PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Frequency Channel Pins
  2. Audio file of a Radial engine starting.....
  3. venus prop
  4. Right thrust Vs. Left thrust ?
  5. *Recovering A Plane*
  6. superfabric covering?
  7. Lustrekote compatibility
  8. Engine trouble
  9. Why is there all that blood on your RC equipment?
  10. Greene County PA flying clubs
  11. SIG Something Extra kit vs ARf
  12. Sig Somethin' Extra
  13. windshield washer pump as glow fuel pump ?
  14. fuelproof paint for coro
  15. Stuka flying videos?
  16. Trainer Cord Quandry
  17. removing cured Epoxy?
  18. scanning and converting to cad file
  19. Focke-Wolf 190 D9
  20. PT20 - CG Location?
  21. Hobby shops in savanna Ga ?.
  22. SIG Somethin Extra
  23. COVERITE TURNING DULL
  24. Flying in Oklahoma???
  25. CG Question
  26. Paint question
  27. Robart Robo-struts on a 1.20 Ryan STA
  28. servo wire extension
  29. need crankcase for a rossi .61 df engine
  30. Cheapest place to buy RC airplane items
  31. Futaba Exp, D/R Programming.... a Little help please
  32. autonomous UAV
  33. Need help getting fuel tank over CG - See pic
  34. Hangar 9 F4U Corsair Flaws
  35. Small Gap Filler
  36. Need to add tail weight -help please
  37. Front landing gear
  38. rubber ducky ant.
  39. deflectors...do they hurt performance?
  40. conecting batteries with a y harness
  41. stupid question?
  42. CG on a Lowwing
  43. Battery Voltage / Charger Discrepency
  44. sig something extra
  45. Time for some safety checks...
  46. Buying JR radio equipment
  47. SCR?
  48. Allen Screw Heads ???????????? HELP
  49. Stinger Wing Tip Smoke
  50. Glow Plug Types
  51. Super Tigre G75
  52. Question for the experts!
  53. Pacer glue
  54. substitutes for old products
  55. Covereing bottom wing question
  56. (NEWBIE) Does a lower wingloading number mean it can fly slower without stalling?
  57. Peeling MonoKote... am I retarded ?
  58. Wood glue or Epoxy for wing halves and firewall?
  59. Where to get Aileron Stock?
  60. My very first set of carbon fiber landing gear, question concering paint
  61. COG for Minicraft Bucker Jungman
  62. Senior Student
  63. How much does a Dubro 3" light weight wheel weigh ???
  64. Robostrut 650 mounting question...
  65. make my own smoke coil?
  66. What do you use to weigh your planes?
  67. one hold down bolt?
  68. How do you determine what size 4S will work
  69. responce time
  70. 2 blade to 3 blade prop equivalent
  71. Great Plane Christen Eagle Ailerons
  72. Clear coat fuel proofing
  73. Correct thrust angle
  74. Futaba recievers with JR radio
  75. side mount engine and in cowl muff
  76. pica enterprises inc
  77. Problem with RBCKits
  78. Balsa USA Pheaton 90
  79. O.S. FS91 SURPASS II-PUMPED
  80. My wife is throwing me out...
  81. How do you get CA residue off monocote?
  82. Ever Seen Axle Separation?
  83. Handibond CA gel??
  84. servo reversed?
  85. Antenna survey - How Many use rubber duckies?
  86. Flying sites
  87. FIRST GAS ENGINE
  88. O.S. FS-70s fueling?
  89. Top-Flite Corsair with Gremlins
  90. how do I fill in a big space
  91. Futaba 3010 Servos
  92. safety issues
  93. Plug In Wings, Yes or No?
  94. K&B Conundrum
  95. Enya .53-4C
  96. Nitro & Ultracote
  97. WHAT HAPPENS WHEN YOU FLY WITH YOUR ANTENNA DOWN?
  98. most versatile engine type/size
  99. Repainting an ARF kit??
  100. It's like a 4 star
  101. Scale sizes?
  102. rounded or squard TE of control surfaces ?
  103. Repainting an ARF kit?
  104. 5mm X 3" Cap Head Screw
  105. What is it?
  106. Covering wing question/ Herr J3 Cub
  107. someone asked about different p-51 paint scheme
  108. Sig Kobra Owners and fliers
  109. Tapered Wing Dihedral Measured to Where?
  110. Gas problem PLZ HELP?
  111. custom harness
  112. Setting wing and thrust incidence
  113. Setting wing and thrust incidence
  114. Mechanical retracts/servo question
  115. DPM Extra 330 L Review
  116. How much is this all worth?
  117. Computer Made Graphics
  118. Painting Question
  119. RE: ringed/non-ringed
  120. What is the most difficult R/C vehicle to learn?
  121. On-board generator
  122. ring/no ring
  123. tower hobbies tuned muffler?
  124. Goldberg Decathlon Manual
  125. wing loading?
  126. Need Paint for Plastic Parts Please
  127. GMS RC Engines
  128. cross-post, spinning
  129. Thin CA Pours too fast
  130. CG for Kyosho Superstearman .40
  131. Landing Gear
  132. supterstar-30 knife edge flying?
  133. Covering alternatives
  134. spinner instead of prop nut for performance
  135. Great Stuff! spray foam for repairs?
  136. any one ??any club or rc air fild in.....
  137. TF lustercote paint!!
  138. URGENT => 3W-240 Ceiling?
  139. CG Question
  140. Tower Hobbie engine/radios
  141. Which "Size" (60 Size, 40 size...?)
  142. *Inverted Engine Problem*
  143. How do you transport your planes?
  144. tailwheel
  145. G2 lite question?
  146. Looking for Champion 45L (Thunder Tiger) plane/parts
  147. Hobby Store in Cincinnati
  148. Flap control rods
  149. Andy Lennon
  150. odorless cyno advice?
  151. Reshape fiberglass
  152. WHAT IS THE BEST DARNED FLIGHT SIMULATOR !!!
  153. COmputer Power SUpply with Triton HELP
  154. Mylar template material
  155. Magnum .61 RFS ?
  156. Fuel level indicator?
  157. Gorilla Glue
  158. McDaniels RC Glow Drivers
  159. Do Monokote Trim Sheets Shrink?
  160. RC Airplane Magazines dating to the 50's
  161. ?on ace add a trickle
  162. Max 4-stroke for cap?
  163. u can do 60
  164. Retirement time Looking for place to live?
  165. What is the right motor angle?
  166. Opinions on scaled-up Hog Bipe?
  167. fuel pump/can
  168. wing bags
  169. Waco YMF-3 1/6 scale questions
  170. How to set up a flying club?
  171. Plans for Ultimate bipe?
  172. PRO LINKS - BALL LINKS AND LOCKTITE?
  173. Ft. Worth Texas R/C Aircraft Clubs
  174. Is this plane overpowered with a .40?
  175. Engine for a 10lb biplane
  176. Cleaning engines
  177. Field work tables
  178. TF Mustang muffler
  179. A book about Biplanes?
  180. landing gear
  181. Hays engine mount screws
  182. Italy radio controlled aviation parks
  183. Need a Head for Webra BlackHead .61
  184. Mystery Biplane What is this thing?
  185. MOVED: great planes 182 problem
  186. Thrust or HP, what's more important?
  187. Bending brass tubing
  188. What should be my first plane?
  189. Radio questions? Wrong forum?
  190. Prop wash?
  191. servo torque???
  192. Tuned pipe
  193. Changing transmitter frequency
  194. Aerobatic maneurs,where online?
  195. Cajun RC website??
  196. [Deleted]
  197. PCM receivers and Digital servos
  198. bubbles in covering??
  199. Thrust angle on GP .40 Cub
  200. Super Sportster Help
  201. Painting fabric
  202. NASA's RC Legacy ((photos))
  203. RS Systems MIG-27 Flogger
  204. Moving Engine Forward
  205. What does a tail heavy plane do?
  206. Can't decide...2 battery packs for Tigershark with retracts or one?
  207. getting elevator or rudder to return to neutral
  208. Has anybody put retracts on a super sportster 40
  209. OS 46 AX on a 11X6
  210. how do i lower the tank
  211. SU-31
  212. Servo flutter/hesitation what now?
  213. Do I need an on-board ign.??
  214. kwik-fill valve?
  215. Shielding external servo's
  216. 21st. Century paint
  217. what type of paint should i use...
  218. Magnetic Building Board?
  219. Balancing My Tiger 2
  220. Canopy striping tape help please
  221. Graphics
  222. Matt Chapman question
  223. How to get a tighter fit in servo horn
  224. How to paint fabric
  225. Plans for wing jig Where can you find them?
  226. Biplane Question
  227. how to mount the mount engine that is
  228. Pin Hinges
  229. Hanger 9 Cap 232
  230. wing tubes
  231. Who makes pneumatic tires?
  232. What kind of Airplane is this ?
  233. Changing Frequency
  234. Epoxy question
  235. What kind of plane is this?
  236. Smallest, lightest NiMh's
  237. Alpha tail wheel conversion
  238. Foam, Depron, Extruded Polystyrene ??
  239. NexSTAR Engine Removal
  240. RAM lights
  241. NexSTAR Bubbles in Fuel Line
  242. Internal Rudder Control Rod Help.
  243. Help; I CAed my tail wheel
  244. sig 1/5 scale cub
  245. Vibration problem
  246. Shrike photos and question
  247. Prop Questions
  248. Pull Pull Angle of Deflection?
  249. Electronic Ignition
  250. a question about foam core wings
