PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Aquirred a kit from 1961
  2. Priming Discolored wood before monokote?
  3. kouger markII
  4. Aerobatics Websites
  5. Sounds funny,but where do I get Srews?
  6. HITEC Flash 5 trainer capability
  7. How to reinforece the landing?
  8. Goldberg Chipmunk and Sullivan Tail Wheel
  9. MonoKote glue change?
  10. How do you clean smeared monokote coloring
  11. R/C Flying in West Central LA
  12. Sanding Freshly Glassed Compound Curves?
  13. float landing gear
  14. Easiest way to remove monocoat
  15. can i use wing instead of stabilizer?
  16. Phone-in Weather Station
  17. Nylon Hindge Installation - getting it right!
  18. Wanted: DuBro Hub Caps
  19. PICA MODELS
  20. Taiwan RC Shops
  21. servo speed vs torque
  22. MOVED: READ ALL ABOUT IT!! Futaba's Newest Toy
  23. Females in the hobby???
  24. Know when to quit!!!
  25. Foward Air pick up ?????
  26. Thunder Tiger , problem with spares.
  27. Paint color match for UltraCote...
  28. Nonmember without frequency pin ??
  29. Servo tray
  30. Little Red Vac Vacuum Former
  31. giant scale planes (china model productions)
  32. Pull-Pull
  33. Super sterman 1.20 ARF from GREAT Planes
  34. Pro Smart Level to check incidence
  35. Alternative way to attach CA hinges
  36. need a plane for 2 kids....12 and 9 yo
  37. CA or Wood glue
  38. Sig S/E slow flying characteristic
  39. U-joint for motor mount instead of flaps?
  40. One aileron servo or two?
  41. GEAR DOOR HINGES
  42. Need help with tail dragger landing gear
  43. Global P47 -paint match
  44. Hitec to Hitec Buddy Lead
  45. Is building a constructive outlet for OCD
  46. maximize the RC radio range
  47. *Sea Level VS Power*
  48. Question about debonders
  49. plans
  50. Where is your favorite hobby shop and why ?
  51. Insulation between pipe and tank?
  52. METRIC AXLES????
  53. model airplane banners
  54. best Filler for cracks/fillets
  55. Engine size vs. Airplane weight
  56. Engine test stand.... what do you think
  57. HOW MUCH SHOULD I CHARGE TO BUILD AN ARF?
  58. MOVED: charging my 12v field gear battery
  59. pilot figures
  60. Monokote over Clear coat????
  61. Glueing laser cut parts
  62. pull-pull setup tips
  63. Sig areokote covering
  64. What skill level am I!??
  65. Removing wood glue?
  66. pushrod guide tubes
  67. Pushrod guides
  68. Pull Pull Servo Connections
  69. Monokote on ply
  70. Aileron Servo Extension Cord placement
  71. Warped aileron?
  72. shrike (.10) wing height?
  73. Incidence
  74. Bipe aileron setup?
  75. Trailer purchase
  76. Need help with repairs
  77. Simply question
  78. Scale Models
  79. ZDZ 60 or sachs 100cc
  80. P-15 MUSTANG
  81. What is this plane called
  82. painting plastic parts
  83. PROP BALANCER FOR 3-BLADE PROP
  84. how to build light
  85. Silicon molds
  86. Sig AeroKote
  87. Information needed making landing lights
  88. Problem with fuel tank screw
  89. Snow Skis
  90. Buliding a plane help is needed
  91. Engine thrust angles
  92. Laser Cutter questions?
  93. enlarging plans
  94. looking for cnc/ machinist
  95. TRANSPORT aircraft via RC network of travelers - Discuss idea!
  96. HOW do you identify different film coverings???
  97. Piper Cub Windows
  98. Please Help me!
  99. Where to get Easy Cote in US?
  100. Iron on hinges?
  101. Threading 4-40 Rod?
  102. Large Shipping box
  103. Covering with Aluminum
  104. Skies for taildragger
  105. Staying into it...
  106. Beechcraft balanceing act
  107. Aileron servo wires(help)
  108. A health issue
  109. Couldn't find the Sureflite Website
  110. Solartex Covering
  111. MOVED: TX question. PCM and FM receivers, Futaba
  112. Covering cowling?
  113. aerobatic trainer ?
  114. Polyester Covering Help needed
  115. Shocked at Shipping Prices
  116. Wives
  117. Shipping to Mexico
  118. Hardwiring fuel pump
  119. acceptable filler
  120. What happened to rubber bands quality?
  121. I am shocked ! what happened.
  122. Diference between...
  123. how do you calculate (blank) into inches?
  124. Help with fiberglass finishing.
  125. 1949 Piper PA-16 Clipper
  126. Stupid wheel axles twisted...should I switch to oleos?
  127. 4*120 dimension
  128. Tail heavy aircraft
  129. How many coats for a cowl
  130. Fueler
  131. New Covering
  132. Countdown to crash?
  133. b-17 engines
  134. Ricks RC airplane Clearwater, FL
  135. Hobby Shop Question...
  136. Which iro-on Covering Works Best for a Painted Trim Scheme
  137. rockwell b-1b
  138. OS 70 Surpass II or Saito FA-72
  139. Can't get air into Robart retracts
  140. ANY CLUBS IN OR NEAR DALLAS,TX?
  141. Pull-Pull Control
  142. Saito 91 inverted mount - Fuel usage
  143. how to convert scale?? 1/4=?
  144. LEARNING TO FLY IN FORMATION
  145. Great Lakes Trainer
  146. cooling heads
  147. micro servo for throttle
  148. Gluing the canopy on
  149. Help with Aerotow !!
  150. Futaba update questions
  151. Are you retired/unemployed/kids?
  152. Great Planes Super Sportster with a .90?
  153. Monocote vs Oracover
  154. Covering a Sig Craftsman Kit Cub
  155. 3 & 4-bladed props
  156. painting foamies
  157. Spinner cutting into prop
  158. All this plugs and connectors etc... what is what?
  159. Fiberglass Painting Nightmare
  160. Knoxville TN Hobby Shops
  161. CG
  162. Painting 33% Cowl Help
  163. Painting Question - How to paint so it looks like polished aluminum
  164. Building my own FighterBird Wing....
  165. Starter motor weak, new battery
  166. Glow plug problems
  167. Anhedral
  168. Saito 4-stroke disassembly
  169. Covering Foam Wings ~ ideas ?
  170. Strobes & Folding Wings for F4U Corsair
  171. 7 millimeters = 0.275590551 inches
  172. os bgx-1
  173. century jet retracts
  174. * * * Converting degrees to inches ! ! * * *
  175. Pull Pull cable contols
  176. Painting over covering
  177. How can I remove Lustrecoat from canopy?
  178. In-cowl muffler
  179. Glow powered glider, folding prop?
  180. Is there a flying field in Cozumel Mexico?
  181. Fiberglass coating on bulsa?
  182. B & D retracts
  183. covering 1st plane
  184. super chipmonk fuselage
  185. servo horns
  186. How to figure out what cc engine is?
  187. trim covering?
  188. 2-56 0r 4-40 Rods?????
  189. Stans Fiber Tech
  190. What kind of Spray Plane is this?
  191. Tailwheel Question ??
  192. Help? For Sale?
  193. Foamie anyone?
  194. Plans on CD
  195. Using Clear lacquer on Covering?
  196. Onboard glow problem?
  197. Draganfly Predator
  198. CONVERTING ELEC. TO GLOW
  199. Paint Question
  200. Cowling vs. Muffler on a Funtana S 40
  201. Leaking Robart Cylinder
  202. Dual Aileron Question
  203. Having problems landing my 4*60 in a crosswind
  204. Fokker eindecker Looking for wheels 3 3/4
  205. Trim Question -- Airplane Wants to Climb
  206. How far will you go to stay to fly?!?
  207. Tailwheels
  208. Fuelling Valve
  209. keeping the plane clean
  210. retract servo
  211. Pump question
  212. paint
  213. HELP WITH UNKNOWN JET PLANE
  214. Covering Tapered Fusalage Surfaces?? Solartex...
  215. Magnets
  216. Simulated Corrugated Metal
  217. Landing Strip
  218. Kit Box + Powerpanel question
  219. Glue Question
  220. West Palm Beach modellers...please read
  221. Flaps on Sig Kadet LT-40
  222. Which is the best MPX receiver for 3D and aerobatics???
  223. soldering tools
  224. Cutting hinge slots in hard wood?
  225. vmar arf 10ft beaver
  226. Decals
  227. Gluing an "extention" on to an existing firewall
  228. Decathlon or Cub?
  229. tail heavy bipe
  230. Ever heard of Rich Uravitch?
  231. Graupner Extra 300S Help!!!!
  232. nitrate dope
  233. *Where To Get Custom Made Decals*
  234. Who cuts foam wings?
  235. Matching Ultracote colors
  236. Help buy servos for Funtana 90
  237. can you use white glue????
  238. Homemade prop materials
  239. Radio Interference from Florescent Lights?
  240. WING / FUSE JIG
  241. Three questions: Tach, engine orientation & paint
  242. Adhesive backed sandpaper & T blocks
  243. Lustrekote?
  244. Kit Bashing to a taildragger
  245. Aerolgloss dope cracking
  246. 4.8 or 6.0 volt battery with 1/4 scale servos?
  247. foam genius - where are you?
  248. Tail dragger for Kadet Senior?
  249. Using a slightly large clevis
  250. What size nose gear?
