PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Tower Hobbies - Pattern on discounts?
  2. overheating a pusher?
  3. Frequency scanners?
  4. MOVED: Hobbico charger - info wanted please
  5. aileron/servo/receiver question
  6. GP RV-4 Spinner problem for FS-70
  7. Checker Board Techniques??
  8. New OS 30 FS ....and a Question
  9. GWS Pico RX!?
  10. Holy ****...any idea what the heck happened here?
  11. Goldberg Extra 300 Canopy
  12. Du-bro fuel line barbs HELP!!!!!
  13. Blooming Glue!!!
  14. CA glues is there any difference?
  15. K & S Coil Bender?
  16. engine mount for funtana 90
  17. Fly RC magazine
  18. NICD/NIMAH Charger advice
  19. Aileron movement
  20. Trim painting blisters on a Waco cowl help
  21. Trans-Atlantic record fuel
  22. Engine starting without spinner
  23. Sealing Trim
  24. V tail direction of travel????
  25. Glues?
  26. Lancair Onboard Glow Driver for my Saito 100?
  27. GWS servos (too much play)
  28. what size fuel tubing for .40-1.10 engines
  29. Help Needed With HAL Autopilot
  30. Watt-Age Mad Dog powerplant
  31. Retract clip
  32. 25-10 3 Blade prop?
  33. Pneumatic Retracts
  34. Lubricating Pushrods?
  35. 9c and 9z futaba
  36. Extra vs Edge,,, the why and what's ????
  37. Good Hobby Shops in Manhattan, NY
  38. Hobby Shops in LA?
  39. rx and tx repair in Sydney Australia
  40. Uproar Kit vs ARF differences.
  41. Robart Problem
  42. Sanding Drum
  43. Needle settings for Thunder Tiger Pro .46
  44. Makinig Your Own Cabane Struts?
  45. Real-Flight G3 simulator multiplayer question
  46. Shop in Osaka, Japan?
  47. OS 120 surpass and non surpass difference
  48. Anyone know what kind of .061 this is?
  49. 1930 Fleet Biplane dummy cylinders
  50. Magazine
  51. what engine for tower Hobbies Uproar?
  52. Pitts S-2A .10 Need more info on this plane? Pics
  53. funtana 90 w/saito 1.20 engine mounts
  54. lithium Ion radio glitch
  55. Midwest Aero-Star 40
  56. Sophisticated Lady
  57. longitutde + latitude....of field and home
  58. Flying in Southern Illinois
  59. Lustrekote primer peels right off
  60. Weak landing gear on my sukhoi
  61. OS 60 questions
  62. unknown pattern plane
  63. 4C engine install on J-3
  64. Should I take a "step back"??
  65. Saito website?
  66. Thinning white latex??
  67. Need help with plane racks for trailer
  68. Where should I exit my annteanae?
  69. Project for a Saito 1.20?
  70. Expanded scale voltmeter question
  71. Pollution regulations in California???
  72. How to balance a 3 blade prop?
  73. prop?
  74. Seagull PC9 40
  75. I want a Stagger Bee!
  76. With What Can Fuel Proofer Be Used?
  77. Spinner sizes?
  78. Tinting the canopy
  79. Servo "Jitter" interferance
  80. I miss my old heat gun?
  81. what size spinner for a 16x6 and where?
  82. CHIEF AIRCRAFT, INC.?? Futaba 9C super
  83. SHOULDI APPLY LITE COAT OF EPOXY ON S. DECATHLON FRAME????????
  84. Nose steering for my jet?
  85. what type of paint to use on monocote?
  86. 1/5 Piper J-3 Cub Landing Gear Replacement
  87. Balsa Sealant for Painting
  88. Balancing the plane
  89. what size prop for my twist 3d
  90. Problem with trainer cord
  91. Magnets???
  92. Find a previous post
  93. Floquil jar and Iwata compatibility?
  94. servo glitching problems
  95. EPOXY THINNED WITH ALCH. KINDA RUBBERY WHY????
  96. help engine/feul problem sig something extra
  97. covering wing slots
  98. quick fueler question
  99. Do I really need a Tailwheel?
  100. First Manufacturer- Fibreglass & Foam kit
  101. Safety fence
  102. Servo Jitter
  103. Keep it simple stupid!!!!!!!!!!!, I'm trying
  104. Removing old silk and dope covering
  105. Flight characteristics... Trainer
  106. Haze on covering left by CA???
  107. monokote question
  108. Covering Wingtips?
  109. Help..need servo .. advice
  110. CA Shelf Life
  111. Polks Hobby Tracker Radio
  112. Saturday Night And...
  113. High rates or Low rate
  114. flexing control rods in a goldberg model 12pitts
  115. why no space shuttle rc ?
  116. Towerkote
  117. Easiest/best hinge repair?
  118. Sig coverall
  119. Help with Spring Air air control valve .
  120. Flying Fees
  121. Reedy Quasar # 610 AC/DC Charger
  122. Ultracote or Fabric?? ARGH!
  123. Cline Fuel System
  124. need to level horizontal fin...how?
  125. interference......metal brackets
  126. Sanding sealer and Prestain conditioner
  127. Changing from a regular servo to a mini servo
  128. Help!!How do you fly a Canard????
  129. Thinning CA
  130. Triming using Ultra-Coat
  131. Poltergiest???
  132. balsa grain?
  133. Just joined the forum
  134. Where to fly near San Francisco?
  135. 35mhz, which band?
  136. 51" wingspan and engines
  137. setting up the fuel pump?????
  138. Paint the inside or outside of canopy?
  139. Antenna Question
  140. where can i find TOC videos
  141. pica 1/5 scale cessna 182
  142. Glow Drivers............. Best value
  143. WEBRA Speed .91 muffler
  144. Monokote instead of paint on a car?
  145. Hitec Servo Arms
  146. Tailplane Struts
  147. Y Harness and Servo Glitch
  148. Receiver antenna wire
  149. feild frequency control board
  150. cutting out wing ribs
  151. I have a question about Airleron movement, Please
  152. where can i find the course of flight controller?
  153. Perry Pumps
  154. paint schemes?
  155. Can a propeller be redrilled???
  156. Trim tape for canopy
  157. Spring Air air system operation?
  158. j-bolts
  159. Used wrong charger
  160. Place to fly my plane
  161. Nose Wheel Steering Setup
  162. Tail dragger main gear placement question
  163. ICS Robin Hodd
  164. Anybody ever use rustoleum silver metalic paint?
  165. I HATE Bending Balsa Sheeting!!!!!!
  166. Clear over Latex??
  167. Monokote still has quality problems!
  168. Is there an engineer in the house?
  169. Covering Econo-coat Mono-Coat etc
  170. any good radial engines for ziroli planes?
  171. Servos for Skybolt
  172. how do I cut the prop holes in a 4"spinner?
  173. Digital Servos
  174. Fuel tank vent line optional?
  175. What are the best colour for "Sunnies" in different light conditions?
  176. A non steerable tail wheel
  177. AIR-Retracts POLL !
  178. Extra 300s by Ohio R/C??
  179. Help me find out what plane this is???
  180. Retract filler valve
  181. electric start for g-62 ?????
  182. Batery Capacity of a Slow Stick 300 Motor
  183. Need a field / club near Watertown (Fort Drum) New York
  184. Engine Interference
  185. Hangar 9 paint over Lustercoat primer??? everdoneit?
  186. Who Makes the Best Cockpits?
  187. Smoker fuel line melting at exhaust port.
  188. NEW TO ELECTRIC PLANES NEED HELP.
  189. Radio Interferrence with Metal Clevises
  190. Radio Interferrence with Metal Clevises
  191. Hobby Stores In NY
  192. Cockpit Piping
  193. monokote covering methods
  194. New Plane Recommendations Please
  195. "snapping out" what's the cause ?
  196. Do you know any 1/8 - 1/5 kit/parts selling hobby shop in Munich, Germany?
  197. Smoothing out sheeting?
  198. Is there a really Flexiable fuel tank material?
  199. Engine mounts and fuel control...
  200. Metalic Paint???
  201. Brass tubing hinges
  202. Anyone used LustreKote spray paint from top flight?
  203. Not equal elevator movement
  204. Covering with Koverall???
  205. Nylon Wing Bolts
  206. Won't Suck Fuel
  207. How in the world do you balancea prop HUB?
  208. What are exponential rates?
  209. split elevator
  210. runway lenght
  211. What prop ?
  212. Someone Willinng to Test Flight My plane?
  213. Trimming Shrink Film
  214. Quick charger for 7 cell Battery?
  215. where to find cowl
  216. HVLP Spray Paint System question
  217. Looking for an easy building, high quality kit
  218. Painting over Ultracoat
  219. steerable tail wheel
  220. glass cloth?
  221. Best Auto for Hauling Planes
  222. Any site better than Tower Hobbies out there?
  223. How to remove CA hinges?
  224. GP Skyboldt wants to spin!
  225. MOVED: Dual receivers
  226. Wing Incidence
  227. I need some help! 1/4 scale cub
  228. HAM License for 50Mhz range
  229. gapless hinges?
  230. Using Lusterkote Flat Clear over Monocote?
  231. Phoenix Models
  232. Wheel collar problems??????????
  233. Sig Aerokote
  234. ALUMINUM ARROW SHAFTS FOR PUSHRODS
  235. Decal Templates
  236. Tiger Moth
  237. T.T.36 prop?
  238. Attaching Fuel Line
  239. 4 Star 120 cowl
  240. Futaba Receiver compatibility
  241. Building the ultimate hobby room!!
  242. How do I plumb two tanks?
  243. servo placement ultra stick 60
  244. The C.G. on a avistar adv trainer 40 is 3 5/8"
  245. covering and painting Spacewalker II
  246. Looking to build a fuel tank
  247. Need info on retract article...
  248. Macs Header- Need to bend.
  249. 4 * landings
  250. motor for a hanger 9 twist 3d will it work
