PDA
View Full Version : Questions and Answers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102
  1. General Prop Question....
  2. can i replace my 7.2 volt battery to a 8.4 volt ?
  3. OLD Radio
  4. Jack Bale Plans and Parts
  5. ASP .61 two stroke... OK or junk...?
  6. cleaning your aircraft
  7. buddy box question
  8. GP Ultimate Owners, Help!
  9. JR Servos
  10. dope & paint
  11. Here take a look at this link i also wanted to open a hobby store.
  12. Need help finding C.O.G
  13. Wing Tube
  14. modify reciever ??
  15. 72 Mhz Single Conversion RX
  16. what to use for cleaning?
  17. Cassutt Racer
  18. OS Surpass 91 Removing the Springs
  19. K&B .20 break in
  20. Anyone own a hobby shop?
  21. What is the ABSOLUTE BEST PROP
  22. Devcon Epoxy ... Help
  23. How do you get a skybolt to flat spin better
  24. Plane for an OS .40 4-stroke
  25. Black Baron and Solartex covering
  26. Hi-temp tubing for smoke systeme?
  27. How'd ya guys mask your spray paint jobs for a neat 2 tone finish?
  28. Need good method to get wing servo extensions aft
  29. Starting Engine & Propeller Spinners?
  30. Large Payload Experimental Airframe
  31. Fuel pump on the fuel jug setup (electric or manual).
  32. OS engine trouble
  33. Antenna
  34. Diesel engine or conversion
  35. lean
  36. Why two elv servos
  37. graphics
  38. Vinyl Graphics Source
  39. Magnum 30 problem
  40. engine stalling question
  41. Mejzlik balancing
  42. props and plugs
  43. to balsarite or not
  44. do i really need to use glass
  45. Where to get H9 Pro Links?
  46. Why are we hooked on flying?
  47. diagonal cuts appearing in covering during flight
  48. Flag Towing
  49. Sullivan Tank w/Aircore Colt 40
  50. Bipe Fever???
  51. World Models Utlimate 30 BiPlane
  52. Ultracote & Monokote Similarities
  53. ARF Chipmunk
  54. Weird Action
  55. dp 120 ultimate+gas engine = ?
  56. J3 as a Tow plane ?
  57. Hyloc Ltd
  58. my LA .40 keeps stalling
  59. Flying Boise Idaho
  60. Epoxy Strengths
  61. Futaba Super 8 Series Help!!
  62. Decals For Zirolli Corsair
  63. Where to connect the DSC cable to R149DP?
  64. Sharks Mouth Markings?
  65. great planes Ryan wheel pants
  66. Canopy cuts
  67. help
  68. Bud Nosen Website
  69. Question concerning where Kits and ARF plans derive from?
  70. Fowler flap hinges
  71. Balancing Goldberg Ultimate
  72. Zenoah G-23 Easy Link Carb Adapter
  73. Cats
  74. Robart hinge points - use point pockets?
  75. Robart hinge points - unassembled???
  76. US40+ vs US40
  77. Easy link carb adapter
  78. Anemometer
  79. radio control training schools
  80. How to best repair tail section
  81. prop size
  82. Fuel tank & plumbing set-up on a pattern ship w/ pumper
  83. Slimline Showcase
  84. on board glow system
  85. Hitec Eclipse HELP!!!!
  86. BAD reaction to different fuel???
  87. best hinge to use
  88. Engine for H9 Ultra Stik 40?
  89. Goldberg Eaglet & TT 36
  90. Paint
  91. eagle/cobra epp aileron Q's
  92. Phoenix Models
  93. Balancing Aluminum Spinners
  94. selling online (Paypal)
  95. Sig Hog-Bipe Engine size?
  96. dual aleron servos
  97. Prop Conversion?
  98. Hey you guys over there !
  99. Mystery Flyig Wing
  100. wing loading?
  101. 1/4 Airfoil Aviation Para(chute)plane?
  102. G.P. JU-87 Stuka ARF feedback please
  103. Looking for a builder
  104. Biplane- I have a ? about the Kyosho pitts special .46 size ARF
  105. Aileron differential uses???
  106. Hitec buddy cord
  107. Servo Speed
  108. WW1 German cross
  109. Looking for a method....
  110. graphics
  111. Midwest Super Stinker
  112. Cambrian line of Fun Fighters - Your Experience???
  113. RC Shops in Singapore and Hong Kong
  114. Paint on Monokote
  115. Pizzaz 4.75 Lbs W/xls .46 & Tower Muffler
  116. I need some advice for a .91 four stroke
  117. How long can fuel be stored??
  118. Installing Wing Bolts for an Midwest Aerostar 40
  119. AARRRGHHHH 4-40 rods & clevises
  120. Looking for July 1982 RCM Issue
  121. Battery connectors??? Why so many????
  122. cg question?
  123. Hanger 9 Edge 540 Question
  124. Gear Door Hinges
  125. Hello All Question on Cyprus
  126. Goldberg Extra 300 - Control Throws
  127. Swapping crystals between identical transmitters???
  128. Prince American (Gemini) parts
  129. Best Low-Bounce Wheels?
  130. Landing technique for faster airplanes
  131. Old Engine questions
  132. Cg
  133. I have a couple of questions
  134. Little Bee
  135. OS 46 FX needle valve bracket
  136. cowl plane valve adjustments
  137. What do you call these things?
  138. This can't be true...
  139. CA going bad?
  140. Mounting FMA Copilot
  141. Airshow?
  142. citabria- correct pronunciation
  143. Paint Matching Ultracote Pearl Blue?
  144. Hot melt glue?????
  145. Nitro blast question
  146. Latex runs
  147. Solarfilm colours
  148. glow plug thread size
  149. Landing Gear Freezed
  150. What are "Fuel Dots" ??
  151. Is this wood prop for electric or glo motor
  152. Priming F'Glass
  153. Personal Preferances
  154. painting aluminum landing gear
  155. 3W and AVGAS
  156. What can I use for nose weight?
  157. Frequency Display
  158. OS46FX Problems?
  159. Glassing wing center
  160. smoke system question?
  161. Tracer W/ Novarossi .50 & Tuned Pipe
  162. Best technique to mount antenna on vert stab??
  163. Zdz 40
  164. Goldberg tigersport .60
  165. Where to get long exhaust deflector?
  166. lookin 4 a new bipe
  167. O-Ring supplier
  168. Fuel Pump Problems!
  169. Smoke System
  170. Getting more power out
  171. Pull-Pull controls - Bellcrank material question
  172. fixed tail wheel or castering tail wheel
  173. Aerobatic Planes for a US Engines 41
  174. Negative Expotential
  175. fuel filler
  176. Yellow Gas/Oil Tubing Melting
  177. Balance question ?
  178. Searching for tall Field Box
  179. What is a good gas engine to get
  180. lear liner 40
  181. astro-hog
  182. How Fast is "Fast Enough"?
  183. 2-stroke!!smoke?
  184. fuel tank to engine distance
  185. battery question
  186. Servo leads: how long is too long?
  187. Device for transporting airplanes to the field site
  188. reciever sensitivity??
  189. Full scale pilot gone berzerk
  190. Simulator interface
  191. super cub
  192. Carb Clearance
  193. Telemaster sr 2 pc wing
  194. Pt-17 bottom wing
  195. Prop Length VS Cowl/Fuse Width
  196. OS 120 pump question
  197. Please tell me about smoke systems.
  198. Avistar nose gear help - QUICK!
  199. Where to buy one 3 x 8mm screw?
  200. Wheelpants busted, My first fiberglass repair need help. Pics inside.
  201. Field charger
  202. RC Hotel, Corfu
  203. Maiden Flight Rituals
  204. Glassing vs Weight
  205. Cleaning 21 Century Fabric,Streaks, what do u use
  206. using a rc throtle on a control line Tanager w/ a T Tiger .46
  207. Ohio RC Sukhoi
  208. which fibreglass do I use?
  209. Battery Cutoff Voltage
  210. Problem Starting New Engine
  211. servoes
  212. Cap 232 and it's "habbits"
  213. Fuel Soaked Wood?!?!?
  214. Why Doesn't More Women Fly R/C
  215. How much for a glider
  216. Balancing the plane
  217. Heatshrink paint bubbles
  218. World Models P51
  219. Eagle 63 does not want to steer properly
  220. Old Plane Safe to Fly?
  221. New Forum
  222. Looking For A Good Second Plane
  223. 3 channel receiver?
  224. Servos in tail of CG Ultimate
  225. Muffler extensions for an OS. 91 surpass
  226. Apc Props
  227. TF F4U Corsair
  228. planes CG ?
  229. Minor problem with SpringAir retracts.
  230. Looking for info on the Giant Scale Planes P-26 Peashooter ARF
  231. Receiver Problem
  232. landing gear blocks.
  233. Foam Wings - Lightweight Covering
  234. Lancair ES ARF
  235. accessory module
  236. Flight Box?
  237. Why do my planes do this?
  238. Lanier Dart turns into Razzle
  239. Music Wire. How to bend, or best place have it done
  240. GWS in giant scale???
  241. smoke pump hookup??
  242. simulators
  243. matching ultracote pearl colors
  244. Nice plane for an O.S .10
  245. Servo question for the GP Shoestring owners
  246. Importance of thrust line!
  247. Wire dimension
  248. Looking for some advice
  249. CG Ultimate and OS91fs
  250. Cianoacrylate bottles
