PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. R/C history
  2. Ducted fans
  3. Dazzler engine thrust angle
  4. Engine Thrust angles on low wing planes
  5. Bad landings
  6. Receiver Battery Life
  7. Changing Landing Gear - Easy Sport 40
  8. OS 61 FS Series (4-stroke)
  9. paint questions
  10. Help
  11. 14 MZ Receiver help
  12. Tail dragger takeoff
  13. Afro-American pilot figure
  14. Re-covering control surfaces?
  15. Hindge gaps
  16. Your favorite tool on your workbench...
  17. Good starter kit for 13 Year old
  18. wing tube diameter. plz advice
  19. Wrapping fuel tank in plastic bag for fuel leaks
  20. Balancing question - TT Giles 202 .40
  21. Cleaning an old engine
  22. Field Box Battery Problem Charging
  23. Surefight website
  24. Hitec Optic 6 or Eclipse 7
  25. buddy box with Optic 6 or Eclipse 7
  26. Clubs / Stores in Arizona Scottsdale ??
  27. Covering question
  28. What is lighter than glass ?
  29. Which film covering do you you prefer?
  30. mini Funtana
  31. WANTED: Some Education in Fuel..
  32. pinning the hinges ...
  33. AMA and Insurance
  34. Dubro Pull/Pull help...
  35. Covering
  36. Nashville hobby shops
  37. Epoxy and CA
  38. Engine for GP Cap232?
  39. Where to find plans
  40. Park Zone Decathalon
  41. Programming Futaba 7CAP for Ultra Stick 60
  42. cutting flexible pushrod
  43. old planes
  44. *Dubro Adjustable Control Horn*
  45. Covering methods
  46. Servo reverse on FP-T7UAF, need for event on Sunday!
  47. Looking for "The Cutting Edge" Bi-Plane
  48. P51D by Seagull ARF
  49. pros / cons to hitec spectra
  50. MOVED: wireless rc camera Help!!!
  51. Joss Stick 1.09 on gas?
  52. figuring out low or high band receiver
  53. Putting OMEGA (gas) in a motor that has run Bryon ?!
  54. What plastics for glow fuel??
  55. Ultrasport 40 veers to left
  56. source for small 'pop' rivets?
  57. Sig Lite-Coat & Lacquer Thinner question
  58. Easystar servo noise
  59. Four Stroke Muffler Question????
  60. Servo setup for Springair Retracts.
  61. Saving radio data
  62. Prop choice for a GP Wagstaff & G-62
  63. Transporting big planes in small cars
  64. hangar 9 corsair retracts
  65. air brake mix
  66. How do you load an avatar?
  67. Which Futaba 9CAPS should I get?
  68. What's better?
  69. Tower vs. Horizon
  70. Aluminum land gear legs
  71. Ailerons & flap throws on 1/3 scale super cub
  72. Midwest Aero-Star 40
  73. 3 Line Fueling & Cowls
  74. World war 1 Biplane
  75. Control hardware
  76. Fuel jug fitting
  77. cowl chopping
  78. Uniflow fuel tank set-up
  79. Sig Four Star nose drops with rudder input
  80. OS 61 Hanno question...
  81. Correct Engine for Great Planes Gee Bee ARF
  82. how to repair stripped thread?
  83. Tower Glo Plugs any good?
  84. best way to clean engine
  85. Wanted: SIG AH Wing Templates
  86. Great Planes CG balancer
  87. filling the fuel tank
  88. Help in selecting correct speed controler
  89. Stit's covering
  90. Is rubbing alcohol safe for monokote?
  91. Antenna Question
  92. TF Cub Control Throws???
  93. B&D retract question
  94. upset buyer question
  95. Which Airbrush-Iwata eclipse or badger anthem
  96. Anybody know where sonic tronic went?
  97. Looking for picture
  98. Decision time: AeroMaster configuration...
  99. Goldburg kits
  100. Old RC TV Program Help!!
  101. No words for this (just watch the video)
  102. Transmitter Neck Straps
  103. CAn I use a rc car motor in a combat plane
  104. How do I transport aiplanes in my truck?
  105. Best Tach ?
  106. Fuel delivery problem with inverted engine.
  107. fuel line check valves
  108. Machine Gun Sound
  109. Beckman Concealed Actuators?
  110. wing tubes-where to get them?
  111. Monokote wringkle Expert, how to get it right? vs Oracover excellent!
  112. Elevator counterbalance
  113. cloth covering question
  114. *Prop To Big For Spinner*
  115. New Web Site
  116. Covering like a Bald Eagle
  117. FLUTTER problems flying the "U Can Do 3D"
  118. MOVED: OS 50 SX and prop question
  119. I need advice for bending 1/4" wire
  120. Hobbico Voltwatch question
  121. 3rd hole in fuel tank?
  122. Using different servos with NiMH packs
  123. Wing Area
  124. Control rod upgrade for GP Cessna 182 ARF?
  125. Sig Fourstar 120 thrustline V enginethrust?
  126. Building Surface Questions
  127. Northeast Engineering Power Panel
  128. GP Patty Wagstaff 25% wieghing in @19.5 lbs
  129. My prop keeps coming loose??
  130. Proper Tank install
  131. Problem with covering
  132. Fuel tank for OS .50 SX
  133. Burned fuel?
  134. Midwest Aero-star 40
  135. source for 'smoke' canisters?
  136. Tower Hobbie 46
  137. What painters tape to use
  138. gorilla glue quick fix??
  139. Stalling on powered dives!!
  140. Sig Kougars!
  141. ANOTHER Tower Hobbies question
  142. CA sensitivity. Any suggestions?
  143. O.S. 40 LA, Stalls out at 1/2 tank
  144. What is the best sealing iron??
  145. 2-Minute Flights
  146. CG Ultimate and what motor?
  147. On TF Cool Glove
  148. Webra and Bully mods...?
  149. rfi
  150. Has this ever happened to you with Tower Hobbies ?
  151. Two piece wing needs ...
  152. servo question
  153. battery question
  154. Plastic Wood (Trex) & Fuel
  155. MODELTECH MAGIC SPECS
  156. Hanger 9 Alpha Trainer 40
  157. Y Harness Volt Monitor and RX Battery
  158. *Turning An Engine Horizontal*
  159. 4 Star 40 Landing Gear Wipeout
  160. Aircraft Covering Design question
  161. McDaniel's MCD471 glow driver, battery?
  162. Glow Fuel what is the shelf life?
  163. On board starter systems
  164. Has anyone used Dubro's Super Strength Landing Gear?
  165. Giles G-300 wing repair
  166. Assembly Stand
  167. Electronics Question for JR Users
  168. EXHAUST PIPE HEX NUT 11M. (Don Harris smoke muffler)
  169. Ultra Stick .40 Airtonics programming guide??
  170. ULTRA STICK 60 MANUAL
  171. How to best set ailerons for neutral point?
  172. *Epoxy On Monokote*
  173. first crash repiring question
  174. Building on glass?
  175. Short life on Lipoly Batteries.
  176. .90 sukhoi
  177. Ok to swap out the 600mAh NiCd transmitter battery for a 1650mAh NiMh?
  178. Horizon Hobby Aerobird Challenger tips
  179. Radio Search help
  180. Funtana 40 fuel tank?????
  181. cowl for Cub
  182. Mixing fuel?
  183. Need Help On Somethin'
  184. Covering question
  185. Trying to identify this plane!!??
  186. CA glue - What brand do you suggest ?
  187. Motor mount
  188. Airplane stands
  189. Tinting a clear canopy
  190. Anodize Aluminun Spinner
  191. Buffing question on Acrylic laquer paint
  192. Is this a thrust issue?
  193. 3 aileron servos?
  194. Glue drop on canopy
  195. Stop wheel swiveling from CJM retracts
  196. O Ring failure; Smoke muffler
  197. Ultra Stick Lite 120 - Engine Thrust Angles???
  198. receiver crystal
  199. Plettenburg Question
  200. Buying from abroad into the UK
  201. Should I make the switch from MK to Ultracote?
  202. Do you have this page?
  203. depth charges
  204. Zurich Sunglasses-which color??
  205. how to repair cowling, please help
  206. covering scheme help!
  207. depth charges
  208. Poor depth perception
  209. n anyone help
  210. Soldering... Gun vs Torch
  211. building boards
  212. GP Extra300 40 engine choice; deadlocked
  213. Making your own Decals
  214. Type of wheels?
  215. Painting a spinner
  216. Super Dri
  217. What exactly is Nitro Fuel and how is it different from Regular Gas?
  218. Throttle Curves?
  219. Richmond Va LHS
  220. Oh no! I think my hinge points are loose!
  221. Making tail braces with just Kevlar thread and CA
  222. coast gaurd livery, red or orange?
  223. Covering Material Problems
  224. mechanical expo?
  225. How do you remove wax paper?
  226. 3d aerobatics pattern sport flying whats the dif?
  227. *Extending The High Speed Ajustment*
  228. does anyone know who makes this airplane
  229. using the 3 pin dean's connectors in my wings for servo connection
  230. Retracts in WM skyraider machII ?
  231. phx-link driver issues
  232. Anybody tried por15 for fuelproofing/clearcoating?
  233. Getting a 25ft UFO airborne.
  234. using a heat gun 4 covering ...
  235. Old fuel?
  236. Antenna Routing
  237. Glow fuel proof automotive paint
  238. Covering over covering
  239. positve vs negative expo
  240. Wife is on my butt
  241. question on fuel line T's...
  242. Hoping someone can help me out
  243. Fuel Proofer
  244. GP Super Decathlon
  245. Disappointment of the 1st kind
  246. !20 minuite Epoxy
  247. RC Flying field/club in and around Middlesbor/Pineville
  248. down thrust, right thrust question...
  249. old proline transmitters
  250. reciever battery
