View Full Version : Questions and Answers
- running in old engine
- Dead servos
- Wing joint fiberglass, what grade?
- Desperado 3000 plans
- techometer
- Space Walker CG
- Airplanes to go with the OS FS 120?
- Anyone ever hear of a Pica Touche' ?
- CA debonder question
- Which magazine?
- balancing plastic spinners
- Do manufactures need to make a hotter looking trainer
- Parts for mds .40
- landing gear: aluminum or carbon fiber?
- choosing a plane
- two servos per aileron
- how do i adjust servo
- Saito 170 - Which Onboard Glow? Cline?
- Washout question
- Snapped both a bipe's wings in two...how to fix properly?
- retracts in a hangar9 p51 pts?
- Flying crutches
- R/C airplane tee shirts
- Where to drill holes for Macs smoke system
- RCC?
- Futaba T12Z and ultimate kit issues
- Pilot Bust Suggestions?
- Small table saws
- is it rich or lean?
- Masking Tape Blues
- Name that carb?
- Great Planes Ultimate l struts
- Adrenaline 120 with a bent firewall?
- prop pitch
- Preventing trim line tape from unsticking
- Forum thread search?
- best way to ship planes
- Tail brace wire installation question
- Goldberg Anniversary J-3 CG
- What Plane ?
- best sites to RC plane footage
- Loose cowling
- Inverted trim\balance
- HS-55 servo arms
- 12x4 on a TT .46 Pro?
- K B 40 strapon muffler
- What's the difference??? Edge, Extra, Yak?
- Hobbico 90 Starter question
- signal lost.
- Kyosho BF109 Help
- A question of weight....again
- EPA for electrics?
- New sky bolt w/ gms 76
- General "glassing" question
- General building Q, how to fill a low spot
- What size drill bit??
- Rudder control horn alignment
- Night time plane pictures
- member videos
- prop balancing
- King air 350
- TOC1 30% Yak 54
- Where to store R.C planes?
- DUAL BATTERIES
- Covering removal
- Building twist 40 kit - messed up. Will this pose a prob?
- parachute
- Two questions.
- Choosing sunglasses?
- Gas engine
- Control Horns
- Looking for air imput valve nut
- Gorilla Glue
- Retract speed
- bubble wrap for vibration insulation
- Buying from Canada?
- Using Shear Bolts for Landing Gear
- OS .20 Woes
- Interesting Engine Observation
- Saito 120 Starting Problems
- Towing Guidelines
- Sig Koverall
- Servo Failure
- Slimline pipe, runs lean?
- inverted glow engine
- New to the forum, got a Cox question
- Help with Tru-Turn Spinner
- Servo Reverser?
- Field box battery
- What do people mean by making a CG point on your plane?
- Questions about the Great Planes Cap 232?
- 4-40 Rods on Standard Servos?
- Have you ever get bored in RC?
- PCM or FM Radio????
- tiers,, rubber vs foam
- Harmon Rocket 46 Arf
- Difficulty Tuning an Evolution Engine
- futaba 9caps conversion
- Prop for OS 61
- Slimline Pressure Fitting
- Futaba 6EXAS & Receivers
- control rod installation
- Engine problems
- Stick on weights.... how to make them STAY?
- Fuel Tank Help
- EVO Engine Not Shutting Down
- mds .61 what size prop?
- Is this enough engine cooling?
- Prop For a Gold Edition P-47
- help identify these carbs
- stick mount ?
- Spoileron? with futaba 6EXA
- pitts muffler
- Dynathrust props-still made?
- prop adaptors
- the best
- making struts for .40 citabria
- Kadet Senior Ailerons
- Can I use Li-Po cell phone batteries
- Up thrust instead of down thrust???
- Effect of magnets on airplane electronics
- Phoenix extra 330 wat engine...?
- engine choice for a 15-4W prop
- quick questions on my mag 52
- engine is extremly hot
- A very basic question
- 3W Ignition RPM OUTPUT
- Saito 220 Bent Crank by 0.030 inches
- Futaba radio repair
- Futaba 9cap just the radio please
- Sig Epoxolite
- Converting from tricycle gear to taildragger ??'s
- Hobbypoxy Stuff
- Elevator Mixing
- Switch Failures or ???
- How to quiet a Saito 1.80?
- Changing Receiver Frequency
- FACTORY SAITO 100 needle setting
- Anyone know where to find a good 48" straight edge?
- Tapered wing CG
- FEEDBACK ON SIG AEROKOTE COVERING
- Is an "Elder" an actual WW1 Airplane ?
- how to get the specifies cg
- Advice required - Cutting openings in Glass Fibre cowling
- Discharging Battery
- Short shaft, thick prop/spinner?
- PCM RX
- Engine Question
- What's that smell?
- extra 300s
- Lateral Balance Goldberg ultimate
- When's a 4 stroke worn out?
- Help breaking in Super Tigre ABC .45
- What's the effect of propeller pitch?
- 1/48th AeroMaster 48-033 "Thunderbolts Galore"
- How close can I mount an engine to the firewall without heat effects?
- S2 Models 1/3 scale Decathlon
- How to keep Ultracote corners and seams from peeling???
- CG on two planes ??
- Runway surface?
- Debonding CA Hinges
- du-bro glow fuel pumps keep seizing
- Multiplex LN-5014
- 7cap problems
- P-51 Inverted Engine Problem
- Can you identify this plane?
- Hardware Selection Question.
- What makes a good NECK STRAP?
- Flight logging
- nitro to electric conversion on cap232?
- crystal question
- 9ZAP synthesized module with non Futaba PPM receivers
- "Pinking" tape--what is it, how do you use?
- RCModeler September 1992.. Anyone have it?
- How to build a plastic pipe shelf??
- catching a .40 sized trainer
- Convert a ys 80 heli to airplane?
- Help needed 3d prop for 46 AX
- How many air tanks?
- Anyone ever use two fuel tanks for one engine?
- Phone Number For CURTEK
- Futaba R129DP receiver question
- Airplane Mounted Camera?
- AIRPLANE KIT OR PLANS
- Paining Iron on Fabric
- Swampy Ugly Stick
- Putting Battery in Back Of Plane
- O.S. Max SF .61 Engine Questions
- Flying Field in ORILLIA/RAMA area?
- What prop for a slow flying Telemaster?
- Fiberglass Lycoming cowl for CG Chipmunk
- HANDIBOND CA's
- ArF . . . Modifications (?)
- Smoking glow fuel?
- KMP retract question/ problems
- alfa F-86 Saber
- sig something extra question?
- .15 Fp 3d profile plan
- Glue for sheeting foam wings?
- Futaba RX/JR servos???
- Would like to move into fuel powered planes
- Plans for Break in Bench?
- looking for a stearman kit
- Design Covering Idea
- 9CAPS output
- Inverted Engine need help
- How to build a Canopy
- alerion flutter 27% 260
- need info on os fs 61 4 stroke
- OS 91 FX rear bearing
- Piper Cub 1/4 Scale Wing Strut Failures
- Fuel tank question
- Counter Rotating
- Need help Setting up the B & B smoke system.
- Using a DX6 on a typhoon 3d?
- Battery back up !!!!
- Mounting a brushless motor?
- priming fuel lines
- Linear actuator servo?
- Plane yaws to the left - thrust angle off?
- speed controller problems
- Anyone on RCU flying in Meridian, MS., or near Starkville, MS.?
- Engine / Radio swapping ??
- Flaps and retracts but only 5 channels?
- OS MAX .46 AX
- muffler needed for a Super Tartan 22cc
- Kalt Engine
- AN-2
- Super Cub Cowl?
- Need help with a 4 aileron set-up
- Where do I have plans copied?
- manifold length
- Charlotte NC Flyin field ?
- Sometimes can't post problem fix
- What happened to Rccanada?
- easy flyer
- Painting a swirl / spiral on a spinner ?
- Where to get Squeeze ball fuel pump for gas
- Lanier contact
- Starting Zenoah G-38
- What is a "Shear Web-for a GS wing?
- Ailerons on a Senior Kadet
- Flaps-switch or dial?
- HELP! -- .074 Norvel Engine Mount? Micro RX
- Info on a .25 BRAT engine?
- Lipoly Batteries
- Makeing a scale Bristol F2B exhaust
- Reversing a servo
- Tow-in and taildraggers?
- Need some Decal Help with flames please
