PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99 100 101 102
  1. C-3603 Questions for the Swiss modelers
  2. Sullivan start cone...?
  3. Charging Question ?
  4. Black Horse Home Run Landing gear problem
  5. How to make good pushrods
  6. recovering
  7. Spacing--Spinner backplate too cowl??
  8. Want To Add An Additional Tank
  9. T-34 ARF construction advice
  10. Power Panel, Which One?
  11. Mechanical Retracts - Any good
  12. "Senior Frontier" by World Models? (found it, never mind)
  13. Looking for a canard
  14. Cub tires coming off rims!! Help!!!!!
  15. APC Prop problem
  16. Kange arf's
  17. Robart Robo Struts Help
  18. Calculating wing area, are wing tips outboard last rib included?
  19. del this i oops'ed
  20. Servo grommet and eyelet
  21. Pilot painting tips...It's finished, thanks! Pics of pilot..
  22. Online hobby stores?
  23. Feedback ?
  24. clunk problems
  25. os .25 FX questions
  26. CG Ultimate 10-300
  27. is this a real futaba controler?
  28. Kevlar for pull pull.
  29. Wood screw size
  30. What prop do you use?
  31. engine for funstar 3D
  32. Fox Engines
  33. Need some help with..
  34. older radios still AMA legal?
  35. super coverite edges
  36. Hinges-Top, bottom or centre
  37. Four quick questions
  38. Dynathrust prop incident
  39. whats a good advanced arf
  40. What is best working in cowl mufler to GMS 1.20 engine?
  41. Charger diagram
  42. Zinger Prop Reamed Too Small
  43. Servo Horn and Surface Horn configuration, your thoughts please.
  44. Scale Builing techniques
  45. Robart hinges
  46. Cline Regulator
  47. looking for Website www.s2gcz.com??
  48. Smoke system
  49. Pitts on Satio????
  50. Cap 232
  51. Fuel Starvation
  52. Re-use of Rubber Bands?
  53. Antifreeze Cleaning Method???
  54. How to balance a 22x8 or 24x8 prop?
  55. OS. timing
  56. Prop Balancer help...
  57. Sealing control surfaces
  58. IP adress for simulator
  59. Which glow engine for Firebat?
  60. traveling to Pensacola
  61. glow plug connectors
  62. Tilted vertical fin, will that hurt.
  63. Sig piper cub 71"
  64. Splined shaft U-Joint Supplier
  65. Help! Wing hold down broke on Big Stik 60
  66. KAOS 40 CG Question
  67. Rit Dye Canopy...
  68. Need some suggestions
  69. specs. on Thunder Tiger Slow Fly Mustang
  70. Will a slanted elevator effect my flight
  71. How can I make my own cancopy
  72. Help with a new plane doing loops.
  73. US60 With 10X SETUP???
  74. wagner paint sprayer?????
  75. What's the CG on Graupner Cub?
  76. miles reed solution X
  77. Drilling For Rocket City Type Control Horns
  78. Mixing Automotive Paint?
  79. Pull Pull versus pushrod on rudder.
  80. Gluing a Foam wing without Spars? Ace Hi Mark 2
  81. Flying Again in MN
  82. :confused:
  83. need three bladed prop for .25 os FX
  84. giant aeromaster
  85. What to use for pull pull cable exits?
  86. Super Sportster with Retracts
  87. convert chainsaw engine to aircraft engine?!?!
  88. fx or la
  89. you pick! its a poll
  90. Repairs for Gyro ?
  91. prop balancing
  92. Seamaster CG
  93. Covering Question
  94. Aluminum Spinner Choice
  95. Throttle Servo Location And Pushrod On Gas Model
  96. Prop Question
  97. that glue for a canopy
  98. Where to fly in Santa Barbara, Cali
  99. Stinger 60 Cg
  100. Bmfa
  101. Where to find Menz props
  102. Clear hospital tubing?
  103. Carb setup
  104. Small plane big engine . what happens next!!!
  105. Who makes clunk filters for gas applications?
  106. springy landing gear on 4 Star 40
  107. Gya 352
  108. The New Evolution Engine?
  109. Servo safety/ part number needed
  110. Question on engine size for a CAP 232 / 60 - 90 size
  111. Crossed Pull Pull cables?
  112. flying fields
  113. Thrust angles on a Modeltech Extra 300
  114. switch/charge jack ?
  115. Landings without landing gear, advice on
  116. Vacation!!!
  117. Fabio Trento TOC freestyle question
  118. Engine question...
  119. CA on GOLF PANTS!
  120. smoke system questions
  121. futaba TX frequency flag
  122. House of Balsa Corsair - 25/30 size
  123. Guillow's F4U-4 Corsair Kit help
  124. Dual Tank safer?
  125. Goldberg Super Chipmonk
  126. Cows and exhaust tips
  127. Painting a fully sheeted kit
  128. Magnum .61 XL vs. Magnum .61 Pro
  129. ZDZ 50 carburetor ??
  130. byron originals a6 texan
  131. Onboard: Generators, Starters, and Airpumps?
  132. Servos - Coreless or Digital?
  133. 30-40 size ducted fan plane
  134. UltraCoat/Monocoat Characteristics?
  135. Torque rods
  136. Flying wing
  137. Excel Fuelers
  138. selling on the web
  139. Do you prefer a OS BGX3500 or Moki 2.1?
  140. Comeback flier needs a little info
  141. super stick prop
  142. scaple good investment?????
  143. Moki 2.1 in a Big 85"Bingo?
  144. Alternator system, "Alter-mini" for R/C
  145. Robart "Oleo" strut innards are.....
  146. CG for Sig Four Star Forty
  147. Air retract system converted to hydraulic with ATF?
  148. C.G. For Zlin
  149. Where do i measure from for CG
  150. Funtana S .40 3D
  151. Irvine .40 RC Sport Engine-What Have I Got?
  152. JR Batteries - Best charger analyzer, conditioner
  153. Shim?
  154. Xmtr, rx, servo compatibility
  155. How much pressure in air retracts system???
  156. Taking off with tail dragger
  157. Thinning Epoxy...
  158. Easy Formula for Engine Choice
  159. Resin or covering
  160. Ambroid glue question
  161. Whats the best way to realign vertical fin
  162. Flight Stabilization systems
  163. Fiberglass Techniques
  164. The best digital servo to buy is.........
  165. Help!!!!
  166. Prop Question
  167. Where is the CG on a Great Planes Super Sportster 40?
  168. j-3 + OS 65 + = floater?
  169. Tiger II Flying Problem or Building Problem
  170. Modifying Accu-cycle Plus for NiMh batteries? Has anyone heard of this?
  171. Is RTV fuel proof?
  172. Low Idle Adjustment
  173. C-130
  174. Lengthening Brass Rods
  175. Servo size Airtronics vs Futaba, Jr, etc
  176. Digital servos?
  177. TT 5.5 Spinner
  178. Vertical climbing tank/rover
  179. Pica-Waco ymf-3
  180. Edge 540 kit/plans/whatever
  181. can i use this ply?
  182. Sig Ringmaster C.g.
  183. CA Glue Types
  184. Combat Plane Thrust Angle Issue (I Think)
  185. 4 cycle backfiring
  186. Cowl Cutting
  187. A-10
  188. Where can I get a needle shutoff valve for glo fuel line.
  189. Where the heck can I get some wire crimps for pull pull cable?
  190. engine for a 4 Star 40
  191. Running engine in reverse Harmfull?
  192. roll enershia
  193. tai ji 40
  194. smoke question
  195. is a 1.08 engine too much power for a cg extra 300?
  196. Adding 1/2 inch extra length to each wing tip
  197. Sig Four Star 120-- proper propellor
  198. How many of you are below 20?
  199. Primer for Fiberglass Cowl
  200. What kind of plane is this?
  201. aeroworks extra 33%arf which engine?
  202. Lead around antenna??
  203. Power Panel Question
  204. Lights...lookin' for source
  205. covering on fiberglass
  206. anybody transport fuselage on top of car?
  207. gas engine mess
  208. mrc/altech EZ Dago red covering
  209. Gyro Use...........
  210. CG? Thrust angle? Neither?
  211. Need Help on an EXPERT onboard glow driver.
  212. Y pushrod
  213. 3W75 Spark Plug Gap
  214. Venus 40 Problem
  215. Wing Shapes
  216. What type of plane is this
  217. Servo Y Connect Query
  218. removing paint from plastic parts?????/
  219. 48 surpass vs 46la
  220. Futaba FF6 Battery ?
  221. Cross Country RC Flight - Need Permits, etc?
  222. *newbie* Whats the difference between prop types
  223. floats for a duraplane 40
  224. No throttle on redundant receiver set up. Right?
  225. Digital Levels
  226. What's the BEST AEROBAT?
  227. plane fuel
  228. Best Prop Size???
  229. Studacher gs300 for second plane?
  230. IT'S GOING CRAZY!!!! :(
  231. Nosen 310 CG correct?
  232. Need some help with GWS Naro Rx
  233. Airtronics Servos
  234. Masking
  235. What plane is this
  236. Moki 2.1
  237. Help locating a particular type of fuel pump
  238. Muffler Mod - Saito 91S
  239. Opinions on this package deal
  240. Tail wheels on Trainers?
  241. CG on a Aeromaster
  242. Dalotel 74" WS need C/G
  243. CG help for Lazy Tiger 51
  244. Painting..... and compatibility
  245. Who's a good shop in Ottawa, Ca?
  246. CG location on GP F-14
  247. Saito Mufflers!
  248. Magnum 91 XLS
  249. Rippled Balsa Sheeting
