- Landing gear location on a taildragger
- Your Brand of Nitrate dope?
- Carbon Control Rods
- who makes these fuel pumps?
- Tailwheel Help PLease
- Monokote over Oracover
- Lanier Ultimate Pitts
- Engine cleaning
- Fixing hole in Fuse
- No Heat????????????
- Removing epoxy
- Clearcoat on Primer for fiberglass.
- 1st Time Using Point Hinges = LARGE Gap
- Coverig question
- question about cap strips
- White Monocote
- MOVED: Futaba's S3151 Digital Servo: a good choice?
- Radio Gear
- Covering old wood
- Whats the Best way to cut a cowl
- Putting a .91FX in a .61 size plane?
- Sig Kadet Senior ARF Taildragger Conversion
- Alienator or Stryker....???
- 4 blade props
- Nylon steering block question
- Folding wings
- tiger 75?
- Door closing mechanism
- Heat Covering How to Guide?
- Soldering tips
- Preventing CA Hinge Fogging
- water proofing/fuel proofing
- Propeller Question
- Dubro E/Z Fill Fuel Pump
- Control rods/linkages
- REGULATOR POSITION ON 6V SYSTEM?
- Carbon fiber arrow shafts
- RETRACT STRUT HELP
- plastic kits are to much money
- Propellers
- monokote over silkspan
- Gluing Carbon Fiber
- Looking for a Prop
- Does anyone have video of slow poke
- T-Pin Containers
- World Models Extra 300s - CG Question
- Royal D-17 Beech Staggerwing
- Covering help:)
- Good 2nd plane
- Looking for cheap fuel proof spray paint
- Camouflage Covering?
- Throttle arm shaft on G-62 ?
- Onboard Glow Setup
- Needle lengthening for cowl
- L.E.
- Bending retract wire legs
- the future of r/c airplanes
- Which gender is which? (for battery connectors)
- How many different fuel types?
- Sig Aerocote
- Cockpit/Winshield Trim?
- 4 stroke tank height
- matching covering
- 1/16" SHEETING ON WING COMMON?
- smoke system in .15?
- CG
- Prop Nuts
- Formation of 4 planes
- Rossi 91 F1
- White Crystals on edge of battery pack
- Making paratroopers
- Plastic Wheel Pants
- 35% Edge 540 Specs
- e would help.TT Pro 25 parts list
- Cutting foam from plans??
- Englargin Retract Wells in Wing ????
- How do you drill your holes square?
- Motor mount saito twin
- Ultimate 10-300 color schemes
- Removing Old Monokote
- Fixing Servo's in the Wing ???????
- Clean up!!!!
- thread size for glow plugs?
- What Diameter Wing Tube to Use?
- GP Super Skybolt Fuel Tank
- taube flying
- Best engine for Tiger 2
- Astro Hog Recovering/refurbishment
- Recomended Prop Sizes for OS160FX
- Finishing foam wing
- Flying sights around Altus AFB, OK?
- Glassing with Polycrylic instead of epoxy resin.
- Hand launch ?
- Need help to convince school about RC
- How Many Functional Airplanes You Have?
- Torn / Cut Lipo Battery - OK to use?
- Best 3 blade propeller for Pica 206
- fuel tank
- Wing loading
- Fibreglassing Questions
- Fly across Lake Michigan!
- Towerkote covering
- Flaperons, yes or no?
- Tower Promo codes - please-please add as you get them
- Source for Solartex
- Filler for abs cowel
- Looking for info about RC-flying at Italy
- Keystone heights Florida flying field
- Charging 6 volt RX battery
- capiche 50
- Engine mount fitting
- Byron AT-6 Canopy
- Need a better Starter
- How to repair a gas tank???
- Current draw of one std servo ?
- sig aerokote\ topflight monokote
- Sirius charger
- Cessna 210
- Control horn and Plate alignment.
- YS F-91AC and on- board glow starter
- Is Testor's spray enamel fuel proof?
- Hinge
- Tach......Yes or No?
- Front windshield for a PICA 1/6 scale Cessna 182
- Servo extensions & Y connectors
- 3 switches for 3 batteries?
- Glueing Ply to fiberglass
- How do You Sand?
- biplane, 4 aileron servo's how too
- Club improvements
- wanted, cheap flat working surface
- Attaching an air tank
- Aircraft or Airplanes
- Where to fly
- Starter Problems.
- What plane should I get?
- Balance question...
- Polyurethane Glues
- CG and Kit Bashing
- Help identifying a plane please
- Prop thrust in MPH??
- YS 91 Factory Settings?????
- What do you think of this statement?
- Pined hinges or CA hinges
- Wing load formula
- new company?
- Spinner and Prop Size
- HP VT21 (Austrian made) anyone?
- Engine recommendation for 4*60?
- rohm air retract fittings
- Mac smoke system?
- Engine tweaking?
- WARNING! Cleaning Transmitter Joystick Pots
- Magnet building boad?
- ? on atlas 25 mercurio gas engine
- OS La .46
- where to find a old engines value
- Engine flexible exhaust
- Converting Electric to Glow
- Sig Koverall Repair How to
- Rx Battery for Lancair?
- Pica 1/5th Scale P-51d help
- Lexel as Canopy Adhesive?
- Mac's Muffler for Thunder Tiger
- another fuel proofing question
- Need some glow plug education
- Worn out ARFs?
- Painting over dark colors
- A good all-around charger
- Dynamic Balsa Master Cockpit Kits?
- lights
- tuned pipes for XLS .46
- engine troubles.
- ula ula Bambula props
- trying to find a good field tote
- Marvel Mystery Oil?
- OS 7D Carby
- Coverings
- Got my new Funtana 90 Wing Bags...Wahoo
- Wood Screw Stripped In Plywood
- REcovering and old model
- Paint coverage - airbrush
- What plane has the worst memories for you?
- fuel tank location
- OS Carby Identification.
- hanger 9 cap 232 need help
- Top Flght Bananza
- T.V. at the Field? (Super Bowl!)
- can anyone help with repair?
- painting question?
- When I use a heat gun the edges of my covering curl up
- SC-53
- Trim question
- Should I feel bad?
- Throttle servo on 1/4 scale Nieuport
- Speed control help
- Hitec 5645s
- Trim ideas?
- Getting new members
- RADIO HELP>>>>>
- Airtronics radio question?
- "HOB P51D plans .29 to .40"
- Any good magazines still left for BUILDERS ???
- Recovering - How To Get Rid Of Adhesive?
- Monokote trim solvent?
- Engine mounting bolts
- Got problem with monokote !
- what type of covering material used?
- wire hangers?
- How do you install a fuel pump ?
- Sources for glass cloth
- covering questions
- Fiberglassing Canopy?
- t.v. show
- PAPER SERVO WIRE TUBES
- is kylon paint fuel proof?
- Futaba Trainer Cord
- ultracote
- Cell phones and RC signals?
- Soldering next to servos and Elec Motors "BAD" ???
- Any suggestions to reduce covering vibration
- transport rack
- painting over wood
- Aircraft Ideas?
- Determining the size of wing bags needed?
- Build a radio controlled Spitfire Magazine in the UK
- Hanger 9 P51
- Cosmo 25sr anybody else have/had one?
- 3 blade pusher prop
- Help, elevator servos running at different speeds!
- Smoke system a .82Saito on Decathlon
- prop search
- Where to get Wing Bags?
- Engine mount mounting question
- Figuring thrust, engine mount location
- axle shaft ?
- Keeping the plane clean in storage ?
- Can you paint 21st century
- Robo Struts - Getting the bushing in the tube
- Prop won't tighten
- Fingers or thumbs
- Flying wing in Indiana Jones
- Airtronics RD 6000 Newbie Question
- great planes extra 300s
- Cermark F20 Tigershark 60 Size
- Curved spars
- How fast can a trainer go?
- 40 size Ultimate Bipe ARF
- Stripe stick-um doesn't stay stuck
