PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. what do you do with your abs cowls
  2. os max 60 sr
  3. Genesys inflight alternator
  4. 2 blade to 3 blade?
  5. building table
  6. Wings, Engine, radiog gear, Empanage, NO FUSELAGE!!!
  7. Flexible Straightedge???
  8. Where's That 300 M.P.H Jet Video??
  9. euro kit spring air retracts
  10. Name that plane!!!
  11. 4-stroke: How Much Compression?
  12. hanger9 corsair retracts
  13. Best Epoxy for construction?
  14. Wrinkled wing tip covering
  15. Propellor Bore/Engine Shaft Clearance?
  16. Flexible pushrods?
  17. futaba J connectors
  18. Gyro for fixed wing aircraft
  19. Can i use any kind of wood?
  20. PLane Screensavers
  21. Covering Question
  22. plane choice for satio .91--please help. :)
  23. has anyone seen this flight box?
  24. Rustoleum primer over balsa
  25. Fuse Measurements?
  26. Why call it moneykote?
  27. Magnum 52 muffler
  28. propellor shaper
  29. Air ram
  30. Hitec QPCM HPD-07RH Reciever problem
  31. Digital LCD voltmeter selection/building
  32. What plane is this,???
  33. canard cg
  34. Here Piggy, piggy! SOUUUIIIEE!
  35. 4stroke fuel for 2 stroke
  36. Throttle connection query!
  37. H9 Edge 540
  38. Scratches when covering sheeting with Monokote.
  39. Remove #56 canopy glue?
  40. Irvine 53 and muffler questions
  41. Small Gas Engine
  42. OS91 upside down?
  43. paint schemes
  44. Ospray ?
  45. Could I Put Monokote in my HUGE gaps to lower flutter or eliminate it??
  46. We need a field to fly!
  47. got it
  48. Wildest, Brightest, Visible Colors?
  49. R138DP vs R148DP vs R149DP receivers..
  50. Substitute for Super Poxy Thinner
  51. To cover or to wait
  52. Mac's Muffler screw size
  53. Help me bend aluminum!
  54. Dyeing the canopy
  55. Can You make a leading edge
  56. HANGER9 CORSAIR/SIATO 130!!
  57. Taildraggers vs. Tricycle gear
  58. HOW DO U GET FUEL OUT OF BALSA
  59. Any .40 4-stroke WWI planes ?
  60. Reworking my CG Exteme 330
  61. "Top Flite Lustrekote" where I can get tem?
  62. Best Source of Information on Covering?
  63. Dope & paper covering question
  64. monokote over slick plywood sheeting
  65. Advice on Exhaust pipe under cowling?
  66. Wouldn't a Fully Sheeted Stained Plane w/ no Covering Look JUST GREAT
  67. I want to find LDM Industries
  68. OS .61 FS Fuel Pump??
  69. Source for 3/16" Nose Gear and Bearing
  70. How do you store your Planes
  71. Removing Monokote and that sticky "Trim Sheet" stuff
  72. k&b 61
  73. YS 63FZ
  74. Bladder Tank - how does it work?
  75. Need help: Polks Hobbys Tracker II question
  76. ARF Glow r/c airplane for short field?
  77. Shimitar Have Same "Effect" as APC props w/o the Weight?
  78. Pull-pull rudder?
  79. ACE Digital Commander Flight Pack
  80. moved thread....
  81. Myths
  82. painting a cub
  83. O.S. FT-160 Twin
  84. Where to get good pins?
  85. Do you HAVE to wrap Batteries in foam?? Necessary??
  86. antenna's
  87. Servo Centering
  88. Hazmat fees
  89. Ultracote
  90. How to find a new flying site?
  91. Foam wing construction
  92. Falcon 56
  93. WHO MADE THIS J-3 CUB?
  94. Zinger VS Zinger pro?
  95. Sport vs Pattern vs Pylon APC props
  96. Gorilla Glue?
  97. prop size
  98. Prop Spacer for Quadra 42
  99. Carburetor Air Filters
  100. what is a reverse nose gear?
  101. Ducted fans!
  102. convert my H9 120 US to gas........help!
  103. What covering iron is good out there?
  104. How to figure thrust degree on firewall
  105. Firm up a grass field
  106. TOPSTAR 60
  107. Where can I get Permagrit tools?
  108. Colored Epoxy
  109. Where do you buy your stuff?
  110. Pilot Figures
  111. SPRING AIR RETRACTS...WHERE TO GET 'EM?
  112. Gluto Glue for Decals on Foam
  113. Foam wing weight reduction
  114. Digital servos chattering?
  115. Gas Powered Park Flyer
  116. Problems with Model Products Remote Glowplug Head Lock Remote
  117. Best 2 stoke oil
  118. NORA
  119. Rotate a servo 90 deg
  120. Engine/Muffler cleanup
  121. Could I Use A Y-Harness to Connect 2 600 mAh batteries for longer flights??
  122. Which retracts for my new plane?
  123. body putty?
  124. Gorilla glue ?
  125. Brodak Butyrate Dope Finishing techniques.
  126. Funds for a new runway needed.
  127. Difference in glow plugs
  128. Clubs in Germany
  129. Pica Cessna 182 1/6 engine/muffler?
  130. Smoker For Cap 232
  131. UFO CA
  132. retract pressure guage
  133. Fuel
  134. Blind Nuts How do I?
  135. ESC compatability
  136. can the cold affect a servo?
  137. What prop to use on a kit Stinger 60??
  138. When to pump it?
  139. Retract Help
  140. Microballoons
  141. Really Cool Building Clamps - Origination??
  142. How do I upload a Picture?
  143. airfoils for a Heinkel he 111
  144. building equip
  145. Decibel meter
  146. Aresti 40 landing gear
  147. What is Synthetic Fuel?
  148. rip on koverall
  149. Engine power
  150. Higley Heavy Hubs?
  151. Discharging batteries
  152. Kadet Sr. Aileron Conversion
  153. transmitter damage due to antenna down while on (?)
  154. Prop for an OS 1.08 on the CG Extra300
  155. Charging batteries
  156. Can o' Worms?
  157. Spinner problem - really need help
  158. Covering
  159. Recovering turtle deck, HELP!
  160. looking for inflight altimiter????
  161. PROP SIZES?
  162. Nav Lights ARF
  163. Are 4-strokes better in the cold than 2-strokes?
  164. Radio's Old vs. New
  165. Stabilizer "incedence"? help please =\
  166. Spray paint or brush paint?
  167. storage for rc aircraft
  168. Help with Science Fair Project - Glues
  169. Saito four stroke
  170. YS 53 & Saito 65 performance?
  171. Suspending planes from ceilings
  172. Canopy Tinting
  173. HELP--Fuel line length for Saito .91 - How far is too far?
  174. New Wing, Flight Trimming problems!
  175. onboard glow starter??
  176. Gluing canopy to plane
  177. custom decals
  178. g-23 muffler
  179. polishing anodized aluminum?
  180. Engine Mount Question
  181. Supra Sport?
  182. Pin or not
  183. freesims?
  184. GMS .47 is there a better motor ?
  185. Pneumatic Retract Question
  186. The 'Perfect' Airplane Hobby Room
  187. Ikarus V90 controller
  188. Servo Jitter?
  189. 4.8v vs 6 volt servos
  190. soaked equipment
  191. building table
  192. Stab Alignment? Help please
  193. covering backing not attached good?
  194. Best way to "unclog" CA tips?
  195. Do You have a better idea about cowl mounting blocks?
  196. Snow skis
  197. Mounting a Fuji 32 on a Ultra Hots
  198. Your Favorite Tools...?
  199. Dirty Tricks??????
  200. PT20 Rebuild question, I goofed =\
  201. Anyone using the GP power plane?
  202. HobbyShack's "Flite-Kote"
  203. Best Aerobatic Planes
  204. Anyone from Cal-Grafx out there?
  205. fox .40 carb replacement?
  206. Diesel Conversion
  207. "Speed wings" for Sig Somethin' Extra
  208. Night Flying
  209. What is wrong?
  210. Weird Flying Behavior
  211. Getting Back in
  212. Builder Wanted for Fokker D VII
  213. How to set up Spring air Retracts w/doors?
  214. Robart instead of CA
  215. Illegal radios?
  216. Hey Experts!!
  217. 2mm die left hand and right hand needed
  218. RETAILER - HOBBEES.COM - KNOWN TO ANYONE
  219. Clearcoating waterslide decals
  220. Help identify this Biplane
  221. fiberglass or balsa?
  222. Lanier Razor 3D, good or bad?
  223. covering fuse on cub
  224. New Years Eve flight
  225. Ultracote transparent blue/green
  226. Need a June 1992 Model Airplane News
  227. Field Boxes
  228. Fuel soaked...
  229. anyone fly a gee bee
  230. ultra sport 60 need c off g
  231. After Dying Canopy?
  232. REPAIR PITTS MUFFLER
  233. HELP! Prop for O.S. 1.60FX
  234. I need an airplane rack system for my van
  235. Wingtip Changes/ideas. Neep Help!!
  236. Portable building board recommendations?
  237. Dynaflite Super Cub
  238. Oil or Oil less compressor for painting?
  239. Help Please.... I've been beat up by props....
  240. Owens-Corning "Insul-Pink" for table surface?
  241. Flexible exhaust pipes?
  242. ball links setup
  243. Deans 1003?????
  244. ap.09 running problems
  245. Please Help Me Plane doesnt receive signal or
  246. Kicker help needed
  247. servo leads "crash"
  248. Model shops in Egypt!
  249. STALLING
  250. Covering
