PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Hooking up a 4-stroke!
  2. Saito 100 in a .40 plane
  3. plane stands
  4. plane stands
  5. RV - 4 .40 4 StrokeEngine Size ?
  6. Transmitters and Frequencies??
  7. Where to Recycle Field Box Battery
  8. Replacing CA Hinges
  9. Looking for AutoCAD drawings for O.S. 91
  10. Outdoor carpet for a Runway?
  11. programing trx to operate nose gear steering servo
  12. Any Penn State flyers here?
  13. glue
  14. Warped balsa building board
  15. can decals be covered with clear coat?
  16. Dual Servo Timing
  17. Twin engine position question
  18. Mechanical retracts
  19. CANARD
  20. What kind of glue?
  21. Webra .91 Engine
  22. Looking for the jeffco Aeromodlers in Denver
  23. Propeller Question
  24. KamDax MiG-15 Gas...
  25. trimming threaded rod ...
  26. Glitches
  27. Pull - Pull cable adjustment
  28. Hobbico Quick Field Charger MKII Settings
  29. flying fields in durham-chapel hill area
  30. A-26
  31. speed control question
  32. Shipping large models
  33. inexplicable dive
  34. How should I attach fiberglass cowl? tips?
  35. 9CAP signal
  36. ys 91ac instructin manual
  37. Tower Muffler?
  38. Where to fly in Kennewick,WA.?
  39. JR 6102 travel adjust vs D/R
  40. MRC SERVOS, help ! ! !
  41. Servo-receiver-transmitter/compatibility
  42. Looking for a 4-bladed propeller
  43. Directional Trim Changes With Speed
  44. 10 year resurrection
  45. Avistar wing....
  46. Three dead batteries
  47. Fuel Tank leaks
  48. Basic aerobatic instruction
  49. YS .63FZ?
  50. kyosho plane parts
  51. solid oak wing
  52. JR servo question?
  53. Kadet LT40- ARF
  54. futaba 9zhp-9zap
  55. please help with brushless setup
  56. Where to find aluminum cup washers?
  57. Something happened, but I don't know what
  58. 4 stroke vs. 2 stroke prop
  59. Why join the AMA?
  60. help,help please
  61. Duraplne 40 tail dragger
  62. HINGED CONTROL HORN
  63. which arplane may be right for a my engine magnum 28
  64. Where do you Fly???????
  65. Front gear door.
  66. sheet metal screws
  67. OS 40 LA Mount?
  68. vibration absorbing mounts worth the $
  69. mixing epoxy correctly
  70. flying boat video?
  71. Need Help With Battery
  72. aileron question
  73. Planes designed for gas engines
  74. Exhaust Pipe to Cowl Interference
  75. Another Prop Question
  76. Feild problems?
  77. 90 deg. Rotating retracts (Hobbico) problems
  78. gas fuel tank for glow?????
  79. Multi model radio Q&A
  80. CLAMSHELL NECESSARY?
  81. best transmitter straps
  82. grounding remote glow
  83. What is your real cost for RC?
  84. screwing into a fiberglass fuselage?
  85. Remote Glow connectors?
  86. mousse can pipe troubles
  87. ASP 91 Red Head Tuned pipe?
  88. Building Board help.
  89. What covering over foam?
  90. 1987 Expert Radio
  91. throttle linkage and throttle cut
  92. foam blocks
  93. Lights for my airplane
  94. 21 Century Covering Question
  95. brakes???
  96. engine mounting question...
  97. okay to use extension on battery wire?
  98. Spinner for OS .70
  99. how to make a propeller
  100. CG for Ultimate bipe
  101. Evolution 46
  102. You think this is underpowered?
  103. prop for OS .61fx
  104. MonoKote Colors
  105. How long a muffler extension?
  106. Needle setting on an Evolution 100 engine
  107. Something Extra ARF C.G.???
  108. RCM Magazine?
  109. Saito 1.80 carb question
  110. where is bob shattleroe
  111. Appropriate prop for .40 engine
  112. Tower Hobbies coupons?
  113. Un Gunk an old engine Help !!!!!
  114. MN flying clubs
  115. New ARF stinks like a musty old antique.
  116. bmfa b test
  117. Can you identify this onboard starter?
  118. F-16 built by Walkera
  119. 40 size plane for a YS63s
  120. Robart Retracts in Top Flight Bonanza
  121. Battery Requirements
  122. Anyone know a source for Bolly props?
  123. Item Sought, Battery failsafe switch- Help!
  124. Astro Hog Modification
  125. Vac-u-form windshield
  126. work at home?
  127. Windex with Ultracote
  128. WANTED JR F400 RADIO
  129. what size plane for my .25 OS?
  130. Hobbico Accu-Glo MK II ----- Question
  131. Smoke Systems?
  132. Sending an Email to Mike Mconville???
  133. Black Covering
  134. Kyosho Series 91, 7 Channel
  135. Hobbico Accu-Glow MK II
  136. Covering foam core wings -whats the secret
  137. Radio, Cell & TV Towers
  138. Choosing the right fuel
  139. Positive expectations
  140. Older Byron Pitts rebuild
  141. What does Saito mean by "Benchmark Prop"?
  142. except when it loops .......... SNAP
  143. Better Hinges Than CA?
  144. Covering question regarding Seams. Please help!
  145. Please id, SCORPIO, 3 channel 30-40 plane
  146. Best airplane for an OS 120S-SP
  147. calculating wing area
  148. Fuel tank with oneway valve?
  149. Muffler Extension Problem
  150. Old O.S. 91-FS Parts
  151. ABX owners - antenna question
  152. cordless starters?
  153. Monokote trim
  154. Plumbing Question
  155. LHS in RI
  156. New In The Box Old Radios
  157. snap roll
  158. Wall Chargers - Are they working?
  159. Dual aileron servos for GP Extra?
  160. Sealed hinges on GP Extra?
  161. scroll vs band
  162. Glow fuel storage
  163. Polyester Resin used fuse and wing construction?
  164. Who flies in Manvel?
  165. Polyurethane vs fiberglass resin
  166. Sig Tri-Star
  167. need prop help
  168. SAITO 72 PROBLEM
  169. Softening music wire
  170. Buddy Transmitter
  171. Futaba S3004 Servos
  172. Biplane vs Single
  173. Non RC Question about telephone install
  174. HI-TEC OPTIC 6 ?
  175. TT Pro 120 Low Speed Needle Adjustment?
  176. Acid Flux, where to buy?
  177. Mounts for wing-mounted wire gear
  178. SIG Astr Hog templates needed ...
  179. dust devil cg
  180. Gorilla Glue
  181. mode 1 or mode 2?
  182. Can't figure this out! Help!
  183. mother f**kin fuel pumps!!!!!!!
  184. GMS 47 glowplug
  185. Cartop carrier
  186. inverted my OS 65 now I have problems
  187. extra 260 landing gear
  188. thinking of buying New JR 10X, but all my planes have Futaba Receivers, compatible?
  189. Countertop recommendations?
  190. Ultimate R/C Aircraft CD Plans
  191. Drilling clean holes in Balsa???
  192. Where to Fly in the Bay Area????
  193. Is it safe to store glow fuel in the same compartment with gel cell and electric panels/fuel pump?
  194. Plastic/nylon bendable fuel tubing?
  195. Saito 1.80 question
  196. Sirius Quad, wont switch to maintenace mode on TX port!!
  197. Cajun R/C Website Check it out!
  198. I over revved my Saito on during break in.
  199. Shipping an airplane to canada
  200. Futaba ALVATR- servos travel is differant,
  201. Fuel oil ....
  202. kando40
  203. Parlor City Pilots
  204. What would a good first time kit to build be?
  205. Thunderbolt R/C Long Glo Plug Substitutes?
  206. PROP AND FUEL SUGGESTION FOR SAITO 100 ON A AT-6 TEXAN
  207. Can you change the shift of a receiver?
  208. SIG Skybolt CG
  209. f you have
  210. mufflers
  211. Paint Guns
  212. 3 blade props
  213. Top Flite P-47
  214. Not my
  215. Where to buy H9 Funtana
  216. Dremel Mini-Mite Battery
  217. 4 Cycle power VS 2 Cycle and mounting inverted.
  218. Is there an AM pico-size receiver
  219. Top Flight P-40 covering question,,,
  220. "Glassing" an airplane
  221. Tuned pipe design
  222. Help with Sullivan Smoke (Skywriter)
  223. Hinges - How free should they be?
  224. What Channel range are you in?
  225. Power panel + Charger wiring
  226. Spinner questions
  227. Import/Export tax
  228. CA or Pivot Point Hinges??
  229. where to buy ETOC winners' models?
  230. fuel tank
  231. What brand of servos do you prefer?
  232. Dummy Radilas
  233. status of the hangar 9 edge 540 1.20 size
  234. Pull pull on split elevator
  235. Removing ARF graphics?
  236. Is this loud sound flutter?
  237. Aluminum stock for landing gear fabrication
  238. moki 1.80 inverted problems
  239. BEST REC. ON PLANE CLEANER
  240. BLUEBIRD SERVOS?
  241. gas pumps
  242. Hobby Shops in Beijing/Shanghai
  243. Tail Gear for 1/3 scale
  244. Helium availability in Australia?
  245. Covering - Flame Graphic...
  246. Taking my planes overseas
  247. Some Basic Prop Questions
  248. Covering Foam
  249. I have built an onboard glow...
  250. Philadelphia
