PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Model shops in Hong kong....any good ones
  2. Can you paint apc props
  3. Saito 150 engine, urgent help please!!!!
  4. Easy Star turns right
  5. PA-York-Manchester Anyone?
  6. mx22 vs mc22
  7. Options for onboard starting (Moki 1.8)
  8. B&D Pneumatic Retracts
  9. Recharging Starter Battery
  10. HELP! 7CAP and The Ultra Stick 60
  11. 3 line fuel with valve
  12. Dead Glow Fuel?
  13. Heres a Chart of Engine Prop Sizes that you all might be able to use
  14. OS .46 LA Disassembly???
  15. Specs on an old Airtronics 94152 or 94151???
  16. Spec for Mill tolerance on Plastic????
  17. Epoxy Question
  18. Polks Hobbies Tracker Radios
  19. OS .46 LA???
  20. Titebond III?
  21. .46 for Tower Trainer....
  22. WC-1 Sundancer
  23. Hitec trainer system won't operate
  24. SHOW US YOUR SHOP!
  25. Installing flaps to lessen tip stalling
  26. Remedy for fuel soaked balsa?
  27. CG Location on Dave Patrick extra 330L
  28. Large Slow Flyer
  29. correcting downthurst
  30. Nitroplanes.com good company?
  31. Fuel in car on a hot day.
  32. fuel tank
  33. Epoxy is tough!?
  34. cs-64
  35. GP FlatOuts/Foam plane questions
  36. Can't Taxi out, Can't idel low enough
  37. onboard telemetry? (altitude, airspeed, direction, etc)
  38. Fuel question
  39. Critter Air Brush
  40. ripmax electric spitfire setup
  41. strip covering or put over existing covering
  42. Anyone used Ultracote Pearl Charcoal or other Ultracote Pearls?
  43. showtime
  44. Prop Expert wanted .....
  45. Gorillia on firwalls?
  46. Getting back into it after 12 years
  47. My propeller/nut came off ...
  48. Covering tips/questions
  49. best prop for madness
  50. Eletric fule filler problem -???
  51. vector grphics wanted
  52. Covering Question
  53. Looking for a good match for my Saito .91S
  54. HELP Engine mount problems on a Tower KAOS
  55. Decals/help with figuring out if upside down
  56. Engine Mounting Question!!
  57. Thrust to weight ratio for sport / aerobatic flying
  58. Prado?
  59. How do I make these retracts fit?
  60. sporadic smoke system
  61. Monokote sagging in sunlight?
  62. How to remove barrel from OS carb
  63. MICROPILOT UAV GPS AUTOPILOT
  64. QUESTION ABOUT SPINNERS, DO THEY EXPLODE?
  65. Dolly undercarriage
  66. Re-Coating Q's...
  67. Air Cylinder for Gear Doors
  68. JR 770 PCM question
  69. HUGE PROBLEM... I think I broke my block
  70. Dual servo question
  71. Bridi Kits NIB
  72. Too much compression?
  73. Storage Issues
  74. Need help with Thunder Tiger exhaust?
  75. Two and Four Stroke Fuel
  76. Nose Gear suggestion
  77. Epoxy Question - am I doing something wrong?
  78. Servo lifecycle
  79. Evolution Power system HP?
  80. O.S. or Saito
  81. Any rating,coment o feedback for the LA Flyer 40 from Airborne-Models?I can't find any!
  82. RADIO QUESTION
  83. Setting up flaperons...
  84. EXPANDO FOAM ???
  85. Sig Scamp
  86. Axle size for 17.5 pound plane
  87. Engine set-up on TowerHobbies KAOS ARF
  88. Turbo???
  89. Pitts S12
  90. Super Tiger engines
  91. unknown plane
  92. Kadet MkII
  93. Do you recognize these retracts?
  94. what will happen in the future for r/c?
  95. glow plug driver
  96. battery on/off switch and external testing battery plug
  97. Weight
  98. Setup Du-Bro RC Kwik-Fill Fueling Valve
  99. TME smoke / Futaba 9c xmitter
  100. Cline Setup U-can-do 60 saito 125
  101. Air Tank Size For Pneumatic Retracts
  102. Problem removing crankshaft on OS 46 FX
  103. 160 twin; 12mm Reamer or ?
  104. Simple question
  105. flaperons for F4U
  106. 6 Volt Futaba
  107. Paint Color
  108. Has anyone ever fixed a perry pump
  109. tunning
  110. Shop machinery
  111. Adhesives
  112. Dave Patrick Models Ultimate 40 C/G
  113. New runway help
  114. Gluing hardwood dowels to carbon fiber tubes
  115. Coverite 21 century cub paint doesn't match
  116. How do you get it to them to the field?
  117. U.S. Engines ?
  118. POLL - RC PLANE RESEARCH
  119. What weather sites do you use?
  120. Help our SCHOOL PROJECT do RC Plane RESEARCH !!!
  121. naming a company...
  122. Futaba 9CHP
  123. Red/White Checkered Ultracoat
  124. Negative Buying Experience
  125. what fuel
  126. CA hinges
  127. Supra retracts parts?
  128. Looking for 22AWG Battery wire
  129. wash out
  130. Question about prop
  131. my first EDF jet
  132. Do I need to remove all the old covering?
  133. PCM vs FM
  134. Finding somes covering desings
  135. Event
  136. Enough room for carb?
  137. Going from 2-blade to 3-blade
  138. covering turning yellow
  139. Cleaning after flight
  140. In Search Of..........
  141. List events
  142. Sticks
  143. Staying in Little Rock- What to do?
  144. Accu Cycle Elite Problems
  145. *How to keep wheel pants on*
  146. How do you store your planes?
  147. Graupner MC-19 + Buddy Box???????
  148. Servo Buzzing
  149. Testing Receiver
  150. Hi-Tech Servos
  151. control question
  152. tower hobbies
  153. asp engine
  154. Source for Frequency Pins
  155. Where can I get an Enya crankshaft?
  156. h9 1/4 scale cub windscreen
  157. Wagstaff wingtube problems
  158. New Engine Start
  159. How do you transport to the Field?
  160. George ? Aldrich
  161. Shipping time from Hong Kong?
  162. Remote Fuel Tank
  163. prop to hover
  164. Amelia Earhart question
  165. WIND PLANE FROM H@##
  166. Engine / Prop Vibration
  167. Solder help
  168. MK retracts specs
  169. Recovery Systems
  170. New Zealand Flyer ?
  171. Ultimate and Challenger draw???
  172. Fun flys in IL, IN, or WI?
  173. reciever/battery quest. voltage???
  174. fuel question
  175. WC II programming issue HELP Ultra stick
  176. F4U Corsair Erection & Maintenance Manual - Page 36
  177. Combat Models
  178. nexstar fueling prob hellllllp
  179. custom cover desingners
  180. Sig Rascal 40 Engine Fitment
  181. RC in China
  182. Engine question?
  183. retracts
  184. How to get a nice even paintcovering on an elapor plane?
  185. Ultimate bipe questions
  186. whip antennas?
  187. Bipe CG location
  188. Motor and battery for my new plane...
  189. Field chargers?
  190. Japanese silk tissue question
  191. More Gorilla glue questions
  192. How many of you coordinate rudder w/ aileron?
  193. Simple field box electrical problem 12v/24v
  194. Charging with Ace Super Digipluse
  195. Mystery Wings...
  196. Dynaflight DECATH radio install ???
  197. servo extensions
  198. 3-line tank, why won't it fill ?
  199. Trim solvent
  200. old powermaster thread
  201. newbie question: covering iron
  202. west systems epoxy
  203. Futaba PCM 1024 R136HP 6 Channel Receiver 35MHZ
  204. Z-Bend Pliers near SLO, CA
  205. PCM??
  206. Battery life on a glow plug starter
  207. lost tt pro 46 needle
  208. Tower Hobbies Coupons and Discounts
  209. is this combination logical?
  210. ground loop? explain?
  211. Grass or Paved runway
  212. epoxy and non-stick screw?
  213. Bore Bigger Hole in Carbon Fiber Tube?
  214. MIG 27 drone C/G
  215. plane engine vs. heli engine
  216. MINT JULIP CONTEST
  217. Stock Landing gear on Skyraider Mach II?
  218. Respirators for CA?
  219. Flying with floats
  220. Epoxy vs JB Weld for wood to metal
  221. removing a canopy
  222. Enya .15 8 x 6 prop???
  223. cutting wing cores
  224. Max rpm range for an Enya .15?
  225. Karbonite gears
  226. Storing planes
  227. Rudder pull pull question
  228. cutting carbon fiber tube
  229. A little help with valves please
  230. Getting 1/2 stick to equal 1/2 throttle...
  231. TOOL FOR THIS??
  232. What is wrong with my cub
  233. Workbench ideas?
  234. Blue box ww2 American pilot where?
  235. SPCM or PPM
  236. Radio Frequencies-Change 40.830 to 40.835
  237. Shipping 84In airplane
  238. 5-45 screw
  239. Where can I buy flat T6 aluminum for landing gear?
  240. OS 1.08 vs 1.20
  241. "Finished" airplane
  242. Super Stick 40 - What's up?
  243. muffler hunt
  244. Where to buy custom main gear?
  245. Radio system problem
  246. smoke system fluid
  247. Control Surface Linkage questions...
  248. Is it me or has Monokote's quality gone down????
  249. Robart retract question(s)
  250. Tower Hobbies ad number
