PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. German Translation Needed
  2. Polishing Aluminum
  3. Who manufactures in China
  4. keeping monokote adhered to surface
  5. Number of flights?
  6. ducted fan starts
  7. making monokote and ultrakote shinny again?
  8. Wood Selection for Dihedrahl Brace?
  9. Thrust angle and placement in an aARF(other than recommended)
  10. Robart pump
  11. Concerning 15% fuel
  12. Looking for feedback on Radar Gun
  13. What does this size mean ??
  14. Sorry wrong place
  15. Flap knob used for nose gear steering
  16. Hobby shops and Paypal
  17. asp engine
  18. shiny covering
  19. Dual LiPo setup
  20. Spinner prop question
  21. I may have been dumb
  22. Rudder vs Aileron on 3 channel plane
  23. Servo Positioning
  24. us 60 fuel tank
  25. RC in Germany?
  26. Retracts for a H-9 T-34?
  27. Elevator, aleron, rudder leading edge cutting.
  28. Super Seven Programming
  29. Small Mejzlik props
  30. Reuse an airplane after 10 months
  31. Tampa Hobby Shops?
  32. Anyone know a reputable builder?
  33. to polish or not to polish ...
  34. Retract question
  35. Source for Powemaster fuel
  36. tail wires on faster planes
  37. Help CA hinge
  38. servo question
  39. AIRTRONICS "RADIANT" RADIO ... HEEEELPPP!!!
  40. MonoKote over Rustoleum – Comments? Tips? Traps? Alternatives?
  41. roo pic and video
  42. galaxy trainer parts helppppppppppp
  43. Deans antenna
  44. Are Hobbico 40-60 size retracts any good?????
  45. Wing Covering Techniques
  46. help
  47. Great service that I did not expect.
  48. 6 cell batterys?
  49. Stupid beginner questions
  50. Visit to Seattle, July 9 - 15
  51. Where can I buy this g-force meter?
  52. I have forgotten, help....
  53. get oil off wood to recover
  54. Nats in my eyes
  55. Repairing a busted up Cowl
  56. Distance Flying, Straight-Line
  57. Hinge Line gap?
  58. AMI Plans Service EL Forte
  59. EL FORTE
  60. Deals in China???
  61. servo direction
  62. Confussing propeller pitch
  63. In search of european model shops
  64. Automotive Paint
  65. castor/synthetic blend in Magnum fuel 5%
  66. Identify an old Stick?
  67. Thrust calculation?
  68. on board glow driver (expert egas 2)
  69. Flying club in Bedford VA
  70. Help picking a new plane
  71. Starter Inserts
  72. Gyro Use to improve tracking on take-off
  73. Solar activity-affect our radios?
  74. What is happening to kit building?
  75. new foamy
  76. playin with nittro
  77. Servo Play
  78. question concerning covering
  79. Servo extention problems?????
  80. Aviation Design F-16 Flight Set-up
  81. Is Lacquer Fuelproof?
  82. Digital Servos and Nicads
  83. SUPER SPORTSTER 20
  84. looking for a Maloney engine...
  85. OS26FS
  86. good way to chemically remove excess Canopy glue?
  87. thunder tiger giles.
  88. SlimLine Pitts Muffler for an Evolution 1.00NX
  89. Question about PETE MODEL CF SPINNER?
  90. Reversing Y-Cable
  91. Plane Enlargement
  92. Macs tuned pipe pressure fitting location
  93. Iron-On Hinges?
  94. Proper mounting of RoboStruts
  95. where to buy a cowl...for a Aeromaster bipe
  96. kyosho cap 232 .40 covering
  97. nverting from a Tric to Tail Dragger
  98. Spinner's and why they never seem to fit. (Help)
  99. Hitec Tx / Futaba Rx ?
  100. how to change futaba`s t6xas battery?
  101. Anyone know BillWill?
  102. Identify this plane
  103. Exploding Battery
  104. Pushrods
  105. flying field in cincinnati, Ohio
  106. OS Engines
  107. Mounting Motor on P51...
  108. Quality Tachometer offered by?
  109. Gear reduction staretr
  110. Enya 50 info....
  111. where do you guys route the antenna ?
  112. New Super Tigre G-90 vs Old... G-90 (Size)
  113. Does any one knows where can I download R/C videos?
  114. 30 min epoxy vs gorilla glue....
  115. Copyright
  116. Variable pitch prop
  117. PULSE JET ENGINE?
  118. Handmade/Custom Pilot Figures
  119. Park Flying in Orlando
  120. Can you Make your own wing jig????
  121. Fuel
  122. building boards
  123. Can anyone here repair a muffler for me?
  124. Help! Fouling glow plugs
  125. Stan's Fiber Tech # ???
  126. Futaba T4YBF radio question
  127. Weight of fiberglass
  128. does anyone know a good online store?
  129. Foam padding for high temp's
  130. decals
  131. cg on sky scooter
  132. Epoxy reaction
  133. CA Hinges(the correct way)
  134. Need help on choosing the right prop
  135. building boards
  136. Help with servo chatter
  137. What can spray paint to use on nitro float plane ?
  138. Trip to New York
  139. help me
  140. bad landing plane HELP
  141. pinstriping
  142. Help, CG for a Smoothie?
  143. O.S. .32 SX-H for airplane?
  144. P-51 trailing edge spliting
  145. What fuel for a Saito .56?
  146. twin elevator servos
  147. OS FS48 Surpass engine parts
  148. MOVED: charging Ni-MH batteries???
  149. RIT Dye over Testors Enamel??
  150. R/C or Aviation Stuff in the Ft. Lauderdale FL Area
  151. super tiger 3000 prop size????
  152. necessary tools for scratch building ...
  153. allergic to glue
  154. Please help identify bipe
  155. Anyone manufacture aftermarket carbon fiber wing tubes?
  156. High temp tubing/ rear exhaust motor
  157. latex paint
  158. Anyway to remove CA hinges?
  159. R/C Flying communities
  160. Crash question
  161. Pros or cons on inverter to run chargers.
  162. Quick field Charger instructions
  163. Painting Floats
  164. what kind of Table???
  165. Servo placement
  166. Hypoxy - Is there a way to make it thinner and more flowable?
  167. Top Flite EconoKote over SIG AeroKote ?
  168. Hobbico Dealer in NY City
  169. *New Color Scheme Needed*
  170. coverings...which are the easiest?
  171. Painting and Airbrushing?
  172. help with repair of wing?
  173. Top Flite T-34
  174. pilot for 28%
  175. Whoops...
  176. cut cowl with what?
  177. Flite Metal (Ed Clayman) Unresponsiveness
  178. Engine Storage
  179. Glow Wire Help? Please!
  180. Handmade/custom pilot figures
  181. Aluminum servo mount... anyone know where to buy this
  182. Fuel soaked wood, does it weaken it?
  183. Tip if your engine suddenly acts up
  184. Rear tuned pipe engines worth?
  185. another stupid question
  186. MOVED: Problem with Fuji 50 EIS
  187. 4.8v to 6.0v retract question
  188. quick field charger fuse
  189. Tell me what am I doing Wrong
  190. Accessories for Kobra RC-53
  191. Battery charger question
  192. need an on board rocket engine ingitor.
  193. How do I convert this logo?
  194. How do I convert this logo?
  195. I have a Futaba 4YF 4-Channel radio that is missing one of its joystick screw on knobs.
  196. 4-stroke Smoke system??
  197. Canopy question
  198. How to remove Monokote
  199. Where's the GLUE ???????
  200. Dubro spinner backplate slipping
  201. Is rustoleum clear glow fuel proof?
  202. Trimming out a windshield??
  203. heating problems
  204. Fuel Proof?
  205. Harmon Rocket Spinner
  206. Prop Pitch
  207. Question about OS 60FP
  208. need help finding replacement parts for Tower Hobbies Uproar
  209. Problem in buying the kit from sig or any other company
  210. Plane builders
  211. Lettering on Monokote
  212. Rudder pull pull dimensions
  213. Homemade Wheelpants
  214. Chrome Paint?
  215. Hobby Shops near Disneyland?
  216. Help with 300 motor
  217. Tapping Threads for Wingbolt?
  218. Right Thrust for 4*??
  219. Handmade/Custom pilot figures
  220. g26 engine mounting question
  221. Thinning Monokote trim solvent?
  222. What is control surface chord and control suface length,how these are measured
  223. plane stand for table
  224. Gorilla glue
  225. Please help me identify this airplane
  226. heat gun - which one?
  227. Can any one tell how to take readings of Max speed of an aeroplane model,Control Surface chord
  228. Nylon vs wood props vs fingers??
  229. FutabaS-9030
  230. TYpe of Servos used For RC-53 Kobra abd its numbers or Product Code
  231. OS 60 MAX H Muffler question
  232. Can I spray clear ultracote over G.P. striping tape?
  233. rebuilding a broken leading edge
  234. "Dopey" question
  235. Covering Technique
  236. Silicon Cowl Bushing / Fastener where to find?
  237. Inexpensive Shipping Carriers for Larger planes
  238. need help with JR631 transmitter travel adjustments
  239. What would be a good second plane but still has some aerobatics into it.
  240. Dean's ant
  241. Magnum .52xls or O.S .50 ringed
  242. PROP TO ENGINE
  243. plans for a topcat
  244. silicone and glow fuel ?
  245. custom cutters
  246. real answers about paint
  247. Transparent Covering: Any visibility concerns?
  248. Plane Storage System
  249. Who sells VQ Models?
  250. all in one power panel by Pacific Aeromodeling: advice needed
