PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Recreating mono/ultracote colors on your PC
  2. How to find a new home for Superpoxy, Hobbypoxy, and some Ultrapoxy
  3. Who can identify maker of this CAP 232 ?
  4. An Ugly Duck?
  5. Skymaster 336 Cessna
  6. homemade mousse can mufflers how are they made
  7. Any Ideas for 3+ mile distance flights for Super Cub?
  8. 2nd Plane?
  9. 3D Passion allround
  10. Little Bit Slow
  11. MOVED: How to charge Li-Poly
  12. MOVED: inverted 2 stroke 40 size engine,which is best?
  13. MOVED: Transmitter Problems!!!
  14. Spraypainting covering
  15. Engine size comparision
  16. How to go 6V?
  17. Hangar 9 Simulator Software
  18. Calculate CG
  19. Good old wood glue
  20. Converting H9 Ultra Stick 40 to Tricycle Gear
  21. Dremel scroll saw
  22. Getting Into Custom Graphics?
  23. Info about Ron Jocelyn´s Culver Dart..
  24. Gluing brass or cooper exhaust extensions
  25. Charging the field battery via the panel?
  26. Need Help with heat skrink film
  27. Great Planes Spinner
  28. MOVED: OK Fess up everyone!!!
  29. Best Colors in the Air
  30. Butterfly or Not a Butterfly? That is the Question
  31. What percent nitro....
  32. Aeromaster Bipe control throws?
  33. *Glue joints on old planes*
  34. In-cowl priming
  35. Moki 2.10, small diameter fuel line
  36. ultimate chaos?
  37. Plane for a YS53 4 Stroke
  38. Braided Wire Isulation
  39. bolley wood props
  40. JR AND FUTABA CONCERN?
  41. Short Solent FLAPS ( SUNDERLAND)
  42. power panel electronics
  43. Car NiCad packs for starter?
  44. Access Door Latchs
  45. value of older plane stuff
  46. good first time cap 232/540/Sukhoi ?
  47. Winterizing Planes?
  48. How do I get in touch with David Hayes
  49. Who sells a 10.5 x 7.5 propellor?????
  50. Trailer owners?
  51. Reversed Polarity?
  52. Spring air retracts and controlling gear deployment
  53. Top Flight nylon props
  54. Baking Soda & Epoxie
  55. schematic for reversing a jackscrew?
  56. MOVED: cd question
  57. Jay Jay the Jet plane (My son is making me ask!)
  58. Radio interference at your field?
  59. Frequency boards
  60. Sig Senior Taildragger conversion?
  61. Need info about Tucson area flying fields
  62. solartex vs coverite
  63. prop for homelite 30cc engine
  64. props
  65. Gas motor
  66. Funtana Pro
  67. Saito 65 Questions
  68. RIP IT OFF?
  69. Swizzle Stick No Loopie
  70. tantrum
  71. Pica models
  72. Wing Repair
  73. Buzzing Battery
  74. Tail Braces
  75. Multi Task from Single RX Channel
  76. Coverite Fabric question... seams lifting.
  77. On Board Glow
  78. SHAPED WING STRUT WOOD
  79. Saito Engines 120 to 180 Conversion
  80. 2 Stroke vs 4 Stroke
  81. AERO SPAN COVERING
  82. Static Thrust vs Actual Thrust
  83. PROPER PROPS?!
  84. carbon fiber gear delamination
  85. ceramic piston/liner for OS 0.46 fx ?
  86. Small servos..... 40 +/- oz in of torque
  87. LANIER LASER 200 CONTROL PROBLEM
  88. Need b.h.p. ratings on a Magnum XLS52 and Evolution 46NT
  89. Ca glue and accelerator… Myth or fact?
  90. GP magnet building board
  91. Panel Lines
  92. Modes
  93. Nitro and Gas
  94. .25 for P-51D Mustang 20?
  95. clear coat over decals...
  96. Dentist type work light
  97. Plane Too BIG?
  98. 2 Stroke v's 4 Stroke Engines??
  99. I need info on CG and tank local
  100. 72 MHz scanner?
  101. SKYGLAS P-47
  102. Flaps
  103. What went wrong with my extra sports 30s?
  104. Identify this brand of retracts
  105. Where can I buy Spring Air Retracts
  106. tank location
  107. Prop reemer
  108. profile fuselage repair
  109. Clancy Ascender EPP Wing
  110. Hitec Eclipse 7 vs Hanger 9 Ultra Stick
  111. Expert Servos
  112. HInge Points
  113. MOVED: covering a float plane
  114. ME-109 House of Balsa - CG and throws
  115. in flight engine problem
  116. percent and aircraft
  117. battery charging question
  118. OS FS-120-SP Supercharged Help Needed
  119. Hanger 9 T-34 mentor and a Magnum XL 91
  120. Affordable vinyl cutter for home use
  121. monokote over lustrecote?
  122. Advantages of Zinger Pro props?
  123. Test Stand?
  124. Pull Pull Set-up Question
  125. Third Plane...
  126. Teach newbe to cut angles in balsa
  127. Why bench run your engine?
  128. servo extensions!!!!
  129. Where can I find plans for a Snoopy Dog house?
  130. Good Candy Drop Airplane
  131. Nelson Clear Coat question
  132. Inflight Horizontal Stab Failure on H9 Aresti 40
  133. Wire
  134. Epoxy Removal Question
  135. 3 Questions about engine + covering + kit
  136. Best Hobby Shop within 5 or so miles of Santa Monica
  137. Smoooooth operating retracts
  138. Help with pneumatic gear control valve
  139. Polyurathane clear for silk & silkspan
  140. Removing Old Monokote
  141. OS 46 Glow Plug
  142. YS 1.20 check valve
  143. Control surface throws
  144. sullivan - th starters
  145. Gorilla Glue and foam questionf
  146. profi motors?
  147. CA and heat
  148. Changing bearings in a Moto Tool?
  149. engine cleaner
  150. How to re-attach lost landing gear?
  151. Cowl for a stick?
  152. My silly question for the day!!!!
  153. Dead RX
  154. Quick prop question
  155. Help with Sig Koverall
  156. Rudder play
  157. How do I get rid of the edges on my stickers?
  158. HELP!!!Transmitter may be possesed!!
  159. Which engine has same mounting hole size?
  160. glass resign
  161. Proper Fuel Line Size
  162. Can I put MonoKote over UltraKote?
  163. Larger Fuel Tank changing CG?
  164. erratic flight
  165. "cracked" wing
  166. Paint question!
  167. Baked on oil
  168. Cutting ailerons from foam wings
  169. Macs Smoke System???
  170. *Fuel Soaked Balsa*
  171. Multiple servos for elevator?
  172. New plan-Hanger 9 Twist or Ultra Stick 40
  173. Noisy Engine
  174. New To 1/4 Scale
  175. WHAT SIZE OF PROP?
  176. How to get a local field started...
  177. Blue Plastic Field Box?????
  178. Painting a foam airplane
  179. COVERING ON OLD PLANE
  180. GP .40 Cub Cowl
  181. Engine Starter, what to use. need help
  182. Hobbico Top Fueler Mk III Electric Pump
  183. Too much elevator ? Rolling...
  184. Bending LG wire on landings
  185. Prop recomendation needed
  186. spacial cover for painting
  187. Need help with flying wires
  188. retracts
  189. Wanted: O.S. Needle Valve Ambly 40G
  190. CENTER OF GRAVITY QUESTION
  191. 40 size best choice
  192. OS-90fs with pump?
  193. Any tips for REMOVING Ultracoat?
  194. sterling models mighty mambo plans
  195. First time w/ gasoline
  196. Smoke systems & Smoke fluids
  197. * Balancing a Goldberg Ultimate Biplane *
  198. * Covering around the cabanes on a Goldberg Ultimate biplane *
  199. New kit from Great Planes????
  200. Who makes a good "on-board-glow" driver system?
  201. Dubro Heavy Duty Pull Pull Question/Help
  202. OS FS120 Engine
  203. Prices
  204. 2nd plane
  205. Metal ro Metal Connection !!!!!!!!
  206. CG on my CAP 232
  207. Telemaster Senior (Help Needed)!
  208. FutanaS 90 & Saito 150 What prop?
  209. how to hover an airplane
  210. Good Smoke Kit for Giant Scale
  211. Prop Ratios 13-4 to 13-6 ?
  212. vacum forming
  213. Question for those in the Everett Wa. area
  214. BB and epoxy weight
  215. How do you balance APC props?
  216. Magnum rfs 80/91 same mounting holes?
  217. Strange Servo Behavior
  218. Evolution prop pitch?
  219. Which hinges should I use?
  220. Ultimate Bipe
  221. Cowl problem
  222. Wax Paper for Plan Protection??
  223. Having a CG problem...Help?
  224. Anyone fly in Irvine, CA? especially Electrics?
  225. foam cutters
  226. looking for the right prop
  227. Who makes this thing?
  228. fin How to cut a cowl?
  229. Amount of epoxy to use while sheeting
  230. Big Stick 40 Engine
  231. Tiger Stick 40 Rolling Too Slow
  232. Designing Own Retracts
  233. futaba cr-2000 charger?????
  234. Please Help I dont know what I have
  235. Ultimate Bipe: fuel mess!
  236. *Streamline Canopy Needed*
  237. Enlarging prop hole. Drill or ream?
  238. IMAC Sportsman sequence?
  239. Sterling F-51 Mustang plans
  240. bouncing elevator???
  241. what ARF could i build with these parts?
  242. First tail dragger questions
  243. How to sell a design to a manufacturer
  244. Is this a fuel delivery prob. or an engine prob??
  245. Plane wants to climb on takeoff
  246. What Glue?
  247. Hobbico Power core with car battery charger?
  248. MOVED: Poker?
  249. Painting questions
  250. Frequency Channel Pins
