PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Towerkote covering
  2. Flaperons, yes or no?
  3. Tower Promo codes - please-please add as you get them
  4. Source for Solartex
  5. Filler for abs cowel
  6. Looking for info about RC-flying at Italy
  7. Keystone heights Florida flying field
  8. Charging 6 volt RX battery
  9. capiche 50
  10. Engine mount fitting
  11. Byron AT-6 Canopy
  12. Need a better Starter
  13. How to repair a gas tank???
  14. Current draw of one std servo ?
  15. sig aerokote\ topflight monokote
  16. Sirius charger
  17. Cessna 210
  18. Control horn and Plate alignment.
  19. YS F-91AC and on- board glow starter
  20. Is Testor's spray enamel fuel proof?
  21. Hinge
  22. Tach......Yes or No?
  23. Front windshield for a PICA 1/6 scale Cessna 182
  24. Servo extensions & Y connectors
  25. 3 switches for 3 batteries?
  26. Glueing Ply to fiberglass
  27. How do You Sand?
  28. biplane, 4 aileron servo's how too
  29. Club improvements
  30. wanted, cheap flat working surface
  31. Attaching an air tank
  32. Aircraft or Airplanes
  33. Where to fly
  34. Starter Problems.
  35. What plane should I get?
  36. Balance question...
  37. Polyurethane Glues
  38. CG and Kit Bashing
  39. Help identifying a plane please
  40. Prop thrust in MPH??
  41. YS 91 Factory Settings?????
  42. What do you think of this statement?
  43. Pined hinges or CA hinges
  44. Wing load formula
  45. new company?
  46. Spinner and Prop Size
  47. HP VT21 (Austrian made) anyone?
  48. Engine recommendation for 4*60?
  49. rohm air retract fittings
  50. Mac smoke system?
  51. Engine tweaking?
  52. WARNING! Cleaning Transmitter Joystick Pots
  53. Magnet building boad?
  54. ? on atlas 25 mercurio gas engine
  55. OS La .46
  56. where to find a old engines value
  57. Engine flexible exhaust
  58. Converting Electric to Glow
  59. Sig Koverall Repair How to
  60. Rx Battery for Lancair?
  61. Pica 1/5th Scale P-51d help
  62. Lexel as Canopy Adhesive?
  63. Mac's Muffler for Thunder Tiger
  64. another fuel proofing question
  65. Need some glow plug education
  66. Worn out ARFs?
  67. Painting over dark colors
  68. A good all-around charger
  69. Dynamic Balsa Master Cockpit Kits?
  70. lights
  71. tuned pipes for XLS .46
  72. engine troubles.
  73. ula ula Bambula props
  74. trying to find a good field tote
  75. Marvel Mystery Oil?
  76. OS 7D Carby
  77. Coverings
  78. Got my new Funtana 90 Wing Bags...Wahoo
  79. Wood Screw Stripped In Plywood
  80. REcovering and old model
  81. Paint coverage - airbrush
  82. What plane has the worst memories for you?
  83. fuel tank location
  84. OS Carby Identification.
  85. hanger 9 cap 232 need help
  86. Top Flght Bananza
  87. T.V. at the Field? (Super Bowl!)
  88. can anyone help with repair?
  89. painting question?
  90. When I use a heat gun the edges of my covering curl up
  91. SC-53
  92. Trim question
  93. Should I feel bad?
  94. Throttle servo on 1/4 scale Nieuport
  95. Speed control help
  96. Hitec 5645s
  97. Trim ideas?
  98. Getting new members
  99. RADIO HELP>>>>>
  100. Airtronics radio question?
  101. "HOB P51D plans .29 to .40"
  102. Any good magazines still left for BUILDERS ???
  103. Recovering - How To Get Rid Of Adhesive?
  104. Monokote trim solvent?
  105. Engine mounting bolts
  106. Got problem with monokote !
  107. what type of covering material used?
  108. wire hangers?
  109. How do you install a fuel pump ?
  110. Sources for glass cloth
  111. covering questions
  112. Fiberglassing Canopy?
  113. t.v. show
  114. PAPER SERVO WIRE TUBES
  115. is kylon paint fuel proof?
  116. Futaba Trainer Cord
  117. ultracote
  118. Cell phones and RC signals?
  119. Soldering next to servos and Elec Motors "BAD" ???
  120. Any suggestions to reduce covering vibration
  121. transport rack
  122. painting over wood
  123. Aircraft Ideas?
  124. Determining the size of wing bags needed?
  125. Build a radio controlled Spitfire Magazine in the UK
  126. Hanger 9 P51
  127. Cosmo 25sr anybody else have/had one?
  128. 3 blade pusher prop
  129. Help, elevator servos running at different speeds!
  130. Smoke system a .82Saito on Decathlon
  131. prop search
  132. Where to get Wing Bags?
  133. Engine mount mounting question
  134. 3 blade pusher prop
  135. Figuring thrust, engine mount location
  136. axle shaft ?
  137. Keeping the plane clean in storage ?
  138. Can you paint 21st century
  139. Robo Struts - Getting the bushing in the tube
  140. Prop won't tighten
  141. Fingers or thumbs
  142. Flying wing in Indiana Jones
  143. Airtronics RD 6000 Newbie Question
  144. great planes extra 300s
  145. Cermark F20 Tigershark 60 Size
  146. Curved spars
  147. How fast can a trainer go?
  148. 40 size Ultimate Bipe ARF
  149. Stripe stick-um doesn't stay stuck
  150. Saw/Blades/Display Prop for F4U Corsair Kit
  151. Saito Carb to Fuel Tank Placement Help
  152. DA 50 vs Brison 50(3.2) Gas engines
  153. 3 Blade Prop for Moki 2.1
  154. Canopy Tinting Using Paint
  155. any new publications on how-to's and tips?
  156. Does anyone know???????????
  157. Building Board
  158. 3 bladed Propeller question.
  159. problem with steering on the ground
  160. Do You NEED to SELL your RC Stuff?
  161. Stupid Building Tricks!!
  162. Spinner size for APC 15x6?
  163. Quick question
  164. 2-56 sized titanium pro links?
  165. Ultracoat Covering-MatchingCream Paint
  166. CG location
  167. lanier f4 phantom
  168. light pink fuel tubing ??
  169. could you tell me what this means?
  170. Die cutting my balsa and light plywood parts
  171. How to size servos?
  172. prop balancing
  173. Question about wood filler.
  174. specs. for G 60 supertigre bluehead
  175. flight log for rc?
  176. Interested in Magnum .91 4-Stroke
  177. What's the smallest R/C Airplane
  178. Throttle Push Rod Connection........
  179. Best Razor PLane (Wil-Kro)
  180. Paralleld receiver packs
  181. RC Aircraft Flying Field with onsite hobby shop
  182. How to Trim Canopies
  183. Using Two Receiver Batteries
  184. Multiplex space scooter battery help
  185. Help
  186. Radio expo question......
  187. Painting nylon
  188. Batteries - "top up" or "discharge and charge"
  189. hobby cnc kit
  190. K&B 65 MOTOR
  191. 11lb Biplane with OS FS52?
  192. using switch to charge
  193. Why do you enjoy flying RC?
  194. fiberglass as doubler?
  195. lazerlizard
  196. What songs go through your head as you go through the sky?
  197. Hobbico TwinStar
  198. on board glow system
  199. What small desk top disk sander do you use??
  200. Brakes?
  201. whats a decent foamie
  202. Robart Hinge-Point "POCKETS"
  203. Fuel Proof Panel Pen
  204. Harassment of wildlife
  205. Hobby Dynamics Company
  206. OS 120 w/pump
  207. Control horns
  208. Fuel Proof Paint ???
  209. Quick Filler Position Question
  210. YAK Comparison
  211. Landing gear mounting
  212. Brushless motor problem, need help.
  213. Removing previous monokote
  214. Why apply fiberglass to an entire plane?
  215. TYNDAL A.F.B. FLORIDA
  216. scratch building seats
  217. Storage - I am running out of room
  218. Pins
  219. Help spraying Rustoleum!!
  220. Micro system question
  221. Paint compatability?
  222. Why?
  223. I need 2-1/2" spoked wheels
  224. Fuel tanks
  225. Covering fuel impregnated balsa
  226. Help!FUEL TANK SIZE?
  227. P61 60 size mechanical retracts recomendations.
  228. Goldberg Ultimate 10 300 Power train Questions?
  229. Piece O' Cake w/O.S. Max .10?
  230. Lettering
  231. Gas or Glow
  232. Flying To Music
  233. HK
  234. Arizona DR-1 C/G
  235. Looking for some Fiberglass!!! Help
  236. green guy glues 1st step of construction to plans
  237. Hitec or Futaba?
  238. HELP !DRILLING HOLES IN ENGINE MOUNT
  239. A Builder's Magazine?
  240. Top Flight Beechcraft Bonanza
  241. 4 channel radio with 5 servos what does this mean.
  242. Speed control Qs
  243. aileron differential question
  244. Great Planes F-14
  245. Hobbico Pro Torch II
  246. Monokote multi-colors
  247. Sig Kadet Senior ARF & Saito Question
  248. Plug in Wing Hardware???
  249. preventing loose connectors
  250. Hobby shops in Newark N.J.
