PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Pnuematic Retracts HELP!!!!!
  2. Why mount servos that way?
  3. Painting ultracoat covering
  4. Robart Hinges. @#$%%##@%@!!!!!
  5. 3"x3"x36" balsa or foam needed
  6. WING LOADING????????
  7. Stabilizer/Wing angle
  8. exhaust
  9. RC Club in Maui.
  10. Get a Slot Machine!!!-Really!!
  11. crash and burn twist!!
  12. *Exhaust Extension*
  13. MOVED: To regulate 6V or not; that is the question
  14. Shipping Airplanes
  15. piper J-3 cub
  16. Hobbico retracts - nose gear steering
  17. Sealing Towerkote/Monokote seams
  18. Coloring epoxy
  19. TF Cessna 182 Skylane Longitudinal Balance
  20. Fuel pumps= how far can they lift fuel ??
  21. Weight bags
  22. Just a propeller question
  23. Messed up epoxy...HELP PLEASE
  24. Where Can I Find 40mm 3 Blade Spinners??!!
  25. Quad split servo extension for bi-plane
  26. saito tear down problem
  27. 4 stroke compression
  28. UltraCote Paint and Fiberglassed Surface
  29. Flair Focke Wulf 190 prop size?
  30. Double Post!
  31. Radio compatibility
  32. Z-bend
  33. servo eyelets
  34. FM to AM radio differences?
  35. Aircraft sound track
  36. Laminating (protecting) plans ...
  37. Elevator question
  38. epoxy
  39. What do you use to TINT your CANOPY?
  40. CG on 40 size WILD THING???
  41. ADVANTAGES / DISADVANTAGES TO REMOVING MUFFLER BAFFLE?
  42. Panel line pens
  43. question about engine selection
  44. helicols for os91 exhaust port
  45. Pica 1/5 Scale Waco Graphics
  46. Futaba Field Force 9 question
  47. Rossi 60 Settings - Help!
  48. JR 9303 question....
  49. Sealector Iron for Monokote
  50. BudBarkley"s Vintage models TIGER MOTH DH 82 airplane kit
  51. Pica Enterprises
  52. Quality question on GMS Engines
  53. antenna
  54. Smoke tank where to put it?
  55. How to paint canopy framework??
  56. Silkspan
  57. Where to fly in Orange County CA
  58. battery charger connection
  59. Toledo Ohio
  60. homemade push/pull will it work
  61. is that possible to build boeing 737?
  62. Anybody no Slimline Muffler on cap 580
  63. Lightest rubber?
  64. MOVED: Saito FA130 Twin Fuel line routing ???
  65. Goldberg Sukhoi .90 1st edition
  66. U.S navy decals
  67. Futaba Servo FP514B, Does anyone know the torque and/or speed rating
  68. What is the root chord?
  69. Hanger 9 Cap 232?
  70. Paint Suggestions for Inside Canopies?
  71. Anywhere else to buy Solartex other than Balsa USA?
  72. Am I in trouble?
  73. Saito FA 100 muffler coming loose
  74. 1/16" (1.5mm) Lite Ply?
  75. does any body know where i can buy a blue angels formation flyer?
  76. NEWBIE QUESTION: Motor Shutdown
  77. WHAT DO YOU DO TO NEW MONOKOTED WINGS TO MOUNT BALSA STRUTS???
  78. need help-disasemble to clean-gumed up
  79. What ever happened to?
  80. Could this be a scam?
  81. P - 51, Retractable gear or not?
  82. Pictures on Line
  83. REMOVAL OF IRON MARKS ON MONOKOTE
  84. Flite Metal
  85. Balsarite Question
  86. Airbrushing
  87. Looking for a book titled........
  88. Dubro Pull-Pull 2-56 kit question
  89. Throttle Servo
  90. MONOKOTE?? WRINKLES!!
  91. Help with 3 blade prop
  92. need flying site help
  93. Dual Fuel Tanks
  94. MVVS
  95. Foam core wing repair...
  96. building light
  97. H9's P-51 PTS Problems Startng
  98. Engine Mounting
  99. Spring Air Retracts
  100. Sheeting on Foam Wing Repair?
  101. Epoxy/ alcohol mix
  102. Removing SUPERGLUE
  103. Prop weights?
  104. T-34 Racing
  105. Best Prop?
  106. Starting a new ARF business
  107. MacGregor Tx
  108. Canard flying charactaristic
  109. TT.46 with this prop?
  110. Spektrum 2.4GHz use in Australia
  111. Thinning CA
  112. monokote over solartex
  113. electric conversion question
  114. HELP!!
  115. Propellers/Pitch/Diameter
  116. Receiver antenna cut
  117. what planes to buy?
  118. Valve settings for a Magnum 90 4cycle
  119. JR RX/ SERVOS
  120. *Sealing Control Surfaces*
  121. EZ ARF's
  122. Crystal changes
  123. Carburetor & Exhaust Covers
  124. mono to biplane
  125. RCV 58 performance?
  126. teaching your significant other to fly?
  127. twist engine
  128. Installing canopy
  129. C/G
  130. Does ANYONE HERE actually have a AR400 radial in a plane?
  131. cockpit window....
  132. Removing old tape residue from foam parts?
  133. How Much Thrust?
  134. Foam cutter power supply
  135. fliteline scat cat
  136. what kind of motor is this
  137. Receiver Range - Claims & Truth?? FUTABA
  138. Saito 120
  139. Online Promotion Codes V2.0
  140. Transmitter crystal
  141. Drill or bevel first for Robart Hinge points?
  142. need balsa wood
  143. Average speed of a wot4
  144. Futaba T6XAs -Good Radio?
  145. tow plane
  146. screaming servos ?
  147. twist p-n-p antenna routing
  148. Zap (Pacer) Hinge Glue - caution
  149. Ultracote Corsair Blue Paint Match
  150. Dynatron Starter Convert
  151. TIMING OS 91 SURPASS
  152. Bending Thin Ply
  153. Pushrod connectors
  154. Crystal Exchange?
  155. Parts from one place
  156. Propeller hole larger than shaft???
  157. Model Sport Video ?
  158. everything electric
  159. Titanium landing gear legs
  160. CA on Canopy and Monocote
  161. Buying used engines-horror stories?
  162. One-Way fuel valve
  163. Need Help Finding A Plane
  164. RC Parachute Men
  165. Post your Retract Pics!!
  166. Super Dry / Smoke Oil
  167. charger/switch
  168. Need landing gear bolts recommendation
  169. Best place to find pilot figures
  170. glow plug question
  171. "Pilot" brand Giant Decathalon questions
  172. Engine Size Selection
  173. Danielle's Hobbies
  174. c.g. on gee bee - y.
  175. how to figure wing area / loading???
  176. Why no "stick" type plane with the capabilities of an Extra?
  177. Aerobird Xtreme Battery???
  178. Saito 82 installation problem
  179. fishtailing plane
  180. New please help with evaders
  181. 6v batt versus 4.8 v ????
  182. WANTED - Fexable Pushrods!!!
  183. Toughlon coating for World Models
  184. China Model Productions
  185. Changing Channels in Receiver
  186. Recommended Prop For Astro Hog
  187. MDW Aviation Super Dri Smoke
  188. Loooooong Screws?
  189. Fuel Line Size
  190. PLEASE HELP!!!
  191. exhaust deflectors killing power?
  192. *Free Wheeling*
  193. Smoke system
  194. What aircraft is it?
  195. Cleaning old engines
  196. Black Baron
  197. Airtronics VG6000 trainer cord compatable with Hitec Flash 4/5 SX?
  198. Hard Point Location?
  199. What is this plane?
  200. Need to find centerline!
  201. 2 and 4 stroke engines
  202. Is the HS 85BB Micro Servo up to this job?
  203. satio 90 ft twin
  204. Copper tubing (fuel lines)
  205. *Attaching To Fiberglass Cowl*
  206. Need a plane for Saito 82
  207. retracts by 3dxhobbies.com
  208. Tower Hobbies ad codes
  209. FUEL FUEL FUEL
  210. glow plugs
  211. Dual Receiver/Dual Battery Setup Question
  212. Printing on Ultracote
  213. can't locate a mftr who can supply a 3 1/2'' nylon spinner
  214. Cleaning fuel soaked plane for covering?
  215. Aeromodelling shops on New York and London UK
  216. 3 Blade prope for saito.82 ?
  217. Dot vs Easy fueler
  218. Help with Great Planes Pivot Point Hinge.
  219. Oily balsa
  220. Pull-pull system question!
  221. What is it ?
  222. Extra antenna wire-where's it go?
  223. Need a 16x8 3-Blade Prop
  224. cutting CA hinge slots
  225. Real world measurments
  226. Propeller question
  227. soldiering brushless motor multi strand magnet wire
  228. Balancing a bipe
  229. How to paint polyurethane plastic?
  230. Cleaning engine after flying
  231. Trouble with FL-70 O.S. Engine
  232. Where can you find the flight box with folding legs?
  233. Help with engine selection?
  234. Request for "deep blue" and "midnight blue" ultracote photos.
  235. Magazines
  236. Lighting System
  237. Does anybody know what this plane is
  238. What glue to use on Depron ?
  239. Sullivan Dynatron starter cone removal?
  240. foam cutting tools
  241. balistic recovery systems
  242. stretched checkerboard design
  243. curved piston rod on fuji 35?
  244. h1 racer kit
  245. RC Blimp.....help me find one
  246. LiteFab Covering?
  247. Covering with monocote
  248. monokote over monokote-big graphic
  249. What size gas engine???
  250. where is a good place to get tools mail ordered?
