PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Bumper stickers
  2. U-can-Do .46 Ailevator
  3. looking for a new plane
  4. Blue-ish green prop?
  5. How do you fully discharge a Dynamite glow plug thingy.
  6. legal question
  7. 120 glow and 26cc gas
  8. jr xp 8103 dual elavator servos
  9. New? sanding CA joint technique
  10. Club Fees? $$
  11. Dyna-Glow Charging
  12. Electric Zagi
  13. Tricycle retracts --- how they work?
  14. Any body know what this plane is worth???
  15. Any body know what this plane is worth???
  16. Silencer for OS twins
  17. Prather Engine drill jigs
  18. DUAL RECEIVERS QUESTION
  19. Kyosho AT-6 Texan Help.
  20. World Models
  21. Oil on my servo connections
  22. localised radio interference
  23. Fuel Tank Frustration
  24. can anybody name this airplane!
  25. APC Props
  26. pull-pull cable w/tiny bb crimped on end
  27. Futaba 7CAP Support
  28. Replacing tricycle with aluminimum strip
  29. Wood dowel push rods
  30. akernims? (pardon my funnyneticks)
  31. Ultra Stick 60 rudder design question
  32. Saito Glow Plugs
  33. Which model airplane magazine
  34. Between these Four airplanes for Imac and 3D as the best one
  35. Strobe Lights???
  36. How many aircraft are too many?
  37. 1970's fun fly?
  38. Spray Gun/Compressor - Help/Advice
  39. Underpower Shrike 40
  40. What fingers do you use on the control sticks ?
  41. 4-stroke on US 60
  42. fiberglass cowls
  43. Finding aerobatic .61 plug-in wings
  44. Thinning Epoxy?
  45. SERVOS MAKING NOISE
  46. Thinning CA Glue
  47. My repaired OS engine won't stop running .
  48. piper cherakee
  49. Moki 2.10 motor mounts mod. ??
  50. solartex not sticking
  51. How do I repair cracked windshield?
  52. Nova Rossi .50
  53. MPI On-board glow system
  54. Great Planes Ultra Sport Engine Question\Suggestion
  55. Covering Coverite 21st Century Fabric with?
  56. 2 cell lipo rx, miracle switch
  57. Should I drop a GP Cub 40 for a different plane?
  58. Hinge slots
  59. 10 size nose retract
  60. Elevator Halves
  61. Painting with automotive spray lacquer (cans) ?
  62. monkote wax?
  63. ARF Building
  64. Buzzing Servos
  65. which engine?
  66. Carburator
  67. another painting question.
  68. flying field in Lander WY
  69. Transmitter Stick Resistance?
  70. what is the best airplane
  71. U-CAN-DO-3D Gas Tank
  72. buddy box setup.
  73. Size compressor needed for spray painting ?
  74. original JR Datasafe Program needed
  75. retaining nuts on control valve
  76. Silly Question on Prop Load: APC17x8 = APC18x6W
  77. How long will glow fuel last?
  78. Monocote over FG fuse?
  79. Most Popular Engine Brand
  80. Adding weight
  81. Funtana s 40 With OS 50 SX
  82. Aluminum Landing Gear and Wing Tube Mfg.
  83. Foker tri-plane
  84. Servo End Point Adjustment
  85. TME, slimline & sullivan smoke pumps
  86. Fiberglassing Wing Center
  87. side mounted tanks
  88. Landing gear foot print ?
  89. crossing pull pull cables
  90. Cermak Graduate VS. Great Planes Easy Sport
  91. Need a canopy for my ultimate
  92. Servo problem
  93. Engine Mount
  94. Four Star 60
  95. Spinner for Large Props
  96. Bending small tubing
  97. Automobile stickers: R/C:Where?
  98. Three dimensional piolt busts from photos
  99. os91fs and palmer plans
  100. asp 1.08 prop size
  101. CG
  102. Fuel proofing inside of fuselage.
  103. is this a 51D painted like a p40 warbird?
  104. servo torque requirements
  105. RC Parachute
  106. Bisson or Slimeline
  107. Electric or gas scale ARF 60
  108. Perry Pump Pressure Line Broke
  109. SK engines
  110. Solar Or Wind To Charge Field Box Battery?
  111. sterling stearman pt17
  112. Ironing on Balsa sheeting
  113. Hinging gluing tips: How you do yours on Dubro hinge.
  114. SCALE PILOTS
  115. I'm coming to L.A. next week
  116. Third number in prop size??
  117. Transmitter Holder
  118. CG: how do you do this?
  119. SPACEWALKER ll 40 BY SEAGULL - GAS TANK PLACEMENT
  120. Hanging planes from ceiling???
  121. hobby shop in Seymour IN
  122. Missaligned engine
  123. Fuel Pump
  124. Do You Have Pactra Piper Yellow, formula U #20138?
  125. Prop design
  126. 3 or more planes....charging question...
  127. WING JIGS, WHICH ONE?
  128. *Adjusting The High Speed Needle Inside A Cowl*
  129. 4stroke vs 2 stroke
  130. AirTrax 90
  131. Applying Graphics using Frisket Film
  132. Easy Star Electronics Troubleshooting.
  133. OS .91 FS Surpass (W/O Pump)
  134. Supertiger Engines
  135. Great Planes F-14 Tomcat
  136. Electric Starter Problems
  137. need manual for RFB 600 by dave duesing
  138. Access hatch construction
  139. Which Spray Paint (cans) for Best Finish ?
  140. JB Weld really stronger than epoxy?
  141. 27/28% pilot figures?
  142. Flex CA-what and where?
  143. Hinge question
  144. KANGKE WACO
  145. Saab J 21 a Three views Does anybody
  146. Saito 120 and 10mm shaft
  147. I've got gas
  148. Difference between high and low freq. bands
  149. Spray Painting Monokote
  150. Monokote removal
  151. War Bird covering?
  152. Connecting two transmitters?
  153. QUESTION!!!
  154. Saito 180 upside down???
  155. Hitec servo programmer question
  156. CG check
  157. The season of spring
  158. What kit ?????
  159. Where do I put the battery
  160. Carbon push rods, best way to build?
  161. Futaba 9C set up question
  162. banner pull
  163. Needle valve- remote adjustment
  164. Help--Build A Charge Jack Into The Bed Of My Truck?
  165. Ryan STA parts needed
  166. After Run Oil to the muffler ?
  167. how to get ca off my canopy
  168. how to remove ca hinges
  169. suevia 400 ?
  170. Muffler extension
  171. warped wings, oh my ...
  172. Propeller Selection
  173. Is this engine toast?
  174. Looking for a replacement
  175. Help Please... Oriole No.8910 Props...Thanks
  176. *Digital Servo Reaction Time*
  177. Hotwire cutting templates
  178. slop between clevis and control horn
  179. servo speeds
  180. Super Coverite Iron On
  181. building board ?
  182. Is it a old telemaster kit?
  183. tires
  184. EXPO ? What happened to it ?
  185. how to pull thrust washers?
  186. Battery recharge
  187. Receiver antenna length
  188. Got a free plane - need help please
  189. Filling the tank with the cowl on
  190. Starter dilema...
  191. 3-1/2" 3-Blade Red Spinners for a P-51???
  192. Monokote/Lustrekote color match??
  193. Futaba Receiver Schematic
  194. smoke substance
  195. Muffler design for 'scale' sound?
  196. Looking for your advice on next plane
  197. Convert a 2 blade prop size to a 3 blade prop?
  198. Cermark Pitts s2b
  199. Best "light" covering
  200. Center of Gravity
  201. U-Can-Do 3D/"#36 holes"
  202. Diesel?
  203. Programmable Crystals
  204. Remote Needle valve question
  205. A Great Builders Table Saw
  206. Bending Balsa
  207. Engine cutout on tight turns
  208. RC Power Duck?
  209. Glow Plugs
  210. making fuel proof decals
  211. Monocoat or Ultracoat?
  212. Radio Control Foam Modelling by David Thomas, Sid King
  213. Stencils
  214. Servo Size
  215. Great Planes ElectriFly BL-8 Brushless ESC
  216. Spinner question
  217. Gas Engine, or 4Stroke for 1/6 Scale P - 51
  218. a couple questions here
  219. Kevlar cable
  220. Servo geometry question
  221. can you fiberglass foam???
  222. Need Advice on Ultracoat Paint
  223. Hobbico product support rules!
  224. Odd Question about computers and servos
  225. custom fuel tanks???
  226. batteries with s connectors
  227. Thunder tiger carb adjustments
  228. Bonding foam? spray glue/CA/epoxy?
  229. incidence meter
  230. Old canopies that have turned yellow.
  231. Fuel tank position
  232. Hobbico Digital Voltmeter eating 9 volt batt's
  233. Spinner Nuts?
  234. Need CG info
  235. Folding Propellers
  236. Dubro Super Smoker
  237. MPI Power Switch w/LEDs, installation question.
  238. cowling mounts
  239. Covering
  240. Confidence shaken...trim problems
  241. Interference or Failure?
  242. balance prop
  243. I would to see your JIG for build fuselage
  244. 3 blade props
  245. Reciver battery pack???
  246. Mustang P51 PTS radio problems?
  247. Is there a soft mount for a Saito 2.20
  248. End of winter maintenance??
  249. Covering Question
  250. Sheeted foam wing basics?
