PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. How often does your spouse/significant other come to the field?
  2. Monrovia California
  3. Bad Experience with Pacer Formula 560
  4. another smoke system question....tank location and more please help?!?!?
  5. Who's the best online store?
  6. need more speed or power for take off
  7. What size to make replacement wing...details inside...
  8. Transmitter/Receiver Compatibilty
  9. Hinge Point Question
  10. Paint Shaker - Pint Size or Less?
  11. weather websites
  12. 4 stroke vs. 2 stroke
  13. My Airtronics has poor ground range.
  14. Trust for Public Land
  15. Cycle Transmitter battery
  16. Balancing an unknown staggerwing biplane?
  17. Can gyros be used to stabilize aircraft?
  18. All EPP Zagi-like plane?
  19. Stunt book.
  20. Bunch of newbie questions...
  21. Charging a 2000 mAh NiMH Battery
  22. Klass Kote clear?
  23. is this glue ok to use for wood to foam?
  24. Flap hinges?
  25. Citabria N struts?
  26. "Epoxy Fortified Wood Stain"
  27. Lightening up Aluminum Gear
  28. determining proper thrust
  29. Paint scheme blues!
  30. LEFT OR RIGHT THRUST??
  31. Kavan wheels?
  32. Who won the Magnum 4 stroke ?
  33. repairing a crashed cub
  34. O.T.question-what Image host are you using?
  35. SMOKE OIL
  36. dremel 9.6v or corded dremel?
  37. THE TAIL DRAGGER
  38. Engine position from firewall?
  39. Using Monokote
  40. VMAR easy 3d
  41. Magnum 1.20 choke question
  42. Looking for F-4 Phantom Plans
  43. HOW DO YOU TRIM A BUDDY BOX?
  44. Field Plane Stand Plans
  45. repairing silk/dope
  46. R/C Shop at/near Kokomo Indiana
  47. 4-40 threads on pushrod
  48. gluing wood to foam?
  49. Converting electric to gas???
  50. SOUTHEASTRC - GREAT PRICES - GOOD PEOPLE SO FAR
  51. How to re-insert a ringed piston
  52. Dropping eggs from planes
  53. Fuel Pump Connections
  54. Magnum 91 4c
  55. Klett tailwheel and pull-pull rudder
  56. fuel pump .61 sf
  57. Flex pipe leaks oil
  58. Smoke problems...help
  59. Fabric pinholes...
  60. Obeche wood??? Where to get???
  61. Anyone know where I can get Ambroid glue in the UK?
  62. Throttle servo inside engine compartment?
  63. What primer to use?
  64. What Windshield material
  65. FUEL LINE ID SIZE CONVERSION TABLE
  66. Range check for radio
  67. Fixing my super sportster
  68. metal covered airplane
  69. Epoxy substitue
  70. CORROSION
  71. airplane weight
  72. help!! my Saito .56 keeps stalling at 1/2 tank
  73. Changing ducted fan to prop driven
  74. Gear reduction starters?
  75. prop braking
  76. Futaba hi/lo band whats the dif?
  77. Oil base Polyurethane ?
  78. servo size question
  79. AM Servos--can FM ends be put on and used??
  80. Rx-Tx for second plane?
  81. Receiver Foam Enough?
  82. Petrol in plane engine
  83. Best glue for field box?
  84. Covering bubbles
  85. balancing ?
  86. Nicad vs nimh
  87. servos on a 65"plane
  88. Metric tap/die confusion
  89. name that plane
  90. using and unbalanced prop on purpose
  91. Polyurethene glue crumbles?
  92. Recommendations for How-To-Cover Books/Videos?
  93. Ultimate 10 dash 300s Blue hawk
  94. CBA/Tatone Exhaust Off Neoprene 3/8"
  95. How to bend balsa sheeting
  96. C/G for unknown plane?
  97. alternative fuels?
  98. mounting engine upside down os 46 LA
  99. mvvs gas engine
  100. wrinkles in silk
  101. Polyester Chinese silk.
  102. Major help needed with GSP Yak54!
  103. foam vs built-up balsa
  104. Need plane and engine advice please.
  105. Charger fo NiMh
  106. How do you hold the control sticks?
  107. Futaba Tx with Hitec Rx
  108. enya 90 engine
  109. Using Hitec servos on PCM Mode of Futaba receiver
  110. Channel 36 crystal works on channel 26 reciever
  111. RUBBER GROMMETS
  112. What is it
  113. Pitts Muffler type.
  114. extra260
  115. remote starter
  116. fuel properties
  117. Sukhoi 30
  118. Bomb Bay Doors
  119. Microballoons?
  120. Safe distance from other feilds?
  121. FIRST TIME FLYING/BUILDING CAP 232,
  122. GLOW PLUG CLIP USING ALKALINE BATTERIES
  123. saito exhaust routing problems
  124. Ultra Hots Kit
  125. small rotating retracts
  126. Evolution engine question
  127. Will sig canopies accept a dye?
  128. pitts muffler on cap 232 40 size?
  129. Old Super Tigre
  130. Cowl Spacing Question
  131. Fuel tank, no idea where to put it!
  132. H9 Corsair Dual Rate Question
  133. Servos
  134. Decals and pin striping
  135. What engine to use?
  136. Engines
  137. need help with engine choice
  138. OS 40 Max H
  139. Pica 1/6 Sport Scale North American T-28B
  140. Wobble Engine
  141. H9 1.20 CAP 232, SAITO 150 or 180?
  142. Engine exhaust on Waco
  143. Transmitter throttle problems !!!
  144. DUBRO KWIK FILL FUEL VALVE
  145. Speed 400
  146. Shipping damage, PLEASE HELP!
  147. Bondo problem...
  148. removing CA from monokote?
  149. How Do You Keep You Aluminum Spinner Clean from the Starter Stuff??
  150. Which prop balancer is good?
  151. .60 engine problems
  152. I complain about Tower, but there service is good
  153. how to mount canopy's????
  154. Comparing Magnum 4 cycle
  155. Ultracote over Ultracoat....
  156. wood pecker tool
  157. can I put a servo in the engine bay
  158. Shipping help/ ideas
  159. 3 and 4 balded props
  160. futaba 6 exa set -( LA address)
  161. Convert GP Spectra to Glow
  162. Fuel tank size help.
  163. hmmm? C G Question
  164. Two axis gyro help...
  165. Importing to the UK or Canada
  166. Counter balance! How do you do it?
  167. Covering for a trainer
  168. Last thing you check or do
  169. Connecticut Flying Club
  170. Fuel question
  171. Repair (Strengthen) ABS Wheel Pants?
  172. keeping engine running
  173. Posting/Hosting digital movies
  174. Nose Cone Size
  175. Cowl cutting
  176. Dynaflite Super Decathlon vs Lanier Taylorcraft
  177. Another Sig 4 Star 40 Question
  178. Hitec 555 Receiver in a Glow Plane?
  179. Who built it????????????
  180. Servo control horn question
  181. SUPER TIGRE 2500-3000
  182. Which of the two is better overall?
  183. Prop too close to cowl
  184. Where to buy 2mm carbon fiber rod?
  185. 3.5" Ultimate Spinner??
  186. Loctite and Blind Nuts
  187. Trike to taildragger, ??
  188. FMA DIRECT AUTO PILOT
  189. fuel pump and injectors
  190. Problem with reciever battery
  191. titebond red or blue?
  192. GP filler valve question
  193. Pacific Aero Tiger Moth
  194. Battery Placement
  195. tf giant scale corsair wing sheeting ?....
  196. SAITO 40 fs
  197. Who sells metric "O" rings?
  198. What kind?
  199. CLIP ART
  200. Where can I buy Nelson glow plugs?
  201. What's a good starter for larger motors?
  202. RETRACT MAINTENANCE ????
  203. Put this one to rest (glues
  204. How to??? Control surface removal
  205. Thinning Stix-it
  206. Will the disorientation get easier to deal with?
  207. Adding Lead Weight to tail
  208. Sig Senior Taildragger Conversion question
  209. recivers schulze
  210. Where to buy Sig kits in Augusta GA or surrounding areas
  211. Is There a Doctor in the House?
  212. Looking for pilot figures!!! HELP!!!
  213. Music Wire
  214. Banner Towing
  215. Smoke for 91 Four Cycle?
  216. Large Wings-How to build to transport?
  217. Whats wrong with my starter?
  218. High temp silicon coupling?
  219. Name of kit
  220. receiver battery
  221. Best attached starter battery set-up
  222. OS46 Propeller Nut
  223. Extrem Pilots?
  224. Zurich Removable Optics
  225. Toledo Show
  226. SERVO SETUP
  227. mounting L.E.D light
  228. Getting out.......
  229. Roll'em or Fold'em?
  230. Can you tell me what font is this ?
  231. Buggy blast motor cleaner on fuel-soaked reciever?
  232. Rcvr Batt. Charger / MRC
  233. glow engine fuel
  234. Covered Pop Up's for Fly Ins - Where do you get em
  235. WINGS
  236. car wax for cowl protection?
  237. Balsarite and Foam
  238. Steel pull-pull cable & RF interference??
  239. Web site for Sierra Precision
  240. Opinion on Satio 40 / 30 fs - OS 40 - 30 magnum
  241. "clam shell" for covering exposed servos?
  242. Inverted Circular Saw as a Table Saw?
  243. Starter for big engines?
  244. leading ailerons?
  245. RC Graphics
  246. Debonder on My Canopy
  247. ARE ROMOTE STARTING SYSTEMS AVAILABLE
  248. RECOMMEND WING BAGS
  249. Prop Reaming?
  250. Dave Brown Lock Nut?
