PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102
  1. how to make actuators
  2. After Run Oil
  3. Has anyone used "Center Wing Plug"?
  4. Don't ya need a special prop for park flyers?
  5. Horiz Stab flutter
  6. servo help
  7. Fuel Filler Brand?
  8. Dubro swivel ball links safe?
  9. Engine life
  10. Ultra Coat...people who know help
  11. mounting tank across fuz.
  12. Clancey models
  13. DP Ultimate Landing Gear Replacement?
  14. Newbie + OS .46 LA = Starting Problems
  15. control horns
  16. Hitech Eclipse radio
  17. Engine Mounting Question !!!!!!!!!!!
  18. Super Coverite and Dope.
  19. Need a new plane!!!!
  20. Difference between TT 40 and 42
  21. Wacos
  22. Senior Telemaster + ASP 1.08???
  23. storing a large plane
  24. Great Planes Learjet 40 problems
  25. Ultra Stick 40 / Fuselage Access Panel
  26. Question on JR DS8411's
  27. Spray Paint Help Needed!
  28. Where to buy APC 14 x 4 prop?
  29. fiberclasicsp51
  30. Reliability!?!
  31. 4*40 tailwheel
  32. GP Extra 300S 40 size
  33. Sport, 3-D, Fun Flyer, Park Flyer
  34. heli gas in airplane engine
  35. need help with 4*40?
  36. EDGE 540 or CAP 232
  37. OS 160 with Bisson Pitts muffler
  38. Side thrust GP RV4
  39. Found plane
  40. Chroming Cylinder Heads
  41. Model Products Ultimate 120?
  42. attaching parchment paper templates to wood?
  43. connecting 3/16 plywood sheets end to end????????
  44. looking for a company, Ram-Air??
  45. Remote Camera Operating
  46. I need to make a Siren sound for Plane!
  47. Nelson Hobby ?
  48. 6inch wheels
  49. Pilot Diablo
  50. Dremel Tool = POS?
  51. Ultracoat and automotive paint
  52. need help with ordering from harbor freight
  53. Fuel Tank setup
  54. shipping
  55. Need R/C TRAILER info & advice
  56. Is a tail wheel necessary on grass?
  57. baffle
  58. How to make cheap remote glow ignitor?
  59. Monokote 'Smart Stripe' cutting tool is a POS.
  60. Skis on Trainer
  61. Aeileron Plug for GP DR-1
  62. GWS P51 - too heavy / underpowered?
  63. mounting a muffler on a soft mounted engine?
  64. What constitutes a first plane or trainer?
  65. Matching covering
  66. Dual fuel tanks question
  67. Fuel Line
  68. testors spray gun
  69. Nieuport 28 2 piece wing
  70. 14x6 prop does not fit
  71. Muffler back pressure
  72. Alternative wrapping mat'l ???
  73. Super Stinker - 2 Or 4 Servos on Ailerons ??
  74. Fuelproofing Krylon
  75. What is Pattern / 3D / Aerobatic
  76. Wirwing
  77. Ikarus Gyros
  78. Black exhaust residue
  79. world model p-51 retracts??
  80. 2 Quick Questions ? :)
  81. Leaky tank
  82. air retract hookup
  83. Water Cooler
  84. Homemade Graphics
  85. Saito 150 - Graupner 15x8 3 blade, which Spinner will fit this prop???
  86. looking for a small piece of polycarbonate
  87. Fuelproofing something already soaked
  88. props
  89. Ultimate Bipe servo question
  90. painting aluminum
  91. Tumbalina
  92. Muffler for Thunder Tiger Pro .61
  93. my first crash
  94. Engine Recommendations
  95. Tips for Aerobird, Fighterbird and Firebird Pilots
  96. Hanger 9 Funtana
  97. Anyone have plans for a home-built tachometer?
  98. H-9 Super Stick and Saito 91
  99. Z-Best Engine Cleaner
  100. Finding the Ultimate Field Box
  101. Problems finding the C of G
  102. Propeller size
  103. ucando control surface problems
  104. Fuel tank hook-up
  105. Convert 1 piece wing to 2 piece wing?
  106. need help with GP gas power pod
  107. New TX
  108. How do you tint a canopy?
  109. Battery Charger Question !!!!!!!!
  110. Phaeton 90
  111. Landing Gear for DP Extra
  112. Anyone remember "Ultra R/C Products"
  113. Moki 2.10 smoke system?
  114. Hangar 9 Edge540 covering
  115. Thrust Line?
  116. ys 4 stroke
  117. Landing gear question, part 2
  118. Uproar Cg
  119. How to replace clip that holds needle valve
  120. Engine and Radio suggetions for 8' Senior Telemaster
  121. Swift Electronic
  122. Things you won't find at the hobby shop.
  123. How do I use a tachymeter? tachometer
  124. Gee Bee Y
  125. Battery for Futaba FP-T5FG/K
  126. 3d Flying
  127. Prop Size
  128. H-9 Super Sport 60 Wing Bolt???
  129. Cambria(n) Funfighter kits
  130. Flying Models Magazine
  131. any tips to repair main spars
  132. close
  133. Installing a larger engine than recommended
  134. alpha trainer bubbles in covering/ steerable nose gear
  135. G.P Shoestring ARF
  136. Robart Super Fueler connections
  137. Robart air valve problem?
  138. Banner Towing
  139. Dual Starter Batteries
  140. How do I Clean an Engine?
  141. where can I get the rcaerosport logo?
  142. why is lusterkote so expensive?
  143. CA glue applicators
  144. How do you remove epoxy stains from covering?
  145. VQ Models ? Looking for Info
  146. seized glow engine
  147. Super Sportster Questions
  148. Irvine 61 prop??
  149. font style for aircraft numbers
  150. JR10X vs JR10SX
  151. trimming question
  152. Midwest Attacker
  153. Battery question/need help
  154. 1/4 scale plan Neiuport 11
  155. Need Help! What plane is this?
  156. Dose anyone make a .60 to .120 christian eagle
  157. Converting landing gear question
  158. Need help to identify gas engine
  159. Goldburg Extreme 330L - Wing rib repair and replacement
  160. Kyosho Agwagen question
  161. What ARF for 1.60 twin?
  162. Real Time Air Speed Indicator
  163. Can someone identify this plane???
  164. Starting Problems ??
  165. Pull Pull setups
  166. 4 blade prop
  167. 4 blade prop
  168. Futaba & Jr
  169. Piano wire jig method
  170. Flaps on a Great Plane Easy Sport 40
  171. Painting?
  172. composite or aluminum landing gear
  173. Towing the banner ?
  174. Paypal?
  175. other than epoxy??
  176. 3d?
  177. radio and receiver for giant scale cap 232
  178. Du Bro Transmitter Tray
  179. LT-40 Nose Tail Info
  180. SUKHOI 71" span Need Info!
  181. electric brakes
  182. FMA Copilot help
  183. Home for OS .46LA
  184. looking for fiberglass landing gear
  185. 21st century fabric
  186. Sterling Stearman Question
  187. Four Star 60 question
  188. Converting the Hobbistar to Bolt on Wing
  189. plastic 5" spinner
  190. Need Help With Ohio Rc Ultimate
  191. where to buy Mezlik props??????
  192. How Do I Paint My Monocoat And Make It Stick
  193. Building Cockpit dash
  194. Battery in the tail......How to..?
  195. Painting oracover???
  196. Making A Lithium Cell Battery Pack.
  197. Firewall Repair Advise - Hobbico Avistar
  198. Fueling valve location?
  199. Clear Coat Fuel Proof
  200. How do I fill tank when fuel lines are in cowl?
  201. where did it go?????
  202. where to buy in Europe
  203. Anyone dealt with Flyhobbies.com?
  204. Satio 150 compresson problems
  205. Radio problem
  206. Hobby Shop franchise
  207. To Flap or not...
  208. tractor prop 2 pusher
  209. Epoxy Cure problem
  210. bushing or not?
  211. 60 engine review
  212. decals
  213. Ultracote Paint
  214. what size electric to 040 fuel?
  215. PLEASE HELP!!-Can I redrill this prop?
  216. Dyna Flite PT 19
  217. Question about Transporting Planes
  218. Prop balancing
  219. More Time In The Air Less Time On The Ground
  220. 1 Hour Epoxy?
  221. Balance methods?
  222. what do i need to tell the blue print shop about enlarging my plans?
  223. Finish
  224. can these plans still be enlarged???
  225. I need HELP on EXTRA 300
  226. wing repair question
  227. Sail"CAR" Anyone???
  228. Ready2 on floats: CG?
  229. Best Brushless Electric Motor?
  230. Dual Receivers??
  231. Tapeing Control serfaces, whats the deal?
  232. Tucano by "The Amano Factory" Background??
  233. Engine won't stay running
  234. Byron Corsair--Size of Engine and Center of Gravity?
  235. K-2 Spot Remover has a new name
  236. KUDOS..! SONIC TRONICS Mnftnrng
  237. What is this called & where can I get one?
  238. Making paper plans transperent
  239. 76" Lazy Ace
  240. pictures??? How do I..................
  241. Ca
  242. 4*60 Cowl Question
  243. Hyde Soft mount
  244. Twin Tank Setup
  245. FM vs. PCM
  246. C/G for ziroli zero
  247. 4 stroke engine
  248. Spinner size
  249. World Models Cap 232
  250. easy motor mount machining - where to go??
