PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Replacing Crystals
  2. Help with B&D pneumatic retracts
  3. Drill hole for servo leads in foam wing???
  4. Mixing with a Mini-3D?
  5. Canada
  6. Fueling Systems?
  7. Ailevator on 6 EXA ??
  8. Ultracote material makeup?
  9. Glo to Gas Conversion
  10. Fixing Dents in foam wing?
  11. YS 140 DZ Muffler Falls Off
  12. Bomb Drops
  13. cooling your fuel!
  14. Fuel Line syphon problem
  15. Great Planes RV-4 whit smoke!!!
  16. Control throws on an older Kit
  17. Request for specifications for do-it-yourself Building Board featured in RCM
  18. Glue tips
  19. Whos prop is this?
  20. Do you use a exhaust deflector or not?
  21. DC-DC converter
  22. Is poly glue fuel proof?
  23. servo buffers
  24. SuperTigre neadel valve "O" ring
  25. Drawing Outline of Extra 300s
  26. TOC?
  27. Rit dye, what color to tint a canopy?
  28. interference help metal rudder wire
  29. R/C Planes and equipment STOLEN!!
  30. 4* 40 Throttle Linkage Problem--Help!
  31. Slimline muffler
  32. Hanger 9 Edge 540 1/4 scale
  33. The Effect of Heat on Models
  34. pitts for K&B 65 sportster
  35. What fuel can I use?
  36. Magnum 1.20 dilemma!!!!
  37. paint match
  38. Need to find hobby shopp in South Bend Indiana
  39. Flying site opinion.
  40. Sig Koverall
  41. Looking for replacement canopy company
  42. CG QUESTION
  43. RAVEN
  44. Replacement wing for 4-Star 60?
  45. Anyone remember the Goldberg Vector trainer?
  46. Connectors
  47. Need some help with getting hinges out
  48. Solartex
  49. Glow plugs????
  50. Anything special about mounting my prop to my four stroke?
  51. to all experienced builders
  52. help w flag monokote design
  53. Thanks RCU
  54. 1st time w/ flaps
  55. Vortech spinner question?
  56. Best prop for OS 46 LA on Fun Air 3D
  57. dead sticks on down line
  58. Mask for making flames?
  59. dirt in carb
  60. Change to Synthetic Fuel
  61. Futaba 9CAP Charger Question
  62. Retracts
  63. Shops in NY and LA
  64. building in dihedral
  65. what is joe nall?
  66. OK Models Titanium Retracts??
  67. Edge 540 Problem
  68. Heavy Mufflers
  69. sanding sticks
  70. Manufacturer question
  71. Retract question - Does it make sense?
  72. CALLING ALL EXPERTS--NEED TO LIGHTEN MY PLANE THATS ALREADY DONE--HELP!!!!
  73. Looking for flyers to test crystals
  74. MOVED: Searching for lost flying budy
  75. Enya 155R w/an 18x6 Zinger?
  76. Good site for covering techniques/tips?
  77. Steerable Tail Wheel for LT-40
  78. Ultracote over Ultracote
  79. Fuel Filters necessary?
  80. glichting
  81. How to use FLAPS on P51-D Mustang
  82. OS 91 DF low end help
  83. MEAN AERODYNAMICK CHORD
  84. How to tint a canopy ?
  85. Need help picking out a good workshop board
  86. Tail wheel on LT-40
  87. 1/5 waco flying wires
  88. Assembling Laser Cut Parts
  89. Import duties/tax's (HELP)
  90. PREVENTIVE MAINTENANCE
  91. Mounting Aux Car Battery
  92. fiberglass landing gear
  93. kit builders
  94. need to add 1" to wingtip
  95. Fathers Day Gift: Need info quick!
  96. Good wing loading for a 1/12 plane???? HELP PLEASE
  97. Z bends with thick Control Horns
  98. How about a prop for climb out for hand-launching...--in->
  99. Lost important part, need help
  100. Sealing hinge gaps
  101. The Hammer?
  102. MEGATECH AIRSTRIKE any good?
  103. Hitec to futaba or JR trainer cord?
  104. BatteriesAmerica Service?
  105. Painting
  106. How many Top Flite P-51 Mustangs?
  107. What kind of plane is this??
  108. what size plane is this?
  109. Prop for under 4 pound plane with .46 os la, for speed??
  110. J'tec muffler experience?
  111. Balsa USA Cub
  112. Anyone have a contact for Ripmax UK
  113. tinting plastic for canopy
  114. Control hardware question for GP Extra 60
  115. Epoxy as Fuel Proof Clear Coat
  116. Antenna Housing
  117. IS THIS STUPID->.46 in a 1/12, .25 size Hawker Typhoon...????-in->
  118. Variable-pitch props
  119. Bugatti airplane
  120. G/P super stearman 1.20 cowl Dim.
  121. Krylon or other Paint over Luster Coat
  122. Quality of Hobbico mechanical retracts?
  123. THANKS!
  124. How do you protect the covering while in the car?
  125. 3D/IMAC
  126. Modification ?-Which Is The Lesser Evil
  127. flap servo's
  128. Servo Torque question?
  129. Can the G2 Interlink Controller (USB) be used as a buddy box?
  130. Super Hots control throws
  131. The World Models
  132. Have you ever seen a mid-air?
  133. Post's Tracker II
  134. Flying site in Kearney NE?
  135. painting plastic parts
  136. Polk Seeker II
  137. covering a wing tip
  138. C.G. Chipmunk & S.T. .90. performance??
  139. VectorFlight Sukhoi Thrust/CG
  140. Easyfly Simulator Landscapes Question?
  141. Flying field info
  142. High torq engine staters
  143. Best pushrods
  144. CG for Jungmann
  145. What fuel should I use?
  146. GP J-3 ARF fuel dot
  147. Lite Ultracote
  148. Kobra CofG and throws???
  149. 4*60 kit..which 2 stroke
  150. Exhaust extension for Saito
  151. Need tips on covering with solartex and hiding the seams
  152. Fuel tank capacity
  153. Reuse Titanium Rod Ends
  154. Best plane and engine you ever had.
  155. Need new starter for large engine
  156. Ironbay Fuel Regulator
  157. when do you need to use a regulator?
  158. Fuel shelf life
  159. Clear Coat Sprays
  160. Slimline Muffler Repair / Engine Problem
  161. Hinge Question
  162. RX antenna routing
  163. Need a small part for a Rhom-Air Retract
  164. 4-40 die problem
  165. Thrust on the cermark pitts?
  166. 3 Blade spinners
  167. Different Type of Balsa????
  168. Flying the Sig Liberty Sport
  169. Camouflage painting...need help
  170. RC Shops in Albany
  171. monokoteing over glassed strip in center of wing.
  172. 4 stroke Maqgnum 90 Smoke system?
  173. Tail wheel spring alternatives
  174. Does building keep you in shape?
  175. engine choice for extra 300
  176. Transportation
  177. Airbrush users - which model and why?
  178. Any tricks on drawing centerline on a fuselage?
  179. 1.60 FX smoke pump and perry pump?
  180. gas engine fuel flow
  181. servo mounts...
  182. lancaster!
  183. Shortening Robart Hinge Points
  184. crystal set question...
  185. Comments please - do you trust Polyurethane Glue?
  186. AM Receivers
  187. best sealer for balsa for painting??
  188. Looking at going GAS!!!????
  189. Where to get a wing-bag?
  190. engine dies
  191. Red Bull Graphics....
  192. RCM Trainer Questions
  193. SIG 4 * 40
  194. Servo horn screw type and size?
  195. HOW FAR I CAN PUT THE FUEL TANK WITHOUT PUMP??
  196. MOVED: Damaged Li-Polys
  197. Sureflite?
  198. Floats for Alpha Trainer...
  199. MOVED: GWS servos
  200. MOVED: AIRTRONICS RADIO QUESTION??
  201. Flying while driving
  202. MOVED: Gold Sticker Futaba FG "Legal?"
  203. Best place to buy online?
  204. multiplex twinstar
  205. compreion gauge,proper useage?
  206. Neon Green Monokote paint matching
  207. batteries how low on tx/rx/
  208. question about painting!
  209. 232 sig ex
  210. Canopy problem
  211. 15 year old ultimate
  212. Paint on polyethylene
  213. Dreamer II, who made? Pics inside
  214. Flying wires needed?
  215. cutting balsa sticks
  216. What kind of biplane is this???
  217. MOVED: Another word about CA
  218. Need Servo Arms For Cirrus CS-21
  219. Counter-rotating props on a single engine?
  220. Dremel Moto-Tool parts/repair source needed
  221. PICA Cessna 182 C/G??
  222. Fuel Tank for Saito 300
  223. how do I?( hot wire foam cutting)
  224. i think is screwed my voltmeter
  225. Zurich glasses
  226. What's the minimum amount of torque that can be used for aileron direct drive?
  227. rubber by the pound?
  228. ABS seam filler???
  229. Help with Servos
  230. has anyone tried...
  231. show and tell..
  232. How to seal the edges of monokote
  233. 74" ws Extra 300 servos
  234. RCM Magazine sure takes their time, don't they..??
  235. Paul's Model Supply
  236. thunder tiger
  237. Wrong voltage reading on Hitec Flash 5 tx
  238. How do you shave 1.5 lbs off an airplane?
  239. Flying Sites in Herndon, Reston Leesburg Virginia
  240. Glitch problem with my system(Help)
  241. Repairing Foam Core Wings
  242. Cleaning questions
  243. New Radio
  244. charging time
  245. Healy coil
  246. Down Thrust?
  247. Flight Pack
  248. trying for an answer agian
  249. paint....compatibility?
  250. Mac pipes
