PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Who Makes The Best Tail Trap
  2. Manual
  3. Need Advice on Repairing Kyosho Corsair Cowl
  4. Shelf life of fuel
  5. How to make LE extensions
  6. Hayes Fuel Tanc Assembly?
  7. Minwax Polycrylic, how fuel-proof?
  8. Verifying solder quality with DMM?
  9. MOVED: Electric to Glow conversion
  10. Carbon Fiber - How fuel proof
  11. Sanding Block?
  12. Bending control rods
  13. PAINTING MONOKOTE
  14. Covering help please
  15. I could really use some help
  16. armorall in fuel?
  17. Water mixed with Fuel?
  18. How to get the glue off?
  19. Magnetic Building Board?
  20. what rubbers to use??
  21. MOVED: How to post pictures on RCU
  22. Transparent Covering
  23. space between aileron and wing
  24. Mixing fuels?
  25. Smoke mufflers?
  26. Tacho
  27. Wood dowels - what type of wood to use?
  28. Installing nylon hinges
  29. What grit sandpaper for final sand?
  30. Help with old Irvine engine
  31. prop selection
  32. prop selection
  33. RPM tach
  34. Fuse Building Hints
  35. Ho to derive wing area of a scaled down plan?
  36. Econokote on ABS, and matching Monokote
  37. prop selection
  38. where can I get detailed nitro powered rc paraglider Autocad drawings? Thanks
  39. 60 Size Big Stick
  40. coverall and dope
  41. Pusher prop/engine question
  42. Need Forensic help on weird crashes
  43. Firberglass finish with paint - help?
  44. Bladder type or long range fuel tank
  45. Flying in a open park.
  46. Two-tone covering woes
  47. Quick CA question
  48. Hinge Question !!!!!!!!!!
  49. CA hinges installed too tight
  50. covering../ trim / design question
  51. Float flying with a canard
  52. midwest cherokee
  53. Expert Digital Glow Driver
  54. what do I use for decal fuel proofing
  55. Moki 2.10
  56. Charge jack?
  57. Help w/CG and fuel tank location, giant scale!!!
  58. Nylon screws for landing gear?
  59. soldering threaded steel clevis
  60. 6 or 8 channel radio?
  61. Fuel Help Please!
  62. Where do I fiind Control Line Forums
  63. another prop question
  64. I NEED HELP WITH SELECTING FUEL TANKS!
  65. 4 Stroke Prop Mounting
  66. battery checker plugged into a y-connector?
  67. NEED WING PLAN FOR PT60
  68. Using Spray Paint From Can
  69. RETRACTS
  70. where do I find a part number
  71. Best colors?
  72. TowerKote vs. MonoKote
  73. supertiger 2000
  74. did I break my engine? OS .46 AX
  75. CA glue and Epoxy quality
  76. Antenna inside or out?????
  77. Repairing sheeted foam
  78. 4* engine
  79. Four stroke oil spray/residue question.
  80. Wheel Pants
  81. Lost Dealer
  82. Need an Electric Motor
  83. R/C Model Airplanes clubs in New Milford, Connecticut
  84. Where can I get DECENT rubber bands?
  85. comp arf 2.6 yak, extremeflightrc 87" yak
  86. Balancing a Bipe.... HOW???
  87. Switch size question
  88. Surpass .26 4 stroke question
  89. Remote carb adjust retrofit???
  90. I want to build some support for radio
  91. Flying field locations
  92. Enya 60 parts
  93. Estimating wind velocity
  94. Great Planes F15 Eagle
  95. Inverted 46FX not running well...
  96. Do you know any pro cowl painters????
  97. Lowering idle speed of .40 LA
  98. Crashing - Which is worse?
  99. Sealing wing and fuselage
  100. Spinner Reaming Question
  101. 2-56 screws 1 inch or longer. Can't find.
  102. Cline regulator
  103. GWS Beaver
  104. foam core wings
  105. Hanger 9 mechanical pump
  106. What Is It?
  107. Can You Use Jasco On Balsa??
  108. Latex Fish Eyes
  109. Royal 40 muffler screw replacement
  110. 40 sized bipe?
  111. reversing Y harness
  112. Radio South CA Hinge Question
  113. Landing Gear wire
  114. Telemaster trimming question?
  115. K&B Ultrapoxy, Value?
  116. What prop? Moki 210
  117. Free Style Rush by ESM
  118. Can I use a Hitec transmitter with Futaba RX??
  119. What Mode Do You Fly?
  120. antenna
  121. Great Planes Cessna 182 .40
  122. Piper Cub with Norvel 15
  123. Need a builder
  124. LED for Onboard Glow?
  125. Receiver Identification
  126. Receiver Identification
  127. Tail Bracing - When To and How To
  128. Pre/Post Covering
  129. How to measure DC current
  130. Vintage Kits
  131. Transmitter Trays/dumb thumbs transition
  132. ASP 61 carb. adjustment question
  133. thining epoxy
  134. Larger Building Surfaces
  135. canu make a rc c-47 di this
  136. Robart Air Retract Question
  137. Multiple Batteries ?????
  138. Prop balancing
  139. Please help, I'm a first time flyer!
  140. new jr radio?
  141. Extremely tail heavy kit built
  142. Pica Models
  143. APC, Plastic, or Wooden Prop?
  144. Engine continues to suck air!
  145. GAS ENGINES AND FM RECEIVERS
  146. 3/4" MDF+Ceiling TIle=Good Work Service
  147. Dope & covering questions
  148. Any interest in LARGE decal sets?
  149. how long does standard mail take?
  150. How to calculate CG for glider w/ long antenna wire
  151. HELP REQUIRED IN LOCATING ITEMS!!!!!
  152. Is selling for profit "disgraceful" or "dishonest?
  153. Futaba Jumper
  154. help w homemade voltwatch
  155. Has anyone received any CF from Air Dynamics Lately?
  156. scales used to weigh a plane??
  157. Ceiling Tiles
  158. DIY Retracts??
  159. chart tape a glass
  160. Fuel tank location with inverted OS .91 Fx
  161. Size engine for Ohio R/C ULTIMATE ?
  162. TIPORARE / Tipo
  163. GP spinner and APC prop question
  164. getting hinges right
  165. BTE Venture 60
  166. MDS 40 help
  167. looking for a certain glow fuel pump
  168. Drilling spinner backplates
  169. Finishing in Cotton rather than fibreglass
  170. Would you buy a R/C plane calendar with bikini clad girls ?
  171. Questions with micro servos
  172. Engine Troubles
  173. Sullivan Carbon Fiber Reinforced Push Rods
  174. Aviation Designs Starjet
  175. Control Mystery
  176. Venus 40 engine mount marks off center
  177. Muffler Problems
  178. Muffler Problems!
  179. Has anyone built this 182?
  180. extra 300 87" ws
  181. FUEL CLEAN UP
  182. 9C dual elevator servo programming???
  183. Suggestions For Smooth Flyer?
  184. Charging Glow Plug Heater
  185. 2 Blade or 3 Blade??
  186. Private Messages?
  187. Unimat 3
  188. High Band, Low Band. Does it really matter?
  189. fuel tubing size for Saito 1.50
  190. What maneuvers give you the most EXCITEMENT!
  191. Pilots for forty size planes
  192. WING LOAD
  193. Butyrate dope and stixit, nitrate. I know now
  194. X-country R/C flight with a full scale plane?
  195. 4.8v or 6.0v
  196. midwest super hots balance point and engine
  197. Bruce Lund 28% Staudacher help with...
  198. Making Koverall lighter than Plastic film?
  199. fiberglass cowl
  200. where to buy a servo
  201. Something to think about.
  202. Can a leaky front bearing cause problem ?
  203. Problems with inverted 2 stroke
  204. MOVED: Driving me Nuts !!!!!
  205. Hobby shops in Atlanta
  206. Ys 140 3 blade prop size?
  207. My servo went Kapoof
  208. New Battery questions by implication
  209. Hobbico Recievers and servos?
  210. Landing gear snapped off...
  211. Plans for frame for transport...
  212. Futaba 9C or Multiplex Royal Evo 9
  213. Rom-Air Retracts
  214. Decal Re-Application
  215. shipping cost for plane
  216. Koverall and no nitrate???
  217. Prop
  218. Best Simulator
  219. best way to side mount a servo
  220. 2 glue questions
  221. Hangar 9 cap 232 40
  222. OS 70 Supass II and RV-4
  223. WHERE I SEE ABOUT LARGE DISTANCE FLYING??
  224. Need Help With US Gas Engine RPM
  225. gummed up motors
  226. How do I use z-ends microtubing
  227. Hog Bipe flight woes...
  228. decals
  229. MOVED: Hi Tech receiver & other servo brands
  230. replacement motor mount for Modeltech MAGIC
  231. MOVED: Radio Inteferance from ESC or Motors?
  232. Sig Kadet Senior &O.S.70 surpass 4-stroke
  233. How many cans of paint?!
  234. Covering Videos
  235. jr servos
  236. futaba gyro fp-g154
  237. i need some serious help
  238. Battery testing
  239. Zenoah G38 - Suitable plane
  240. what radio
  241. Inverted 4 stroke mount
  242. Frequency Flag Connector
  243. covering fabric
  244. this is a stupid r/x question but i need help
  245. prop
  246. Fuel Tank/Line problem
  247. DECAL REMOVAL
  248. How do I build my own Flying wire/Tail Brace?
  249. Thread Lok on Clevices?
  250. Loose monocote
