JR 7202 mode 1 transmitter
  71. Fasst and fhss
  72. Gp slow poke 40 arf
  73. too much weight and power for a plane?
  74. Airtronics rx 92824 installing new antenna
  75. How to lengthen aileron
  76. motor power insufficient
  77. Flywheel machining
  78. Crusader 2 build
  79. Control Horn screws
  80. Nitro September Fury
  81. DX7tx?
  82. SAFE Technology Question
  83. 20 year old engine issue
  84. need some help finding the colours for this plane
  85. high speed needle prob
  86. Stupid things we have done
  87. Company selling RCM plans
  88. Nose retract
  89. Sig Four Star 60 - engine upgrade
  90. Os fx 160
  91. topflight texan
  92. Motor mount with Aluminum standoffs
  93. CG Location
  94. Carbon tube 5/11" - where in US
  95. How many CA hinges to use ?
  96. Sig Rascal
  97. Spektrum DX6 transmitter
  98. No fitting on JTEC Incowl Inverted muffler for OS 46AX?
  99. need help big time.........1/5 or 1/4 scale cub?
  100. Flap Servos
  101. radio interferance
  102. Drilling servos holes in deep and hard to reach places
  103. Seagull AT6 46 size
  104. Futaba 9CA anyone
  105. "Airkill" products plans needed Bearcat F8F
  106. Different ways to start a glow engine
  107. Looking for a good switch mount
  108. battery cycling a tx
  109. Hand turn drill
  110. Pathching Pin Holes in Cowls
  111. Air bubbles in Epoxy
  112. covering question
  113. How best to copy a canopy or windows
  114. cycling batteries
  115. futaba 3010 servo
  116. Paint in mold question
  117. magum xl fs52ar engine
  118. nav lights for 1/4 scale ?????????????????????????????????
  119. On board glow
  120. Ball bearings for OS FS .26 ????
  121. anyone flying in or near Southport or Shallote, North Carolina
  122. looking for wing struts
  123. De-Ice
  124. Remove CA Glue?
  125. smoke tanks
  126. Differences between Servos
  127. plane purposing badly at higher speeds
  128. Solartex covering
  129. First kit, rookie question - custom made tail?
  130. A question
  131. Why no motor forums ?
  132. Parkszone Sukhoi 29MM Problems?
  133. control throws
  134. have questions about using titebond
  135. URL not high lighted
  136. Idel ajustment
  137. scared to fly the real planes
  138. Stits Lite fabric covering, Pros and Cons
  139. dx8 transmitter switch select setup
  140. Piper Cub, Who made this kit? Photo included
  141. Servoless electric retracts questions
  142. Carbon fiber wing tubes
  143. Rudder servo orientation for 52 inch OV-10
  144. Recommendations for a 'disposable' RTF?
  145. Help / DX7eu pros binding to spektrum AR636 reciver
  146. Evolution 15cc
  147. Futaba duel revivers and telemetry
  148. Undelivered/Returned email for offers and questions to other members
  149. What's up with my cub????
  150. Mode 1 and mode 2 hook together using trainer cord.
  151. iron on fabric"whats a good choice please.
  152. I need a canopy !!
  153. Hitec servos
  154. Inverted OS Engine Flooding
  155. Main Aluminum Landing Gear Reinforcement Fittings
  156. electronic ignition
  157. what realflight 7 add on has the topflite fw-190
  158. Help needed with programming Eurgle TX
  159. aileron problem
  160. aileron problems
  161. New to retracts, need help with parts definition
  162. Balsarite for film
  163. Voltage on LED light
  164. Film Covering ?
  165. Trouble tickets
  166. Does anyone know who makes a on board starter for 35cc gas engines?
  167. nitro models yak
  168. Tail wheel for push rod steering?
  169. MPI Lighting module?
  170. Converting a sig wonder from glow to electric
  171. Building a PT20, should I reduce the amount of dihedral?
  172. New Zealand
  173. Does the balance point on a tapered wing stay the same from the leading edge ?
  174. Getting back into RC after three year hiatus. Need help with a Futaba 10J set up.
  175. Soliciting Tips For Vintage Restoration Methods
  176. Low cost gas can
  177. Identification
  178. Cessna 120
  179. OS120 Destryed... ***?!?!
  180. Sig acft
  181. Receiver for JR x-347 w/Graupner JR T-35
  182. Help!! Is this HUB the right size for a 5" tyre??
  183. Spektrum 6 i radio programming
  184. Dubro/hobbico,quik fill crank gas pump
  185. Has anyone else ever put an ARF together called a " Fascination-50" ???
  186. Kraft(RJL) engine problem
  187. Robart 619 DC-3 retracts
  188. Paint Test Panels. (Gas)
  189. Low temp Iron on Fabric
  190. Recover or Patch Wing
  191. Flight box
  192. Wing tubes and sockets
  193. Single axis gyro for rudder
  194. Super Chipmunk
  195. OS .91 FX engine lacks compression
  196. Grass Runway
  197. Prooper prop
  198. Anyone else have a problem with TexasRCPlanes?
  199. need help from you guys finding a manual for a Altech tamcat
  200. OS FS-91 - Carb Set Up
  201. GP Lancair flight characteristics
  202. Ziroli 70" P-47 Build
  203. os pump problem
  204. Charging life batteries
  205. Builders
  206. Flight box
  207. Sig covering
  208. G 62 Carb settings and mag setting
  209. Dragon Lady 60
  210. buying new radio
  211. Ailreons
  212. swap meet
  213. Need hel on my KT 100G jet turbine
  214. Receiver battery redundancy installation question
  215. weird spektrum receiver problem
  216. Making my own servo "Y" cables
  217. Phoenix Tiger 3 or Phoenix Scanner
  218. is there anyone that can help me????
  219. Sullivan smoke pump tube????
  220. Mixing servos
  221. Glow fuel Tubing and Pump OK with Aviation Fuel?
  222. DX6 vs DX6i
  223. oil mix for gas engine
  224. DA 50 engine parts
  225. information on selling all R/C.
  226. Dick Sarpolus Thermix "13
  227. Spectrum receivers
  228. Dual ailerons and duel elevators
  229. receiver or battery switch wires
  230. dle 20 voltage
  231. How Low of an Idle?
  232. POLL: Anyone Using Futaba S-Bus?
  233. Problems during running in a West Eurotec 52T1 ABN (Made by Webra)
  234. Eneloop charging
  235. alter-mini???
  236. Strange problem with oscillating wing servo
  237. CMP PA-28 Cherokee
  238. where can i find replacement battery packs for my jr sx600
  239. Spektrum DX6 -Travel Adjust question
  240. Super Tiger G 20 engine
  241. Silly guy with a silly idea need clever help
  242. Servos have gone in reverse of their original settings since last flight
  243. Spektrum GPS sensor question
  244. Tactic compatible rx
  245. Do you ever change from a used airplane from one pushrod system to another?
  246. Several questions glow plugs?
  247. Glow Fuel Proof paint/coating
  248. engine thrust line
  249. Plans for B&M Models 84 inch span Miss America
  250. Applying Decals
