PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Worldtex finishing
  2. Model Airplane News
  3. re-covering top-flite P-40
  4. Coverite 21st CenturyFilm
  5. clear aro?
  6. ubec problem
  7. smoke systems
  8. RX Battery Voltage
  9. model airplane restraint
  10. model airplane restraint
  11. Retract Servos
  12. Wing bag material?
  13. Engine Identification
  14. 3D Flying & Normal Regular Pattern Flying same time
  15. 1/4 20 bolts: Metal versus nylon
  16. looking for high temp muffler ext tubing
  17. Mds 48
  18. Os 91 ?
  19. Nylon clevice
  20. Ohlsson and Rice Ignition Engine
  21. Converting a Futaba 4YF transmitter to rechargeable battery pack
  22. OS 91 fs
  23. Control horn backing plate
  24. spark plug wire issueon my
  25. Radio & Servo and Tailwheel Retract Cylinder Question
  26. Intro & Nitro T-28 Trojan Question
  27. EVOA100 Optical Ignition Kill Switch Feedback
  28. hawker tempest/typhoon
  29. recycling
  30. Cheap and good radio and reciever
  31. But what size pack?
  32. Wing Servo Mount Kit
  33. Routing 2.4 gHz antennas
  34. converting from nitro to gas
  35. Paint and monokote do not match
  36. Hobbyking trainstar tough electric problem
  37. too good to be true??
  38. The real deal on voltage
  39. Aircraft Balance
  40. Engine surging
  41. Which Primer??
  42. Magnum .52 glow carb problem
  43. Pawnee question, or flap question.
  44. what wire to cut
  45. Are 8411 and 8611 Gears Interchangeable?
  46. Why most modellers prefer left counterclockwise turns with their planes?
  47. Aerobeez MSX-R and DLE 35 R alingment
  48. Re-linking more than one plane on my transmitter.
  49. Best cold weather flight pack
  50. Laser Cut Servo Tray
  51. Original Swizzel stik question
  52. Electric retract install?
  53. Tamiya Acrylics and Klass Kote?
  54. Scroll saw, band saw or other?
  55. to add flaps to main wing of aGREAT PLAINS spectra
  56. ok got a ew futaba 8fg super now i want to transfer my settings from my 6ex ?
  57. Flat Black F-117; Alternatives to Monokote?
  58. Pattern vs. sport propellers
  59. eflight xtra
  60. Aroma Therapy?
  61. Getting back into RC: Looking for advice/warnings
  62. Wing Servo Hatches
  63. Covering with silk and dope
  64. evolution 10cc gasser??
  65. Is it really 18 channels?
  66. 60 size P-47 OLEO STRUTS
  67. Saito 150
  68. Futaba T8FG switch servo throw adjustment
  69. SmartCut blade adjustment
  70. Flyzone Nieuport 17
  71. Sunny Hobbies
  72. Question on Servos
  73. Question about Model Airplane Weight Limits
  74. Aileron Authority
  75. The BEST 4 stroke fuel ??
  76. blue E Z balancer question
  77. Aileron + Elevator + Rudder or Flap Mixing for F117?
  78. Super Tigre engines/parts. Who else is still waiting?
  79. qx300 quad
  80. Question about Epoxy Turning to Crystal Gel?
  81. Golden skies RC????
  82. please help me with my LED's
  83. Pilot Figure has lost his head!
  84. Saito .72 low speed needle
  85. Can you help me identify this giant scale landing gear????
  86. What to use for ding filler
  87. Throttle will not go to tick-over
  88. Identify S motor, cant remove cylinder
  89. Need some help finding Aluminum block material
  90. frame material.
  91. SIG LT-40 ailerons
  92. YS FZ115 Sport quits in flight after 2-3 flights
  93. connector?
  94. brand new to rc universe.
  95. bob Johnson giant scale B25 canopys
  96. best batteries
  97. Corsair F4U Cowl Mounting Question
  98. Whackie pull-pull horns, Do-Bro
  99. New Nitro Engine Revving Up and Down
  100. Chart of HP vs RPM for APC props?
  101. How long can battery leads be?
  102. Servo lead change out, will it damage them
  103. Will Clear Butyrate Dope Yellow?
  104. DLE 30 ignition sensor
  105. Adding Weight To Balance
  106. Poly-Lite versus Dacron???
  107. Need Help to Find out what a Older Scratch built model is
  108. One radio- multiple aricraft
  109. Covering
  110. Pilot for Sig Somethin' Extra
  111. tail group support wires
  112. Dave Brown motor mount shims?
  113. DLE 20 - how much thrust angle?
  114. Slow stick and brushless
  115. Epoxy question
  116. Leviosa F3A
  117. can any one tell who makes this plane and model name?
  118. Cold ca glue???
  119. How do I get Decals, Stencils or color for and on fabric
  120. Micafilm Questions
  121. Foam jet 3d model files
  122. have you seen this hogbipe? i miss it.
  123. night flying
  124. ASP 61 4 Stroke running funny
  125. One aileron servo twitching?
  126. Hobby Shops in San Antonio TX??
  127. Devcon 5min epoxy problem
  128. Flying fields/clubs in and around Salvador Brazil
  129. Historic RC Cartoons featuring faceless person(s) at the field
  130. I totally screwed up my bi-plane parallelogram jig
  131. DUBRO Spinner
  132. Ripmax WOT 4 Xtreme ARTF .... What Servos/
  133. Sullivan Smoke Issues
  134. Flat foam tires
  135. TF P-47 60 ARF Smoke System?
  136. Looking for "Bird" foamie plans
  137. Can't upload photos
  138. GP Revolver 70" Which engine
  139. What side of the fence are you on?
  140. R & K super chipmunk
  141. Micro vents/louvers for cowl's
  142. Colour Codes for UltraCoat and Monocoat????
  143. Aurora 9
  144. Solo Props...Good, Bad or Ugly???
  145. My Review of the Flyzone F4U Corsair
  146. R & K super chipmunk
  147. Good cleaner for monokote?
  148. Best High Wing Model for a 20cc gasser ?
  149. What model is this? I have no idea what it is.
  150. hinges
  151. I got the 46 FX Blues
  152. muffler interchange
  153. Funtana 125
  154. Futaba 14SG, R7008SB and S.Bus
  155. Nelson (South Hertz) Intelligent Glow Driver Users
  156. Dle 20
  157. FM Radio question
  158. Can you help me identify this pair of gasoline r/c airplane engines??????
  159. kaVan starter
  160. Performance between Low Pitch Props vs High Pitched Props
  161. Bec went on fire
  162. Need a thingy to make plugging in my aileron and flap servos easyer
  163. Vess prop
  164. 4 Stroke Break In
  165. Newbie to cowled engine
  166. engine mount for an os 200
  167. Stampe Control throw question
  168. Hobbico power core starter pack
  169. Fuel Filter question
  170. Any plug makers here?
  171. Problem with Top Flite Giant Scale P51 ARF
  172. Is this enough motor?
  173. Source for Clippard Urethane URH1-0402 Air Line Tubing
  174. trickler and charger
  175. Wrold engine s16 servo for qu. airplnes.
  176. F4U Corsair 1450mm (New)
  177. What section would I post this tutorial in?
  178. mystery kit
  179. balancing a mid wing
  180. Is it a bad idea to......
  181. R/C Eye Strain
  182. Single bolt prop adapter - cut down prop shaft while still on engine?
  183. Mystery Plane - Need some help please!
  184. Dle-20-ra
  185. DLE 30cc
  186. Smoke pump questoion
  187. Lipos in a futaba transmitter
  188. RC Plane Engineering
  189. Momentary loss of control
  190. Not liking my Hobbico Starter
  191. Como Engines- a little history
  192. Krill 35% Extra 300
  193. What Motor would you use? Airfield P47
  194. Custom flyable propellers
  195. Anyone ever bent their own tail wheel wire?
  196. C A Glue
  197. so upset with my futaba t6ex
  198. Builders
  199. Inverted flight and nose diving
  200. jr 9303 servo travel
  201. Robart Electric Conversion kit infomation?
  202. Futaba FASST receivers
  203. Saito 4 stroke gasoline engine create big interference ..anyone knows why ?
  204. Electronic EXPERTs! Is there a way to TEST servos and detect problems early?
  205. gopro users help!!!!
  206. CG placement
  207. How many flashes in the pan have you seen?
  208. ASP 1.60 twin flooding, fuel regulator?
  209. Protec servos
  210. Aluminum spinner question
  211. fuel proof paint
  212. dummy radials
  213. new bisson muffler for 55 ax
  214. Hangar 9 Aileron servo died
  215. Tractor/ Pusher props
  216. Propeller efficiency 2 vs 3 blade props
  217. motor starter power
  218. sullivan starters increase in price?
  219. OS 120 Pegasus cleaning
  220. Neodymium magnets and radio interference
  221. balincing a bipe with out instructions
  222. Flyhobbies.com
  223. asp 91 2 stroke in hobbico super star 40
  224. to lipo or not
  225. battery charger, which one?
  226. Access old threads of mine
  227. Twinn k Gyro I Balance Point
  228. Replacement Canopy for Dynaflite Chipmunk
  229. How to replace broken control horns on dynam T28?
  230. asp engines
  231. tachometer
  232. Sheeting Giant Scale open framed wings - what glues are best? Suggested techniques?
  233. Notifications
  234. Klass Kote
  235. Fusion 67!! profile
  236. Re -do's
  237. Need help with Futaba buddy box problem.
  238. Solartex ?
  239. AGM 30cc gas engine
  240. Compatibility between HiTec servos and JR receiver
  241. wing tubes
  242. Goldberg hold downs discontinued; substitute?
  243. SwitchGlo onboard Glow Driver
  244. Lustre Kote on Neutral Solartex
  245. What kind of plane and who makes it
  246. Saito FA125 squeal sound
  247. C.g. Help!
  248. Webra 10 ccm
  249. Tactic servos
  250. ot but need help n gyro controlled front foam airboat wing
