PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Receiver question
  2. Checker Board...
  3. IS IT WORTH IT?
  4. Hangar 9 remote glow plug thread size?
  5. Rip stop nylon
  6. transmitter holder
  7. Mk Stuka Instructions needed
  8. removing muffler on magnum .91 fs
  9. senior telemaster
  10. *Spinner For Saito 1.00*
  11. Need cutaway engine pics
  12. Sig Koverall-substitute?
  13. Moving to the United Kingdom
  14. Gas Engine Fueling( electric pump or not)
  15. where to buy
  16. Vacuum Forming Specs.
  17. GSP 72" Extra 300
  18. MonoKote
  19. IMAA legal?
  20. 2-56 threaded rod (hardened)
  21. Mounting An Engine Foward Of Location On Plan
  22. MICROBALLOONS?
  23. SAITO 120 vs 150 vs 180
  24. Aileron Servo reversing
  25. Hangar 9 True Red paint
  26. Seeking fiberglass landing gear
  27. Plan Enlargement
  28. Robart Retract Question
  29. Sealing hinge gaps?
  30. RC clubs & flying fields near Palm Desert & Palm Springs, CA
  31. Taking Care of an Older Saito????
  32. Installing Retracts
  33. 2 stroke rpm's
  34. Scrap Wood from Kits
  35. covering over fiberglass
  36. Ca Hinges
  37. saito 150 fuel problem,,,, PUMP????
  38. How do you apply trims to your model?
  39. Need Help w/ P-51 Spinner Adapter Nut
  40. Is my Saito-FA80 stong enough for my Dragon Lady?
  41. SAITO 100Ti ?????
  42. Covering a PT-40
  43. Converting degrees to inches
  44. Help me with my homework
  45. fuel storage/carrying issues
  46. Can I burn airplane fuel in my car?
  47. ST 90 Muffler Bolts
  48. RETRACTS - PNEUMATIC OR MECHANICAL
  49. muffler problem
  50. foam
  51. Help me tune my Robart retracts please..
  52. New Cirrus Servo ??? Experiences? CS704MG
  53. 4 Bladed Prop Quetion
  54. translation to american from russian
  55. pilot
  56. cold weather storage
  57. pull-pull system
  58. Fuel comsumption of .25 size motor
  59. Largest 2-stroke motor in 60 size plane
  60. Cermark brand "Y" and extensions
  61. aileron servos
  62. Beechcraft Bonanza
  63. quick battery question
  64. Goldberg Pitts
  65. narrow band, wide band?
  66. modification to a Sig SE
  67. Career opportunities with R/C
  68. cantankerious motor
  69. Servo torque question for the maths guru's
  70. RC Modeler magzine
  71. web site for fibergalss
  72. magnum services
  73. Old gear
  74. Any good kit builders for cash in PA ?
  75. SK engines
  76. Lithium rx batteries
  77. Clevis Confusion
  78. New Saito can't draw fuel
  79. Cutting balsa fuse and wing ribs from plans
  80. How much is this stuff worth?
  81. balancers?
  82. A field in Cambridge shire UK
  83. decals
  84. Ziroli F-9-F panther jet need decals
  85. Hangar 9 P51D Miss America Retract Gear Struts
  86. Suggestions for a test bench
  87. 2 Stroke & 4 stroke inverted question
  88. WHAT ARE FUEL DOTS?
  89. GLOW PLUG FOR LARGE MDS ENG
  90. bending balsa, while building
  91. reusable bombs for yellow aircraft bomb release????
  92. hangar 9 cessna 182 help
  93. spinner backplate
  94. Smoke Fluid Recipe
  95. DXP to PDF conversion help!!!
  96. Metallic Covering Question
  97. How do you mount APC 18" props?
  98. Bomb drop for 40 size plane???
  99. Which aluminum spinners fit 3D wide blade props?
  100. Good Field Box Options ?????
  101. Seagull Edge 540
  102. Tx/Rx crystals
  103. Dope Question!
  104. CA Glue Protection
  105. Repairing tips
  106. perfect tanks
  107. Futaba FP-S148 ???
  108. Standard servos on spacewalker??
  109. fuelproofing field box
  110. Blackhorse Matrix HELP NEEDED!
  111. Hardware
  112. Are my servos strong enough for 1/4 scale ????????
  113. tap & drill sizes
  114. Making servo extensions?
  115. Tips on flying large scale SpaceWalker II?
  116. Sig SE throw setup
  117. Ink Jet decal paper
  118. Is LustreKote compatable with 21st Century
  119. power panels
  120. uneven elevator throws
  121. OS .46 AX ABL Pitts Muffler
  122. CONNECTING BATTERY BACK UP ?
  123. B-36
  124. cessna with a tail wheel
  125. ANY GOOD RC SHOPS IN WAUKESHA, WI AREA?
  126. Flying in the UK
  127. Knight Twister Cowl & Magazine Article
  128. Lithoplate....
  129. Old lathe question
  130. RC Hobby.co.uk....Gone bust?
  131. Seagull Razzle
  132. Pilot Figure for P51D Miss America
  133. charging 12v battery through panel
  134. rascal forty engine upside down only?
  135. Brushless motor question
  136. AM Radio Gear
  137. Is this a good deal and for a Newbie?
  138. Williams Bros. 'Universal Cylinders' ? Anyone familiar with them?
  139. GP Super Sportster 60
  140. Pilot w/racing helmet
  141. 50sx in GP Super Sportster 40?
  142. Grinding Flats in Landing Gear
  143. Hangar 9 Skylane 150 horz stab
  144. 1 or 2 engine
  145. RCM Model Magazine
  146. Fueler valve question
  147. Tail Feathers and Polyurethane Glue????
  148. ENGINE SIZE??
  149. over flight
  150. What's Your Favorite Fun Fly Event ??
  151. Robart control horns
  152. There is nipple threaded in the back ???
  153. 3D propeller
  154. gluing to fiberglass...what to use?
  155. Dubro Pinned Hinges
  156. painting with acrylic
  157. Batteries
  158. Glueing With CA
  159. Remember when..............
  160. Need field Box
  161. Kyosho J3 Arf
  162. Browns Illinois fly-in
  163. I need help with destructive jitters
  164. Tiger 2 hole for nosegear wire on wrong side
  165. painting my F-16
  166. Radio South Pro driver III How many starts ?
  167. godfrey aircraft kits
  168. Hitec 5645MG centering
  169. Showtime/ saito 100 vertical dying
  170. O.S. 52 Surpass idling problem
  171. Extended Exhaust Tube
  172. Throttle servo spring Peeve
  173. torquemaster g-62
  174. What clear works over Lustrecoat?
  175. Yellow aircraft P-40 spinner
  176. About Diabolo
  177. HOW DO YOU PROTECT YOUR DECALS FROM PEALING?
  178. Enya SS40, idle adjustment?
  179. Solartex
  180. 1/4 scale servo
  181. covering a plane
  182. RETRACT SERVO PROBLEM
  183. making remote glo plug lead?
  184. Turn on transmitter first, turn off last - WHY
  185. Where can you buy Prince P tip props now?
  186. Bubbles and ripples
  187. Hard time taking off
  188. edge 540 wing incident
  189. WHICH SMOKE SYSTEM FOR SAITO 100?
  190. Choosing a belt/disc sander.
  191. SuperTigre muffler?
  192. Tapping Aluminium
  193. What has happened to RC Modeler Magazine?
  194. old control line rc conversion
  195. A Quick Prop Size question
  196. 4.8 or 6 Volts???
  197. re-sheeting foam
  198. What has happened to RC Modeler Magazine?
  199. local hobby shops
  200. youth masters 2006?
  201. Your Thoughts On a Modified Eagle?
  202. what causes bad range check
  203. Fiber V Metal hinge
  204. CG on a ATI B17
  205. replacing gears in servos?
  206. Running Temp of O.S 40 FP??
  207. 4.8v / 6v receiver?
  208. What is your piano wire soldering technique?
  209. Going away from "recommended" props
  210. fuel line placement
  211. extra 260
  212. Saito 82 fuel question
  213. Good plane hop-up site.
  214. What prop and spinner. Help...
  215. how can I protect my models from kids?
  216. smoke system for saito 100
  217. Help Covering!!! Dope 'n tissue PICs
  218. Reduce voltage 7v to 4.8 to use Lipos, anyone have?
  219. Big plane building board?
  220. How to start again?
  221. New (used) GP Piper Cub on floats
  222. Bending Piano Wire???
  223. 1st bipe, no plans, need HELP!
  224. MAGNUM XL28 ARNV
  225. transmitter mitten
  226. Where to buy Kavan glow plug?
  227. brakes ????
  228. ANy RC Store near San Francisco
  229. Servo Chatter (Help)
  230. balancing and fuel?
  231. Large Starter Cone
  232. glitch problem-something extra with 46ax
  233. Recovering fuel soaked plane
  234. worldengines enticer ?
  235. I'M Lost in my new Super Didg & 2700NiMH
  236. radio check
  237. wheel wells
  238. NICD or NIMH, WHICH IS BETTER?
  239. Foil Streamer
  240. Help me finish my Covering Scheme
  241. RCM status??
  242. finding this prop
  243. Gyros on Airplanes
  244. lustrekote
  245. trainer plan
  246. Ultracote vs solarfilm
  247. Ultra Stick and .51 Super Tigre
  248. Monokote--what's up?
  249. how to check incidence
  250. Fuel tank trouble
