PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102
  1. CF Wing Tubes????
  2. Retracts
  3. Planes?????
  4. Vinyl Sticker Printers
  5. Where to buy Futaba contacts and housings?
  6. OK MY PROP ? again take 2
  7. tiger moth problems
  8. saito's and mufflers
  9. Falcon56 CG?
  10. Scale - for weighing RC aircraft
  11. graupner extra 300s or cap 232
  12. HOW DO YOU CLOCK YOUR PROP?
  13. Cowl for Joss Stik
  14. Harry Higley Spinner Nuts
  15. Best method for applying fiberglass to wing center section?
  16. Sig 1/4 scale SpaceWalker II CG?
  17. great planes j3cub engine size
  18. MOVED: New RCU sweet!
  19. Magnum .91 XLS/Pitts
  20. shipping Questions
  21. Where to get velcro strips? Please help.
  22. Fuel Systems
  23. Flying field in Costa Rica
  24. Glue applicator
  25. Convert from fuel to electric
  26. 1/8 ply or CF plate.
  27. Need help with 540 Edge landing mushy !!
  28. Plans
  29. fuel for os91 4 stroke???
  30. pull-pull rudder cables
  31. inflight adjustable pitch props
  32. Richmond R/C
  33. anyone flown the Laser Arrow?
  34. Photos
  35. Calculate servo torque
  36. hal2100 autopilot
  37. which cheap TOY plane for evening fun??
  38. You prefer 9252 Digital, or 9402 Analog Coreless b.b. ??
  39. Pusher Exhaust question
  40. OH #### I BROKE A PROP?!!
  41. Airplane specs for an OS 40 Surpass
  42. Quantum Models order from hell
  43. Can I smoke with a magnum .28 2-cycle??
  44. Super Hots
  45. Futaba vs Hitec?
  46. Ultracote Paint
  47. Carbon Fibre Prop Balancing
  48. ucando maneuvers where to find
  49. Small aluminum plates
  50. cg and Carl Goldberg Sukoi 73”
  51. how to slow retacts down
  52. Spokane area?
  53. end point adjustment for flaps
  54. Patriot
  55. Play between split elevator halves normal?
  56. pull-pull cable strenth ?
  57. ucando
  58. SIG Seniorita
  59. Web Sites
  60. Good 4-40 die
  61. Uncontrolled Loops ?
  62. I NEED A JR AM CRYSTAL ON CH 58
  63. correct my info plzzzzzz
  64. double servo tray?
  65. Old Plane?
  66. Phoenix Models Giles 202 46 ARF
  67. Dynamix parts??
  68. What to do when supplier is wrong but wont budge ?
  69. No right or wrong on pull pull?
  70. Do you need a licence to fly rc planes
  71. Hobbico Accu-Cycle how to charge 1000mah pack
  72. where to buy worldtex fab
  73. Remote Starters???
  74. Center of Gravity 20%
  75. 3IM
  76. Servo wheels for Hitech?
  77. Swapping Servo Connectors
  78. four star 40 engine mount
  79. Removing bolt after epoxied?
  80. fabric cleaning
  81. Bondo (Plastic filler)
  82. tiger moth big problems
  83. A Leaky Needle valve on OS 40 FX???
  84. uproar
  85. Oil-lubed compressor with air brush?
  86. mds 218 engine What fuel do you use?
  87. Milk Bottle Combat??
  88. Servo Grease
  89. CG for Sig Kadet LT-40
  90. Tail wheel/elevator question/problem?
  91. Iron bay regulator vs Cline Regulator
  92. Building tin/stainless sheet metal fuel tank?
  93. Can you keep the antenna inside the fuselage?
  94. Storing my planes outside in a cold building during winter
  95. Could some one tell whats the spoilerno?
  96. CG
  97. XF props
  98. landing gears
  99. Looking for someone that can recover a airframe
  100. Seagull Strearman, what engine and CofG
  101. Gas/glow Vs Electric RCplanes comparison?which is better,pros &cons?
  102. HOW TO JOIN A CLUB????
  103. Monokote over Ultrakote???
  104. Fuel line
  105. decals
  106. Mascot or Pilot figure pics
  107. Engine Decisions
  108. what does 1/24 scale mean
  109. Rear Exhaust
  110. Walter mitchell whereabouts?
  111. what to put behind fs40?
  112. Help on clubs!
  113. Mounting of Rear Carb 3W Engine
  114. Unknown Flutter
  115. Center of gravity
  116. engine mounting question
  117. ENGINE THRUST?
  118. paint
  119. do extras nose tuck with rudder?
  120. needle valve question
  121. 46 SF needle assemby needed
  122. what is a oldtimer plane
  123. Eagle 2 ARF & 4 Stroke Engine
  124. metalurgy
  125. Mechanical advantage?
  126. Is there any Duct Fans for Gas engines
  127. Rounding Leading Edge On Sheet Stab
  128. Perfect Paint over Balsarite ??
  129. GP Super Sportster
  130. MOKI 1.35
  131. Smoke Fuel
  132. GWS slowstick conversion
  133. Balancing question ?
  134. Can you apply decals with epoxy?
  135. Removing covering
  136. Ultra Stick 120 questions
  137. Hobby Shops in St.Louis area
  138. how to diesel fuel's smoke colour?
  139. 4*60 with TH .75 2st
  140. Do you think engines have a memory ?
  141. FMA FS5 receiver?
  142. Engine forum
  143. Is there any Pitts Specials kit at 60 size
  144. Airplane engine
  145. on board glow driver
  146. Which fuel pump.......Kavan or Slimline?
  147. fuel for an older OS engine
  148. Exhaust flex-tube mounting
  149. Exaust deflector.
  150. Jittery rudder
  151. Starter crapped out?
  152. Info on a T-28...
  153. Great Planes Pushrod Connectors
  154. What Gyro to use?
  155. Recovery Parachutes
  156. where to buy carbon rods
  157. who handles byron's now
  158. fox eagle .74
  159. How to install my elev
  160. Competitions
  161. 25 - 33%
  162. Supra Retracts
  163. The Better Cub / 80" to 100"
  164. Off the wall question...
  165. Fiberglass or ABS Cowl for Astro-Hog
  166. What is pizzabox style?
  167. CA Models Widebody 40 - CG & Throws?
  168. Fuel proof paint
  169. Flutter
  170. Wanting to instal a smoke system, HELP!!
  171. Electric to Nitro conversion, Sky Scooter
  172. SIG Hog Bipe Landing Gear
  173. Cessna stand off scale
  174. stand
  175. help ID this Skylark
  176. ? about pull pull set up on Morris Topcap
  177. HB Engines Designation Question
  178. Where can you buy K2R spot remover?
  179. Cheveron Perfect Pain over Monokote products
  180. ? Fuel proofing decals
  181. flying in a dusty environment
  182. How to use decals?
  183. Receiver "ON" indicator
  184. Rocket City Wing Bolt Source?
  185. Question about Fox 36 and YP .60 Engines
  186. Electonic basics
  187. Good Size Engine????
  188. ca hinges thick or thin glue?
  189. Christen Eagle Pics
  190. Lustrekote Primer
  191. Sig Tristar
  192. Sig King Kobra
  193. Web Site
  194. servo gear broken tooth?
  195. Retracts
  196. tuned pipe Tower 61?
  197. Robin Hood 80 CG
  198. question on a Perry pump
  199. Midwest "Hots" or at least I think thats what it was called
  200. New Dazzler, need help
  201. Glue clips
  202. GP Ultimate Bipe Ant. Route
  203. What Happened To Model Magic by Dave Patrick?
  204. I Have a 3W extra 40%- How much should it weigh??
  205. Thrust
  206. Need Help Starting Hangar 9 Alpha
  207. .60 size edge 540
  208. Trainer Nose Gear.....best ?
  209. Quality difference between TRUE TURN or DAVE BROWN 3.5"alum. spinners?
  210. Confused on pull pull????
  211. Aileron and Elevator servo Mixing
  212. Why the mystery?
  213. combining servos
  214. most user friendly covering?
  215. Air Filters are they any good?
  216. 2servo aileron installation
  217. dirty 4 cycle engine after cleaning new rings and honed or not
  218. Why use a prop reamer?
  219. How to keep exhaust deflector on?!!?
  220. Sealing off Control Surface gaps
  221. gws servos and horns
  222. Control Rod Question
  223. Multiplex UK?
  224. Does anyone fly a Profile Hots?
  225. Best Fuel for Saito .56 GK at 7,500 Feet
  226. How to: part or kit replacement?
  227. Dirty Birdy
  228. pull-pull control systems
  229. Most visiable color to cover plane
  230. Airplane Restraint/Hold-Down
  231. If you could have only one.. which one..
  232. Latex paint
  233. What type of extra is this
  234. flaperons on 4*60
  235. Relationship between prop, RPM & Torque
  236. Dynaflight PA-18 adverse yaw
  237. Where to get P-03 F3A ribbon Diagram?
  238. setup question
  239. Where to buy a ys engine?
  240. My World Model Spitfire flys like a rock
  241. Yellow Aircraft Sukhoi
  242. Help - Looking for remote igniter & starter
  243. Rookie (former flyer) need the experts help to get back into flying
  244. Taking paint/dope out of the can?
  245. grommet position
  246. OK Models F16
  247. Hanger Rash/Camera/Receiver Battery/Sky-writing
  248. how to make actuators
  249. After Run Oil
  250. Has anyone used "Center Wing Plug"?
