PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. what fuel for four strokes
  2. Weight ratio balsa to aircraft plywood?
  3. Supertiger 61 What prop??
  4. CYANO removal
  5. Ultimate Glue/Poly ProBond Question
  6. Back order at Towerhobbies
  7. Covering overlapping covering
  8. OK Model
  9. fried JR XF622 radio? Calling all JR techs!
  10. New Improved Robart Airpump, Anygood?
  11. Monokote issues...
  12. Modifying a Tachometer
  13. Motor Mount question
  14. left hand thread jam nut
  15. Shipping built airplane by Forward Air, prices???
  16. Balancing Tower Hobbies Trainer 40 ARF
  17. SPINNER BALANCING
  18. what's a good first biplane?
  19. Robart Retract Pressure Gauge
  20. change engine position
  21. Sealing edges of Monocoat trim....
  22. hobby shops in austin texas
  23. How to work with Monokote?Help...
  24. How are color fades on planes done?
  25. Making Letters Templates with Windows XP?
  26. Dubro gas conversion stopper with glow fuel?
  27. Best plane after your trainer......
  28. Bridi Bre-Zee Bipe
  29. Delta wing aircraft
  30. super decatlon
  31. old O.S max 50, why Wont it idle?
  32. flying events
  33. RC Scale International Magazine
  34. Covering question (newbie)
  35. HOW DO YOU SHIP BIG PLANES
  36. Ram lighting parts question?
  37. Radio/receiver ???'s
  38. propeller size versus engine displacement
  39. Newby Questions
  40. Your plane history, what models have you had?
  41. HELP BLAST THE RUMORS!!!
  42. foam for lite tires
  43. Monokote Cutter
  44. What engines or brand start/best inverted?
  45. In Cowl Silencers
  46. RD6000 programming question
  47. 4Stroke Muffler Question
  48. New Aeorbatic Foam Airplanes
  49. Slimline Mufflers,OS,Magnum, need help
  50. ringed engine: Caster or Synthetic
  51. prop question again
  52. What prop?
  53. oSport Air Forty
  54. need info about this trailer
  55. OS MAX S 35 MUFFLER INFO NEEDED
  56. Covering control surfaces
  57. ELECTRIC vs GLOW or GAS
  58. *CA Hinges On Bigger Planes*
  59. Ultracote vs Coverite film?
  60. Flaperon , spoileron general question
  61. Laser cutting
  62. Brushless help
  63. 3D Flying Maneuvers
  64. GEE-BEE Muffler Hep Please
  65. Building Board - Slight Warp. Please Help
  66. Frequency Pin Board?
  67. Fuel Tank,engine questions
  68. Which ENGINE?
  69. CAMERA CHEAP
  70. ON BOARD GLOW
  71. Epoxy problems
  72. MOVED: Digital vs Standard servo
  73. Webra 120 on Stinger 120
  74. Fixing Blindnuts
  75. Break in prop for Saito 1.50?
  76. Repairs: how to degrease (fuel) from wood
  77. glow fuel removal
  78. Sullivan Skywriter smoke system
  79. RC Universe Poker game
  80. Smoke System for OS 90 2 stroke
  81. Cutting decals/camouflage?
  82. split elevator problem
  83. Hangar 9 Spares
  84. 4.8/6.0
  85. Need Help With Mechanical Retracts
  86. Robarts and Oleo Struts in a Hanger 9 MA
  87. Large Payload - Help me Find an ARF!!
  88. which plane is faster?
  89. rx crystal help
  90. TowerPro Digi Servo,s
  91. R/C Trailer Question
  92. engines
  93. Help please!
  94. Has Monokote changed??
  95. Williams Brothers has returned
  96. Top-flite magnetic balancer instructions?
  97. BR- 2000
  98. cyl. head purchase
  99. .60 Lanier Stinger balance help
  100. Broken Horizontal Stab
  101. San Antonio TX flyers
  102. Comparable servos-different brands
  103. How are Cirrus Servos
  104. Exhuast pipe
  105. Tiger 60 Motor
  106. What prop for a Ryan STA 1.20?
  107. Four stroke muffler and cowl
  108. Tail Heavy Stinger 120
  109. Problem with Monokote covering
  110. Hydorfoam / Hydroplane
  111. Does CA Glue really have an Expiration Date?
  112. Box fly 20
  113. SturdyBirdy or Duraplane?
  114. sheeting help
  115. Pricing Error at Horizon = Bargain
  116. Opinion on the 4* .40 and 4* .60 please
  117. Does anyone recognize the cowl?
  118. bulk balsa order what to get?
  119. Giant Scale Props
  120. clevis
  121. Problems with Hangar 9 Ultra-Paint
  122. STARTER NOT STRONG ENOUGH!- any suggestions?
  123. Twitchy Servos
  124. Major R/C Fly-Ins: Where? When?
  125. Aerobatic manuvers
  126. paint type on styrofoam
  127. Which color shows up the best?
  128. Rcv 90 Engine & Hanger 9 p-40
  129. seagul super star 1.20 engine?
  130. OS 40 FP FUEL CONSUMPTION
  131. GMS 47 or MAGNUM XLS 46
  132. cessna grand caravan
  133. Sunglasses
  134. Center Line of tank , in REF to CARB.
  135. model airplane generator
  136. Out with the old and in with the new
  137. Benefit of 2 rx batteries in parallel?
  138. Interchangeable Crystals
  139. Storing/Hanging Planes
  140. Servo Current draw
  141. NiMh Charging
  142. Throttle loop
  143. 2-vs-4 Stroke Question
  144. Hangar 9 twist and Magnum 70
  145. Evoloution 100 pitts style mufflers ?
  146. Hobbico Extra 300
  147. Carb Intake...
  148. Shipping & Packing Airplanes
  149. Where does everyone order their supplies?
  150. YT air retracts
  151. tilted building board
  152. Need help finding exhaust pipe
  153. question about my prop nut not coming off
  154. What engines for this model
  155. What fuel regulators/pumps work?
  156. Futaba Radio help needed
  157. hay field to flight field
  158. Empty batterypack, mistaken to be faulty by charger?
  159. Ultracoat for Foam Wing?
  160. tilted building board
  161. Float Plane????
  162. 21st Century Fabric Paint - Lemon Yellow
  163. HELP ON FLOATPLANE!!!
  164. covering for four star ARF
  165. Are you using Gorilla glue?
  166. Century Retracts air leak help!!
  167. Question from a real newbe
  168. Radio is stuck in reverse
  169. Engine won't start up....
  170. fuel delivery problems
  171. Need Ideas for Moving a bunch of planes
  172. Finishing advice needed
  173. Could somone recomend me some good airplane hobby shops in the phoenix Area?
  174. Hobby Shops in Houston TX
  175. CA Glue is there a difference? one Vs other
  176. Santa! Please bring me.............
  177. Cowl doesn't match the color of monokote....
  178. Mode 1/2
  179. FMA Co-Pilot vs. Futaba Pilot Assist
  180. Flaperon /Flap set up
  181. 12 volt starters
  182. Is it to cold to fly?
  183. Hauling a plane in a pickup
  184. NEED HELP INSTALLING CAMERA ON PLANE???
  185. Custom CAD Plans
  186. First Glow Plane: Fuel Proofing Question.
  187. CA on plastic canopy
  188. Setup for Pitts Biplane-Rudder-Elevator
  189. MEK is HEALTH HAZARD SOLVENT
  190. Covering colors
  191. Shipping Large planes!!
  192. Have a Questions
  193. Retractable nose gear steering
  194. Radar Guns and R/C Planes
  195. * Members & Active Flyer's In Your Club*
  196. Expert glow lighter from H-9
  197. Lockheed Vega?
  198. SKY HAWK
  199. Building table
  200. need canopy
  201. Sport v. Scale v. Aerobatics Propeller Choice
  202. How to get epoxy to dry?
  203. Bipe dilema ?
  204. aluminum spinner adapter nut
  205. Recommended smoke pump?
  206. aircraft plans
  207. Limbo Dancer Wing Bands
  208. Flight Pack
  209. Center of Gravity Question
  210. Digital Servos usage.
  211. covering
  212. Micro Reciever Decision... GWS?
  213. Balancing a folding prop....
  214. Trim Solvent uses?
  215. JR
  216. Air Retracts pump, what do u use?
  217. Exhaust Mainifold for Saito .65
  218. *Remote Glow Plug Igniter*
  219. Saito FA-100 Ti dimensions?
  220. Checkerboard ultracote
  221. Coverite 21st Century Sealing Iron repair
  222. Russian Translation
  223. Webra Engine Problems
  224. Engine for sig somethin extra
  225. Canopy hinging suggestion?
  226. wMaking Servo Wires
  227. p-51D mustang
  228. RX Battery Mounting--need answ.
  229. Receiver antenna
  230. source for Lithoplate aluminum sheeting
  231. The Windex works....
  232. Tuning question for .40 mds
  233. house of balsa
  234. PT-40 to a taildragger
  235. Im an idiot, please assist....
  236. Monocote or ultracote??
  237. Nitrate Dope
  238. OS .40 FP Prop Recommendation
  239. Better glue choice than CA types?
  240. coverite over coverite
  241. Solartex
  242. What's in a good receiver?
  243. Tower .61 Engine
  244. bent wing - no not corsair
  245. To Spray Paint or Monokote.....
  246. Anyone Mixing there own fuel?
  247. Dacron Covering Alternative ??
  248. Covering tools, what to buy?
  249. Gearbox Noise - is it normal?
  250. Glow Plugs
