PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. how many pounds does a gallon of water weight?
  2. Engine for a CAP-232
  3. Super Tigre .90 upside down
  4. minwax polycrylic & silkspan
  5. U Can Do 3D 46 Landing Gear Problem??
  6. What blue ultracote matches pre-made ultracote check
  7. Dave Patrick web site
  8. good deals for nitro fuel
  9. Stripped out plug threads on a sato65 head/cylinder
  10. digipace 2 cycler
  11. Plane for OS .52 4T
  12. Drag
  13. Propellor mounting
  14. Best place to buy a new radio online.
  15. ? RC CITY ULIMATE KIT
  16. Post-crash repair & inspection questions
  17. Radio for US 60
  18. Using nyrod linkage for mechanical retracts?
  19. engine
  20. Advice needed on wing tips
  21. To wing tip or not to wing tip.... Advice needed.
  22. more hp
  23. Pick-Up Truck Bed Solutions?
  24. Applying monokote
  25. Tuned Pipe Question.. Please help
  26. Radio Interference Sources
  27. 20 min Finish Cure WILL NOT HARDEN
  28. Center of gravity
  29. Paint question
  30. Diesel question with a O.S. .46AX
  31. great planes ignition kill switch
  32. Where did PICA go?
  33. Gold Edition Top Flite Cessna 182
  34. Engine dieing after Long Runs and Loops.
  35. Flat-wing (non-airfoil) coroplast planes?
  36. Oh NO!!!!
  37. flaps on gaintscaleplanes corsair??
  38. Alternative to microballoons?
  39. Flexible pushrod soldering
  40. SuperStar 60-Covering Repairs
  41. Prop science?
  42. Night Flying
  43. Re.Old Cosmos model nose retract
  44. Mystery Zenoah Question
  45. tank - vent on a pumped engine
  46. Tiger II tricycle-to-taildragger conversion
  47. Name This Plane!!
  48. Does anyone know what this is
  49. carb. leaking fuel ....tank too high?
  50. How does HLH207 BOMB for R/C Airplane release work?
  51. O.S. 91 FX Fuel Question
  52. Wing incidence problem ????
  53. antenna length
  54. Four Stroke Fuel
  55. Radio Channels
  56. Building boards
  57. Best glue for antenna tubing
  58. AEROSHELL DECALS
  59. Information on Goldberg Ultimate 10-300
  60. AM or FM for ign. engines?
  61. Bad roll of monokote?
  62. can i use an os 40-50 drive washer on tt 40?
  63. Klotz 2 Stroke Oil
  64. Strongest, most heavy duty 60 size mechanical retracts?
  65. Another Lost Muffler
  66. Why do you fly airplanes?
  67. RPM Gains
  68. Transparent coverings?
  69. Magnum XL-91RFS 4-Stroke or O.S. FS-91 II Surpass
  70. Midwest P-51D Mustang
  71. Setting the propellor on a G-26???
  72. RC-56 Canopy Glue and Elmers Glue
  73. Work Shop
  74. Sky Inc Not a good Company
  75. Hobby Lobby C5 Tiger
  76. New engine buying/old engine tuning advice
  77. Name this plane
  78. Saito 72 new engine run problems
  79. Hangar 9 Corsair Mail damaged claim
  80. TF giant Mustang motor
  81. Futaba reciever w/JR transmitter??
  82. Hitec 625mg vs 645mg
  83. Glitches of an Extra 330
  84. Airtronics RD 6000 Super
  85. How to ship a plane?
  86. Peak Charging NiMH Rec. batt at 1.0 amp ?
  87. 4.8 to 6 volts
  88. using locked retracts in a fixed gear plane
  89. ?Best Smoke System for CG Super Chipmunk w/.61 K&B?
  90. Jets Crashing video on RCU
  91. Balancing point?
  92. where can i get thunder tiger manual???
  93. Preping b-4 covering
  94. how much do you ACTUALLY fly
  95. Ideal CG for a trike setup?
  96. Using Micro (11 Oz) servo for throttle?
  97. miter sander tool...
  98. how do I bend piano wire
  99. Servo torque??
  100. latex paint color
  101. Regulator and large fuel tubing???
  102. Lightening holes?
  103. Micro servos & receiver ?
  104. Tools for building
  105. Platteville WI, R/C Flying
  106. Flutter.....
  107. Magnets in R/C aircraft?
  108. Futaba S3010 servo batteries
  109. RC history book
  110. Sequencing gear doors on 9CAP
  111. What is nats?
  112. pitts special 60 or larger
  113. How do YOU drill out props for larger cranks?
  114. Who will ship large crates.
  115. Which is heavier? The OS .15 LA or the AP .15?
  116. "Antique" Coverite color
  117. Balance your blades??
  118. Name the plane.
  119. Monocote over Ultracote?
  120. What's the best way to make a hatch?
  121. Help in something I'm lacking in (Installing Wheel pants).
  122. Thinning epoxy
  123. Another Prop Balancing Question
  124. Fiberglass fuse
  125. Saito 180 Carburetor Reversing? Anybody got a itsybitsy flowbench?
  126. Need idea's for a 3rd grade science project
  127. Engine Question (.40 LA)
  128. Fuel tank tubing too stiff
  129. PRESSURE PROBLEM ON CAP 232 .40 SIZE
  130. Iron On covering ??
  131. Great Planes Magnetic Building Board
  132. Steerable front wheel in a trike landing setup?
  133. GWS SERVOS
  134. Saito .72 and Horizon Hobby Twist
  135. Love/Hate
  136. Mounting servos
  137. Mounting the pilot figure
  138. Curious about how a gyro on a rudder acts....
  139. Futaba 148 Servo Conversion to Retrac Servo
  140. OS 61 MYSTERY!!!
  141. battery location
  142. Saito 65 Muffler Tap Question
  143. Reversed servo
  144. batteries
  145. building boards
  146. wire landing gear, too springy
  147. Patch a hole in a tank
  148. overpowering kit planes
  149. Contest Events??
  150. jr 8103 promo pack
  151. Pusher Props Reversed?
  152. RCU Magazine,
  153. R/C Show in Vegas?
  154. Hobbico voltwatch
  155. Canopy and window glue?
  156. What 3 Blade Prop to Use ?
  157. Sig Aluminum Engine mount SH477
  158. Central Hobbies CF rods
  159. Electric Retracts?
  160. Has anyone tried the GP Power Plane?
  161. Hinging tape
  162. Fuel Line Set Ups
  163. Dubro Pull-Pull
  164. RCM&E spitfire plans
  165. Need ideas for finding a flying filed? PLEASE HELP!
  166. Equipment
  167. How to setup FF8 with a 4CH RX?
  168. Best way to operate microswitches?
  169. fuel tank for YS
  170. AM radio usage in the US? how illegal is it?
  171. Servo Questions Please help
  172. water based paint:Life Color
  173. TORNADO FUEL
  174. Dremel Tablesaw
  175. Butyrate clearcoat over lustre kote poly u
  176. Gas or Glow??
  177. Dooh! I glued too soon
  178. Anyone know where to get sheets of coroplast?
  179. Testors Model Masters?
  180. pinning
  181. BOOK FOR STERLING KIT
  182. cover first or not
  183. semi-sweet saito
  184. Painting tips of propellers
  185. control surface loads?
  186. Airbrushing: Color matching paint to Ultracote color?
  187. Any modifications to you E-starter?
  188. Need 2mil coroplast vendor in US
  189. Beginning Gasser
  190. Probond Poly glue for shear webs?
  191. Dave VBrown Products
  192. Buying Sanwa items around Cleveland
  193. fuel tank position for sidewinder plus
  194. Corsair and OS50SX
  195. 25 Sport Sportster
  196. Broken reciver from crash!!!
  197. need tips for foam wings,for wingmfg p40B
  198. Small gasoline engines for U can do 60
  199. plane or truck
  200. Where can I get a Trim Iron in the UK?
  201. Ideas About Sr. Telemaster Crash?
  202. Extra 330 Canopy
  203. KYOSHO CAP 232 BUILDING PROBLEM, HELP NEEDED
  204. Old covering material won't bond to wood.
  205. Quality of Zinger Props?
  206. MOVED: 91 Surpass smoking too much.....
  207. Best Propeller for OS 61 FX
  208. HELP Royal Gull Amphibian plans?
  209. best engine for Hangar 9 Funtana 3D
  210. is smoke supposed to still come out when it is shut off? (smoke system)
  211. inside tank fuel line
  212. Prop not tracking straight.
  213. Antenna routing question
  214. hangar 9 tachometer
  215. Folding prop for Slow stick or GWS engine??
  216. hanger 9 ultra 40
  217. Epoxy. What went wrong?
  218. Polyurethane for firewall
  219. monokote
  220. Any difference between Solarfilm and MonoKote?
  221. Airtronics????
  222. CASTOR OIL
  223. Floor polish as clear coat?
  224. Two-Part Auto clear coat over Rustoleum
  225. correct type of solder?
  226. Hitec reliabilty?
  227. What would you use on landing gear in a 3D plane
  228. Stripped Hex Head Removal
  229. Aerial Photos over Populated Areas
  230. Bad fuel?
  231. R/C retirement community ???
  232. where to buy a cougar 2000 in the US?
  233. Posting Photos?
  234. shaved antenna question
  235. Band Saw
  236. Throttle servo placement
  237. Engine thrust, another question for all the gurus out there
  238. FLYQUIET tuned pipes
  239. OS FS-120 4 Stroke
  240. why 3 bladed props on trainers?
  241. Understanding servo in-oz ratings...
  242. How to get oil out of balsa
  243. Hirobo Pitts S2-c AIRock
  244. where to buy supplies for kits other then tower hobbies?!?!?
  245. Fuel Tank Location=Flooding
  246. Saito FA 90t in a Giantscale P-26 Peashooter?
  247. Converting LT-40 to a tail dragger
  248. How often does your spouse/significant other come to the field?
  249. Monrovia California
  250. Bad Experience with Pacer Formula 560
