PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. Busting out blind nuts!
  2. All about Glue
  3. Spinner
  4. ultracoat
  5. Help with a manual pump
  6. Brazing instead of soldering
  7. European Plans
  8. Soldering (sp) from a alligator clip to a banana clip?
  9. Glassing the wing joint -- question
  10. H9 Super Cub
  11. ACE CHARGEMASTER HELP
  12. Which "Yellow" Matches Ultracote Yellow and Black Squares
  13. Bondo?
  14. Having trouble silver soldering control rods
  15. Starter stands?
  16. RC club Patuxent River, Maryland
  17. radio south hinges
  18. Flame Red vs Dark Red
  19. dope question
  20. What do you build on?
  21. what would you do?
  22. Can JB Weld take the heat?
  23. Looking for discount supplies.
  24. Failsafe Switch
  25. Hair dye?
  26. Question about building services.
  27. engine for dynaflite fun-scale 60
  28. fueling with cowl. how do i know its full?
  29. Help finding 1960's control line pusher .049
  30. O.S. 70 surpass II and tork
  31. Inverted OS .61 FX Help Needed !!FAST!!
  32. Large Prop Suppliers? (like 24x22)
  33. Good US Model shops
  34. Come have some cheese /w the whine!
  35. 30 min epoxy
  36. nexstar props
  37. Wing mount for servos?
  38. Sheeting Foam Wings
  39. Quadra eng How do I know what cc it is?
  40. remote glow doesnt work properly
  41. HOW FAST IS THIS PLANE?
  42. Goldberg tiger II
  43. CA and hinge plastic...
  44. os 120
  45. Split Elevator
  46. Quality of GMS Engines
  47. Tower Hobbies servo
  48. R/C airport retirement community
  49. Anyone know thw monocoat color's and part #'s for the Kyosho Majestic??
  50. Microballons in Alphiatic resin ?
  51. Servo Torque
  52. MOVED: nicad to AA battery change, advice?
  53. Sig Kadet JR.
  54. Question About Epoxying Nylon Hinges
  55. Oracover
  56. Solartex covering
  57. RC mailorder companies in US
  58. Too much gap?
  59. covering on top of covering
  60. Has anyone used a .61 engine on a 1.20 supersportster?
  61. Rules of thumb for how hot the iron should be when covering w/ Monokote?
  62. Large slow airplane
  63. functional drop tanks?
  64. gettin into large scale aircraft
  65. Attaching antenna wire to vertical stabilizer
  66. HELP:'War Weary' Decals
  67. question about installation of a strobe light mpi from MAXX Products
  68. Control throw Question
  69. Epoxy mix
  70. finding the right retracts!?
  71. RCM parachute jumper
  72. Change in CG-how to adjust?
  73. lusterkote help
  74. Painting Coverite
  75. Landing gear repair
  76. Question on Cowls
  77. Miller R/C reduction gear
  78. RC Universe abreviations, terms and acronyms list
  79. Anyone used the Genis (sp??) in-flight "generator" charging system for planes??
  80. Strip Ailerons vs. Barn Door which is better?
  81. Help Please In Removing Silkspan and Dope
  82. Lustrecote Overspray
  83. where to put the servo cables in the wing?
  84. Yellow glue - how much is too much?
  85. Problems!!! Screws can't get out!
  86. Poly-u
  87. os 46 la, what prop is best?
  88. Removing epoxy
  89. Computer Generated Decals
  90. monocote on monocote
  91. U.S. AirCore flight box
  92. Warped Plywood
  93. Can I get a Job in USA as a RC-Modeler?
  94. TRIM OR MOUNT ADJUSTMENT REQUIRED
  95. Will Monokote stick to painted plastic?
  96. Most Air Movement on Planes Surface??
  97. Covering
  98. Robart Hinge Point Halves?
  99. smoke help
  100. Fabric covering strips
  101. CG Anniversary Piper Cub
  102. Hinges, kinds and differences?
  103. What does the tab on the vert & horz stab do?
  104. Complicated covering job.
  105. what size drill bit for 1/4 20 tap?
  106. CA and acetone
  107. Sig Lapped Edge Wingskins??
  108. 2 questions
  109. Fiberglassing And painting
  110. Dare Hobbies, any experience with them?
  111. Servo problem - help please!!
  112. Epoxy Fuel Proofing
  113. hinge installation
  114. Match the plane to the engine...
  115. how to set new engine
  116. Remote Glow
  117. Radio gear compatability
  118. Flying Field Controversy
  119. Horizontal Stab Repair
  120. Radio: positive and negative shift
  121. balsa/foam wing
  122. Steerable Nose Gear Wheel Brake ?.
  123. gluing sheeting to foam
  124. nav lights
  125. painting epp foam
  126. canopies
  127. Old JR receivers & radio Equipment
  128. JR receivers
  129. UCanDo 60
  130. slower landing speed
  131. Carbon Rod or Tube
  132. Making wire landing gear
  133. Building Planes For Others
  134. Fuel Tank Size Question
  135. Craft that fit the 25 OS FX engine?
  136. Unmanned Aerial Vehicle-(UAV)
  137. Don's Hobby Shop - e-mail
  138. can someone suggest a good remote glow ?
  139. What brands and types of coverings are there?
  140. Ultra Stick 60
  141. Help with LED's
  142. How far do you drive to your flying field?
  143. Flaperons
  144. Dremel cordless lithium
  145. Prep for covering new airplane
  146. Createx and Nelsons clear coat
  147. Staining Balsa?
  148. Futaba T6XA problems
  149. Nav Light Switch
  150. servo's
  151. Anyone know what this is?
  152. Zagi CG
  153. Hitec servo question
  154. Help...Monokote Wrinkling Under Vinyl Decal
  155. Sig 1/5 scale cub engine reccomendation
  156. Suggestions on 4-stroke eng for a Cessna Skymaster?
  157. Prop suggestion please
  158. Tips for Measuring Engine Thrust Angles???
  159. "Why Don't He Write" ??
  160. Is there a difference in CA brands?
  161. Bambula props
  162. 6v receiver batter
  163. Whats the dif between these types of flying?
  164. two models-two engines ?????
  165. Redundant battery install?
  166. tiger 2 w/2 servos
  167. Transmitter Channels
  168. a return to R/C, observations, okay mild rant
  169. Flaperons with a Futaba 6XAS and FMA M5?
  170. Glass filled engine mount
  171. Selling models
  172. Oz Cover and paint
  173. owners manual needed
  174. Four stroke Engine questions
  175. Engin Mount's Wrong Holes!!
  176. store info
  177. TRAINER CORD BUILDING HELP!
  178. determining flight attitude
  179. Clear coat
  180. Engine mount
  181. Um, kinda funny. plane retreival help please
  182. GP Realfight usb controller
  183. Sig SE Wing Tube, Carbon Fiber??
  184. Releasing CA
  185. Laminating Lite Ply
  186. i need a 15x12 3 blade prop
  187. Optiglo II
  188. covering iron question
  189. odd question
  190. Painting Foam
  191. Fuel consumption question, between Saito, OS, Magnum....
  192. Has anyone ever used this: Eagle Tree Systems R/C Flight Data Recorder
  193. HITEC 81 or 85 mg servos
  194. alternate Tx batts
  195. Alternate Way of Taking out CA Hinges other than debonder??
  196. Pinning A Hinge ?
  197. GEE BEE 120 size... Servos?
  198. What's in a servo?
  199. 27% CA Models Extra 300L Servos
  200. Fuel Proofing...How
  201. Give me R/C CODE....Not like BTW or ROFL...??
  202. Cutting sticks for framing
  203. Nail Polish instead of Acetone
  204. How to color CA
  205. Hobby stores in PA?
  206. GP Cap 232, Extra 300s, or Somethin Extra
  207. fuel tank problems
  208. To clearcoat or not to clearcoat
  209. PVC & CA
  210. static thrust on shrouded propeller
  211. Servo Throw question
  212. Hi-Tech Radio/Receiver Problem
  213. Flight Logs - Anyone keep these?
  214. ARGH!!! Fuel Eats Hangar9 Ultracoat Paint
  215. How to connect an LED indicator light?
  216. Futaba "G" Connectors?
  217. bison muffler
  218. A6M-Zero plans
  219. I want to build but not fly...YET.
  220. how to get part of screw out
  221. glow fuel shelf life?
  222. help!
  223. Installing engine on glass mounts.
  224. How do I catagorize my Testor's glue?
  225. Graupner Trainer 65 R/C Plane wing panels
  226. BIG CA reaction
  227. Fueling Question
  228. anyone have a link for Byron's planes ??
  229. servo control arms
  230. Grassy landing
  231. Servo blow out?
  232. A matter of degree
  233. problem with blind nuts
  234. Custom aircraft covers
  235. Flying Field
  236. ST 40 blue head ?
  237. Liability of Modification Kits?
  238. Newsletter picture/clip art source
  239. Airbrushing??????
  240. Silkspan and dope covering
  241. Scale airplanes
  242. How many Robart hinge points?
  243. Goldberg Eaglet
  244. Canopy Hatch
  245. Will it fly?
  246. Help please help me!!!!!!!!!!!!!!!!!
  247. 2 Electric motors turning same gear...
  248. How many Robart hinges to use?
  249. How do I convert control throw measured in inches to degrees
  250. Painting while Raining Outside????????
