PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. How much nose down when balancing plane?
  2. Kit Cutters From Plans
  3. Prop Balancing 14 and 15 inch diameter props
  4. Vinyl cutter for names and trim items
  5. OS 120 FS engine - older - pre Surpass
  6. Smoke pump / receiver RF interference??
  7. helicoil
  8. Real Time Mixture Control
  9. ACE Wheel Pants
  10. What is it?????
  11. Lazy Bee Parts....Help
  12. Prop Question... Help
  13. GP Spinners????
  14. Inverted pitts muffler for ys 110? Please?
  15. Old RC equipment
  16. Multiplex Twin Jet Accesories
  17. Inflight variable pitch props. HELP!
  18. How to get CAD dimensions from a file??
  19. BTA Autopilot Systems
  20. Tape Over Hinge Gaps?
  21. Quick Prop Question !!!!!!!
  22. Aileron failure?
  23. Cold weather flying
  24. Glo-Bee Tach;
  25. Ultracote Violet
  26. Retracts
  27. How to go overseas and still fly?
  28. Cg for Hangar 9 Edge 540 1/4 scale
  29. Prop/Spinner installation
  30. Airtronics rd 6000 super / buddy box
  31. Need info on setting up 9C futaba trans. for Ultra stick
  32. Heavy duty switch wiring?
  33. Servo Reversal in U-Can-Do 3D
  34. flaps on GP p-51 40 kit
  35. Thunder Tiger Pro .25 carb
  36. Pitts CG need help!!!
  37. Aileron throw on Biplane?
  38. imposible Super Tigre S-90
  39. GP Ultimate Pictures
  40. battery checker - where do I plug it it?
  41. Freak signal causing crash?
  42. MACS SMOKE SYSTEM
  43. Tailwheel spring tension
  44. need nenya manuel
  45. 21st paint
  46. Primming a Cowled Engine ??????
  47. Sugestions for overseas trip-What plane?
  48. Leading Edge and Sheeting Repair?
  49. thunder tiger .20
  50. Purchase HELP!!!
  51. Longer 8-32 socket head screws?
  52. Center of gravity
  53. adding a trainer plug to my sanwa tranny
  54. Engine for GP Extra 300S .40 ARF
  55. O.S. .46FX W/ .50 SF Piston and Sleeve
  56. Finishing question for painters
  57. Inverted engine problems?
  58. Windex Method
  59. df thrust formula
  60. Slimline Extreme Pilots?
  61. OS 48 SURPASS
  62. What engine for my plane? HELP!
  63. Painti9ng glow models?
  64. Aileron Trainer
  65. Needle valve
  66. parachute recovery system
  67. Redundant battries - what size plane ?
  68. How nose heavy
  69. electric starter
  70. SIG supercoat
  71. 2 part marine epoxy varnish
  72. DuBro smoker valve
  73. low end adjustment
  74. Kyosho 232
  75. Redundancy.
  76. Howard Pete
  77. Removing adhesive from balsa
  78. Wing loading, what am I doing wrong!?
  79. Wing moves when bolted down
  80. What's the new name for K2 spot remover?
  81. I've never used pinstripe. Will it stay on?
  82. Electric Motor Question
  83. Making Skis
  84. p51 byron (power)
  85. Sealing edges of ultracoat
  86. stik 20
  87. Storage?
  88. best electric starter/battery
  89. IDEA
  90. How to make smoke fluid/oil?
  91. Is an OS 70 (4S) big enough for a DPM ultimate 40?
  92. Reducing Airspeed?
  93. Where to buy
  94. rockwell international p51
  95. Ailerons/Flaps or Flaperons
  96. How much length to my wing should I add??
  97. NEED A LINK
  98. Opinion on the Thunder Tiger FS-91S
  99. Servo reverse possible?
  100. Engine Tuning
  101. Help me decide...Lancair 60 ARF or Heli Raptor 30 v2?
  102. The correct spinner question
  103. .40 sized brakes?
  104. Who is an epoxy expert?
  105. Easy way to spot neg-rot???
  106. Are there any RC Shows on the Airwaves?
  107. Replacing a bent needle valve body in a Saito 56
  108. shops in the uk
  109. airfoil
  110. Jemco PT19 Fairchild Kit
  111. run testing an engine!
  112. Where to buy Nylon Wing Bolts?
  113. engines
  114. Bending push rods?
  115. bipe wing offset
  116. WED SITES!
  117. HELP! I need one JR4721 and I need to know what the torque is on a JR 4011 servo
  118. Breaking in an OS46FX
  119. Fuel Line Harding (Gasser)
  120. Hanger 9 T-34 cowl
  121. Cargo plane in "Flying Tigers"
  122. To G2 or not to G2?
  123. Fiber optic kill switch?
  124. Smoke for my OS 70 SURPASS??
  125. Fuel filler
  126. Air America Movie
  127. Fuel Proof Enamel ??
  128. latex paint help
  129. OS 91 FX
  130. CF LG failures?
  131. Which Glue
  132. Goldberg Ultimate C/G, how far back can you go?
  133. magnum 4T 120FS - prop
  134. Custom CF Spinner?
  135. Carbon Fiber Q-500?
  136. big stik 40 underpowered?
  137. Mounting a G26 in Cermark Pitts
  138. CG and side mounted engine
  139. Antenna Routing !
  140. Painting over covering
  141. prop. numbers/ sizes
  142. Goldberg Sr Falcon PLans
  143. Smoke set up
  144. Sturdy Landing Gear For Ultra Hots
  145. What's the cheapest trainer out there?
  146. How do you build the left wing if you have only the right wing on plans
  147. Glow Plug Idle Bar
  148. Formation Lights
  149. Interference with engine at full power
  150. HELP! need paint to match oraover.
  151. 3 or 5 views where to look
  152. Bent crank shaft???
  153. what to do/how to sell etc
  154. airvista wing
  155. Where to fly in Montgomery Alabama?
  156. Chicken Stick??
  157. Which is better? O.S. 70 or Saito 72
  158. How much is enough servo torque?
  159. modeltech magic
  160. covering too old?
  161. Removal of CA Hinges
  162. Engine Placement on AT6 does 1/2 in matter ?
  163. Parts box, and rebuilding plane.
  164. NEED HELP LOW WING PLANE WILL NOT TAXI
  165. os 46 not enough for a ucd 46?
  166. What size prop for a u can do 46?
  167. Computer Radios
  168. Fuel?
  169. Building from plans, need wood advice
  170. Laws and Rules around airports
  171. enya 120...4-c
  172. engine diagrams
  173. Carbon fiber ultracote covering
  174. 12V Power Supply hook-ups
  175. Pull Pull Controls
  176. DEFECTIVE AVISTAR BOUGHT FROM TOWER HOBBIES
  177. 40 size edge
  178. airplane design
  179. PURCHACED AVISTAR FROM TOWER HOBBIES THAT BROKE APART IN MID AIR HELP
  180. Ailerons Size For Biplanes?
  181. Retracts? - Graupner SuperAir
  182. Field Interference?
  183. Multiplex Modul 72 MHZ
  184. Prop suggestions for Moki 135?
  185. Water soaked serveros and reciever
  186. Slow down
  187. how do you folks tell where trees are?
  188. Exhaust routing
  189. What could cause this?
  190. How do I hinge flight controls in foam?
  191. tools
  192. hobbico quick field charger
  193. 96 extra recovering covette to monokote
  194. "RC PLANE HANGAR"
  195. Is Lite Ply ribs in a 85" wingspan plane overkill?
  196. Recess for Robart Hinge points?
  197. Paint
  198. Props at altitude
  199. Balsa USA Phaeton II
  200. Need info on Accu-Tach/Service
  201. Whats best for smoke?
  202. Use of gyros in A/C?
  203. Plane is it good??
  204. .40 planes
  205. need to find asp
  206. Delta Drill Press
  207. Joining a club, .40 Size?
  208. If K&S Engineering doesn't have it, I guess it doesn't exist?
  209. Gas??
  210. I give up! Where do you find a silly little Aluminum extension block??PICTURE...
  211. Where is a flying field N-NW of Houston, TX?
  212. Glow Or no Glow
  213. big bee 60"
  214. Gator RC retracts...anyone tried them?
  215. engine cuts off because of fuel tank. need help
  216. Ideas for Fixing a broken Vert. Stab???
  217. Lightweight pilots?
  218. Smoke questions
  219. DVIII Color Scheme
  220. SAITO 100 Break-In
  221. Robart Hinge points installation
  222. ECU?
  223. Retracts
  224. Guarantees
  225. Closed Loop (Pull-Pull) Questions
  226. butyrate paints?
  227. Slow down a servo?
  228. How much is too much weight to add to the nose?
  229. Hard Landing or a Crash
  230. Custom Fieldbox
  231. Fuel soaked balsa.
  232. what engine to use in a gp u-can-do 3d .46
  233. Spinner for APC Props
  234. Backyard flying
  235. My First Air Compressor
  236. Best Model for a Windy Day ???
  237. Fun with extra channels
  238. building propellers
  239. Shipping a "Giant"
  240. Servo Repair Suggestions and or Guidance
  241. Frequency Scanner
  242. Electronic Speed Control
  243. Hobby Industry resume???
  244. How do you align and drill holes for your control horns?
  245. FG series charger/ battery
  246. Help and idiot like me understand international ordering
  247. Big Stick Covering New/Old??
  248. Gee Bee's
  249. glue accelerator
  250. Props for ASP .91 & YS .53
