PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Fuel dot on 4-stroke 1.20
  2. carbon muffler
  3. Cowl Prep.
  4. Pinch test 4 stoke
  5. Finding a Flying Site In Nebraska
  6. how to determine prop size?
  7. Power Panels
  8. MORE UP ELEVATOR
  9. Dried on Epoxy can it be removed?
  10. Club in Nevada ?
  11. Kyosho series 91 radio?
  12. Cline Regulator on OS91FX
  13. NEED IDEAS: Please show me your shop/Airplane storage
  14. What is the trick in Havoring ?
  15. shops needed!!!!!
  16. Big servo problem! Help wanted. Please.
  17. what is the name of this plane
  18. HELP Retract Door
  19. YS 63 FZ - Does it wear out quickly?
  20. Nerf football whistle on plane?
  21. Filling Pinholes
  22. Clancy Stagger Bee
  23. dual fuel tanks
  24. TRIMMING OUT PROBLEMS
  25. R/C planes in public parks
  26. OS Max .25 carb adjust
  27. How do I hook two elevator servos together
  28. pushrod connected to each side of elevator
  29. FLAPERONS?? FUTABA FF9
  30. good primer?
  31. Join AMA for 19 dollars.
  32. Fuel Filter?
  33. Painting Monocoat
  34. Shoestring Racer "?" About 2 stroke Eng.
  35. Banana Fuselage
  36. GOLDBERG TIGER 60
  37. Futaba 8U Synth. Modules
  38. CA hinges not grabbing
  39. C/A glue question
  40. Large Checker pattern on bottom wing
  41. Mufflers, what metal?
  42. Glue for sheeting
  43. Cutting down props
  44. need plane for a ryobi 31cc
  45. Rustoleum-- Is it really Fuel Proof?
  46. Granite State iron on gapless hinge
  47. Crazy Pilots
  48. 5 minute resin, 30 minute hardener. Huh?
  49. Electric speed 400 twin motor set-up
  50. Throttle Trim Not Working
  51. Cleaning a new paint gun
  52. Stan's Fibertech
  53. Funtana and Saito 72
  54. DECALS Where or how?
  55. Fuel flow
  56. Cactus Aviation out of business?
  57. How to paint Roundels on fabric covering?
  58. os .80 dual plug engine
  59. 40 size airplanes and 4 strokes
  60. 9VAP Owners
  61. Hobbico Mech Retracts "slop"
  62. Micro-balloons question
  63. Field Flight Box
  64. Wing Tips
  65. Ellipse...it looks like a spitfire
  66. Air brushing videos?
  67. Extra Long Steering arm
  68. bands or wingbolts
  69. Slimline Excel fueler
  70. Is there a way to fix this?
  71. Fabric over foam?
  72. what airbrush or gun to get?
  73. miniwax, not clear?
  74. NiMH Discharge Rate
  75. "Snap"
  76. CA vs Titebond and other yellow or white glues
  77. Custom Fuel Tanks
  78. Gasoline & Cline regulator
  79. Stinger CG
  80. Is epoxy fuel proof?
  81. Spinner size
  82. SRAC Club
  83. RECEIVERS: CHANGE FROM AM TO FM
  84. Rustoleum sanding primer
  85. Shops in NY and LA
  86. engine tuning
  87. Matching Spinner, to Motor, to Prop
  88. Giant scale corsair prop types
  89. .46 or .61 for 40 size Super Stick
  90. How to get those really sticky, really thin decals on straight?
  91. RCV 58 CD engines...
  92. Exterior Engine Cleaning
  93. Hobby shops in Perth, Australia.
  94. Any thing besides castor oil
  95. Futaba Campac compatability
  96. Covering repair question
  97. Flying wires
  98. Silk and dope on tail feathers
  99. Painting over Monocote?
  100. how do I remove winter storage AFR monokote wrinkles and bubbles?
  101. Covering a Turtledeck
  102. Balancing a plane
  103. Fuel Proofing Model Master Paints
  104. Klett TA3 tail wheel assy
  105. Ace R/C Finger Protector
  106. applying covering, so darn frustrating!
  107. stallion .35
  108. Supernewbie Q
  109. gas fuel tank
  110. Glow Fuel Allergies?
  111. Cowl Hatch Pressure Question
  112. OS BGX vs Zenoah, what do you think?
  113. Transmitter Battery Charging Question
  114. Fuel Tank Location - does it need to be at carb level?
  115. How can you attach you canopy and make it look good??
  116. favorite flight path
  117. Is Water Based Polyurethane fuel proof?
  118. smith mini plane
  119. Which Mac's muffler for OS 25 Fx
  120. Canopy Curled after painting
  121. want to open a hobby shop question????
  122. Article on "Power Isolator"
  123. anyone ever hit a bird??
  124. Carbon Fibre
  125. Best Sunglasses at the right price?
  126. Antenna routing in plane with rear servos
  127. two stroke .74 fox wont idle
  128. DOES ANYONE KNOW WHERE/WHAT PITTS MUFFLER WOULD FIT ON AN OS 50SX
  129. thick as a brick/ why isnt 1/4 .25 120 scale???
  130. Futaba's T6AXS Radio
  131. Fuel Dots? Fuel Valves
  132. Fuel storage containers
  133. Austin Tx area clubs & Fields
  134. GP J3 ARF 4-Stroke Mounting Question
  135. Colored Foam Rubber and other Things?
  136. Paint Bleeding Under Masking Tape
  137. epoxy question for all the epoxy experts
  138. making instrument panel
  139. engine thrust question
  140. where did sky shark rc web site GO?
  141. J-3 Cub Plans 1/3 scale needed
  142. ENYA 15-lll Motor conversion
  143. Rich's Brew Website
  144. PBF elevator
  145. T-28 MFG. ?
  146. Where can I buy Nitrate dope, colored tissue?
  147. Duel fuel tanks for gasser
  148. Identify bad battery cell?
  149. small plane design and materials
  150. whats the best dead stick landing plane
  151. Balancing question
  152. Prop Retailer
  153. 9z 7 chan. Ultra stick set up flaps????
  154. Robart & Century Jet Air Controls ..Same ???
  155. a quick spinner question
  156. Can anyone provide info for plane I bought today
  157. Fiberglassing
  158. Is your club on or near an Enviornmental/wild life area?
  159. Frozen motor
  160. PT-19 Windscreen Supplier?
  161. Issues w/ converting a foam wing to nitro
  162. Side and down thrust
  163. Wanted instruction pages for Pheaton 90 kit
  164. Propeller styles and differences
  165. Surpass 70 II power.
  166. Help needed in designing an aircraft
  167. What are the best hobby stores in Omaha,ne
  168. Is Plan Protector available in the UK - Or suitable alternative?
  169. Electric Jackscrew
  170. sheeting on foam, is it me
  171. hanger9 cap232 da50 fuel tank question
  172. UK Supplier of......
  173. Another push rod question
  174. Best Scroll Saw?
  175. is any polyurethane fuel proof?
  176. Pushrods
  177. Any hobby shops in Toronto?
  178. Photochemically Reactive
  179. Cheaper Nitrate dope?
  180. Digital tachometer Lighting Need Help
  181. Waxing the plane???
  182. fuel proof paint
  183. Higley Book Tom's Techniques Question
  184. Looking for a 3 blade prop
  185. 3 blade props
  186. Lead, and where to attach it.
  187. 4 BLADE PROPS
  188. wingbags.com out of business
  189. Automobile battery charger
  190. MOVED: Video Camera in plane - and wife let me live!
  191. Packing a box 101 (Warning Rant)
  192. Evolution propellers
  193. Balanced??
  194. Good deal on engines
  195. Balance point for Thunder Tiger 45 L
  196. help with covering (im crap!!)
  197. Rebuilding Hinge Line
  198. most powerful rc electric motor
  199. silk and dope over plastic?
  200. Strobe lights...any problems?
  201. Superstar folded
  202. Ni-Starter charging
  203. Midwest AT-6
  204. HOGBIPE smoke
  205. Composit-ARF 2.3
  206. Removing the Covering of My Airplane
  207. Flashing LED for tail ?
  208. On Board Plug igniters
  209. servos
  210. Cleaning Exhaust Residue...any tips???
  211. Walbro carb. WT - 481
  212. What is this plane?
  213. Nitro effect on temperature?
  214. Sig Astro Hog and landing gear
  215. Storage (when not in use)?
  216. Is Krylon Spray Paint (over decals) Fuelproof?
  217. "S" cubed model company
  218. Sig dope over luster coat
  219. LED LIGHT HELP!
  220. superkote
  221. MOVED: beer run
  222. Anyone have luck with lustrecote?
  223. Need Easy Way To Mark & Drill Wing Dowel Holes
  224. How long will a 600mah RX battery last.
  225. Aluminum prop nut
  226. epoxy HELP
  227. Liberty Sport
  228. should I find it amusing
  229. Flex wire or steel pushrod for elevator/rudder?
  230. Covering
  231. Covering problems-monocote wrinckles
  232. J&B Access Panels
  233. Squares, Triangles etc
  234. Dyeing canopies
  235. UFO CA
  236. Servo Placement, Alerons
  237. Difficulty trimming transparent ultracote?
  238. Champion Focke Wulf
  239. edge 540 hover configuration
  240. How to cover an ABS plastic cowl with Monokote ?
  241. Some help with 30 minute Epoxy "problems"?
  242. Foremost Products
  243. Ultra Stick 60/standard BB servos?
  244. JR, Tower Hobbies Radios
  245. Ultracote Transparent blue
  246. Servo lead connecters
  247. Busting out blind nuts!
  248. All about Glue
  249. Spinner
  250. ultracoat
