View Full Version : Questions and Answers
- servo's
- Anyone know what this is?
- Zagi CG
- Hitec servo question
- Help...Monokote Wrinkling Under Vinyl Decal
- Sig 1/5 scale cub engine reccomendation
- Suggestions on 4-stroke eng for a Cessna Skymaster?
- Prop suggestion please
- Tips for Measuring Engine Thrust Angles???
- "Why Don't He Write" ??
- Is there a difference in CA brands?
- Bambula props
- 6v receiver batter
- Whats the dif between these types of flying?
- two models-two engines ?????
- Redundant battery install?
- tiger 2 w/2 servos
- Transmitter Channels
- a return to R/C, observations, okay mild rant
- Flaperons with a Futaba 6XAS and FMA M5?
- Glass filled engine mount
- Selling models
- Oz Cover and paint
- owners manual needed
- Four stroke Engine questions
- Engin Mount's Wrong Holes!!
- store info
- TRAINER CORD BUILDING HELP!
- determining flight attitude
- Clear coat
- Engine mount
- Um, kinda funny. plane retreival help please
- GP Realfight usb controller
- Sig SE Wing Tube, Carbon Fiber??
- Releasing CA
- Laminating Lite Ply
- i need a 15x12 3 blade prop
- Optiglo II
- covering iron question
- odd question
- Painting Foam
- Fuel consumption question, between Saito, OS, Magnum....
- Has anyone ever used this: Eagle Tree Systems R/C Flight Data Recorder
- HITEC 81 or 85 mg servos
- alternate Tx batts
- Alternate Way of Taking out CA Hinges other than debonder??
- Pinning A Hinge ?
- GEE BEE 120 size... Servos?
- What's in a servo?
- 27% CA Models Extra 300L Servos
- Fuel Proofing...How
- Give me R/C CODE....Not like BTW or ROFL...??
- Cutting sticks for framing
- Nail Polish instead of Acetone
- How to color CA
- Hobby stores in PA?
- GP Cap 232, Extra 300s, or Somethin Extra
- fuel tank problems
- To clearcoat or not to clearcoat
- PVC & CA
- static thrust on shrouded propeller
- Servo Throw question
- Hi-Tech Radio/Receiver Problem
- Flight Logs - Anyone keep these?
- ARGH!!! Fuel Eats Hangar9 Ultracoat Paint
- How to connect an LED indicator light?
- Futaba "G" Connectors?
- bison muffler
- A6M-Zero plans
- I want to build but not fly...YET.
- how to get part of screw out
- glow fuel shelf life?
- help!
- Installing engine on glass mounts.
- How do I catagorize my Testor's glue?
- Graupner Trainer 65 R/C Plane wing panels
- BIG CA reaction
- Fueling Question
- anyone have a link for Byron's planes ??
- servo control arms
- Grassy landing
- Servo blow out?
- A matter of degree
- problem with blind nuts
- Custom aircraft covers
- Flying Field
- ST 40 blue head ?
- Liability of Modification Kits?
- Newsletter picture/clip art source
- Airbrushing??????
- Silkspan and dope covering
- Scale airplanes
- How many Robart hinge points?
- Goldberg Eaglet
- Canopy Hatch
- Will it fly?
- Help please help me!!!!!!!!!!!!!!!!!
- 2 Electric motors turning same gear...
- How many Robart hinges to use?
- How do I convert control throw measured in inches to degrees
- Painting while Raining Outside????????
- what do you do with your abs cowls
- os max 60 sr
- Genesys inflight alternator
- 2 blade to 3 blade?
- building table
- Wings, Engine, radiog gear, Empanage, NO FUSELAGE!!!
- Flexible Straightedge???
- Where's That 300 M.P.H Jet Video??
- euro kit spring air retracts
- Name that plane!!!
- 4-stroke: How Much Compression?
- hanger9 corsair retracts
- Best Epoxy for construction?
- Wrinkled wing tip covering
- Propellor Bore/Engine Shaft Clearance?
- Flexible pushrods?
- futaba J connectors
- Gyro for fixed wing aircraft
- Can i use any kind of wood?
- PLane Screensavers
- Covering Question
- plane choice for satio .91--please help. :)
- has anyone seen this flight box?
- Rustoleum primer over balsa
- Fuse Measurements?
- Why call it moneykote?
- Magnum 52 muffler
- propellor shaper
- Air ram
- Hitec QPCM HPD-07RH Reciever problem
- Digital LCD voltmeter selection/building
- What plane is this,???
- canard cg
- Here Piggy, piggy! SOUUUIIIEE!
- 4stroke fuel for 2 stroke
- Throttle connection query!
- H9 Edge 540
- Scratches when covering sheeting with Monokote.
- Remove #56 canopy glue?
- Irvine 53 and muffler questions
- Small Gas Engine
- OS91 upside down?
- paint schemes
- Ospray ?
- Could I Put Monokote in my HUGE gaps to lower flutter or eliminate it??
- We need a field to fly!
- got it
- Wildest, Brightest, Visible Colors?
- R138DP vs R148DP vs R149DP receivers..
- Substitute for Super Poxy Thinner
- To cover or to wait
- Mac's Muffler screw size
- Help me bend aluminum!
- Dyeing the canopy
- Can You make a leading edge
- HANGER9 CORSAIR/SIATO 130!!
- Taildraggers vs. Tricycle gear
- HOW DO U GET FUEL OUT OF BALSA
- Any .40 4-stroke WWI planes ?
- Reworking my CG Exteme 330
- "Top Flite Lustrekote" where I can get tem?
- Best Source of Information on Covering?
- Dope & paper covering question
- monokote over slick plywood sheeting
- Advice on Exhaust pipe under cowling?
- Wouldn't a Fully Sheeted Stained Plane w/ no Covering Look JUST GREAT
- I want to find LDM Industries
- OS .61 FS Fuel Pump??
- Source for 3/16" Nose Gear and Bearing
- How do you store your Planes
- Removing Monokote and that sticky "Trim Sheet" stuff
- k&b 61
- YS 63FZ
- Bladder Tank - how does it work?
- Need help: Polks Hobbys Tracker II question
- ARF Glow r/c airplane for short field?
- Shimitar Have Same "Effect" as APC props w/o the Weight?
- Pull-pull rudder?
- ACE Digital Commander Flight Pack
- moved thread....
- Myths
- painting a cub
- O.S. FT-160 Twin
- Where to get good pins?
- Do you HAVE to wrap Batteries in foam?? Necessary??
- antenna's
- Servo Centering
- Hazmat fees
- Ultracote
- How to find a new flying site?
- Foam wing construction
- Falcon 56
- WHO MADE THIS J-3 CUB?
- Zinger VS Zinger pro?
- Sport vs Pattern vs Pylon APC props
- Gorilla Glue?
- prop size
- Prop Spacer for Quadra 42
- Carburetor Air Filters
- what is a reverse nose gear?
- Ducted fans!
- convert my H9 120 US to gas........help!
- What covering iron is good out there?
- How to figure thrust degree on firewall
- Firm up a grass field
- TOPSTAR 60
- Where can I get Permagrit tools?
- Colored Epoxy
- Where do you buy your stuff?
- Pilot Figures
- SPRING AIR RETRACTS...WHERE TO GET 'EM?
- Gluto Glue for Decals on Foam
- Foam wing weight reduction
- Digital servos chattering?
- Gas Powered Park Flyer
- Problems with Model Products Remote Glowplug Head Lock Remote
- Best 2 stoke oil
- NORA
- Rotate a servo 90 deg
- Engine/Muffler cleanup
- Could I Use A Y-Harness to Connect 2 600 mAh batteries for longer flights??
- Which retracts for my new plane?
- body putty?
- Gorilla glue ?
- Brodak Butyrate Dope Finishing techniques.
- Funds for a new runway needed.
- Difference in glow plugs
- Clubs in Germany
- Pica Cessna 182 1/6 engine/muffler?
- Smoker For Cap 232
- UFO CA
- retract pressure guage
- Fuel
- Blind Nuts How do I?
- ESC compatability
- can the cold affect a servo?
- What prop to use on a kit Stinger 60??
- When to pump it?
- Retract Help
- Microballoons
- Really Cool Building Clamps - Origination??
- How do I upload a Picture?
- airfoils for a Heinkel he 111
- building equip
- Decibel meter
- Aresti 40 landing gear
- What is Synthetic Fuel?
- rip on koverall
- Engine power
