PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Pull Pull Angle of Deflection?
  2. Electronic Ignition
  3. a question about foam core wings
  4. Aileron Differential
  5. 1/4 20 Hand twist bolts
  6. engine test stand ?
  7. Tachometer Problems
  8. Ultracote glue
  9. Tank Plumbing
  10. no warranty
  11. Pre-Flight and G2 lusbInterlink controller
  12. scanning our frequencies
  13. Proper procedure to trim out a new plane
  14. Any tips on finding a lost plane?
  15. Multiplex IPD Synth' Compatible ? Futaba
  16. What motor is this?
  17. CA Glue
  18. Need help with painting tips
  19. Mounting Retracts in Foam Core Wings...?
  20. Monokote white paint
  21. Dial / Digital Calipers
  22. LG Funkiness
  23. Need help in engine selection!!!!!
  24. ultracoat and compound curves....advice
  25. Broken receiver antenna
  26. WHAT PLANE SHOULD I GET!?!?
  27. Engine size for a Goldberg Tiger 2?
  28. Covering - Killing off airbubbles
  29. 1.6 FX Engine props?
  30. Minwax Covering Question????
  31. Recommendations on Sport plane
  32. Monokote white paint
  33. Need help with this covering scheme
  34. 4 stroke fuel vs. 2 stroke
  35. PLEASE HELP ME!
  36. Servo Connecyors
  37. ESM Sukhoi
  38. Too Many Servos???
  39. accucycle battery question
  40. What would you ever NEED 9 channels for?
  41. Airplane Storage
  42. How do I get out of this one ?
  43. Slec tanks? dodgy?
  44. Airtronics radio and futaba reciever
  45. stinger 120 motor & smoke
  46. Ground control Cessna 182 40
  47. Removing Vinyl Graphics??
  48. OS 91 s II low end needle valve?
  49. Who has quality fuel dots?
  50. Aileron Flutter while on the ground
  51. Wax over Monokote
  52. Still Having Hard Time with Sprayer!
  53. Hobby Shops \ RC Clubs in Chicago Area
  54. ultracote
  55. Painting a plane
  56. Cap outline
  57. Fiberglass cloth fraying
  58. Fellas,Where to get lots of EPP or EPS FOAM?
  59. CG for ACE RC WIZARD 40 ????
  60. fuji electric starter for 32b
  61. looking for a fiberglas cowl
  62. hinge tape?
  63. How do I contact Hanger_9??
  64. LA 40/4*40
  65. Can I paint microballoons/filler directly?
  66. What plane for Enya 35
  67. What runway do you prefer?
  68. Extra 300s
  69. engine size need help
  70. Pilatus PC9 - Looking for more colours
  71. Plane choice for ST 2000
  72. Cordless starter conversion
  73. propellor advice
  74. Glow Fuel Question
  75. Where to Fly close to Lansing, Kansas?
  76. tiger moth
  77. Best Flightline Equipment?
  78. So what company is the worst?
  79. Muffler keeps coming loose
  80. .40-size Extra 300 engine choice
  81. Home Made Runway?
  82. Engine Sizes
  83. Anybody Use Super Tacky Glue?
  84. servo repairs
  85. futaba tech support not much help
  86. OS .61 max sf weight
  87. Setting Control Surfaces On New Plane
  88. Air Fields in Northern Virginia
  89. Servo and battery guidelines?
  90. Filler Application
  91. small receiver in giant plane?
  92. Clunk Question
  93. Pull Pull Rudder - Rods or Cable?
  94. In-line Fuel Filler
  95. Saito 120 on a GP Super Skybolt?
  96. Zenoah G26 on the goldberg Ultimate
  97. Naples, FL Flying Fields
  98. CA Glue, how long does it last
  99. the simple one :)
  100. Dubro Heavy Duty Pull Pull System Installation Trouble
  101. simple series 400
  102. Monokote Trim
  103. Is Vinylwrite out of Business?
  104. **Wings**
  105. Tips on spraying emulsion/latex paints?
  106. sticky hinges
  107. Ammonia to twist thick balsa
  108. Hobby Stores in Southern California
  109. Removing decals from Solartex?
  110. To sell, or not to sell. That is the question!!
  111. Ace cloud dancer 60 kit
  112. Epoxy question
  113. Looking for Flying Sites or clubs in Watkins Glen ,NY
  114. Best Receiver Battery Charger & Conditioner
  115. Solid Propellent Rocket Engine in Trainer!!!
  116. Reception range problems
  117. douglas tbd-1
  118. engine size ? please help
  119. Engine size for Kantana 140?
  120. how many clubs have this flier?
  121. 6 volt Rx battery
  122. which are best?
  123. Building board recommendations please
  124. Covering won't stay put...
  125. Downthrust...NEEDED?
  126. Engine Mounting question ?
  127. moki 135+hanger 9 funtana 90?..
  128. custom graghics
  129. Tee shirts???
  130. Silver vs Aluminum (U-Cote vs MonoKote)
  131. D A N G E R - Scam - W A R N I N G
  132. Matching Engine, Prop and Plane?????
  133. horizonal stab incidense help
  134. incidence on the hor...stab
  135. IMAA Requirements
  136. Covering or painting foam wing?
  137. Looking to subscribe to a magazine; What do you subscribe to?
  138. Funtana .40 - Engine Brand and Size ??
  139. incidence on the stab
  140. CG for Super Stik
  141. pinning the hinges
  142. what engine for 90 size edge?
  143. Car fuel on .25 Airplane Engine ?
  144. Variable Pitch Props
  145. De-bonding a plane
  146. which is better
  147. 2 1/2" aluminum spinner for 16X6 APC
  148. Greatest Achievement in Modeling?
  149. futaba radio AM / FM for training
  150. edge seal for monokote
  151. Shock Flyer Question
  152. C bends for control rods
  153. Applying Decals
  154. Vinly Graphics Supplier?
  155. Balsarite (thumbs up or thumbs down?????)
  156. heat shrink question
  157. "Tractor" powered Kangaroo
  158. horizontal fin question
  159. Funtana W TT 91 4stk Need help!
  160. Orange County California Flying Fields
  161. Where to fly in Richmond VA
  162. Using Flecto Varithane for fuelproofing cabin
  163. Which rubberized CA is best ?
  164. Need help identifing aircraft ?!?!?
  165. Plots of power absorbed by props of various sizes and rpm?
  166. First Place 1.3 CI engine in a Ryan STA ??
  167. Wood Glue
  168. Painting a cowl
  169. Balance Point
  170. crystal swapping Hitec Rx to Futaba Rx
  171. CG problem on my greatplanes Ultimate.
  172. Servo Reversing by rewire?
  173. WRIGHT FLYER
  174. Fibreglass wing fairings
  175. Velcro for battery
  176. Does anyone know what this plane is?
  177. fiber glass covering
  178. Shipping Plane
  179. Proper assembled model shipping
  180. what plane is this?
  181. CG Question
  182. Four Star 60 Receiver Antenna
  183. removing/gluing doped fabric
  184. U control to be turned RC
  185. Help with CG and prop size
  186. Perry Pump VP-22SG
  187. learning aerobatics
  188. Proper charging
  189. Cessna Plans
  190. Any flying sites around Alexandria MN?
  191. Battery Chargers
  192. frequency bands
  193. Laminating Aircraft Ply
  194. How realistic is an electric conversion?
  195. LustreKote Paint?
  196. Where so I find Info for a Cirrus HS-874 Receiver?
  197. How much space do i need to learn to fly?
  198. NEED TRUE WEIGHT OF MOTORS???
  199. Black Head
  200. Prop size for Tower Hobbies 46 on Fun Air?
  201. Please Help "Acro-Wot" Engine ?
  202. Will my Cap 232 be happy with Saito 100?
  203. control surface settings
  204. orange blossom
  205. Monokote temperatures?
  206. APC Props...Balancing
  207. Good deal or not????
  208. Using Expo Rates versus point mixing
  209. Why is the engine cocked to the right?
  210. Realflight (Original) vs Realflight G2
  211. Why are APC props so heavy?
  212. What plane?
  213. Ringed 2 Cycle Break In
  214. swizzle stick 40
  215. 4* 60
  216. koveral,, clear dope,,Why???
  217. Can anyone identify this plane (Ugly Stik)?
  218. fuse plug and foam core wings
  219. OLD Futaba Contest 7 Radio....is it upgradable?
  220. hobby shops in miami??? please help
  221. Anyone Using - TOP GUN REMOTE IGNITER???
  222. Anyone Else Experiencing Fuel Line Corrosion?
  223. old OS 120FS HELP!
  224. Prop question
  225. Glow plug
  226. Fuji BT-50SB Engine will not Start HELP!!
  227. internal control horns????
  228. goriila glue or bust
  229. Ideas for storing RC planes?
  230. Test Fuel tank for leaks
  231. GSP P47 What type of retacts to use?
  232. in-flight adj. Propeller
  233. MOVED: Who fly,s at home?
  234. Construction Manual for a B - 17 G
  235. Where Do I get the Metal Battery Stips for Futaba Radio?
  236. What shall I put into the Chris Foss Wots Wot Bi plane?
  237. CA Debonding balsa?
  238. Solder Clevis
  239. mechanical mixer
  240. Frequency Control Board Stickers?
  241. Setting up pull pull
  242. T-28 cockpit
  243. engines
  244. Wheel Pants
  245. TME Simple Smoke Pump II
  246. Too Many Planes?
  247. What type of fuel tubing goes inside the tank?
  248. AM radio still allowed?
  249. Difference w white monokote
  250. Covers for servos mounted on wings...
