PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Problems connecting elevator control.
  2. NiCd Battery Charger For NiMh
  3. Walbro carb needle settings
  4. counter rotating engine ?
  5. Prop Hubs
  6. Pitch down, engine dies....GRR!!!
  7. Questions about Futuba 14mz vs 12mz
  8. Tower Hobbies .75 Muffler Extension???
  9. nexstar
  10. changeing degrees to percentages in the radio
  11. Ziroli Ercoupe
  12. Problem with yallowaircraftplanes web
  13. Radio Experts, HELP
  14. did I ruin my battery?
  15. 12 6-10 prop. What pitch is it?
  16. WEBRA 32 PROP SIZE
  17. Naca ducts
  18. Techniques for glassing a warbird
  19. How to deal with the wife???
  20. Nomadio Telemetry
  21. CG Chipmunk Prop Choice
  22. BIPLANE INCIDENCE AND CG QUESTIONS
  23. How do you keep CA for going Bad
  24. Which plans?
  25. Which motor?
  26. best prop for TT 46pro
  27. Colored Smoke
  28. Painting on covering?
  29. Monokote decal application
  30. Wing diehedral ?
  31. How to start up a Hobby Shop ?
  32. Fuselage jig
  33. Need Covering Advise
  34. Advice on painting with Topflight Lusterkote
  35. u-can-do .60
  36. plane hold back
  37. Which fuel pump to use?
  38. evolution engine shutoff
  39. Question on Landing Gear Mounting
  40. Adding fuel line filters ...
  41. DAVE Brown Wheels, a quick Q
  42. dad servo
  43. brushless set up?
  44. propeller shaft thread size, prop nuts, etc
  45. transporting 80" warbirds
  46. sealing ailerons?
  47. Epoxy Help
  48. my plane blew up
  49. Great Place to Check Flying Field Conditions
  50. Prop and Fuel for Magnum 90 size
  51. Are there any cool Tower Hobbies sales for Memorial Day
  52. Broken trim tabs on futaba TX
  53. Replacing Antenna
  54. LOOKING FOR VK CHEROKEE
  55. Need to know how much my RC's are worth
  56. OS 120 FS bearing direction
  57. need ideals for my new shop
  58. Finding Aviation Designs site
  59. Tower .75 with a 12x4 prop?
  60. expo on throttle?
  61. Help with CJM rotating Corsair retracts!?
  62. Servo question
  63. Trims, Balance, and Thrust Angles
  64. Want to paint a ice chest..... grin.......
  65. retract question
  66. Hand Crank Fuel Pump Leaking
  67. GAS QUESTION
  68. transfering photos to my gallery
  69. glassing for the first time
  70. Decals "Red Baron"
  71. Instrument Panel
  72. not many events in LA cause the wind?
  73. ABS Plastic Paint Prep...
  74. Bipeplane CG
  75. Servo Covers
  76. How do you Store your CA?
  77. Question about ply hinges for the "older" modeler/builder
  78. airplane
  79. RTV
  80. CANOPY 4-3/4" WIDE ?
  81. Tower Hobbies Epoxy - Is it Fuel Proof?
  82. TX JR Quattro Batt LED Indicator
  83. I would like to obtain the C.G. location for the Sterling Fokker D-7
  84. Rx LED voltage indicator
  85. prop pitch
  86. Air Flow Around a Nose Cone
  87. Saito 65 best Sunday Plane
  88. Weatherproofing event signs
  89. Cleaning Glow Motors
  90. OK, you might laugh at this.. but wingtip question.
  91. powel panel
  92. Need advice on sunglasses Who makes the best?
  93. Expanded Scale Volt Meter\Digital Volt Meter
  94. How to hook up this tailwheel?
  95. NEXSTAR
  96. Price of Doss Steed's P51?
  97. u can do 3d .60 tailwheel
  98. Smoke system
  99. Venus 40 Saito 82
  100. Ultra Rc Giles OS 160 Cline Regulator Concern
  101. Staten Island feild ? Directions needed
  102. Balancing a plane with string? cmp
  103. Madison/Mayodan model airplane field
  104. Sullivan Starter
  105. Inverted Saito 100 Problems
  106. cordless starter
  107. Hobbico Avistar Trainer 40 CG location?
  108. hobbico nexstar
  109. Saito 100 in Miss America
  110. 3 blade or Two?
  111. Black oily mess from the engine ...
  112. Spring-air retracts losing air some place??
  113. 10x6 Prop on a OS .40 FP?
  114. EXPERT GLOW DRIVER PROBLEMS
  115. GLOW PLUG?
  116. LT-40 Balance Point?
  117. Pizzaz
  118. Coweled engine
  119. JR Recievers
  120. picture problem
  121. Sig Mfg.
  122. MONOCOTE VS ULTRACOTE
  123. Towing Banners, has anyone done it?
  124. SAITO FA45 header pipe
  125. Building Table
  126. Sub-Trim question
  127. Carb Settings Saito FA-125
  128. International orders best store?
  129. Has anyone tried Davis Diesel Products?
  130. ON-BOARD GLOW SYSTEMS ???
  131. R/C accident in Hungary!
  132. build boards
  133. How to remove spilled glue off the covering?
  134. H9 Cub/OS 70
  135. Help with Spinner Question
  136. Preferred Latex Brand
  137. Does ca go bad with age ?
  138. Ultracote Paint
  139. fiberglassing
  140. Wing warp or washout
  141. Bennett muffler problem
  142. Radio Interference
  143. possible lower nitro content than stated?
  144. radio issue
  145. fishtailing
  146. realistic engine sound module
  147. Does nitomethane disolve polystyrene?
  148. What makes a accu-cycle quit on 125ma.
  149. 12v Batteries Value for Performance
  150. RC swapmeet...
  151. exaust problems with 4 stroke sato 100
  152. Do you think an RC boomerang would work?
  153. World Models cap 232
  154. OK Model's Pilatus Porter
  155. Need wheel pants for 3in wheels.
  156. SIG MAYHEM 72"/YS 120NC--What to expect
  157. Grass length at your field?
  158. Black Horse Sukhoi SU 31 1.60 throws and CG
  159. Looking for places to fly in South Mississippi
  160. Have you try to use a different Engine in a Hangar9 P-51 PTS?
  161. CG Question
  162. where can i get one of those hydrofoam (car boat plane) ic version?
  163. Who makes an covering iron that's actually good (not just "it can be made to work")?
  164. Suggestions needed for new plane
  165. Glues
  166. Powerline 23% Edge 540 Specs?
  167. Fun with knifes...
  168. yout tube rc club
  169. A/C weight specs
  170. Butyrate sanding sealer
  171. Price/Place to sell my J3 Piper Cub
  172. BEST PLACE FOR FLYING RETIRING SOON
  173. elmers ultimate
  174. .dxf drawing
  175. stripped saito threads
  176. Loss of Power in O.S. FL-70
  177. Cockpit dash question
  178. re-temper landing gear struts
  179. Fuel suction problem in vertical
  180. ASP 1.00 engine in a Patriot
  181. evo 46 tuning
  182. Fuel question
  183. Convert control throw inches to degrees
  184. where can I buy a Super Tartan muffler ??
  185. Coverting Computer Power Supply to 12V Power Supply
  186. LiPo amp output ???
  187. To run pressure or not ??
  188. CG
  189. How to remove CA haze from canopy?
  190. Big Fuselage Covering Question
  191. Window plastic material
  192. Servo help
  193. Battery infor for electrics needed
  194. Tight glowplugs? (or ... my glow plug fell out)
  195. Servo question
  196. Carbon Fiber Pushrod End Failure (Twice)
  197. How do you store your planes
  198. A lean run then loss of power
  199. Natchez,MS?
  200. Dodgy Receiver?
  201. JR 4721 servos on 6 volts
  202. glueing balsa to foam
  203. Balancing
  204. João
  205. When to use side slipping
  206. Questions about fueling
  207. what is this bands name?? MUST KNOW
  208. O-Ring kits for carb and pump repair
  209. What to do if can't move tank?
  210. 7+ channel transmitter info Hitec rcvr cmptbl
  211. 4/B connector
  212. Monokote design on sailplane wing.
  213. CA glue
  214. Great Planes Big stik 40
  215. Tiger 60 and Saito 82
  216. QUESTIONAIRE- Please can you fill this in; for GCSE project =D
  217. fuel/oil question
  218. Pictures
  219. Great planes cap 580
  220. Futaba 7c TX crystal change
  221. What company made this kit built skyraider
  222. Bending brass/aluminum fuel tank tubing?
  223. Century Jet Kit are Goods?
  224. Stick pots for transmitter
  225. Trouble with Y-Harnesses
  226. monokote inside the cowl
  227. Flite Metal... Help!!!
  228. Is it loseing recption?
  229. 4 Stroke to Cowl Clearance?
  230. Rossi 65 question
  231. flight timer
  232. OS 46FX Fuel question
  233. is anyone spinning 3W props
  234. Easy refueler question
  235. What happened to Falcon Trading Company?
  236. Futaba T7CAP Dual Rates Problem
  237. Synthisized module
  238. GORILLA GLUE
  239. hobbico nexstar
  240. OS FS 120-Surpass carb adjustments
  241. Which 3 blade prop for Magnum XL-91RFS 4 -Stroke
  242. Fuel Regulator
  243. Transmitter
  244. Question About A Rudder Pull-Pull System?
  245. Problem with DuBro balancer
  246. What type of spray gun with this compressor?
  247. Super Tigre won't return to idle
  248. Needle Settings for SAITO 182 Twin? help... thx
  249. German 35 MHz radio in the US
  250. Servo lead length
